Thanks for the handy tip Kurt.
Should be able to come up with a technique with your post.
"Kurt" <kb0000@yahoo.com> wrote in message
news:e2lse6$ojb$1@forums.macromedia.com...
> This is just some fluff, but one method that I use for
checking if
> something is
> being viewed over SSL or not is to check the
CGI.SERVER_PORT variable. SSL
> typically runs on port 443. So doing the following check
will easily tell
> you
> if you're script is being viewed over SSL or not ,and
you don't have to
> worry
> about doing any text comparisons.
> <cfif NOT CGI.SERVER_PORT EQ 443 >
> <cflocation url="#somwhere#" >
> </cfif>
> Of course a much better way to do this would be to do
what I do for all
> projects I work on. Use configuration values!!! I always
set 3
> Application
> variables for every project I work on, they are:
> <cfset application.webRoot="
http://#CGI.SERVER_NAME#" >
> <cfset
application.sslRoot="https://#CGI.SERVER_NAME#" >
> <cfset application.sslPort=443 >
> <cfif NOT CGI.SERVER_PORT EQ application.sslPort >
> <cflocation url="#application.sslRoot#" >
> </cfif>
> And if I need a URL or FORM to point to my SSL site,
then I write these
> URLs
> as:
> #Application.sslRoot#/order/process.cfm
> and of course to get back OUT of SSL and into regular
HTTP, write your
> links
> as: #Application.webRoot#/index.cfm
> The default values for the 3 config values above usually
suffice just
> fine,
> but if you're roots are different, then it takes only a
second to change
> them
> and have it propogate throughout your application
instantly if you used
> the
> config values properly. I have found this technique VERY
convenient to aid
> in
> testing since the site I'll have setup on my local
development machine is
> always "test.<domain.com>" so when it comes time
to actually put my
> configuration LIVE and into production after doing all
my testing, I don't
> have
> to modify 50 files, I just replace the "test." with
"www." and I"m set.
> This
> technique also helps if you don't have SSL installed on
your test/local
> machine. For testing purposes you can set the SSL port
to 80, and the
> sslRoot
> to "HTTP" (not HTTPS) and you'll be able to easily test
out that parts
> that
> would normally be under SSL over HTTP while in test
mode.
