I am using Ant to build a series of swfs in an Actionscript project and I want to compile them as small as possible, but I can't compile them as small using Ant and the mxml compiler as I can compiling in FB using the Release Build. What options can I use to emulate the FB release compilation?
I use optimize=”true” and debug=”false”
I have also seen this asked here:
On: http://flex.gunua.com/?p=79 Chris asked:
Does anybody know why the swf file is bigger when compiled by Ant, as opposed to when it’s done by the Flex Builder. It is even smaller (1/2 the size) when I use the “Export Release Build” option.
I am using optimize=”true” and debug=”false” in the mxml task, but it does not seem to be enough.
Hi Josh,
I think this should help. The -dump-config option should help you get what you want.
http://help.adobe.com/en_US/flashbuilder/using/WSbde04e3d3e6474c4-59108b2e1215eb9d5e4-8000.html#WSbde04e3d3e6474c4-59108b2e1215eb9d5e4-7ff0
Nishad
Thanks Nishad,
I only just saw this now - but it is still useful - I hadn't thought of doing that.
At first glance it was a little disappointing - I didn't see much of interest except:
<!-- compiler.omit-trace-statements: toggle whether trace statements are omitted-->
<omit-trace-statements>true</omit-trace-statements>
