I'm writing reports from data that comes from a 3rd party subscription. The data has not been normalized as you will read.
Requirement: Rank top 3 Dams by the money earned by their foals. List DamID, DamName, and MoneyEarnedByHerFoals (SumOfAmountWon).
A "Foal" is the horse that races, the "Dam" is that race horses mother. The Dam owner will be compensated based on the performance of her foals. A Dam may have many foals active in a year. A foal may earn money many times in a year.
Tables:
Races: Horse race results for calendar year. One record for each performance that earned money.
OBN (FoalID) Amount (Foal Earnings) RaceDate
10 500 02/02/2010
20 1000 02/02/2010
20 1000 03/02/2010
30 500 03/02/2010
40 500 04/02/2010
50 1000 04/02/2010
Racestck: Foal details. This table is a problem. There are often more that one record per foal in this table as one is added when ownership changes. I have no control over this and need a Distinct view of this table.
OBN (FoalID) DamID Breed Owner
10 100 TB Joe
10 100 TB Mary
20 200 TB Sue
30 100 TB Mike
40 200 TB Joe
50 100 TB Joe
DamSire: Dam Details. This table is a problem. There are often more that one record per Dam in this table as one is added when ownership changes. I have no control over this and need a Distinct view of this table.
OBN (DamID) HName (HorseName) Owner
100 BigMomma Smith
200 TrackMom Jones
100 BigMomma Green
Query:
This is the query so far. It applies the Distinct keyword to the Dam Table and the results are accurate if there are no duplicate OBN's in the Racestck table. I've tried to get a "distinct" view of the racestck table as well but I can't figure it out. Everything I try applies the distinct to the SumOfAmountWon as well and that does no good...
<cfquery name="getWinningDams" datasource="#SelectedFolder#">
SELECT TOP 3 D.OBN, Sum(R.Amount) AS SumOfAmountWon, D.HName
FROM (Racestck F INNER JOIN Races R ON F.OBN = R.OBN)
INNER JOIN (SELECT DISTINCT OBN, HName FROM DamSire
) D ON F.DamOBN = D.OBN
Where F.Breed='TB'
GROUP BY D.OBN, D.HName
ORDER BY 2 DESC
</cfquery>
Thank you for taking the time to read...
Lyndon
In the problem tables, are there no fields that might help you identify the current owner? A date field would help.
There is a column "OWNSSNEXT" (Owner SSN Extension) that is an incrementing alpha. Original Owner is "A" fourth owner is "D". So I guess Max(OWNSSNEXT) is the current Owner.
Lyndon
You put that max(ownsnext) in a subquery.
select etc
from table t join
(select field, max(ownsnext) theowner
group by field) sq on t.field = sq.field and t.ownsnext= theowner
etc
You have to give your subquery an alias when you do this.
I have a sloution. Thanks Dan.
Where F.Breed='TB'
And UCase(F.OWNSSNEXT)<'B'
ORDER BY 2 DESC
