Locked
Trunk build failure
Jun 18, 2010 Jun 18, 2010
Checked out the trunk today to build the latest and I received a build failure error when running mvn package.
Here's the error:
Running de.bokelberg.flex.parser.TestPackageContent
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running de.bokelberg.flex.parser.TestInterface
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Results :
Tests run: 128, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar {execution: default-jar}]
[INFO] [license:check {execution: default}]
[INFO] Checking licenses...
[INFO] ------------------------------------------------------------------------
[INFO] Building Adobe Flex PMD RuleSet API
[INFO]    task-segment: [package]
[WARNING] POM for 'jaxen:jaxen:pom:1.1.1:compile' is invalid.
Its dependencies (if any) will NOT be available to the current build.
[INFO] [dependency:unpack-dependencies {execution: unpack-test-resources}]
[INFO] Unpacking /Developer/Web/Flex/adobe/flexpmd/as3-parser/target/as3-parser-1.2-SNAPSHOT.jarto
/Developer/Web/Flex/adobe/flexpmd/flex-pmd-ruleset-api/target/test/generated-resources
with Includes **/*.as,**/*.mxml and excludes:null
[INFO] Unpacking /Developer/Web/Flex/adobe/flexpmd/as3-plugin-utils/target/as3-plugin-utils-1.2-SNAPSHOT.jarto
[INFO] Unpacking /Developer/Web/Flex/adobe/flexpmd/flex-pmd-files/target/flex-pmd-files-1.2-SNAPSHOT.jarto
[INFO] Unpacking /Developer/Web/Flex/adobe/flexpmd/flex-pmd-test-resources/target/flex-pmd-test-resources-1.2-SNAPSHOT-resources.zipto
[INFO] [resources:resources {execution: default-resources}]
[INFO] Using 'UTF-8' encoding to copy filtered resources.
[INFO] Copying 1 resource
[INFO] [compiler:compile {execution: default-compile}]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources {execution: default-testResources}]
[INFO] Copying 96 resources
[INFO] Copying 0 resource
[INFO] [compiler:testCompile {execution: default-testCompile}]
[INFO] Compiling 5 source files to /Developer/Web/Flex/adobe/flexpmd/flex-pmd-ruleset-api/target/test-classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/Developer/Web/Flex/adobe/flexpmd/flex-pmd-ruleset-api/src/test/java/com/adobe/ac/pmd/nodes/utils/AsDocUtilsTest.java:[64,53] cannot find symbol
symbol  : method computeParameterDoc(java.lang.String,java.lang.String)
location: class com.adobe.ac.pmd.nodes.utils.AsDocUtils
/Developer/Web/Flex/adobe/flexpmd/flex-pmd-ruleset-api/src/test/java/com/adobe/ac/pmd/files/FileSetUtilsTest.java:[52,39] buildLogMessage(com.adobe.ac.pmd.files.IFlexFile,java.lang.String) has private access in com.adobe.ac.pmd.files.FileSetUtils
[INFO] Trace
org.apache.maven.BuildFailureException: Compilation failure
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:715)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:556)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:535)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:387)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:348)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:180)
    at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:328)
    at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:138)
    at org.apache.maven.cli.MavenCli.main(MavenCli.java:362)
    at org.apache.maven.cli.compat.CompatibleMain.main(CompatibleMain.java:60)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
    at java.lang.reflect.Method.invoke(Method.java:597)
    at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
    at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
    at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
    at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.CompilationFailureException: Compilation failure
    at org.apache.maven.plugin.AbstractCompilerMojo.execute(AbstractCompilerMojo.java:516)
    at org.apache.maven.plugin.TestCompilerMojo.execute(TestCompilerMojo.java:102)
    at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:490)
    at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:694)
    ... 17 more
[INFO] Total time: 20 seconds
[INFO] Finished at: Fri Jun 18 13:57:21 PDT 2010
[INFO] Final Memory: 72M/460M
FlexPMD
855
Adobe Employee ,
Jun 24, 2010 Jun 24, 2010
Hi Clint,
We can't reproduce the behaviour,
What is your JRE version?
Xavier
It would appear that some of the directories in repository are password protected... this is probably what caused the build failure.
Are the password protected directories intentional?
