Index file (.hhk) not updating with compile/publish
Jun 04, 2010 Jun 04, 2010
Sometime within the last couple of weeks, the Index file (in this case, named cghelp.hhk) in our project is not getting updated when we do our nightly compile and publish of our project. After the compile and publish, I can view the Output and verify that Index changes are there, but the next morning (the Output is stored on a Repository folder and an automated job copies the folder around 3 a.m. to the location where our users access the files that make up the project.) the changes are not visible.
I can't think of anything that would have changed over the last couple of weeks that would prevent the hhk file from getting pushed out.
In talking with our IT, they indicated that the nightly jobs are running without issue and that they only copy exactly what is in the Output folder (results from the compile and publish). Yesterday I checked the Output folder and saw that the hhk file was not there, so I manually copied it over from my local to see if that would help, but today no update. The hhk file is in the folder but the changes are not seen in Production.
Non hhk file changes are appearing without issue, including topic changes. It just seems to be the Index that is having the issue.
I have checked my settings in WebHelp (Primary Layout) and verified that when I publish, the results are going to the correct folder to get copied over. We only have one Index, so it's set to <Default.> Since we were having issues, I did change it to specifically say cghelp instead of <Default> but that has not helped at all.
We are using RoboHelp 8 with a project that has about 3300 topics. Any other suggestions would be greatly appreciated! I have a client calling me daily asking why the new content isn't in the Index.
- Warren
718
Hi there
The output files should not be referencing the .HHK in any way. The .HHK is a source file. During the process of generating the WebHelp, the HHK is converted to an HTML and XML file pair.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7 or 8 within the day - $24.95!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
But that obviously is not occurring since the Index isn't updating. Do you know of any reason why that would not be happening?
Warren- 221-3210
Senior Communications Support Specialist
Hello again
Sorry, but at this stage there are way more questions than possible answers.
You refer to a nightly build. I'm assuming this is this some sort of an automated build? What happens if you simply run the output files from the output folder after they have been generated? Assuming the changes are visible then, it means something went wrong during the process of copying the files to the final destination. But if you don't see the changes when you run from the output location, something went wrong during the actual generation process.
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
RoboHelp Documentation
Download Adobe RoboHelp
