HI my name is saeed and i want ask about when i make application form on this program i want put button (send email) as PDF not XML or html i meaning he send me email after full the application as Attach fail PDF not xml or html is this possible.
have god day
saeed
Solved! Go to Solution.
Total Likes
Try to apply Usage Rights (with Submit form data option enabled) to your document and click on the Send Email button.
Nith
Total Likes
1. Add a button to your form.
2. On the Object Palette, switch the type to "Submit".
3. On the Submit tab, enter "mailto:email@example.com" (or your own address) as the email address.
4. On the Submit tab, switch the submission type to PDF.
Total Likes
thank you for your reply .
i do all that but didn't sent to my email
please look the images
Total Likes
ss91ss wrote on 6/13/2010 9:04 PM:
So what does it do? Do you get any errors?
Total Likes
No When i press the Send button Does not show anything any message and Are not sent to the email in anything
Total Likes
Nith
Total Likes
but i cant understand you (Try to apply Usage Rights (with Submit form data option enabled) to your document and click on the Send Email button)
where i can found the (Usage Rights) and (Submit form data option enabled) .Can you be more Specific . please i need real help as soon as possible.
Total Likes
Do you have Adobe LiveCycle ES/ES2 installed?
If yes, goto the URL http://hostname:8080/ReaderExtensions
Choose your file and click on "Apply" usage rights button
Download the Reader Extended file and try to submit it.
Nith
Total Likes
thank you for your email
yes i have Adobe LiveCycle ES/ES2. and the link you put is not correct . please help me .
Total Likes
You should replace the actual "hostname". For e.g localhost (if LiveCycle server installed on local machine) or hostname/IP address or the LiveCycle server.
Nith
Total Likes
thank you for your email .
Can you clarify more please , Because I could not understand what you mean .
how can i replace the actual "hostname"
what do you mean localhost (if LiveCycle server installed on local machine) and how can i find it .
and how can i Change the hostname/IP address or the LiveCycle server.
i open the outlook on my pc and put my email inside it And then left open, and try the button send but Doesn't make anything.
Total Likes
Goto command prompt and type ipconfig
You will get something like this:
Use the IP Address instead of the word hostname.
The you will get something like this:
Total Likes
you mean must be buy LiveCycle Designer .
And the Try version of LiveCycle Designer ES2 does not work that way.
Total Likes
