6 Replies Latest reply on Jun 8, 2010 9:13 AM by userpsp_
    Extension panel appears empty
    userpsp_ Level 1
      I tried to compile and install the sample HelloCreativeSDK that comes with the SDK, and, after copying  it to the extension directory, the extension appears in the extensions menu, but after clicking on it in Photoshop CS5 an empty panel appears.
      If I try to create a new extension from scratch with only a label, the panel is empty too.
      If I try to load the extension in Illustrator or Fireworks, the panel doesn't appear; in Photoshop the panel appears, but it is empty (it should contain a test label instead).
      Kuler and others default extensions are working fine.
      Nothing appears in the logs mentioned in the SDK Guide. What am I doing wrong?
