I am writing two different web services, "ClientOneOrderIn.cfc?WSDL" and "ClientTwoOrders.cfc?WSDL", for accepting orders based on client requirements. Both require an array of OrderLines called "Line", so the normal approach is:
<cfargument name="OrderLines" type="Line[]" required="yes">
and provide the properties of "Line" in file "Line.cfc".
The problem is that the properties (nodes) in "Line" is different for the two web services.
How do I create two files, such as "ClientOneLine.cfc" and "ClientTwoLine.cfc" that contain the distinct sets of properties that will show
up in the WSDL and require XML of the format:
<OrderLines>
<Line>
</Line>
<Line>
</Line>
</OrderLines>
I need the URL for both web services to be the same except for the web service name, so using different folders isn't an option.
Thanks for any help on this!!!
To give both services the same url you can put each function into the same cfc file.
They each must have their own URL, differing by just the file name: two web services are for two completely different clients.
http://ourdomain/services/clientone.cfc?WSDL
http://ourdomain/services/clienttwo.cfc?WSDL
That's not the problem. The problem is that both clientone.cfc and clienttwo.cfc have this in their argument list:
but the nodes in "Line" for the first client is different than for the second client:
If I build a file called "Line.cfc" with the cfproperties for the nodes for the first client, it is wrong for the second client.
I need two different Line.cfc files: one for the first web service and one for the second. The two web services have to be in the same folder, but the Line.cfc files do not have to be, but I don't know how to get that to work. How does each of the web services know which subfolder to get their copy of Line.cfc from?!
(Or I need a way to have a ClientOneLine.cfc and ClientTwoLine.cfc that each have the proper cfproperties for their client, but get referenced as "Line")
Since I suspect this is a common need, it is probably simple and it is something I'm just not seeing.
