coldfusion user documentation
Guest
Apr 17, 2006 Apr 17, 2006
hi all,
how could documentation for coldfusion be done.
is there any utility in coldfusion which does the functionality of javadocs?
or can we use the javadocs in coldfusion...
thanks in advance
anuradha
Advanced techniques
959
docs galore
Yes, of course. Java objects are at home in Coldfusion.
Guest
Apr 18, 2006 Apr 18, 2006
hi,
thanks for trying to help me.
but may i be i was wrong in expressing my problem...
my requirement is actually to create user documentation for the component or the coldfusion template i create....
say in java javadocs will collect all the comments in the page and generate it as a document...
is there any utility in coldfusion which would do this functionality....
and
if i can use javadocs kindly let me know the way to use it....
thanks in advance....
You have to write your own docs.
Guest
hi,
and
Guest
thanks....
but is there any option that i can use the javadocs feature in coldfusion....
if so, could you let me know the way to do it
Isn't it sufficient that the APIs are available when you create an object in Java, and that the object is in turn available to Coldfusion? It is still not clear to me why you would want to use javadocs in a Coldfusion component.
Guest
Apr 19, 2006 Apr 19, 2006
i want to create user manuals and that should not user-generated....
my client wants a document that is generated by the program itself....
and the problem with using javadocs with createobject is that since javadocs is an utility....that should be invoked at the command prompt....
You've lost me there.
Guest
am i not clear in explaining my problem?
No.
Documentation
