How can I get the value of a key that is in a nested structure?
I have this code
<cfset returnStruct = CreateObject('Component','someCFC').validateData( paramData ) />
<cfdump var="#returnStruct #" />
When I dump out "returnStruct" there are a few keys, I see the outermost structure, and in the first key of the outermost structure is a nested structure. I'm trying to get the value of a specific key inside the nested structure. The problem is the nested structure doesn't really have a name, it's just there
How can I do this? I should know this but can't recall how. If someone can provide the syntax that would be great.
-ws
The first thing one should do when confronted with finding out how to do something in CF is to consult the docs. There's a section on how to use structs, and that covers what you need to know.
http://help.adobe.com/en_US/ColdFusion/9.0/Developing/WSc3ff6d0ea77859461172e0811cbec09f0b-7fe9.html
Adam
Adam,
First and foremost, thanks for taking the time to reply.
I've looked at the docs first, typically I do that before posting. On the flip side, because one posts on the forums, I don't think it's always fair to assume that they haven't looked at the docs
I've uploaded an image of the data structure I'm working with.
I'm trying to get the value of the key "INVALIDFIELDS" and can't quite get the syntax right.
-ws
I ended up getting it using dot notation, for some reason I couldn't get at the value, but it's working now.
Thanks for your post.
-ws
Actually, around here it usually is safe to assume people haven't read the docs, because that's - say 75% (?) of the time - accurate. You're the exception.
I base my replies to people on the info they provide in their initial postings: you didn't mention anything about reading docs or trying anything out, so assumed you hadn't, sorry. Again, running on such assumptions is more often going to be right than wrong around here.
Anyway, glad you got it sorted out.
Adam
No worries.. thanks Adam.
-ws
