I'm currently evaluating Robohelp HTML 8 and am playing with table styles. The version I downloaded from the Adobe web site last week is RH 8.0.023, though apparently there's a more up-to-date release.
The problem I'm seeing is that the border definitions for my new table styles don't appear to be working correctly--I see random thick borders both in RH and in preview mode. This occurs with my custom table styles regardless of how many times I try to modify each separate border setting (left, right, first row, even rows, etc). In addition, borders that appear okay on the RH templates get screwed up as soon as I duplicate an RH table style to add my own modifications, such as duplicating the SimpleGridBlack table style and adding a Fill Color to the top row. The same problem occurs both for new tables created in RH8 and existing tables from my RH7 help files (have been clicking "Clean Table Inline Formatting" when applying the style to pre-existing tables).
I even tried updating the table definition in the CSS, but I'm still seeing random thick and thin borders.
So two questions:
How do I create a simple table style in RH 8 with uniformly thin borders everywhere and a gray shaded heading?
Can I download the 8.0.1 patch for RH8 without having to purchase the software (I'm still withholding judgment til I get this to work)?
Thanks.
Perhaps see if the details in this post help:
I think you should be able to apply the patches - just try Help > Updates and see what happens. (Personally I think it would be very unfair if you couldn't as the patches fix some nasty problems.) From memory you'll have to check after each install to ensure you have all the patches - I think it's up to 8.0.2 and they need to be installed in order.
Amebr
1] Yes you can and should apply the patches before judging.
2] The tables may look wrong in the Design Editor because of the old code. You will probably find they are fine in the output.
3] Make a backup copy first, then run Update DHTML effects. It cleans up more than DHTML. It may make no difference, it may help.
Thanks for the information on how to apply the update. I didn't see the Help > Update link and there were no obvious instructions on Adobe's site to upgrade the software after downloading the eval. My tables are definitely working a lot better after applying the 8.0.2 patch, but I'm still having problems applying a gray background to my table headings. I'm sure it's operator error, but I could use some help trying to figure out how all the new selections in RH8 interact to control table borders. It seems far from intuitive.
Here's what I've done:
Here's where things get screwy:
Since I want to apply a gray background color to my table headings (first row), I:
I've tried lots more stuff to get the borders/shading to work correctly but nothing I'm doing seems to work right. How is this supposed to be done? Would it be easier simply to edit the CSS? (see below)?
Thanks.
PS FWIW, here's the table definition from the CSS. There are no additional table formatting codes in the topic HTML:
table.TableNew
td {
padding-left: 10px;
padding-right: 10px;
padding-top: 0px;
padding-bottom: 0px;
table.TableNew
tr.t1Row td {
border-right-style: Solid;
border-right-width: 1px;
border-right-color: #000000;
border-bottom-style: Solid;
border-bottom-width: 1px;
border-bottom-color: #000000;
font-family: "Times New Roman";
font-size: 12pt;
table.TableNew
tr.t2Row td {
table.TableNew
padding: 0px;
border-top: Solid 1px #000000;
border-left: Solid 1px #000000;
x-border-spacing: 0px;
x-row-pat-1: 1;
x-row-pat-1-name: t1Row;
x-row-pat-count: 2;
x-row-pat-2: 1;
x-row-pat-2-name: t2Row;
x-1st-row: 1;
x-1st-row-name: t1st;
table.TableNew
tr.t1st td {
border-left-style: Solid;
border-left-width: 1px;
border-left-color: #000000;
border-top-style: Solid;
border-top-width: 1px;
border-top-color: #000000;
font-size: 12pt;
figured it out...the thread "RH8 Tables - formatting" had the information I needed. Table borders still seem buggy, but I have enough to move forward with my eval...
