i have a dropdown menu where i disabled custom text entry. the last item in the dropdown is the "Other" option where I want the user to write extra details. I was wondering if there's a way to pop up a text field when the "Other" option is selected.
Also, the dropdown field stretches all the way across the page..so when the "Other" option is chosen, would it be possible to automatically shrink the field to fit a text field next to it for the user to type in details.
I'm not sure if there's a better way to do this....any help would be much appreciated!
thanks!!
Solved! Go to Solution.
Total Likes
Hopefully you will get it working soon.
I suspect that the form is not saved as Dynamic:
Other than that, double check the that the object references in the script matches the objects in the forms, including subforms if objects are in different subforms.
If you could share the problem it would help finding the problem.
Niall
Total Likes
Here are a few options: https://acrobat.com/#d=IGVrIAm2uBngOlVzwKa1Bg
Alos have some layout examples on our blog: http://assurehsc.ie/blog/index.php/2010/06/laying-out-a-form/
Hope that helps,
Niall
Total Likes
thanks again niall for your reply!
i really like option 1..where there's a hidden field
but i have multiple Others in my dropdown menu..is there a way to group all the others together instead of writing them out one by one, like "this.rawValue == "Other1" || this.rawValue == "Other2"....etcetc"
thanks!
Total Likes
o i figured it out...i just had to assign binding values to it!
but i'm having trouble doing option 1 for my form..i have the exact same coding and field settings as yours but i cant seem to work..i even tried to make it a dynamic form but still no luck. do you have any suggestions for me?
Total Likes
The if statement is based on one of the items being "Other". If this does not exist then the script will not work.
Also if you set the dropdown to have a binding (Object > Binding tab) then you need to set the if statement to test against the bound value rather than the displayed value. For example if the "Other" is bound to "4", then the if statement would look like:
if (this.rawValue == "4")
Good luck,
Niall
Total Likes
I coded the fields and copied it to a new form and it worked..but it won't work on the original form...what's the reason for it??
Total Likes
Niall
Total Likes
that's it!
thanks so much!!
Total Likes
