I am using an object called t and its values are like so, when it should be a number
t[1].ask =<<Recursive Reference - Cannot display value>>
anything I can do?
I'm pretty sure you should be able to see it in the Expressions tab... create a new watch expression. Since you can't view an array as simple text, you need to evaluate the element you're interested in. I haven't used the Expressions pane very much... but you might be able to view complex objects in there.
