Hello Everyone,
I am trying to figure out how to do the following:
dropdown1 value (value meaning the textual value and not numerical value) and if selected then var1 = numericfield1.
I thought i could use:
(Using javascript)
if(dropdown1.rawValue == "text")
var1 = numericfield1.rawValue;
Any help is appreciated. I would upload the form but currently I cannot as there is an issue with uploads it looks like so I am placing it on our dev server and here is the link to download the form:
http://www.shingleme.com/CostWorkSheetTest.pdf
Justin
Solved! Go to Solution.
Total Likes
I thnk I see the issue ...The WCSMMonth is not a field but just text and hence it has no rawValue. Is it supposed to be a field?
Paul
Total Likes
had a look at your form and was able to get rid of one line but found that the wMonth was not defined. I do not know if that is a field or a variable that you were trying to set earlier. If I assign a value to it then it works just fine. See my updated sample attached.
Paul
Total Likes
Hmmmmmm then I need to figure out why inside the switch statement code block wMonth isn't taking the value of wCSMMonth then. If i can figure this out I can figure out the math from there.
Here is the code block:
switch
(xfa.event.newText)
case "College Square Mall":
packDes1.rawValue
= null;
packDes1.clearItems();
packDes1.addItem("Website Monthly Contract");
packDes1.addItem("Website Annual Contract");
packDes1.addItem("Eblast Monthly Contract");
packDes1.addItem("Eblast Annual Contract");
packDes1.addItem("Combo Web/Eblast Monthly Contract");
packDes1.addItem("Combo Web/Eblast Annual Contract");
packDes1.addItem("Website Portfolio Monthly Contract");
packDes1.addItem("Website Portfolio Annual Contract");
packDes1.addItem("Eblast Portfolio Monthly Contract");
packDes1.addItem("Eblast Portfolio Annual Contract");
packDes1.addItem("Web/Eblast Portfolio Monthly Contract");
packDes1.addItem("Web/Eblast Portfolio Annual Contract");
var wMonth = wCSMMonth.rawValue;
var wYear = wCSMYear.rawValue;
var eMonth = eCSMMonth.rawValue;
var eYear = eCSMYear.rawValue;
var cMonth = cCSMMonth.rawValue;
var cYear = cCSMYear.rawValue;
var packDisM = packDisMonth.rawValue;
var packDisY = packDisYear.rawValue;
break;
Total Likes
Paul
Total Likes
AAAAAAAAAAAAAAAAAAAAAAAA ha!!!! I didn't create this particular form and should've looked. Geez I can't believe I missed that :-) Good catch my good man. Thank you very much. Things should get much easier going forward now.
Justin (aka not very observant)
_
Total Likes
