I have created the DXX below.However, when I use this module, it cuts a milti page form to a single page document. Can anyone explain why?
I also lose the logo from the file.
<?xml version="1.0" encoding="UTF-8"?>
<DDX xmlns="http://ns.adobe.com/DDX/1.0/">
<PDF result="out.pdf">
<PDF source="inDoc"/>
<NoForms/>
</PDF>
</DDX>
Aditya
Total Likes
Can you post the document?
Jasmin
Total Likes
Did this ever get resolved? I have the same problem except my ddx uses NoXFA
<PDF result="outdoc">
<PDF source="doc1"/>
<NoXFA/>
</PDF>
</DDX>
My 8 pg interactive pdf after running it through this DDX outputs page 1 only.
Total Likes
How do I post a PDF? It only allows images.
This happens with any XFA dynamic doc with more than one page.
Aditya
Total Likes
What happens if you put pages="1-last" on your PDF source?
Total Likes
No luck...
Below is the ddx structure used
<PDF result="outDoc">
<PDF source="inPDFDoc" pages="1-last"/>
<NoXFA/>
</PDF>
</DDX>
Aditya
Total Likes
i was reading your posts and i am not sure if i have the anwsers, however let me point some things out since i believe it is a misunderstanding here.
<NoXFA/> ... Specifies that XFA-based forms in the parent element should be flattened.
This parameter is only working if the source is really a XFA document
<NoForms/> ... Specifies that all form fields in the parent document should be flattened.
This parameter is only working if the source is using form fields on a PDF document (created with the Acrobat Professional for example)
<PDF source="inPDFDoc">
This would expect a source named inPDFDoc which is not inPDFDoc.pdf
As a result it would be also a wise idea to set it to outDoc.pdf maybe this helps
You might miss also to try to apply to the input source to flatten meaning appliying NoXFA or NoForms there
example:
<DDX xmlns=”http://ns.adobe.com/DDX/1.0/”>
<PDF result=”rpt_flattenform_kpi_002.pdf”>
<PDF source=”doc1.source” pages="1-last">
<NoForms/>
</PDF> <---- see here cloeses the source
</PDF>
</DDX>
or
<PDF result=”rpt_xfastripping_001.pdf”>
<NoXFA/>
</PDF>
</DDX>
See if this is helping you to get the example working
rgs
Dieter
Total Likes
If you see the original post, I used NoForms and NoXFA later on. None of these seem to work. Have you tried using either of these parameters in your DDX for a multi page document? Did it work?
I have tried all your suggested combinations as per the previous posts, unless I missed anything?
Aditya
Total Likes
Aditya;
What version of LiveCycle are you using?
When your dynamic form gets chopped to one page is there any data in it, or is the data completely dumped?
Total Likes
There is data...
Aditya
Total Likes
I think it has to do with dynamic forms. It works well with static ones.
Does NoForms,NoXFA work with dynamic forms?
Aditya
Total Likes
Huum, interesting. My suspicion is that the document is being merged with the data, but there is no request to re-render the form happening. With Dynamic forms the document isn't fully rendered until it gets to the client (usually Reader). Since the no-xfa is part of the merge, the request to render at client may be removed with the XFA.
Can you try merging the data with the form using LC Forms? Then take the result and use assembler to do a no-xfa.
The other option would be to use LC Output to merge the template and data. That would give you a non-interactive form without using no-xfa
Total Likes
Which module in Form? I need an interactive form hence, Output will not work.
Aditya
Total Likes
Forms is a module. Try the renderPDFForm operation.
BTW - if you use noXFA you won't have an interactive PDF anymore. That operation "flattens" the form.
Total Likes
