NullPointerException using java to send message
Avatar
Level 1
I have a flex application using 3.x and BlazeDS 3.x that calls a servlet. In the servlet I have the following
            MessageBroker msgBroker = MessageBroker.getMessageBroker(null);
            msgBroker.addDefaultChannel("my-channel");
            AsyncMessage msg = new AsyncMessage();
            msg.setDestination("vle_topic");
            String clientID = UUIDUtils.createUUID();
            msg.setClientId(request.getSession().getId()); //clientID);
            msg.setMessageId(UUIDUtils.createUUID());
            msg.setTimestamp(System.currentTimeMillis());
            msg.setBody("servlet example event");
            msgBroker.routeMessageToService(msg, null);
When the servlet is called, I get a NullPointerException with the following output in the tomcat log:
[BlazeDS] 06/23/2010 16:44:12.254 [ERROR] [Message.General] Exception when invoking service: message-service
  with message: Flex Message (flex.messaging.messages.AsyncMessage)
    clientId = 8539568E76F27D9B515F9947CFC30545
    correlationId = null
    destination = vle_topic
    messageId = 146C4633-321A-3920-1CE7-E5E9DB212EA6
    timestamp = 1277333052242
    timeToLive = 0
    body = servlet example event
  exception: java.lang.NullPointerException
at flex.messaging.FlexContext.isPerClientAuthentication(FlexContext.java:264)
at flex.messaging.FlexContext.getUserPrincipal(FlexContext.java:279)
at flex.messaging.security.LoginManager.getCurrentPrincipal(LoginManager.java:348)
at flex.messaging.security.LoginManager.checkConstraint(LoginManager.java:291)
at flex.messaging.MessageBroker.inspectOperation(MessageBroker.java:1683)
at flex.messaging.MessageBroker.routeMessageToService(MessageBroker.java:1406)
at com.sun.vle.bui.vmvc.AddVmvcsServlet.doPost(AddVmvcsServlet.java:52)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:525)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:567)
at org.apache.catalina.authenticator.SingleSignOn.invoke(SingleSignOn.java:421)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:849)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:454)
at java.lang.Thread.run(Thread.java:637)
Anybody know what is wrong? I suspect it has do with the security setup in the application. We use a custom realm and require a user to login to access the application.
Dave Brininstool
1 Reply
Avatar
Employee
Looks like you need a MessageBroker in the FlexContext. Try calling FlexContext.setThreadLocalMessageBroker().
See http://opensource.adobe.com/svn/opensource/blazeds/trunk/modules/core/src/flex/messaging/  Or rather the 3.x branch: http://opensource.adobe.com/svn/opensource/blazeds/branches/3.x/modules/core/src/java/flex/messaging...
Note that the code was fixed on 5/6/09 to not throw an NPE but return null, so you might want to get BlazeDS 4.0.
