hey guys... so i have a new problem... basically im trying to load a swf, and for this swf to load properly i need to pass it an id, and when the swf, after using the id gets all the necessary data, sets a variable called loadCompleted to true
The problem is after my code encounters the loadComplete == true, it adds an image of that swf to my tileList, and it adds a million of these images, indicating that my event never got removed.... any ideas??
i have the following code
private function swfLoaded(event:Event):void{
trace("-------------> in function swfloader");
childSwf = new MovieClip();
childSwf = event.target.content;
childSwf.init(name[1]);
childSwf.addEventListener(Event.ENTER_FRAME, compFrameEntered);
private function compFrameEntered(event:Event):void{
if(childSwf.currentFrame == childSwf.totalFrames){
if(event.target.loadComplete == true){
trace("<<<<< load complete: " + event.target.loadComplete);
childSwf.removeEventListener(Event.ENTER_FRAME, compFrameEntered);
var myClip:MovieClip = event.target as MovieClip;
var imageBitmapData:BitmapData = ImageSnapshot.captureBitmapData(myClip);
var imgData:Bitmap = new Bitmap(imageBitmapData);
slideImages.addItem(imgData);
trace("load complete company ");
it not only adds a million same images, but it also displays "load complete company" a million times....
any ideas?? any help is greatly appretiated! ive been having this problem for a couple of days now
I tried your example without the Imagesnapshot. For that case, it seemed to be working fine. I suspect something is amiss in the swf code.
Did u have to make any modifications in your flash code for making this line work
Because it flagged a runtime argument error for me.
Nishad
hey nishad... thanks for replying.. the problem i was running into was that i accidently was instantiating the enterframe a few too many times... i had to change the structure of my code to get it working.
