1. Re: Interesting problem with Input text
Karthik R. Jun 18, 2010 1:41 AM (in response to bestanimaster)I was not able to reproduce the problem that u have mentioned. I was able to successfully add two text fields and assign the value from an Input text Field to the dynamic text field at run time.
I added 2 text fields of type Input text field and Dynamic Text field. I named the instances as Inp_txt and Dyn_txt respectively. Pasted the following code on the actions layer and published the SWF. It seemed to work fine
var myListener:Object = new Object();
myListener.onKeyDown = myOnKeyDown;
Key.addListener(myListener);
my_btn.onPress = myOnPress;
//text field///
myListenerObject = new Object();
myListenerObject.onChanged = function(txt) {
//perform this when textfield value has changed
if (Key.getCode()== Key.ENTER )
Dyn_txt.text=Inp_txt.text;
//call the TextField.addListener method to register the object
Inp_txt.addListener(myListenerObject);
As far as opening CS5 file with Flash CS4 is concerned, it is not possible to do so.
