Show 2 replies
1. Re: Lightroom 3 Print Module ?:0: attempt to index field "value" (a nil value)
Dorin Nicolaescu-Musteață Jun 18, 2010 2:59 AM (in response to Matthew A Kraus)You might have an invalid template in your Print Templates. Try removing your templates to see if that is the cause.
You can find print templates in C:/Users/[username]/AppData/Roaming/Adobe/Lightroom/Print Templates folder.
2. Re: Lightroom 3 Print Module ?:0: attempt to index field "value" (a nil value)
Matthew A Kraus Jun 18, 2010 3:16 AM (in response to Dorin Nicolaescu-Musteață)Thanks. That ws the problem. I went through the templates in my Print Template Folder one by one and found the culprit.
Thanks again,
Matthew Kraus
