Hi ,
I am using RH 8.0.2.
Suddenly topics from my search list is reducing.Like in the past release topic found for X was 100 now in this release it is 50.
How can i solve this.
In parent project about 200 childs are merged
Br,
Rahul
There is so much this could be that you'll have to do a bit of detective work. However before you head off in disgust maybe you could tell us a bit more. Has the problem only started happening after some changes? If so, what as changed? Do all the child projects have the same single source layout properties? Are all the projects merged successfully? That will do for starters.
I have done changes in Parent project and almost in 40 different child
project.
Yes,all the child project have same ssl properties.
Do i need to remerge or simply replace the new chm?
Br,
Rahul
One thing more,as i have upgraded the file to RH8.0.2 the topic get reduce
drasticly from 500 to 398.
Br,
Rahul
The missing topics may well prove to be at the root of the problem. Are they all from the same project?
