I'm using RoboHelp v7.02.001 and below I have an example of what my table displays when viewed. The first line is Ok but the second line is indented when viewed. It is not indented when I view it in design. I compared the two line in HTML view and added >span </span> to the line that was off. I also added font family: Ariel; to the line of code thinking that might solve the problem. Even though I can't see any differences between the two lines of code the second line displays a little to the right. I've checked table properties and the settings are the same for both lines. I notice if I arrow down while in design the information above the ruler changes from Document > TextBox > Table > Row > Cell > Paragraph > [ | ] to Document > TextBox > Table > Row > Cell > Paragraph > Span > [ | ]. I thought that might be the problem but rows that are fine show either way. It looks sloppy and I'd like to have all the text align as in the first row.
Sorry I tried inserting the image and for some reason it says the content is not allowed?
The table is displaying this way:
UD Codes UD Code Description
OK for some reason this forum refuses to display the UD code and UD code descriptions as I'm entering them. I wish Robohelp would do the same. Imagine that the second line above is off to the right; the second line begins under the D instead of the U.
I thought I'd give this a try to show how the table is diplaying. Obviously the underscore represents the space I'm getting.
UD Code UD Code Description
_UD Code _UD Code Description
Can you post an example topic and your css so we can have a look? I understand the problem, but without seeing the code, I can't be of much help.
Greet,
Willam
This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
