We are converting documents from several different formats to PDF. We have a requirement that the images must be 300 dpi when converted. I turned off the down sampling option in PDF settings. However, the images are all coming out at 72 dpi. So I have some questions.
Is there a way to control the dpi of a converted image?
How about an image embedded in a document?
Is there any easy way to check the dpi of an image in a PDF? The only way I've found to check the image dpi is use preflight in Acrobat.
-Kelly
