Hi all,
Using RH7.
From within a CHM page, how can I open an independent, non-modal window?
From within a topic I want to display a large picture by clicking an icon. The picture should appear in an independent, non-modal window that the reader can grab on its caption bar and so move the window around. Thus, the reader can move the picture window to one side of the monitor, for example, and then use it as a reference, while continuing to read the topic on the other side of the monitor.
Is this possible in RH7? If so, which RH feature would I use to do this?
TIA
avi
Well I found this link.
http://forums.adobe.com/message/293392#293392
But it was for an old version of RH. I couldn't follow the instructions through until the end.
There is also Menu > Insert > Insert Hyperlink/Popup > Display in Frame - New Window
But that opens the target topic in a browser window (new + default). That's not exactly what I want, but good enough for now.
More ideas?
TIA
- avi
Hi there
I'm guessing you want to simply open a new browser window without any browser controls, right? In this case, you will need to use JavaScript to do it.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Well, a new CHM viewer/window. I assume we are agreeing with each other.
Ummmm ... are the links at the bottom of your post, the links to JavaScript sample code blocks?
tia
- avi
