Show 1 reply
1. Re: Best encoding setting for flv & dvd?
Jeff Bellune Jun 23, 2010 11:44 AM (in response to 2drumstix)It's sounds simple, but just use a preset that matches the final output that you want. If that doesn't produce good results for you then post back with the preset settings that you used, and exactly what isn't right about the result. Then maybe we can point out things that you could tweak.
Encoding is almost an art form, so one-size-fits-all settings are almost impossible to find. Trial-and-error is almost always required.
-Jeff
