Every time I try and import my Captivate 4 project (latest Update) to Flash CS4 Pro (latest Update) I get a error Dialogue that says:
Can't Load Library: 126.
I'm using Window 7 Enterprise and have full admin privileges on the system. Error message happens no matter the order of opening both programs. Tried Import into Flash and also Export to Flash. Same result either way.
Any help on getting by this error would be great.
Thanks in advance.
Daniel McHugh
No solution yet. Any one experienced this before?
PS I've double checked the files: RDMFISTUB10.dll and external libraries file rdjsfl.dll are in the right spots (External Libraries and Importers) RDMFISTUB10 will restore itself if I delete it but not RDJSFL dll.
Problem persists even if I create files on local c: drive documents folder with external files or anything in the Captivate file.
I've changed the Flash CS4 program to run as Administrator and now I can import. Still get quite a few errors on compiling it though. (IE Access of undefined property nCurSlideIndex, all errors are on the Slide Context and Actions Layer.
