Hello,
Has anyone come to a solution on this? We have the same issue:
from WITHIN our company, when you select the link for this PDF, the
File does not begin with '%PDF-' error appears
Outside of the company on other PC's the file opens just fine, no issues
We are going to try and uninstall/reinstall Adobe 9 with the latest version tomorrow
Has anyone seen a resolution?
Sean
If the file does not begin with '%PDF', then it is not a valid PDF file. It may have become corrupted during the upload. You can easily check it with a hex file viewer.
Why want you see the resolution? In Adobe Acrobat you can check the resolution of images in pdf files.
