I have this problem:
It is a database with table that looks like this:
id (int 10) | header (varchar 20) | content (text) inch table has utf8_bin coding,
When I connect everything is fine, but as I begin to use the Polish characters such as (ŚŁĄÓŻŹĆ) shows me #$%^&* instead of Polish characters, while testing gets something like that
"InvocationTargetException: There was an error while Invoking the operation. Check your inputs operation or the server code and try Invoking the operation again.
Reason: An error while reading response occured sent to the server. Try suitably encoding the response before sending it. e.g. If a database column Contains UTF-8 characters then use utf8_encode () to encode its value before returning it from the operation. "
method code
getAllArtykul public function () (
$ Stmt = mysqli_prepare ($ this-> connection, "SELECT * FROM $ this-> tablename"); $ this-> throwExceptionOnError ();
mysqli_stmt_execute ($ stmt);
$ This-> throwExceptionOnError ();
$ Rows = array ();
mysqli_stmt_bind_result ($ stmt, $ row-> id, $ row-> header, $ row-> content);
while (mysqli_stmt_fetch ($ stmt)) (
$ Rows [] = $ row;
$ Row = new stdClass ();
mysqli_stmt_free_result ($ stmt);
mysqli_close ($ this-> connection);
return $ rows;
I think he wants me to use utf8_encode before valuse are called, well, I tried:
mysqli_stmt_bind_result ($ stmt, $ row-> id, utf8_encode ($ row-> header), utf8_encode ($ row-> content));
mysqli_stmt_bind_result ($ stmt, $ row-> id, $ row-> header = utf8_encode ($ row-> header), $ row-> content = utf8_encode ($ row-> content));
$ Header = utf8_encode ($ row-> header)
$ Content = utf8_encode ($ row-> content);
mysqli_stmt_bind_result ($ stmt, $ row-> id, $ header, $ content);
after trying to utf8_encode, simply does not show me anything that is in the header and content (id is displayed), and in desperation I tried to use the utf8_encode on all the variables that are in the method which ended with an appearance of error, searched google, I found only one interesting reply
http://forums.adobe.com/message/2656094
also this solution does not work and displays of anything,
What is wrong with UTF8 ??? I'm trying to solve it for like 3 hour and nothing,
Please help, and sorry for my English
Hey!
have you figured out this utf-8 problem in php?
please let me know. I'm running into this issue and I can't get the other's examples to make my code working..
thanks!
If it's already in UTF-8, then no need to convert. Can you use this function to determine what is the charset it is giving and to convert it to UTF-8
function fixEncoding($in_str)
cur_encoding = mb_detect_encoding($in_str) ;
if($cur_encoding == "UTF-8" && mb_check_encoding($in_str,"UTF-8"))
return $in_str;
else
return utf8_encode($in_str);
You can also find more information in the help link of the API mb_detect_encoding
http://php.net/manual/en/function.mb-detect-encoding.php
If you are not sure whether your db is not UTF-8, the following commands also should help, then you don't need to explicitly encode.
MYSQL - ALTER database_name DEFAULT CHARACTER SET utf8;
PHP - mysql_query( "SET NAMES utf8", $database_connection );
PHP - mysql_query( "SET CHARACTER SET utf8", $database_connection );
-Sunil
Hey,
Yap problem with UTF-8 is a pain in the ass, I try to solve this problem for
about 2 days asking on many forums, and finaly someone give me the answer
here is as php class which return UTF-8 values from mySQL,
<?php
class ArtykulServices{
public function getArtykul(){
$connection = mysqli_connect("localhost", "root", "", "dotestowania", 3306)
or die (mysqli_connect_error());
$sql = "SELECT * FROM artykul";
mysqli_set_charset($connection, "utf8");
$result = mysqli_query($connection, $sql) or die("query faild:
".mysqli_error($connection));
$rows = array();
while($row = mysqli_fetch_object($result)){
$rows[] = $row;
return $rows;
Good luck
2010/8/3 Deh Bontempos <forums@adobe.com>
Hey!
thanks!
In my case it helped to add the following to the config file of mysql (my.ini in windows):
character-set-server=utf8
default-collation=utf8_unicode_ci
