I can't get links to external topics workig. This has never been a problem in the past. I am using RH7 to produce chm files. The external chm file appears in the baggage area.
I have tried starting 2 completely new projects and the same problem
Some more information would be helpful. What is the error message if any? How are the links being created?
I spotted the problem when I had some issue wiht a merged project. This is what I have:
project A is the master
projects B and C are slaves
Project A has its own topics plus projects B and C as merged projects in the TOC. When I run project a all appears to be great I can select the topics form the slave projects, and links form the slave projects to teh master also work (Master is in baggage of 2 slaves). Exactly as I want. Th eproblem occurs whe you run the slave projects on their own the same to the master fails. with the following message:
The page cannot be displayed | |
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings. |
The link is an external link. When you look at what it is trying to display
res://C:\WINDOWS\System32\shdoclc.dll/dnserror.htm#mk:@MSITStore:D:\Documents%20and%20Settings\e301346\My%20Documents\Monitor_Task.chm::/IQ_Tool_Manual.chm::/Clear_the_Grid.htm
The above fails the link below is the one generated when the same page is displayed form the master project
I have tried creating 2 projects from scratch with an external link this also fails.
