Hello,
I have read the Windows 7 & 64 bit thread about how Captivate 4 not work within a Windows 7/ 64-bit environment, some how it worked on this computer before I adopted it. I am trying to record audio on a project and when I go into Audio-Setting--the input device area is greyed out and I can't select a device. I have a Microsoft headset attached to the laptop by USB. I also cannot click on the Calibrate input button because it is greyed out.
This laptop was used to create several Captivate 4 projects without any audio issues as far a I know. I just adopted the laptop and unfortunately the previous user is no longer at this office.
AMT2007
Hello,
Just to be sure: is the update installed? Check the version (should be 1658) or go into Help menu, Updates.
Lilybiri
Yes the update was downloaded. 4.0.1 Build 1658.
Hello,
Did you start Captivate as Administrator?
Another workaround: try to start in XP-simulation mode.
Lilybiri
Hi Lilybiri,
I am running in Administrator mode and XP-compatability mode is turned on.
Sorry, cannot think of something else. Do run CP4 on a Win7 64bit laptop but I'm using another microphon and seem to be lucky.
Lilybiri
