SOLVED
Process Management ES - DB objects reference
Avatar
Former Community Member
Hi - Installed the Process Management ES module. It has created a set  of db tables.
Is there any documentation explaining what are these tables for , which table holds which data ..etc.
Thanks in advance for any pointers.
1 Accepted Solution
Avatar
Correct answer by
Level 10
There are no documents explaining the usage of these table.
All these table are used for internal purposes;
In fact, you are not suppose to modify any of these table directly; which is not supported by Adobe.
Nith
Avatar
Correct answer by
Level 10
Nith
Avatar
Thanks for the response.
So, I suppose there are APIs to query these tables fully.
Just wondering if there are any instances when the tables need to be accessed outside APIs.
We had QLink process management system(Adove bought it), in which we accessed tables directly . Ex: process_instannce, process_branch, process_action, process_type..etc.
Just finding that there will not be any such need here.
