Project: RHX5
Status: Previously good project, changed the index entries,
now no index
In a project that contains an imported Word doc, I deleted a
lot of index entries from the index pane. These entries all began
with the acronym UG. (We didn't like the acronym use and decided
not to use it.)
Then I did the following:
* In the original Word doc, revised the index tags
* In the project, deleted the RHX5 files for that doc
* reimported the updated Word doc using the create index
option
The new index did not create. Instead, RH recreated the old
index (using the UG acronyms). The index entries were bolded,
indicating of course that they were not linked. Ghost entries.
Thinking there may be some unused files in the project
causing the problem, I created a new project using the RH wizard,
and imported the doc again using the create index check box. No
index.
whazzup?
Thank you!
