0 Replies Latest reply: Jun 9, 2010 2:19 PM by Petrula RSS
    Dynamic Link lost after moving Premiere/Encore project
    Petrula Community Member
      CS4 Production Suite
      Windows XP Pro SP 3
      I have a Premiere/Encore project which I moved to a different drive.
      The original drive was physically removed.
      I opened the moved project in Encore.
      I needed to change the transcoding so
      I selected the dynamic link i.e.
      "MySequence/MyProject.prpoj" Premiere Pro Sequence asset
      and did a Revert to Original
      which changed the DVD Transcode Status to italic untranscoded as expected.
      However, in the timeline called "MySequence/MyProject.prpoj",
      I expected to see the clip dynamically linked to the Premiere sequence.
      But instead, it showed the "media off-line" display.
      I did a Locate Asset, but it gave the strange message
      "The selected After Effects project does not contain the missing
      AdobeDynamic Link Composition "Myproject/Myproject.prpoj".
      This makes no sense since I did not use After Effects in my project.
      How do I make the Dynamic Link connect back to my Premiere sequence
      since Locate Asset does not work? I want to avoid redoing the entire
      Encore project with all the button links, etc. This has happened in other
      projects so seems to be a general problem in moving projects to a different drive.
      Note: Cleaning the Media Cache Database in Premiere had no effect.
      Thanks in advance.
