I installed WAMP server on my computer, created a mySQL database from within -- impoeted a Catalyst project, pointed out the output in FlashBuilder to a forlder within www folder in wamp. Created some dynamic text driven by mySQL/PHP. When I run preview, everything looks good -- all the text is working... However I have no clue how to upload the project, how to change the settings from my local database to one that is on my webserver... Which files do I need to change -- what files/folders should I upload...
Can anybody point me to a simple step by step procedure, tutorial or documentation? It seems this knowledge is taken for granted, and I simply don't have it 🙂
To be clear; I am able to export/import mySQL files between the webserver and localhost -- just don't know how to output the Flash builder project and how to move it form my computer to the web... -- I have the Master Collection CS5.
Have you written the PHP code yourself or is this the php code generated by the FB wizard?
In either case, the only change required to point to the new database should the updating of the database connection string. It would involve updating the username, password, hostname and port for the db.
-mayank
Thanks for your help. I had a programmer help me out with the config files and now it works...
Hi, I also have the same problem, can you please tell us what did you do in order to solve this.
Thanks in advance!
