I am using the following code to stylize the cell text depending on what the text is, what I want to be able to do is change the background color of the cell if the text contained in that cell == 'xxxxxx', is this possible? Am I on the right track? if not any help is appreciated.
Thanks in advance,
-Sean
public function myColStyleFuncPRI(data:Object,col:AdvancedDataGridColumn):Object
if(data["PRIMUS"] == 'Ready')
return {color:0x0fff03};
if(data["PRIMUS"] == 'Sent')
return {color:0x044e00};
if(data["PRIMUS"] == 'Not In WH')
return {color:0xff0000};
if(data["PRIMUS"] == 'p/u by andrews')
return {color:0x0000ff};
return null;
and this is the result:
and the image below is that I want to do:
easy try something like this in your renderer:
<mx:valueCommit>
<![CDATA[
if(text.search(new RegExp(/.*\..*\./)) != -1 || text == ''){
setStyle('backgroundColor',0xff8b7c);
else{
setStyle('backgroundColor',0xffffff);
</mx:valueCommit>
<mx:change>
<![CDATA[
this.data.isModifiedClientSide = 0; this.data.depositRequestedAmount = text; } else{ setStyle('backgroundColor',0xffffff); this.data.depositRequestedAmount = text; this.data.isModifiedClientSide = 1; } ]]> </mx:change>Copy link to clipboard
So is this just a copy what you have and paste it in my code type of deal or can you explain exactly how to use this code? because I'm not that fluent in Flex/Flash Builder yet..
-Sean
I tried using this code, but for some reason (maybe th elack of flex coding knowledge) I cannot get it to work.
-Sean
try calling
in a custom itemrenderer
how would I create a custom itemrenderer?
<< remember noob =/
thanks,
-Sean
http://www.switchonthecode.com/tutorials/flex-using-item-renderers
This is the best reference I could find
http://butterfliesandbugs.wordpress.com/2007/07/11/using-an-itemrenderer-to-change-the-background-of-a-datagrid-cell/
To create an item renderer, go through
http://help.adobe.com/en_US/flashbuilder/using/WSbde04e3d3e6474c4-ff135ec1256a38088a-8000.html
For our case you will have to create an item renderer for a particular column. To use the item renderer, the code is-:
<mx:AdvancedDataGridColumn headerText="Column 1" dataField="name" itemRenderer="customColumnRenderer" />
customColumnRenderer.mxml will look like this.
<?xml version="1.0" encoding="utf-8"?>
<s:MXAdvancedDataGridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx"
focusEnabled="true"
contentBackgroundColor="0xFFFF00">
<fx:Script>
<![CDATA[
import mx.controls.AdvancedDataGrid;
import mx.controls.advancedDataGridClasses.AdvancedDataGridListData;
override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
super.updateDisplayList(unscaledWidth, unscaledHeight);
var g:Graphics = graphics;
g.clear();
var grid1:AdvancedDataGrid = AdvancedDataGrid(AdvancedDataGridListData(listData).owner);
if (grid1.isItemSelected(data) || grid1.isItemHighlighted(data))
return;
if(lblData.text.charAt(0)=='F')
g.beginFill(0xCC0033);
g.drawRect(0, 0, unscaledWidth, unscaledHeight);
g.endFill();
</fx:Script>
<s:Label id="lblData" top="0" left="0" right="0" bottom="0" text="{listData.label}" />
</s:MXAdvancedDataGridItemRenderer>
Hope this helps
Nishad
