1 2 Previous Next 44 Replies Latest reply on Aug 5, 2017 6:04 AM by Rocket95
    Copy Filename to IPTC Keywords
    PeteP Level 1
      Hi all,
      I'd like to copy filename to keywords. I've read this forum but I can't find a solution to my case.. So if someone could help me and tell me how to do that I'll be very happy. I don't have any javascript skills, so if someone would push me forward, that'll be nice.
      I'm using Bridge CS3, MacOS 10.5.8. I'd like to use it with Automator, or if someone has better solution, please let me know.
      Pete
        • 1. Re: Copy Filename to IPTC Keywords
          Paul Riggott Level 6
          This should do it..
          #target bridge
          addNametoMeta = {};
          addNametoMeta.execute = function(){
            var sels = app.document.selections;
            for (var i = 0; i < sels.length; i++){
          var md = sels[i].synchronousMetadata;
              md.namespace = "http://ns.adobe.com/photoshop/1.0/";
              md.Keywords = md.Keywords + ";" + sels[i].name;
          if (BridgeTalk.appName == "bridge"){
          var menu = MenuElement.create( "command", "Save Filename in Keywords", "at the end of Tools");
            menu.onSelect = addNametoMeta.execute;
          1 person found this helpful
          • 2. Re: Copy Filename to IPTC Keywords
            PeteP Level 1
            Thank you Paul =)
            What should I do next? I've already save your javascript to .jsx with ESTK, but how could I get it running? Where in system should I save it?
            I'm using Adobe CS3, MacOS 10.5.8
            I'm sorry about my questions, but I'm not familiar with these..
            Thanks again,
            Pete
            • 3. Re: Copy Filename to IPTC Keywords
              PeteP Level 1
              I saved the .jsx inside system folder "Application Support/Adobe/Bridge CS3 Extensions/Adobe Workflow Automation" and it works. =)
              Thank you Paul!
              Pete
              • 4. Re: Copy Filename to IPTC Keywords
                Start Bridge
                Edit - Preferences - Startup Scripts
                Click the "Reveal" button, this will open the folder where the script should be put.
                Close and re-start Bridge, accept the new script.
                Select the documents that require the filename added and then select the script from the bottom of the Tools menu.
                Hope this helps.
                • 5. Re: Copy Filename to IPTC Keywords
                  PeteP Level 1
                  Thanks Paul,
                  is there chance to edit the javascript so, that filetype (".tif", "jpg") is executed from the keywords?
                  Pete
                  • 6. Re: Copy Filename to IPTC Keywords
                    Sorry but I don't understand what you are after Pete?  executed?
                    Do you mean no that the extensions are to be removed for .tif & .jpg or even all extensions to be removed.?
                    • 7. Re: Copy Filename to IPTC Keywords
                      PeteP Level 1
                      Sorry my bad english..
                      I'd like to remove the filetype extension from keywords. Filename is copying ok, but extension ".tif" or ".jpg" goes also to keywords. If it's possible to remove filetype extension so that'll not be shown in keywords? Is it possible?
                      I'll remove filetype extensions now manually. That's because of the structure of the imagebank I'm using, the imagebank doesn't recognize keywords if they're not exact, keywords have to be without dots (.) The search engine doesn't find anything if I'm typing "image", if the image contains "image.tif" in keywords...
                      Thanks again for helping me, =)
                      Pete
                      • 8. Re: Copy Filename to IPTC Keywords
                        This will put the filename only no extension..
                        #target bridge
                        addNametoMeta = {};
                            var Name = decodeURI(sels[i].name).replace(/\.[^\.]+$/, '');
                            md.Keywords = md.Keywords + ";" + Name;
                        • 9. Re: Copy Filename to IPTC Keywords
                          PeteP Level 1
                          That's it! Done!
                          Thank you very much, Paul!
                          Pete
                          • 10. Re: Copy Filename to IPTC Keywords
                            PeteP Level 1
                            Hi!
                            Is there any chance to separate keywords with commas within this script? , or ;? So that the empty space between words will be replaced with commas? That should not affect to the filename, commas should be only in keywords.
                            Pete
                            • 11. Re: Copy Filename to IPTC Keywords
                              ashdflkjh
                              What if I wanted to use the name of the folder the files are in rather than the file name?
                              Say, I have a folder and within it many subfolders. I want to display all of the files within that folder and its subfolders, select all images and transfer the subfolder names into Description filed in IPTC.
                              Thank you for your help.
                              • 12. Re: Copy Filename to IPTC Keywords
                                This should do it....
                                #target bridge
                                   if( BridgeTalk.appName == "bridge" ) {
                                addFolderName = MenuElement.create("command", "Add FolderName to Description", "at the end of Tools");
                                addFolderName.onSelect = function() {
                                   addFolderNameToDescription();
                                function addFolderNameToDescription(){
                                if ( !ExternalObject.AdobeXMPScript ) ExternalObject.AdobeXMPScript = new ExternalObject('lib:AdobeXMPScript');
                                for(var a in sels){
                                            var thumb = sels[a];
                                            if(thumb.type != 'file') continue;
                                            app.synchronousMode = true;
                                            var xmp = new XMPMeta(thumb.synchronousMetadata.serialize());
                                            xmp.setLocalizedText( XMPConst.NS_DC, "description", null, "x-default", sels[a].spec.parent.name );
                                            var newPacket = xmp.serialize(XMPConst.SERIALIZE_USE_COMPACT_FORMAT);
                                            thumb.metadata = new Metadata(newPacket);
                                • 13. Re: Copy Folder Name to an IPTC Field
                                  ashdflkjh Level 1
                                  Thank you very much!
                                  Unfortunately, the situation is more complicated than that. Some of the folder names use accented characters and those do not transfer well. Example:
                                  1. Folder name in Bridge
                                  2. Result in the IPTC Description field
                                  Can this be resolved?
                                  • 14. Re: Copy Folder Name to an IPTC Field
                                    Please try this now...
                                    #target bridge
                                    for(var a in sels){
                                                xmp.setLocalizedText( XMPConst.NS_DC, "description", null, "x-default", decodeURI(sels[a].spec.parent.name) );
                                    • 15. Re: Copy Folder Name to an IPTC Field
                                      ashdflkjh Level 1
                                      Thank you. Even before I try, can you possibly add some comments for the purposes of learning?
                                      • 16. Re: Copy Folder Name to an IPTC Field
                                        ashdflkjh Level 1
                                        Seems to be working fine now. Thanks a lot.
                                        Anna
                                        • 17. Re: Copy Folder Name to an IPTC Field
                                          Said Nuseibeh
                                          Hello Paul,
                                          Thank you for these scripts!
                                          I'm trying to tweak this script to write the Folder Name to the IPTC Keyword field instead of the Description field. This works (when I substitute "subject" for "description") but only when the Keyword field is empty.
                                          What's the trick to append keywords?
                                          Thank you in advance,
                                          -Saïd
                                          • 18. Re: Copy Folder Name to an IPTC Field
                                            Please try this...
                                            #target bridge
                                            addFolderNametoMeta = {};
                                            addFolderNametoMeta.execute = function(){
                                                md.Keywords = md.Keywords + ";" + decodeURI(sels[i].spec.parent.name);
                                            var menu = MenuElement.create( "command", "Save FolderName in Keywords", "at the end of Tools");
                                              menu.onSelect = addFolderNametoMeta.execute;
                                            • 19. Re: Copy Folder Name to an IPTC Field
                                              Said Nuseibeh Level 1
                                              Thanks Paul.
                                              Works like a charm!
                                              i'd tried
                                              that I pulled form another script but, of course, that didn't work.
                                              You've rescued me from disorientation in the Javascript Tools Guide, popping various Folder Object Properties and hoping one would work ;-)
                                              Naturally, no good deed goes unpunished! (Though if you have a solution to this following one then I will donate to your favorite charity).
                                              The next time-saving query that comes to mind is this: File and Folder names are (for me) often concatenated. This means when I add them to Keywords, I must manually edit the text to return it to individual (hence searchable) words. Is there a way to run a script such as this so that the filename (for example) pops up in a dialogue box for manual editing before applying to the XMP field? This would be a real timesaver when applying this script to batches of files.
                                              Much Obliged
                                              -Saïd
                                              • 21. Re: Copy Filename to IPTC Keywords
                                                Paul, you are a Wizard! And an exceedingly generous and
                                                responsive one too.
                                                Alas, the “Add/Replace/Remove Keyword” script does not seem
                                                to work with CS5 (ln 12). The script installs okay but appears
                                                nowhere within Bridge.
                                                • 22. Re: Copy Filename to IPTC Keywords
                                                  Ah, it can be difficult to find, it is in the context menu.
                                                  Mouse Right click (menu) and select "Add-Replace-Remove Keyword" on a PC
                                                  Not sure on the Mac I think it is ctrl/click to get the context menu.
                                                  Hope this helps.
                                                  • 23. Re: Copy Filename to IPTC Keywords
                                                    There it is!  Sweet.
                                                    Doesn’t quite do what I had in mind (automatically populate
                                                    the Replace field with the keyword(s) for subsequent editing)
                                                    but after a good night’s sleep, I think this will work fine.
                                                    My thought would be next-to-impossible to implement on batches.
                                                    Well... unless the dialogue contained a “Go to next file”
                                                    button and automatically re-populated the Replace field.
                                                    However, this beggar will not be choosy.
                                                    Thanks much
                                                    • 24. Re: Copy Filename to IPTC Keywords
                                                      JSG_Alex_B
                                                      Hi Paul,
                                                      as it seems you´re the godfather of scripting ... and now I need your help.
                                                      I´m working on CS4, Windows XP and I have more than 1500 folders in Bridge containing up to 15 pictures to handle.
                                                      I want the name of the folder written in one of the iptc fields, doesn´t matter if it´s the keyword or description. Unfortunately, in some of the pictures these fields are already filled out, so I want to add the foldername.
                                                      Due to the fact that I don´t know how to handle java and how to save it, I really appreciate your help.
                                                      Edit: I finally got it working, but now I have the problem that the folder contains other folders in which are the pictures ...
                                                      Example:
                                                      Folder XY
                                                      • Folder other name_1
                                                      • Folder other name_2
                                                      • Folder other name_3
                                                      • etc etc
                                                      Just the folders "other name" are filled with pictures but I need the "Folder XY" written in the IPTC-fields.
                                                      Can you help ?
                                                      Kind regards and thanks a lot !
                                                      Alex
                                                      • 25. Re: Copy Filename to IPTC Keywords
                                                        If you want the Parent folder name you can use this..
                                                        #target bridge
                                                            md.Keywords = md.Keywords + ";" + decodeURI(sels[i].spec.parent.parent.name);
                                                        Or if you want to do ALL subfolders this might do..
                                                        You need to be in the top level folder.
                                                        This also removes duplicates in the keyword field.
                                                        Amend the folder name to suit....
                                                        #target bridge
                                                        AddFolderNameToMeta = MenuElement.create("command", "Add FolderName to Files", "at the end of Tools");
                                                        AddFolderNameToMeta.onSelect = function () {
                                                           addFolderName();
                                                        function addFolderName(){
                                                        var folders =[];
                                                        var Pics=0;
                                                        folders = FindAllFolders(Folder(app.document.presentationPath), folders);
                                                        folders.unshift(Folder(app.document.presentationPath));
                                                        for(var a in folders){
                                                          var PictureFiles = folders[a].getFiles(/\.(jpg|jpe|jpeg|gif|eps|dng|bmp|tif|tiff|psd|rle|dib|cin|dpx|sct|pbm|flm|psb|exr|pcx|pdp|nef|dcr|dc2|erf|raf|orf|tga|mrw|mos|srf|pic|pct|pxr|pdd|pef|png|x3f|raw)$/i);
                                                        for(var p in PictureFiles){
                                                            addKeyword(PictureFiles[p])
                                                            Pics++;
                                                        alert("Number of Folders Processed = "+folders.length+ " Documents Processed = "+Pics);
                                                        function addKeyword(fileName){
                                                        if (ExternalObject.AdobeXMPScript == undefined)  ExternalObject.AdobeXMPScript = new ExternalObject("lib:AdobeXMPScript");
                                                        var thumb = new Thumbnail(fileName);
                                                        var folderName = decodeURI(fileName.parent.name);
                                                        //Or if you want the folders Parent use the line below.
                                                        //var folderName = decodeURI(fileName.parent.parent.name);
                                                           if(thumb.hasMetadata){
                                                              var selectedFile = thumb.spec;
                                                              try{
                                                              var myXmpFile = new XMPFile( selectedFile.fsName, XMPConst.UNKNOWN, XMPConst.OPEN_FOR_UPDATE);
                                                          var myXmp = myXmpFile.getXMP();
        var keys = getArrayItems(XMPConst.NS_DC,'subject');
        keys.unshift(folderName);
        keys= ReturnUniqueSortedList(keys);
        myXmp.deleteProperty(XMPConst.NS_DC,'subject');
        for(var z in keys){
        myXmp.appendArrayItem(XMPConst.NS_DC, "subject", keys[z], 0,XMPConst.PROP_IS_ARRAY);
        }catch(e){}
                                                        if (myXmpFile.canPutXMP(myXmp)) {
        myXmpFile.putXMP(myXmp);
        myXmpFile.closeFile(XMPConst.CLOSE_UPDATE_SAFELY);
                                                        function getArrayItems(ns, prop){
                                                        var arrItem=[];
                                                        var items = myXmp.countArrayItems(ns, prop);
                                                           for(var i = 1;i <= items;i++){
                                                             arrItem.push(myXmp.getArrayItem(ns, prop, i));
                                                        return arrItem;
                                                        function FindAllFolders( srcFolderStr, destArray) {
                                                         var fileFolderArray = Folder( srcFolderStr ).getFiles();
                                                         for ( var i = 0; i < fileFolderArray.length; i++ ) {
                                                          var fileFoldObj = fileFolderArray[i];
                                                          if ( fileFoldObj instanceof File ) {
                                                          } else {
        destArray.push( Folder(fileFoldObj) );
                                                          FindAllFolders( fileFoldObj.toString(), destArray );
                                                         return destArray;
                                                        function ReturnUniqueSortedList(ArrayName){
                                                        var unduped = new Object;
                                                        for (var i = 0; i < ArrayName.length; i++) {
                                                        unduped[ArrayName[i]] = ArrayName[i];
                                                        var uniques = new Array;for (var k in unduped) {
                                                           uniques.push(unduped[k]);
                                                        uniques.sort();
                                                        return uniques;
                                                        • 26. Re: Copy Filename to IPTC Keywords
                                                          JSG_Alex_B Level 1
                                                          Good morning, Paul and thanks so much for your help.
                                                          Unfortunately, both scripts won´t work the way I wanted it - either I´m doing something wrong or my description of the way the script should work was too complicated.
                                                          First of all, I describe you what I did:
                                                          I marked the parent folder in Bridge without showing the assets in the subfolders, then start the script. The first (short) script has no effect at all, the second (long) script is working, the message pops up and tells me, what the script did. But: The second script puts the name of the subfolders in IPTC but not the name of the parent folder.
                                                          At the screenshot you can see an example how the structure is and what I´m looking for.
                                                          The name of the folder "This folder name in IPTC" (the parent folder) is the information I want to be written in the IPTC-information of the pictures in Subfolder_01
                                                          Is this possible too ? Or did I something wrong ?
                                                          Thanks a lot once again,
                                                          Alex
                                                          • 27. Re: Copy Filename to IPTC Keywords
                                                            aniqO25
                                                            Paul,
                                                            Being a total noob here, is there a way to use this script but only access the filesnames first 7 alpha numerical values, so that the filenames first 7 alphanumeric characters go to the keywords?? absolutely love this script,
                                                            • 28. Re: Copy Filename to IPTC Keywords
                                                              This should do it, hope it works for you..
                                                              #target bridge
        md.Keywords = md.Keywords + ";" + decodeURI(sels[i].spec.name).substring(0,7);;
                                                              var menu = MenuElement.create( "command", "Add First 7 to Keywords", "at the end of Tools");
                                                              • 29. Re: Copy Filename to IPTC Keywords
        charlietownes
        Wonderful. I've been searching hi and lo for the solution to my problem. This is getting very close. I have a need of a slight modification: Getting back to the basic request of "filename to IPTC Title", I want to put the filename into my OWN datafield that is NOT IPTC. I'm wondering where in this code I can apply my own namespace and datafield name, and if it would work with that simple change, or would I need to modify the Adobe libraries as well?
        • 30. Re: Copy Filename to IPTC Keywords
        See if this helps....
        #target bridge
        addFileName = MenuElement.create("command", "Add FileName to My New Field", "at the end of Tools");
        addFileName.onSelect = function() {
        //Your unique name space
        var psNamespace = "http://my.uniqueNameSapce/1.0/";
        //Your chosen prefix
        var psPrefix = "myPre:";
        //Register namespace and prefix
        XMPMeta.registerNamespace(psNamespace, psPrefix);
        for(var a in sels){
        var Name = decodeURI(sels[a].name).replace(/\.[^\.]+$/, '');
        //Create new field  "MyTitile" add file name to it.
        xmp.setProperty( psNamespace, "MyTitle", Name);
        • 31. Re: Copy Filename to IPTC Keywords
        Kramer@Filson
        Like everyone else I need to use this to address thousands of images, and what has been suggested works as it is in Bridge CC 2017. However, I also need a tweak. Would it possible to modify the original script so that it only captures the first 8 characters of the file name?
        • 32. Re: Copy Filename to IPTC Keywords
        Kramer@Filson Level 1
        WHOOT! Figured it out myself. So, what I have is my company's product images that are named by style number and then color code and then pose mnemonic plus file extension. So, I have 12345678Color-main where 12345678 is the number, Color cab be anything from 3 characters to 12 characters and "-main" specifies it is the primary image to be used in print and web presentations. In our DAM system (Canto Flight) I have to be able to search on just the numerical portion of the image. But, Flight not find the numerical string when it runs in to the color name. So I need to add just the numerical portion of the file name to the Keywords field. This is what I modified it to in Bridge CC2017;
        #target bridge
        addNametoMeta = {};
        md.Keywords = md.Keywords + ";" + Name.substring(0,8);
        Works like a charm!
        • 33. Re: Copy Filename to IPTC Keywords
        SuperMerlin Level 5
        Here you are:-
        #target bridge
        addNametoMeta = {};
        var Name = decodeURI(sels[i].name).replace(/\.[^\.]+$/, '').match(/^.{8}/);
        • 34. Re: Copy Filename to IPTC Keywords
        Thanks for the reply SuperMerlin. I appreciate the input even I came up with a solution on my own. But, I will keep your script handy just in case mine blows up down the line.
        • 35. Re: Copy Filename to IPTC Keywords
        Stephen_A_Marsh Adobe Community Professional
        This can also be performed using ExifTool, removing the file extension and replacing any existing keywords:
        exiftool -r '-Subject<${filename;s/\..*?$//}' 'PATH-to-FILE-or-FOLDER'
        Or, to append to existing keywords while removing the file extension:
        exiftool -r '-Subject+<${filename;s/\..*?$//}' 'PATH-to-FILE-or-FOLDER'
        • 36. Re: Copy Filename to IPTC Keywords
        Rocket95 Level 1
        You guys are a bunch of geniuses...  love this thread!!!
        I have filenames like this  Tab_Deep Photo_N252_9c CP and I was hoping to insert a GREP where it grabs the file name and copies it into Keywords like this:  Tab Deep Photo N252 9c CP
        No underscores.  Possible?
        • 37. Re: Copy Filename to IPTC Keywords
        Rocket95 Level 1
        I should add that I am in Bridge only, facing hundreds of snippet thumbnails that need copying Filename to Keywords.   I've been doing it by hand -- and boy am I sore.
        • 38. Re: Copy Filename to IPTC Keywords
        I can do this with the command line interface driven ExifTool using a regular expression search with a replace using a word spaceAs a start, the code to enter into Terminal.app on the Mac OS would be:
        exiftool -r -overwrite_original '-subject<${filename;s/\.[^\.]+$|_/ /g}' 'PATHtoFILEorDIRECTORY'
        While for MS Windows Command Prompt:
        exiftool -r -overwrite_original "-subject<${filename;s/\.[^\.]+$|_/ /g}" "PATHtoFILEorDIRECTORY"
        Use at your own risk – work on copies of the original files for testing.
        Note: I am not 100% happy with the regex search pattern, as it leaves a trailing white space where the filename extension used to be (however that may not be the end of the world and I’ll try to fix that up if I can).
        P.S. I have only had partial success hacking a Bridge script, the regular expression in JavaScript appears to be a little bit different with the /g global option and I don’t now scripting, so bluffing my way through is not working!
        • 39. Re: Copy Filename to IPTC Keywords
        OK, I worked it out – the regex structure is a little different between Perl and JavaScript… anyway here it is, appending the filename without any extension or underscores to existing keywords (either IPTC:Keywords or DC:Subject).
        // https://forums.adobe.com/thread/656144
        // https://forums.adobe.com/message/9744916
        // https://forums.adobe.com/message/9745231
        #target bridge
        addNametoMeta = {};
        var Name = decodeURI(sels[i].name).replace(/\.[^\.]+$|_/g, ' '); //remove extension | remove underscores
        var menu = MenuElement.create( "command", "Filename to Keywords - Removing Underscore", "at the end of Tools");
        Quit Bridge. When you copy the 18 lines of source code, ensure that any quotes are straight and not curly. Save from a plain text editor or ExtendScript Toolkit with a .jsx extension and place in your Bridge Startup Scripts folder (use the preferences menu, startup scripts – reveal startup scripts). Then restart Bridge, enabling the script when prompted. Then select the files and go to the Tools menu and look for “Filename to Keywords - Removing Underscore”.
        1 2 Previous Next
