2 Replies Latest reply: Jun 23, 2010 12:09 AM by dheeraj_c RSS
    Custom effect Reset issue.
    dheeraj_c Community Member
          I'm having an issue  with Effect Reset. In the custom effect I have a SLIDER. Whenever Reset is clicked, the Slider reverts back to the default value. I understand  that this is the normal behaviour but I want the Slider to maintain the  old value before Reset.
      So is there any way to store the old value just  before Reset so that I can set it back after Reset? Or is there any way  to tell the effect not to Reset the particular parameter?
      Dheeraj.
        • 1. Re: Custom effect Reset issue.
          shachar carmi Community Member
          hhhmmmm....
          you can't tell a param to ignore the reset operation.
          what you can do is to store that data with the sequence data,
          and on SEQUENE_RESETUP you can re-apply that value.
          the SEQUENE_RESETUP call is pretty rare, so you don't mind re-applying the value even when not needed.
          if you're using that param for what i think you're using that param (a unique identifier), then you can skip using a param all together,
          and store that data in the sequence data only.
          if another effect wants to read that data it can do it via AEGP_EffectCallGeneric().
          one more thing you could try (which could prove tricky) is to set a different default for that slider during the param_setup call.
          that would cause each instance of your effect to reset that param to a different value.
          but that's all in theory.
          i'm not even sure you get more than one param_setup call per session.
          just throwing some ideas out there.
          • 2. Re: Custom effect Reset issue.
            Thanks a lot again Shachar.
            You guessed right Shachar. I'm using the param as unique identifier.
            Now I'm saving the data in SEQUENCE_SETUP and retrieving it when needed from AEGP using AEGP_EffectCallGeneric().
            I had tried this before but Param setup is called only once when the effect is applied for the very first time.
            But thanks a lot Shachar, your first idea works fine.
