Locked
Flash Builder 4 standalone on win7 64bit is broken after update
Jul 01, 2010 Jul 01, 2010
Today Adobe Updater promted that there are updates for Adobe Flash Builder 4 and Photoshop CS5. The update downloaded and installed without any errors and Photoshop is still working fine for me. But when I open Flash Builder I get a bunch of error messages and can't use Flash Builder any more. Here are screenshots of what the errors looks like:
Sadly not only the Flash Builder perspective is affected but all other perspectives (SVN, Debugging, Profiling) are throwing errors too.
These are the steps I tried to fix these errors - without success:
- switching back to my personal workspace (after the update another workspace was selected)
- opening Flash Builder with the "-clean" parameter (this worked for me several times when plugins didn't want to install properly)
- opening Flash Builder with administration rights
- checking inside Flash Builder for any updates
None of these steps worked for me and I don't know how to fix this problem. Has anyone experienced the same errors after the 4.0.1.-update or are there any infos I missed?
Any help would be appreciated!
Miracula
Installation and activation
13.9K
I'm on a mac and getting this same problem. I'm currently trying to run the updater again.
Yes, I tried this too but it didn't help. I manually downloaded the update installer from this url: http://www.adobe.com/support/flex/downloads_updaters.html - nothing changed...
I've filed a ticket with Adobe, but this is really aggrivating!
http://bugs.adobe.com/jira/browse/FB-27100
Thanks for posting the bug with detailed info about the error. We'll certainly treat this with the highest priority today, and are sorry this has broken your installation.
The error is mystifying, because this update received an enormous amount of testing (both internal and external) before it was released. We'll get to the root of it as quickly as possible.
For those of you experiencing this problem, will you please send any additional info you have available, that might speed up the triage:
- full workspace log, from the root of your .metadata folder
- amt3.log from your tmp folder
- latest installation log
You can find the installation logs in these locations:
Mac - /Library/Logs/Adobe/Installers/
Win - \Program Files\Common Files\Adobe\Installers\
You can send any info to this address:
cagruss [at adobe dot com]
-Chris
I posted this over at http://forums.adobe.com/thread/671680?tstart=0 and someone there thinks it might be teamprise related. I've uninstalled teamprise from my copy, but still seem to be getting this error.
Interesting enough I don't have the Installer folder located within Library/Logs/Adobe/   - seems there is no log of my update of my flash builder. Could this be stored elsewhere?
I don't have teamprise installed, so I don't think it is a problem with this specific plugin. I sent my log files as requested - hopefully it helps.
@Miracula.42
Thanks for send me your full workspace log. The root error in the most recent entry there was different from the one at the top of this thread, so I attached your log to the bug report.
At the end of the error stack trace of "caused by" entries is this particular one:
Caused by: java.lang.NoSuchMethodError:
flex2.compiler.mxml.lang.StandardDefs.getStandardDefs(Ljava/lang/String;)Lflex2/compiler/mxml/lang/StandardDefs;
at com.adobe.flexbuilder.codemodel.internal.parsing.mxml.MXML3ToASConverter.<init>(MXML3ToASConverter.java:55)
I wonder if this error is a result of loading a Flex 2 project that didn't get converted/upgraded normally? That's a wild guess, but if so, I also wonder why the error doesn't happen with FB 4.0?
Please let me know if I'm all wet about the Flex 2 project format.
-Chris
Jul 02, 2010 Jul 02, 2010
Chris, I didn't read all these errors in detail, because everytime I am clicking somewhere there is a new one
But I don't have any Flex 2 project in my workspace. In fact I am using mostly ActionScript projects and one or two flex 3.5 projects. But I am quite sure I never had any Flex 2 project opened on my machine.
Thank you.
Miracula
Guest
I couldn't reproduce the installation failure on my desktop - the upgrade went smoothly without any problems. For further investigation, would it be possible to attach the configuration data of the installation ?
Help -> Product Details -> Installation Details -> Configuration tab.
Copy the content from the Configuration tab and attach the file/content here.
@pinnamur:
here is the log you requested. I am not allowed to attach text files, so here is the content:
*** Date: Friday, July 2, 2010 9:42:59 AM Germany Time
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=com.adobe.flexbuilder.standalone.FlexBuilderApplication
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\FlashBuilder.exe
-name
FlashBuilder
--launcher.library
C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
-startup
C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins/org.eclipse.equinox.launcher_1.0.201.R35x_v20090715.jar
-nl
en_US
-vm
C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin\client\jvm.dll
eclipse.home.location=file:/C:/Program Files (x86)/Adobe/Adobe Flash Builder 4/
eclipse.launcher=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\FlashBuilder.exe
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=profile
eclipse.product=com.adobe.flexbuilder.standalone.product
eclipse.startTime=1278056489353
eclipse.vm=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin\client\jvm.dll
eclipse.vmargs=-Xms256m
-Xmx512m
-XX:MaxPermSize=256m
-XX:PermSize=64m
-Djava.net.preferIPv4Stack=true
-Dorg.eclipse.equinox.p2.reconciler.dropins.directory=dropins
-Djava.class.path=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins/org.eclipse.equinox.launcher_1.0.201.R35x_v20090715.jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=50.0
java.endorsed.dirs=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\endorsed
java.ext.dirs=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre
java.io.tmpdir=C:\Users\Tine\AppData\Local\Temp\
java.library.path=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4;.;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files (x86)/Adobe/Adobe Flash Builder 4/jre/bin/client;C:/Program Files (x86)/Adobe/Adobe Flash Builder 4/jre/bin;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Common Files\Roxio Shared\10.0\DLLShared\;C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\;C:\Windows\Microsoft.NET\Framework\v2.0.50727;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files (x86)\Common Files\DivX Shared\;C:\Program Files\TortoiseSVN\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_16-b01
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_16
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=14.2-b01
line.separator=
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=false
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows7
org.osgi.framework.os.version=6.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 7
os.version=6.1
osgi.arch=x86
osgi.bundles=reference:file:org.eclipse.osgi.nl1_3.5.0.v20091121043401.jar,reference:file:org.eclipse.equinox.ds_1.1.1.R35x_v20090806.jar@1:start,reference:file:org.eclipse.equinox.simpleconfigurator_1.0.101.R35x_v20090807-1100.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\Users\Tine\.eclipse\com.adobe.flexbuilder.standalone.product_4.0.1_1084004438\configuration\org.eclipse.osgi\bundles
osgi.configuration.area=file:/C:/Users/Tine/.eclipse/com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/configuration/
osgi.framework=file:/c:/Program Files (x86)/Adobe/Adobe Flash Builder 4/plugins/org.eclipse.osgi_3.5.1.R35x_v20090827.jar
osgi.framework.extensions=reference:file:org.eclipse.osgi.nl1_3.5.0.v20091121043401.jar
osgi.framework.shape=jar
osgi.framework.version=3.5.1.R35x_v20090827
osgi.frameworkClassPath=., file:c:/Program Files (x86)/Adobe/Adobe Flash Builder 4/plugins/org.eclipse.osgi.nl1_3.5.0.v20091121043401.jar
osgi.install.area=file:/C:/Program Files (x86)/Adobe/Adobe Flash Builder 4/
osgi.instance.area=file:/D:/flashBuilder_workspace/
osgi.instance.area.default=file:/C:/Users/Tine/Adobe Flash Builder 4/
osgi.logfile=D:\flashBuilder_workspace\.metadata\.log
osgi.manifest.cache=C:\Users\Tine\.eclipse\com.adobe.flexbuilder.standalone.product_4.0.1_1084004438\configuration\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.nl.user=en_US
osgi.os=win32
osgi.sharedConfiguration.area=file:/c:/Program Files (x86)/Adobe/Adobe Flash Builder 4/configuration/
osgi.splashPath=platform:/base/plugins/com.adobe.flexbuilder.standalone
osgi.syspath=c:\Program Files (x86)\Adobe\Adobe Flash Builder 4\plugins
osgi.tracefile=D:\flashBuilder_workspace\.metadata\trace.log
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\resources.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\rt.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\sunrsasign.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\jsse.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\jce.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\lib\charsets.jar;C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\classes
sun.boot.library.path=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=
user.country=DE
user.dir=C:\Program Files (x86)\Adobe\Adobe Flash Builder 4
user.home=C:\Users\Tine
user.language=de
user.name=Tine
user.timezone=Europe/Berlin
user.variant=
*** Features:
com.adobe.flexbuilder.feature.standalone (4.0.1.277662) "Adobe Flash Builder Standalone"
com.adobe.flexbuilder.feature.standalone.nl1 (4.0.1.277662) "Adobe Flash Builder Standalone"
com.collabnet.subversion.merge.feature (2.1.0) "CollabNet Subversion Merge Client"
com.sun.jna (3.2.3) "JNA Library Plug-in"
org.eclipse.cvs (1.1.101.R35x_v20090811-7E79FEd9KKF5H2YDWFLLBL01A16) "Eclipse CVS Client"
org.eclipse.datatools.connectivity.feature (1.7.2.v200909251450-7B7OANEn1Xi4gycmhPC6njFVDz0q) "Data Tools Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.7.2.v200909251450-7E7C7BDZRDIVDUKiEaXU) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.7.2.v200909251450-7H797BCcNBHBBHMWDbRK) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.7.2.v200909251450-47C08w95ENAK6AFDFK7) "Data Tool Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature (1.7.2.v200909251450-7768dBmKDLfMjHuIFJW7SBI) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.7.2.v200909251450-7J8i7UBWwSLRWdU50unZvFu_Pz0t) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.7.2.v200909251450-67B2AqGBJVKbGuH3GP7SBI) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.7.2.v200909251450-7F47HFC7sRTNSjXAYIRR) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ingres.feature (1.7.2.v200909251450-540AkF77g7VBLBPH7) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.jdbc.feature (1.7.2.v200909251450-4-29oB55W5P7G6RAH) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.jdt.feature (1.7.2.v200909251450-2-07w311A1A351453) "Data Tools Platform Connectivity JDT Extension Plug-in"
org.eclipse.datatools.enablement.msft.feature (1.7.2.v200909251450-542AkF78Y7SBU9UAB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.mysql.feature (1.7.2.v200909251450-546AkF78Y7R9PAX87) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.oda.designer.feature (1.7.2.v200909251450-3328s7353356I4F53) "Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.7.2.v200909251450-7A7T78DZRDFuD_KmFcNp) "Eclipse Data Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.7.2.v200909251450-548aAkF77g7XAO9aBB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.postgresql.feature (1.7.2.v200909251450-542AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sap.feature (1.7.2.v200909251450-540AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sqlite.feature (1.7.2.v200909251450-541AkF79P7N8NAQ97) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.7.2.v200909251450-7E45F9NiNWvOOXxPdVT) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.modelbase.feature (1.7.2.v200909251450-77-5CcNBCtCcCQJYZl) "Eclipse Data Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.ddlgen.feature (1.7.2.v200909251450-7A-1F7RZHKFIwMhStRm) "Eclipse Data Tools Platform FE UI Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.7.2.v200909251450-7N7q7GFDr_mX5M8JAs38u8wWDRWU) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqldevtools.parsers.feature (1.7.2.v200909251450-602BgJ99q9_9OGXFJ) "Eclipse Data Tools Platform SQL Parser Plugin"
org.eclipse.draw2d (3.5.2.v20100111-1352-4417w311A223702A19) "Graphical Editing Framework Draw2d"
org.eclipse.emf (2.5.0.v200906151043) "EMF - Eclipse Modeling Framework Runtime and Tools"
org.eclipse.emf.codegen (2.5.0.v200906151043) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.5.0.v200906151043) "EMF Ecore Code Generator"
org.eclipse.emf.codegen.ecore.ui (2.5.0.v200906151043) "EMF Ecore Code Generator UI"
org.eclipse.emf.codegen.ui (2.4.0.v200906151043) "EMF Code Generation UI"
org.eclipse.emf.common (2.5.0.v200906151043) "EMF Common"
org.eclipse.emf.common.ui (2.5.0.v200906151043) "EMF Common UI"
org.eclipse.emf.converter (2.5.0.v200906151043) "EMF Model Converter"
org.eclipse.emf.databinding (1.1.0.v200906151043) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.1.0.v200906151043) "EMF Edit Data Binding"
org.eclipse.emf.ecore (2.5.0.v200906151043) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.5.0.v200906151043) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.5.0.v200906151043) "EMF Sample Ecore Editor"
org.eclipse.emf.edit (2.5.0.v200906151043) "EMF Edit"
org.eclipse.emf.edit.ui (2.5.0.v200906151043) "EMF Edit UI"
org.eclipse.emf.mapping (2.5.0.v200906151043) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.5.0.v200906151043) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.5.0.v200906151043) "EMF Ecore Mapping Editor"
org.eclipse.emf.mapping.ui (2.5.0.v200906151043) "EMF Mapping UI"
org.eclipse.gef (3.5.2.v20100111-1352-777928194B66D5D476C33B2A) "Graphical Editing Framework GEF"
org.eclipse.help (1.1.1.R35x_v20090811-7e7eFAnFEx2XZoYz0uPgIfwD) "Help System Base"
org.eclipse.jdt (3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6) "Eclipse Java Development Tools"
org.eclipse.jpt.eclipselink.feature (2.2.2.v200911250220-65A9AkF77g8OFL7BB7) "Dali Java Persistence Tools - EclipseLink Support"
org.eclipse.jpt.feature (2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je) "Dali Java Persistence Tools"
org.eclipse.jst.enterprise_ui.feature (3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq) "Eclipse Java EE Developer Tools"
org.eclipse.jst.ws.axis2tools.feature (1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe) "Axis2 Tools"
org.eclipse.pde (3.5.2.R35x_v20100119-7Z7_FA2FDX-aXQYWqYDBz-z0qufo) "PDE"
org.eclipse.platform (3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7) "Eclipse Platform"
org.eclipse.rcp (3.5.1.R35x_v20090811-9SA0FxVFqE70OL1ARMrfcO6e7BA6) "Eclipse RCP"
org.eclipse.wst.jsdt.feature (1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb) "JavaScript Developer Tools "
org.eclipse.wst.web_ui.feature (3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3) "Eclipse Web Developer Tools"
org.eclipse.wst.xml_ui.feature (3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo) "Eclipse XML Editors and Tools"
org.eclipse.wst.xsl.feature (1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1) "Eclipse XSL Developer Tools"
org.tigris.subversion.clientadapter.feature (1.6.12) "Subversion Client Adapter"
org.tigris.subversion.clientadapter.javahl.feature (1.6.12) "Subversion JavaHL"
org.tigris.subversion.clientadapter.svnkit.feature (1.6.12) "SVNKit Client Adapter"
org.tigris.subversion.subclipse (1.6.12) "SVN Team Provider Core"
org.tmatesoft.svnkit (1.3.3.6648) "SVNKit Library Plug-in"
*** Plug-in Registry:
ActionscriptInfoCollector (0.7.4) "ActionscriptInfoCollector Plug-in" [Starting]
com.adobe.coldfusion.rds.client (1.0.272885) "RDS Core and Database Client Plug-in" [Starting]
com.adobe.coldfusion.rds.client.nl1 (1.0.1.v20100112266797) "Nl1 Fragment" [Resolved]
com.adobe.flash.codemodel.core (4.0.1.277662) "Adobe Flash CodeModel Core" [Active]
com.adobe.flash.codemodel.osgi (4.0.1.277662) "Code Model OSGI Support" [Active]
com.adobe.flash.profiler (4.0.1.277662) "Adobe Flash Profiler" [Active]
com.adobe.flash.profiler.nl1 (4.0.1.277662) "Adobe Flash Profiler Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.ajaxbridge (4.0.1.277662) "Adobe Flash Builder Ajaxbridge" [Active]
com.adobe.flexbuilder.ajaxbridge.nl1 (4.0.1.277662) "Adobe Flash Builder Ajaxbridge Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.as.editor (4.0.1.277662) "Adobe Flash Builder ActionScript Editor" [Active]
com.adobe.flexbuilder.as.editor.nl1 (4.0.1.277662) "Adobe Flash Builder ActionScript Editor Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.axis2 (4.0.1.277662) "Adobe Flash Builder AXIS 2" [Starting]
com.adobe.flexbuilder.axis2.nl1 (4.0.1.277662) "Adobe Flash Builder AXIS 2 Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.codemodel (4.0.1.277662) "Adobe Flex IDE CodeModel" [Resolved]
com.adobe.flexbuilder.codemodel.nl1 (4.0.1.277662) "Adobe Flash Builder CodeModel Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.crimson (4.0.1.277662) "Adobe Flash Builder Crimson" [Resolved]
com.adobe.flexbuilder.crimson.nl1 (4.0.1.277662) "Adobe Flash Builder Crimson Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.css.editor (4.0.1.277662) "Adobe Flash Builder CSS Editor" [Starting]
com.adobe.flexbuilder.css.editor.nl1 (4.0.1.277662) "Adobe Flash Builder CSS Editor Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.DCDService (4.0.1.277662) "Adobe Flash Builder DCDService" [Starting]
com.adobe.flexbuilder.DCDService.nl1 (4.0.1.277662) "Adobe Flash Builder DCDService Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.dcrad (4.0.1.277662) "Adobe Flash Builder Data Centric RAD" [Active]
com.adobe.flexbuilder.dcrad.derived (4.0.1.277662) "Adobe Flash Builder Data Centric RAD Derived Sources" [Starting]
com.adobe.flexbuilder.dcrad.nl1 (4.0.1.277662) "Adobe Flash Builder DCRAD Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.debug (4.0.1.277662) "Adobe Flash Builder Debug Model" [Active]
com.adobe.flexbuilder.debug.e33 (4.0.1.277662) "Adobe Flash Builder Debug Fragment for Eclipse 3.3" [Resolved]
com.adobe.flexbuilder.debug.nl1 (4.0.1.277662) "Adobe Flash Builder Debug Model Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.debug.ui (4.0.1.277662) "Adobe Flash Builder Debug UI" [Active]
com.adobe.flexbuilder.debug.ui.actions (4.0.1.277662) "Adobe Flash Builder Debug UI Actions Fragment" [Resolved]
com.adobe.flexbuilder.debug.ui.nl1 (4.0.1.277662) "Adobe Flash Builder Debug Model UI Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.designview (4.0.1.277662) "Adobe Flash Builder Designview" [Starting]
com.adobe.flexbuilder.designview.nl1 (4.0.1.277662) "Adobe Flash Builder Designview Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.editorcore (4.0.1.277662) "Adobe Flash Builder Editor Core" [Active]
com.adobe.flexbuilder.editorcore.nl1 (4.0.1.277662) "Adobe Flash Builder Editor Core Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.editors.derived (4.0.1.277662) "Adobe Flash Builder Editors Derived" [Active]
com.adobe.flexbuilder.editors.derived.nl1 (4.0.1.277662) "Adobe Flash Builder Editors Derived Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.exportimport (4.0.1.277662) "Adobe Flash Builder Exportimport" [Active]
com.adobe.flexbuilder.exportimport.nl1 (4.0.1.277662) "Adobe Flash Builder Exportimport Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.flashbridge (4.0.1.277662) "Flash IDE Plug-in" [Active]
com.adobe.flexbuilder.flashbridge.nl1 (4.0.1.277662) "Flash IDE Plug-in Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.flex (4.0.1.277662) "Adobe Flash Builder Flex SDKs" [Resolved]
com.adobe.flexbuilder.flexunit (4.0.1.277662) "Adobe Flash Builder FlexUnit UI" [Active]
com.adobe.flexbuilder.flexunit.derived (4.0.1.277662) "Adobe Flash Builder FlexUnit Derived" [Starting]
com.adobe.flexbuilder.flexunit.nl1 (4.0.1.277662) "Adobe Flash Builder FlexUnit Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.help (4.0.1.277662) "Adobe Flash Builder Help" [Starting]
com.adobe.flexbuilder.help.nl1 (4.0.1.277662) "Adobe Flash Builder Help - Localized" [Resolved]
com.adobe.flexbuilder.importartwork (4.0.1.277662) "Adobe Flash Builder Import Artwork" [Active]
com.adobe.flexbuilder.importartwork.nl1 (4.0.1.277662) "Adobe Flash Builder Import Artwork Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.json (4.0.1.277662) "Adobe Flash Builder JSON" [Starting]
com.adobe.flexbuilder.launching.ui (4.0.1.277662) "Adobe Flash Builder Launching UI" [Active]
com.adobe.flexbuilder.launching.ui.nl1 (4.0.1.277662) "Adobe Flash Builder Launching UI Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.monitors.network (4.0.1.277662) "Adobe Flash Builder Network Monitor" [Starting]
com.adobe.flexbuilder.monitors.network.nl1 (4.0.1.277662) "Adobe Flash Builder Network Monitor Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.multisdk (4.0.1.277662) "Adobe Flash Builder Multi-SDK" [Active]
com.adobe.flexbuilder.mxml.editor (4.0.1.277662) "Adobe Flash Builder MXML Editor" [Active]
com.adobe.flexbuilder.mxml.editor.nl1 (4.0.1.277662) "Adobe Flash Builder MXML Editor Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.mxmlmodel (4.0.1.277662) "Adobe Flash Builder MXML Model" [Active]
com.adobe.flexbuilder.project (4.0.1.277662) "Adobe Flash Builder Project" [Active]
com.adobe.flexbuilder.project.e35 (1.0.0.201001080934) "Adobe Flash Builder Project for Eclipse 3.5" [Resolved]
com.adobe.flexbuilder.project.nl1 (4.0.1.277662) "Adobe Flash Builder Project Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.project.ui (4.0.1.277662) "Adobe Flash Builder Project UI" [Active]
com.adobe.flexbuilder.project.ui.nl1 (4.0.1.277662) "Adobe Flash Builder Project UI Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.services.BlazeDSService (4.0.1.277662) "Adobe Flash Builder BlazeDSService" [Starting]
com.adobe.flexbuilder.services.CFService (4.0.1.277662) "Adobe Flash Builder CFService" [Starting]
com.adobe.flexbuilder.services.CFService.nl1 (4.0.1.277662) "Adobe Flash Builder CFService NL1 Fragment" [Resolved]
com.adobe.flexbuilder.services.HTTPService (4.0.1.277662) "Adobe Flash Builder HTTPService" [Starting]
com.adobe.flexbuilder.services.HTTPService.nl1 (4.0.1.277662) "Adobe Flash Builder HTTPService NL1 Fragment" [Resolved]
com.adobe.flexbuilder.services.J2EEService (4.0.1.277662) "Adobe Flash Builder J2EEService" [Starting]
com.adobe.flexbuilder.services.J2EEService.nl1 (4.0.1.277662) "Adobe Flash Builder J2EEService Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.services.LCDSService (4.0.1.277662) "Adobe Flash Builder LCDSService" [Starting]
com.adobe.flexbuilder.services.PHPService (4.0.1.277662) "Adobe Flash Builder PHPService" [Starting]
com.adobe.flexbuilder.services.PHPService.nl1 (4.0.1.277662) "Adobe Flash Builder PHPService NL1 Fragment" [Resolved]
com.adobe.flexbuilder.services.StaticContentService (4.0.1.277662) "Adobe Flash Builder StaticContentService" [Starting]
com.adobe.flexbuilder.services.StaticContentService.nl1 (4.0.1.277662) "Adobe Flash Builder StaticContentService Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.services.WEBService (4.0.1.277662) "Adobe Flash Builder WEBService" [Starting]
com.adobe.flexbuilder.services.WEBService.derived (4.0.1.277662) "Adobe Flash Builder WEBService Derived Sources" [Starting]
com.adobe.flexbuilder.services.WEBService.nl1 (4.0.1.277662) "Adobe Flash Builder WEBService NL1 Fragment" [Resolved]
com.adobe.flexbuilder.standalone (4.0.1.277662) "Adobe Flash Builder Standalone" [Active]
com.adobe.flexbuilder.standalone.nl1 (4.0.1.277662) "Adobe Flash Builder Standalone Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.tengine (4.0.1.277662) "Adobe Flash Builder Tengine" [Starting]
com.adobe.flexbuilder.tengine.nl1 (4.0.1.277662) "Adobe Flash Builder Tengine Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.ui (4.0.1.277662) "Adobe Flash Builder Global UI" [Active]
com.adobe.flexbuilder.ui.nl1 (4.0.1.277662) "Adobe Flash Builder Global UI Nl1 Fragment" [Resolved]
com.adobe.flexbuilder.utils.osnative (4.0.1.277662) "Adobe Flash Builder OS Native Utils" [Active]
com.adobe.flexbuilder.utils.osnative.win (4.0.1.277662) "Adobe Flash Builder OS Native Utils Windows Fragment" [Resolved]
com.adobe.flexide.amt (4.0.1.277662) "Adobe Flash Builder AMT" [Active]
com.adobe.flexide.as.core (4.0.1.277662) "Adobe Flash Builder ActionScript Core" [Active]
com.adobe.flexide.as.core.nl1 (4.0.1.277662) "Adobe Flash Builder ActionScript Core Nl1 Fragment" [Resolved]
com.adobe.flexide.communityhelp (4.0.1.277662) "CommunityHelp Plug-in" [Starting]
com.adobe.flexide.communityhelp.nl1 (4.0.1.277662) "Adobe Common CommunityHelp Nl1 Fragment" [Resolved]
com.adobe.flexide.css.core (4.0.1.277662) "Adobe Flash Builder CSS Editor Core" [Active]
com.adobe.flexide.css.core.nl1 (4.0.1.277662) "Adobe Flash Builder CSS Editor Core Nl1 Fragment" [Resolved]
com.adobe.flexide.designitems (4.0.1.277662) "Adobe Flash Builder DesignItems" [Starting]
com.adobe.flexide.editorcore (4.0.1.277662) "Adobe Flash Builder Editor Core" [Active]
com.adobe.flexide.editorcore.nl1 (4.0.1.277662) "Adobe Flash Builder Editor Core Nl1 Fragment" [Resolved]
com.adobe.flexide.embeddedplayer (4.0.1.277662) "Adobe Flash Builder Embedded Flash Player" [Starting]
com.adobe.flexide.exportimport (4.0.1.277662) "Exportimport" [Starting]
com.adobe.flexide.exportimport.nl1 (4.0.1.277662) "Export Import Nl1 Fragment" [Resolved]
com.adobe.flexide.externaleditors (4.0.1.277662) "Adobe Flash Builder External Editors" [Active]
com.adobe.flexide.externaleditors.nl1 (4.0.1.277662) "Adobe Flash Builder External Editors Nl1 Fragment" [Resolved]
com.adobe.flexide.fonts (4.0.1.277662) "Fonts" [Starting]
com.adobe.flexide.launching (4.0.1.277662) "Adobe Flash Builder Launching" [Active]
com.adobe.flexide.launching.nl1 (4.0.1.277662) "Adobe Flash Builder Launching Nl1 Fragment" [Resolved]
com.adobe.flexide.multisdk.nl1 (4.0.1.277662) "Adobe Flash Builder Multi-SDK Nl1 Fragment" [Resolved]
com.adobe.flexide.mxml.core (4.0.1.277662) "Adobe Flash Builder MXML Core" [Active]
com.adobe.flexide.mxml.core.nl1 (4.0.1.277662) "Adobe Flash Builder MXML Core Nl1 Fragment" [Resolved]
com.adobe.flexide.nativelibs (4.0.1.277662) "Adobe Flash Builder Native Libraries" [Active]
com.adobe.flexide.playerview (4.0.1.277662) "Adobe Flash Builder Playerview" [Starting]
com.adobe.flexide.refactoring.core (4.0.1.277662) "Adobe Flash Builder Refactoring Core" [Starting]
com.adobe.flexide.refactoring.core.nl1 (4.0.1.277662) "Adobe Flash Builder Refactoring Core Nl1 Fragment" [Resolved]
com.adobe.model.core (1.0.2.v20100315273147) "Adobe Data Model Core Wrapper" [Active]
com.collabnet.subversion.merge (2.1.0) "CollabNet Subversion Merge Client" [Starting]
com.crispico.flexbridge (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Flexbridge" [Resolved]
com.crispico.flower.mp (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Core" [Resolved]
com.crispico.flower.mp.dependencies.internal (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Internal Dependencies" [Active]
com.crispico.flower.mp.eclipse (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Eclipse" [Active]
com.crispico.flower.mp.eclipse.compare.base (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Compare Base" [Starting]
com.crispico.flower.mp.eclipse.compare.codesync (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Compare CodeSync" [Starting]
com.crispico.flower.mp.eclipse.uml4as (1.0.0.M0_2010-06-11) "Flower Modeling Platform - UML4AS" [Active]
com.crispico.flower.mp.metamodel.classmetamodel (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Class Metamodel" [Resolved]
com.crispico.flower.mp.metamodel.codesync (1.0.0.M0_2010-06-11) "Flower Modeling Platform - CodeSync Metamodel" [Active]
com.crispico.flower.mp.metamodel.codesyncas (1.0.0.M0_2010-06-11) "Flower Modeling Platform - CodeSync AS Metamodel" [Active]
com.crispico.flower.mp.metamodelset.uml4asfile (1.0.0.M0_2010-06-11) "Flower Modeling Platform - UML4AS File Metamodel Set" [Resolved]
com.crispico.flower.mp.propertieseditor (1.0.0.M0_2010-06-11) "Flower Modeling Platform - Properties Editor" [Starting]
com.ibm.icu (4.0.1.v20090822) "International Components for Unicode for Java (ICU4J)" [Active]
com.idefactory.enterprisehelp (1.0.8.beta) "Enterprise IDE Help" [Starting]
com.idefactory.fxsdk (1.0.1) "Enterprise IDE Fx Sdk" [Active]
com.idefactory.rhino (1.0.0) "Enterprise IDE Rhino" [Starting]
com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
com.sun.jna (3.2.3) "JNA Library Plug-in" [Starting]
FlexASDocGenCommand (0.7.4) "FlexASDocGenCommand Plug-in" [Starting]
FlexPrettyPrintCommand (0.7.4) "FlexPrettyPrintCommand Plug-in" [Active]
java_cup.runtime (0.10.0.v200803061811) "Java Cup" [Resolved]
javax.activation (1.1.0.v200906290531) "Apache Geronimo Activation Plug-in" [Resolved]
javax.mail (1.4.0.v200905040518) "Javax Mail Plug-in" [Resolved]
javax.servlet (2.5.0.v200806031605) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle" [Resolved]
javax.wsdl (1.5.1.v200806030408) "WSDL4J" [Resolved]
javax.xml (1.3.4.v200902170245) "JAXP XML" [Resolved]
javax.xml.rpc (1.1.0.v200905122109) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200905122109) "SAAJ" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge LPG" [Resolved]
org.apache.ant (1.7.1.v20090120-1145) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v200905122109) "Apache Web Services" [Resolved]
org.apache.bcel (5.2.0.v200803061811) "Apache BCEL" [Resolved]
org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.collections (3.2.0.v200803061811) "Apache Commons Collections" [Resolved]
org.apache.commons.discovery (0.2.0.v200905122109) "Jakarta-Commons Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons Httpclient" [Resolved]
org.apache.commons.jxpath (1.2.0.v20080604-1500) "Apache Commons JXPath" [Resolved]
org.apache.commons.lang (2.4.0.v20081016-1030) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.lang (2.1.0.v200803061811) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.logging (1.0.4.v200904062259) "Apache Commons Logging Plug-in" [Resolved]
org.apache.jasper (5.5.17.v200903231320) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.log4j (1.2.13.v200903072027) "Apache Jakarta log4j Plug-in" [Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis" [Resolved]
org.apache.oro (2.0.8.v200903061218) "Apache Jakarta ORO" [Resolved]
org.apache.velocity (1.5.0.v200905192330) "Apache Velocity Plug-in" [Resolved]
org.apache.wsil4j (1.0.0.v200901211807) "WSIL4J" [Resolved]
org.apache.xalan (2.7.1.v200905122109) "Xalan-Java" [Resolved]
org.apache.xerces (2.9.0.v200909240008) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v200902170519) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v200902170519) "Apache XML Commons Serializer" [Resolved]
org.eclipse.ant.core (3.2.100.v20090817_r351) "Ant Build Tool Core" [Starting]
org.eclipse.ant.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ant.ui (3.4.2.v20091204_r352) "Ant UI" [Starting]
org.eclipse.compare (3.5.0.I20090514-0808) "Compare Support" [Starting]
org.eclipse.compare.core (3.5.0.I20090430-0408) "Core Compare Support" [Starting]
org.eclipse.compare.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.compare.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.compare.win32 (1.0.0.I20090430-0408) "Compare Support for Word" [Starting]
org.eclipse.compare.win32.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.boot.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.commands (3.5.0.I20090525-2000) "Commands" [Resolved]
org.eclipse.core.commands.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.contenttype (3.4.1.R35x_v20090826-0451) "Eclipse Content Mechanism" [Active]
org.eclipse.core.contenttype.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.databinding (1.2.0.M20090819-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.0.I20090525-2000) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.beans.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.databinding.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.databinding.observable (1.2.0.M20090902-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.2.0.M20090819-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.100.v20090429-1800) "Expression Language" [Active]
org.eclipse.core.expressions.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.filebuffers (3.5.0.v20090526-2000) "File Buffers" [Active]
org.eclipse.core.filebuffers.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.filesystem (1.2.0.v20090507) "Core File Systems" [Active]
org.eclipse.core.filesystem.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20080604-1400) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.4.100.v20090429-1800) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.jobs.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.net (1.2.1.r35x_20090812-1200) "Internet Connection Management" [Active]
org.eclipse.core.net.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.net.win32.x86 (1.0.0.I20080909) "Proxy for Windows" [Resolved]
org.eclipse.core.resources (3.5.1.R35x_v20090826-0451) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.4.0.v20090505) "Core Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.resources.win32.x86 (3.5.0.v20081020) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.5.0.v20090525) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20090413) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20090413) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.auth.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.runtime.compatibility.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.runtime.compatibility.registry (3.2.200.v20090429-1800) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.runtime.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.core.variables (3.2.200.v20090521) "Core Variables" [Starting]
org.eclipse.core.variables.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.cvs (1.0.300.v200909170800) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.connectivity (1.1.3.v201001230803) "Data Tools Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.100.v200906020900) "Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition (1.0.2.v200906161815) "Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.1.v200906020900) "Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200906020553) "DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.1.v200908130547) "Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v200906020900) "Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (1.0.1.v200906161815) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda (3.2.2.v201001270833) "DTP Open Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.2.2.v201001261113) "DTP ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.2.2.v201001210350) "DTP ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.2.2.v201001210350) "DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.1.1.v201001131420) "Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.1.1.v201001131420) "Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.2.2.v201001210350) "DTP ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.2.0.v200906020553) "DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.1.1.v201001180200) "Eclipse Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.1.100.v200910270525) "Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.100.v200910270503) "Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.1.5.v201001190218) "Data Tools Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.3.v201001270323) "Eclipse Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.7.0.20090521092446) "Data Tool Platform User Documentation" [Starting]
org.eclipse.datatools.enablement.finfo (1.5.1.v200906161800) "Eclipse Data Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform HSQLDB Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.1.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinition (1.0.3.v200906161800) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.1.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.3.v200906161800) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.1.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.1.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinition (1.0.3.v200906161800) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.0.v200906020900) "Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.3.v200906161800) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.1.v200906020900) "Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres (1.0.0.v200906111150) "Ingres DTP Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.dbdefinition (1.0.0.v200906161800) "Ingres DTP Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.ui (1.0.0.v200906111150) "Ingres DTP UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v200909240342) "Data Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v201001180222) "Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200908130512) "Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.2.v201002041110) "Eclipse Data Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.4.v200906161800) "Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.2.2.v201001131420) "Eclipse Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.2.2.v201001260400) "Eclipse Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.2.1.v201001151620) "Eclipse Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.2.1.v201001191820) "Eclipse Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200908130544) "Eclipse Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.100.v200906161800) "Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.1.v200906020900) "Eclipse Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200906020900) "PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.1.v200906161800) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200906020900) "PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform MaxDB Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite (1.0.0.v201002041110) "Eclipse Data Tools Platform SQLite Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.dbdefinition (1.0.1.v201002041110) "Eclipse Data Tools Platform SQLite Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQLite UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200906020900) "High-level Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200906020900) "Sybase ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASA Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200906020900) "Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.schemaobjecteditor.examples (2.5.0.200810071) "Sybase ASA Schema Object Editor" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200906111150) "Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200906020900) "JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASE Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200906020900) "Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200906020900) "ASE Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200906020900) "Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200906090458) "Sybase UI Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.v200906020553) "Data Tools Platform Help Utilities" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.1.v200906022249) "Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby Model Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.3.v200912150851) "Eclipse Data Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.v200906022249) "Eclipse Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.2.v201002020730) "Eclipse Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200906022249) "SQL Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.v200906022249) "Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.1.v200907031118) "DTP ODA Context-sensitive Help" [Starting]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.1.0.v200910161545) "Data Core Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.1.2.v200912080845) "Data UI Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.derby.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.debugger.core.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Debugger UI Framework" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.editor.core.ui (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.1.v200906022302) "Eclipse Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200906030654) "Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.1.v200906022302) "Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Results View Plug-ins" [Starting]
org.eclipse.datatools.sqltools.result.ui (1.0.2.v201002011830) "Eclipse Data Tools Platform SQL Results View UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Tools Routine Editor UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor (1.1.0.v200906022302) "Schema Object Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui (1.1.0.200810071) "Schema Object Editor Framework" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages (1.1.0.200810071) "Schema Object Editor Pages Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.0.v201001200600) "SQL Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.1.v200912241345) "Eclipse Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.v200906022302) "Eclipse Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.v200906022302) "Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.debug.core (3.5.0.v20090526-1600) "Debug Core" [Active]
org.eclipse.debug.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.debug.ui (3.5.1.v20090811_r351) "Debug UI" [Active]
org.eclipse.debug.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.draw2d (3.5.2.v20091126-1908) "Graphical Editing Framework Draw2d" [Starting]
org.eclipse.ecf (3.0.0.v20090831-1906) "Eclipse Communication Framework (ECF)" [Active]
org.eclipse.ecf.filetransfer (3.0.0.v20090831-1906) "ECF Filetransfer API" [Active]
org.eclipse.ecf.identity (3.0.0.v20090831-1906) "ECF Identity API" [Active]
org.eclipse.ecf.provider.filetransfer (3.0.1.v20090831-1906) "ECF Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient (3.0.1.v20090831-1906) "ECF HttpClient Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient.ssl (1.0.0.v20090831-1906) "ECF HttpClient Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20090831-1906) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.0.v20090831-1906) "Eclipse Communication Framework (ECF)" [Resolved]
org.eclipse.emf (2.5.0.v200906151043) "EMF - Eclipse Modeling Framework Runtime and Tools" [Starting]
org.eclipse.emf.ant (2.4.0.v200906151043) "EMF Ant Tasks" [Starting]
org.eclipse.emf.codegen (2.5.0.v200906151043) "EMF Code Generation" [Starting]
org.eclipse.emf.codegen.ecore (2.5.0.v200906151043) "EMF Ecore Code Generator" [Starting]
org.eclipse.emf.codegen.ecore.ui (2.5.0.v200906151043) "EMF Ecore Code Generator UI" [Starting]
org.eclipse.emf.codegen.ui (2.5.0.v200906151043) "EMF Code Generation UI" [Starting]
org.eclipse.emf.common (2.5.0.v200906151043) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.5.0.v200906151043) "EMF Common UI" [Starting]
org.eclipse.emf.converter (2.5.0.v200906151043) "EMF Model Converter" [Starting]
org.eclipse.emf.databinding (1.1.0.v200906151043) "EMF Data Binding" [Starting]
org.eclipse.emf.databinding.edit (1.1.0.v200906151043) "EMF Edit Data Binding" [Starting]
org.eclipse.emf.ecore (2.5.0.v200906151043) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.5.0.v200906151043) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.change.edit (2.5.0.v200906151043) "EMF Change Edit" [Starting]
org.eclipse.emf.ecore.edit (2.5.0.v200906151043) "EMF Ecore Edit" [Starting]
org.eclipse.emf.ecore.editor (2.5.0.v200906151043) "EMF Sample Ecore Editor" [Starting]
org.eclipse.emf.ecore.xmi (2.5.0.v200906151043) "EMF XML/XMI Persistence" [Starting]
org.eclipse.emf.edit (2.5.0.v200906151043) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.5.0.v200906151043) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.5.0.v200906151043) "EMF Model Exporter" [Starting]
org.eclipse.emf.importer (2.5.0.v200906151043) "EMF Model Importer" [Starting]
org.eclipse.emf.importer.ecore (2.4.0.v200906151043) "EMF Ecore Importer" [Starting]
org.eclipse.emf.importer.java (2.5.0.v200906151043) "EMF Annotated Java Importer" [Starting]
org.eclipse.emf.importer.rose (2.5.0.v200906151043) "EMF Rose Importer" [Starting]
org.eclipse.emf.mapping (2.5.0.v200906151043) "EMF Mapping" [Starting]
org.eclipse.emf.mapping.ecore (2.5.0.v200906151043) "EMF Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore.editor (2.5.0.v200906151043) "EMF Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.5.0.v200906151043) "EMF Ecore to Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v200906151043) "EMF Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.5.0.v200906151043) "EMF Ecore to XML Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.5.0.v200906151043) "EMF Ecore to XML Mapping Editor" [Starting]
org.eclipse.emf.mapping.ui (2.5.0.v200906151043) "EMF Mapping UI" [Starting]
org.eclipse.equinox.app (1.2.0.v20090520-1800) "Equinox Application Container" [Active]
org.eclipse.equinox.common (3.5.1.R35x_v20090807-1100) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.common.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.concurrent (1.0.1.R35x_v20100209) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.ds (1.1.1.R35x_v20090806) "Declarative Services" [Active]
org.eclipse.equinox.ds.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.frameworkadmin (1.0.100.v20090520-1905) "Equinox Framework Admin" [Active]
org.eclipse.equinox.frameworkadmin.equinox (1.0.100.v20090520-1905) "Equinox Framework Admin for Equinox" [Active]
org.eclipse.equinox.http.jetty (2.0.0.v20090520-1800) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.0.200.v20090520-1800) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.registry.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.http.servlet (1.0.200.v20090520-1800) "Http Services Servlet" [Starting]
org.eclipse.equinox.http.servlet.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.jsp.jasper (1.0.200.v20090520-1800) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.100.v20090520-1800) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.201.R35x_v20090715) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.200.v20090519) "Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.0.101.R35x_v20090721) "Equinox Provisioning Artifact Repository Support" [Active]
org.eclipse.equinox.p2.artifact.repository.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.console (1.0.100.v20090520-1905) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.console.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.core (1.0.101.R35x_v20090819) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.director (1.0.100.v20090520-1905) "Equinox Provisioning Director" [Active]
org.eclipse.equinox.p2.director.app (1.0.100.v20090521-1912) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.director.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.directorywatcher (1.0.100.v20090525) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.engine (1.0.101.R35x_v20090825) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.engine.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.exemplarysetup (1.0.100.v20090520-1905) "Equinox Provisioning Exemplary Setup" [Active]
org.eclipse.equinox.p2.exemplarysetup.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.extensionlocation (1.0.100.v20090520-1905) "Extension Location Repository Support" [Active]
org.eclipse.equinox.p2.extensionlocation.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.garbagecollector (1.0.100.v20090520-1905) "Provisioning Garbage Collector" [Active]
org.eclipse.equinox.p2.garbagecollector.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.jarprocessor (1.0.100.v20090520-1905) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.jarprocessor.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.metadata (1.0.100.v20090525) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.generator (1.0.100.v20090520-1905) "Equinox Provisioning Metadata Generator" [Starting]
org.eclipse.equinox.p2.metadata.generator.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.metadata.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.metadata.repository (1.0.101.R35x_v20090812) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.metadata.repository.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.publisher (1.0.0.v20090527-1812) "Equinox Provisioning Publisher" [Active]
org.eclipse.equinox.p2.publisher.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.reconciler.dropins (1.0.100.v20090520-1905) "Dropin Reconciler Plug-in" [Active]
org.eclipse.equinox.p2.reconciler.dropins.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.repository (1.0.1.v20090901-1041) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.repository.tools (1.0.1.R35x_v20090806) "Equinox p2 repository tools." [Starting]
org.eclipse.equinox.p2.repository.tools.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.touchpoint.eclipse (1.0.101.R35x_20090820-1821) "Equinox Provisioning Eclipse Touchpoint" [Active]
org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.touchpoint.natives (1.0.101.R35x_v20090806) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.ui (1.0.101.R35x_v20090819) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.ui.sdk (1.0.100.v20090520-1905) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.0.0.v20090520-1905) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.updatechecker (1.1.0.v20090520-1905) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatechecker.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.p2.updatesite (1.0.100.v20090525) "Update site repository adapter bundle (Incubation)" [Active]
org.eclipse.equinox.p2.updatesite.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.preferences (3.2.300.v20090520-1800) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.preferences.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.registry (3.4.100.v20090520-1800) "Extension Registry Support" [Active]
org.eclipse.equinox.registry.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.security (1.0.100.v20090520-1800) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.security.ui (1.0.100.v20090520-1800) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.security.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.equinox.security.win32.x86 (1.0.100.v20090520-1800) "Windows Data Protection services integration" [Resolved]
org.eclipse.equinox.simpleconfigurator (1.0.101.R35x_v20090807-1100) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (1.0.100.v20090520-1905) "Simple Configurator Manipulator" [Active]
org.eclipse.equinox.util (1.0.100.v20090520-1800) "Equinox Util Bundle" [Active]
org.eclipse.gef (3.5.1.v20090910-2020) "Graphical Editing Framework GEF" [Starting]
org.eclipse.help (3.4.1.v20090805_35x) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.400.v20090429_1800) "Help Application Server" [Starting]
org.eclipse.help.appserver.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.help.base (3.4.0.v200909170800) "Help System Base" [Starting]
org.eclipse.help.base.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.help.ui (3.4.1.v20090819_35x) "Help System UI" [Starting]
org.eclipse.help.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.help.webapp (3.4.1.v20090819_35x) "Help System Webapp" [Starting]
org.eclipse.help.webapp.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.jdt (3.5.2.v201002111343) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.apt.core (3.3.202.R35x_v20091130-2300) "Java Annotation Processing Core" [Starting]
org.eclipse.jdt.apt.pluggable.core (1.0.201.R35x_v20090925-1100) "Java Compiler Apt IDE" [Starting]
org.eclipse.jdt.apt.ui (3.3.200.v20090930-2100_R35x) "Java Annotation Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.201.R35x_v20090925-1100) "Java Compiler Apt" [Resolved]
org.eclipse.jdt.compiler.tool (1.0.100.v_981_R35x) "Java Compiler Tool Support" [Resolved]
org.eclipse.jdt.core (3.5.2.v_981_R35x) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.3.0.v20090603) "Java Code Manipulation Functionality" [Starting]
org.eclipse.jdt.debug (3.5.0.v20090526) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.4.1.v20090811_r351) "JDI Debug UI" [Starting]
org.eclipse.jdt.doc.user (3.5.2.r352_v20091015) "Eclipse Java development user guide" [Resolved]
org.eclipse.jdt.junit (3.5.2.r352_v20100113-0800) "Java Development Tools JUnit support" [Starting]
org.eclipse.jdt.junit.runtime (3.4.100.v20090513-2000) "Java Development Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.1.0.v20090513-2000) "Java Development Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.5.1.v20100108_r352) "Java Development Tools Launching Support" [Active]
org.eclipse.jdt.ui (3.5.2.r352_v20100106-0800) "Java Development Tools UI" [Starting]
org.eclipse.jem (2.0.301.v201001252130) "Java EMF Model" [Starting]
org.eclipse.jem.proxy (2.0.201.v200908101600) "Java EMF Model Proxy Support" [Starting]
org.eclipse.jem.util (2.0.201.v201001252130) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (2.0.201.v200911302230) "Java EMF Model Workbench Support" [Starting]
org.eclipse.jface (3.5.1.M20090826-0800) "JFace" [Active]
org.eclipse.jface.databinding (1.3.1.M20090826-0800) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.databinding.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.jface.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.jface.text (3.5.1.r351_v20090708-0800) "JFace Text" [Resolved]
org.eclipse.jface.text.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.jpt.branding (2.2.2.v200911250220) "Dali Java Persistence Tools" [Resolved]
org.eclipse.jpt.core (2.2.1.v200908270220) "Dali Java Persistence Tools - Core" [Starting]
org.eclipse.jpt.db (1.2.102.v200911250220) "Dali Java Persistence Tools - DB" [Starting]
org.eclipse.jpt.db.ui (1.1.100.v200906070220) "Dali Java Persistence Tools - DB UI" [Resolved]
org.eclipse.jpt.doc.isv (1.2.0.v200906050220) "Dali Java Persistence Tools Doc - ISV" [Starting]
org.eclipse.jpt.doc.user (1.1.1.v200908270220) "Java Persistence Documentation - Doc" [Resolved]
org.eclipse.jpt.eclipselink.branding (2.2.2.v200911250220) "Dali Java Persistence Tools - EclipseLink Support" [Resolved]
org.eclipse.jpt.eclipselink.core (1.2.0.v200905310000) "Dali Java Persistence Tools - EclipseLink Support - Core" [Starting]
org.eclipse.jpt.eclipselink.core.ddlgen (1.0.200.v200906070220) "Dali Java Persistence Tools - EclipseLink Support - DDL Generation" [Resolved]
org.eclipse.jpt.eclipselink.ui (1.2.0.v200905310000) "Dali Java Persistence Tools - EclipseLink Support - UI" [Starting]
org.eclipse.jpt.gen (1.3.2.v201001290220) "Dali Java Persistence Tools - Entity Gen" [Resolved]
org.eclipse.jpt.ui (2.2.2.v200911250220) "Dali Java Persistence Tools - UI" [Starting]
org.eclipse.jpt.utility (1.4.0.v200905310000) "Dali Java Persistence Tools - Utility" [Resolved]
org.eclipse.jsch.core (1.1.100.I20090430-0408) "JSch Core" [Starting]
org.eclipse.jsch.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.jsch.ui (1.1.200.I20090430-0408) "JSch UI" [Starting]
org.eclipse.jsch.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.jst.common.annotations.controller (1.1.100.v200805140020) "Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.200.v201001272230) "Annotation Core Plug-in" [Resolved]
org.eclipse.jst.common.frameworks (1.1.301.v201001252130) "Integration Plug-in" [Starting]
org.eclipse.jst.common.project.facet.core (1.4.1.v200911141836) "Eclipse Faceted Project Framework JDT Enablement" [Starting]
org.eclipse.jst.common.project.facet.ui (1.4.1.v200912011928) "Eclipse Faceted Project Framework JDT Enablement UI" [Starting]
org.eclipse.jst.ejb.doc.user (1.1.100.v200810092245) "EJB docs" [Starting]
org.eclipse.jst.ejb.ui (1.1.301.v200908131325) "WTP EJB UI Plug-in" [Starting]
org.eclipse.jst.ejb.ui.infopop (1.0.200.v200905141725) "EJB infopop" [Starting]
org.eclipse.jst.j2ee (1.1.302.v201004131604) "Java EE Component" [Starting]
org.eclipse.jst.j2ee.core (1.1.301.v200911302230) "J2EE Core Component" [Starting]
org.eclipse.jst.j2ee.doc.user (1.1.100.v200810071436) "J2EE tools documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.301.v201001252130) "EJB component Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.102.v200805140020) "EJB Annotation Model Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.102.v200805140135) "EJB Emitter Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.102.v200805140020) "EJB Annotations Ui Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.2.0.v200805140020) "Xdoclet Annotations Plug-in" [Starting]
org.eclipse.jst.j2ee.infopop (1.0.300.v200805140415) "J2EE tools infopops" [Resolved]
org.eclipse.jst.j2ee.jca (1.1.301.v201001252130) "JCA Plug-in" [Starting]
org.eclipse.jst.j2ee.jca.ui (1.1.300.v200809052300) "WTP JCA UI Plug-in" [Starting]
org.eclipse.jst.j2ee.navigator.ui (1.1.301.v201001252130) "J2EE Extensions to Common Navigator" [Starting]
org.eclipse.jst.j2ee.ui (1.1.301.v201001252130) "WTP J2EE UI Plug-in" [Starting]
org.eclipse.jst.j2ee.web (1.1.301.v200911302230) "Web Plug-in" [Starting]
org.eclipse.jst.j2ee.webservice (1.1.300.v200901220600) "Web Service Plug-in" [Starting]
org.eclipse.jst.j2ee.webservice.ui (1.1.300.v200902052230) "WTP Webservice UI Plug-in" [Starting]
org.eclipse.jst.j2ee.xdoclet.runtime (1.1.102.v200805140135) "XDocletRuntime Plug-in" [Starting]
org.eclipse.jst.jee (1.0.201.v201002021055) "JEE common Plug-in" [Starting]
org.eclipse.jst.jee.ejb (1.0.201.v201002021057) "JEE Ejb Plug-in" [Starting]
org.eclipse.jst.jee.ui (1.0.201.v201002021208) "Eclipse Java EE Developer Tools" [Starting]
org.eclipse.jst.jsf.apache.trinidad.tagsupport (1.1.0.v20090525) "JavaServer Faces Tools - Taglibrary Metadata (Apache Trinidad)" [Starting]
org.eclipse.jst.jsf.common (1.1.9.v201001271707) "JavaServer Faces Tools - Common" [Active]
org.eclipse.jst.jsf.common.runtime (1.0.201.v20090205) "JavaServer Faces Tools - Common Runtime" [Starting]
org.eclipse.jst.jsf.common.ui (1.1.1.v20081209) "JavaServer Faces Tools - Common UI" [Starting]
org.eclipse.jst.jsf.core (1.2.5.v201001271707) "JavaServer Faces Tools - Core" [Active]
org.eclipse.jst.jsf.facesconfig (1.1.3.v20090902) "JavaServer Faces Tools - FacesConfig Model" [Starting]
org.eclipse.jst.jsp.core (1.2.204.v201001270045) "Structured Source JSP Model" [Starting]
org.eclipse.jst.jsp.ui (1.1.401.v200908111935) "SSE JSP Source Editor" [Starting]
org.eclipse.jst.jsp.ui.infopop (1.0.100.v200805301545) "JSP tools infopops" [Resolved]
org.eclipse.jst.pagedesigner (1.2.3.v20100211) "JavaServer Faces Tools - Web Page Editor" [Starting]
org.eclipse.jst.pagedesigner.jsf.ui (1.1.4.v20100203) "JavaServer Faces Tools - Pagedesigner UI" [Starting]
org.eclipse.jst.pagedesigner.jsp.core (1.1.3.v201002111131) "JavaServer Faces Tools - JSP Core Pagedesigner" [Starting]
org.eclipse.jst.server.core (1.2.1.v20100127) "Java Server Support" [Starting]
org.eclipse.jst.servlet.ui (1.1.301.v200908101600) "WTP Servlet UI Plug-in" [Starting]
org.eclipse.jst.servlet.ui.infopop (1.0.300.v200805140415) "Servlet infopop" [Starting]
org.eclipse.jst.ws (1.0.407.v200905191120) "Web Services" [Starting]
org.eclipse.jst.ws.axis.consumption.core (1.0.306.v200810082309) "Web service Axis Consumption Core" [Starting]
org.eclipse.jst.ws.axis.consumption.ui (1.0.405.v200901261650) "Webservice Axis Consumption UI" [Starting]
org.eclipse.jst.ws.axis.creation.ui (1.0.406.v200903031852) "Webservice Axis Creation UI" [Starting]
org.eclipse.jst.ws.axis.infopop (1.0.300.v200805140230) "Web services Axis context sensitive help" [Starting]
org.eclipse.jst.ws.axis.ui.doc.user (1.1.0.v200806092139) "Axis Web services documentation" [Resolved]
org.eclipse.jst.ws.axis2.consumption.core (1.0.104.v200810151442) "Webservice Axis2 Consumption Core Plug-in" [Starting]
org.eclipse.jst.ws.axis2.consumption.ui (1.0.102.v200807232000) "Webservice Axis2 Consumption UI Plug-in" [Starting]
org.eclipse.jst.ws.axis2.core (1.0.104.v200810151442) "Webservice Axis2 Core Plug-in" [Starting]
org.eclipse.jst.ws.axis2.creation.core (1.0.105.v200901220134) "Webservice Axis2 Creation Core Plug-in" [Starting]
org.eclipse.jst.ws.axis2.creation.ui (1.0.103.v200807162242) "Webservice Axis2 Creation UI Plug-in" [Starting]
org.eclipse.jst.ws.axis2.ui (1.0.302.v200905260749) "Axis2 Tools" [Starting]
org.eclipse.jst.ws.axis2.ui.doc.user (1.0.1.v200807302329) "Axis2 Web services documentation" [Resolved]
org.eclipse.jst.ws.consumption (1.0.408.v200911241817) "Web Services Consumption" [Starting]
org.eclipse.jst.ws.consumption.infopop (1.0.300.v200805140230) "Web services UI" [Resolved]
org.eclipse.jst.ws.consumption.ui (1.1.106.v200911241851) "Web Services Consumption Graphical User Interface" [Starting]
org.eclipse.jst.ws.consumption.ui.doc.user (1.0.550.v200901232040) "Web service consumption documentation" [Starting]
org.eclipse.jst.ws.creation.ejb.ui (1.0.200.v200805140230) "Web Services Creation EJB Graphical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ui (1.0.409.v200911241856) "Web Services Creation Graphical User Interface" [Starting]
org.eclipse.jst.ws.doc.user (1.0.500.v200809092107) "Web Services UI" [Resolved]
org.eclipse.jst.ws.infopop (1.0.300.v200805140230) "Web services UI" [Resolved]
org.eclipse.jst.ws.uddiregistry (1.0.400.v200901261650) "Web Services Universal Description Discovery and Integration Registry" [Starting]
org.eclipse.jst.ws.ui (1.0.402.v200903111822) "Web Services Graphical User Interface" [Starting]
org.eclipse.ltk.core.refactoring (3.5.0.v20090513-2000) "Refactoring Core" [Starting]
org.eclipse.ltk.core.refactoring.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ltk.ui.refactoring (3.4.100.v20090604) "Refactoring UI" [Starting]
org.eclipse.ltk.ui.refactoring.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.osgi (3.5.1.R35x_v20090827) "OSGi System Bundle" [Active]
org.eclipse.osgi.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.osgi.services (3.2.0.v20090520-1800) "OSGi Release 4.2.0 Services" [Resolved]
org.eclipse.osgi.services.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.osgi.util (3.2.0.v20090520-1800) "OSGi Release 4.2.0 Utility Classes" [Resolved]
org.eclipse.osgi.util.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.pde (3.4.100.v201002111343) "PDE" [Resolved]
org.eclipse.pde.api.tools (1.0.101.v20090714) "API Tools" [Starting]
org.eclipse.pde.api.tools.ee.javase16 (1.0.0.v20090407-1030) "Environment Description for JavaSE-1.6" [Resolved]
org.eclipse.pde.api.tools.ui (1.0.101.v20090820) "API Tools UI" [Starting]
org.eclipse.pde.build (3.5.2.R35x_20100114) "Plug-in Development Environment Build Support" [Starting]
org.eclipse.pde.core (3.5.101.v20100104) "PDE Core" [Starting]
org.eclipse.pde.doc.user (3.5.0.v20090818) "PDE User Guide" [Resolved]
org.eclipse.pde.ds.core (1.0.1.v20100118) "PDE DS Core" [Starting]
org.eclipse.pde.ds.ui (1.0.0.v20100209-maintenance) "PDE DS UI" [Starting]
org.eclipse.pde.junit.runtime (3.4.0.v20090527) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.4.100.v20090731) "PDE Runtime" [Starting]
org.eclipse.pde.ua.core (1.0.0.v20090429-1800) "PDE UA Core" [Starting]
org.eclipse.pde.ua.ui (1.0.0.v20090511) "PDE UA UI" [Starting]
org.eclipse.pde.ui (3.5.1.v201001121200) "PDE UI" [Starting]
org.eclipse.pde.ui.templates (3.4.100.v20090527) "PDE Templates" [Starting]
org.eclipse.platform (3.3.201.v200909170800) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.user (3.5.1.r351_v20090821-0800) "Eclipse Workbench User Guide" [Resolved]
org.eclipse.platform.doc.user.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.platform.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.rcp (3.5.0.v200909170800) "Eclipse RCP" [Starting]
org.eclipse.search (3.5.1.r351_v20090708-0800) "Search Support" [Active]
org.eclipse.search.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.servertools.doc.isv (1.0.100.v20090414) "Server Tools - Developer Guide" [Starting]
org.eclipse.swt (3.5.1.v3555a) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.5.1.v3555a) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.team.core (3.5.0.I20090527-0620) "Team Support Core" [Active]
org.eclipse.team.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.team.cvs.core (3.3.200.I20090430-0408) "CVS Team Provider Core" [Starting]
org.eclipse.team.cvs.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.team.cvs.ssh (3.2.100.I20090508-2000) "CVS SSH Core" [Starting]
org.eclipse.team.cvs.ssh.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.200.I20090508-2000) "CVS SSH2" [Starting]
org.eclipse.team.cvs.ssh2.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.team.cvs.ui (3.3.201.R35x_v20090826-0905) "CVS Team Provider UI" [Starting]
org.eclipse.team.cvs.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.team.ui (3.5.0.I20090430-0408) "Team Support UI" [Starting]
org.eclipse.team.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.text (3.5.0.v20090513-2000) "Text" [Resolved]
org.eclipse.text.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui (3.5.1.M20090902-1000) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.300.v20090526) "Browser Support" [Starting]
org.eclipse.ui.browser.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.cheatsheets (3.3.200.v20090526) "Cheat Sheets" [Starting]
org.eclipse.ui.cheatsheets.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.console (3.4.0.v20090513) "Console" [Starting]
org.eclipse.ui.console.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.editors (3.5.0.v20090527-2000) "Default Text Editor" [Active]
org.eclipse.ui.editors.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.externaltools (3.2.0.v20090504) "External Tools" [Starting]
org.eclipse.ui.externaltools.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.forms (3.4.1.v20090714_35x) "Eclipse Forms" [Starting]
org.eclipse.ui.forms.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.ide (3.5.1.M20090826-0800) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.101.M20090826-0800) "Eclipse IDE UI Application" [Resolved]
org.eclipse.ui.ide.application.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.ide.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.intro (3.3.1.v20090805_35x) "Welcome Framework" [Starting]
org.eclipse.ui.intro.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.intro.universal (3.2.300.v20090526) "Universal Welcome" [Starting]
org.eclipse.ui.intro.universal.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.navigator (3.4.1.M20090911-1550) "Common Navigator View" [Active]
org.eclipse.ui.navigator.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.navigator.resources (3.4.1.M20090826-0800) "Navigator Workbench Components" [Starting]
org.eclipse.ui.navigator.resources.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.net (1.2.1.r35x_20090812-1200) "Internet Connection Management UI" [Active]
org.eclipse.ui.net.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.100.I20081007-0800) "R21 Presentation Plug-in" [Starting]
org.eclipse.ui.presentations.r21.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.views (3.4.1.M20090826-0800) "Views" [Active]
org.eclipse.ui.views.log (1.0.100.v20090731) "Log View" [Active]
org.eclipse.ui.views.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.views.properties.tabbed (3.5.0.I20090429-1800) "Tabbed Properties View" [Active]
org.eclipse.ui.views.properties.tabbed.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.win32 (3.2.100.v20090429-1800) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.5.1.M20090826-0800a) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20090429-1800) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.ui.workbench.texteditor (3.5.0.v20090603) "Text Editor Framework" [Active]
org.eclipse.ui.workbench.texteditor.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.update.configurator (3.3.0.v20090312) "Install/Update Configurator" [Active]
org.eclipse.update.configurator.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.update.core (3.2.300.v20090525) "Install/Update Core" [Active]
org.eclipse.update.core.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.update.core.win32 (3.2.100.v20080107) "Install/Update Core for Windows" [Resolved]
org.eclipse.update.scheduler (3.2.200.v20081127) "Automatic Updates Scheduler" [Active]
org.eclipse.update.scheduler.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.update.ui (3.2.201.R35x_v20090813) "Install/Update UI" [Starting]
org.eclipse.update.ui.nl1_3.5.0.v20091121043401 (3.5.0.v20091121043401) "nlFragmentName" [Resolved]
org.eclipse.wst.command.env (1.0.408.v200903110045) "Environment Command Framework (headless)" [Starting]
org.eclipse.wst.command.env.core (1.0.204.v200805140020) "Environment Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.doc.user (1.5.200.v200806092138) "Web services Axis Ant task documentation" [Starting]
org.eclipse.wst.command.env.infopop (1.0.100.v200805301544) "Web services UI" [Starting]
org.eclipse.wst.command.env.ui (1.1.2.v200811200248) "Environment Command Framework (GUI)" [Starting]
org.eclipse.wst.common.api.doc (1.0.1.v200807181737) "Environment API Documentation" [Starting]
org.eclipse.wst.common.core (1.1.201.v200806010600) "WST Common Core Plug-in" [Starting]
org.eclipse.wst.common.emf (1.1.301.v200908181930) "EMF Utilities" [Starting]
org.eclipse.wst.common.emfworkbench.integration (1.1.301.v200908101600) "EMF Workbench Edit Plug-in" [Starting]
org.eclipse.wst.common.environment (1.0.301.v200908101600) "Enviornment Plug-in" [Starting]
org.eclipse.wst.common.frameworks (1.1.300.v200904160730) "Common Frameworks" [Active]
org.eclipse.wst.common.frameworks.ui (1.1.301.v200908101600) "WTP UI Plug-in" [Starting]
org.eclipse.wst.common.infopop (1.0.100.v200805301550) "Common WST infopops" [Starting]
org.eclipse.wst.common.modulecore (1.1.301.v201001252130) "Modulecore Plug-in" [Starting]
org.eclipse.wst.common.project.facet.core (1.4.1.v200911141735) "Eclipse Faceted Project Framework" [Active]
org.eclipse.wst.common.project.facet.ui (1.4.1.v200908111817) "Eclipse Faceted Project Framework UI" [Starting]
org.eclipse.wst.common.snippets (1.1.301.v201001280015) "Snippets View" [Starting]
org.eclipse.wst.common.ui (1.1.402.v200901262305) "Eclipse Base UI extensions" [Starting]
org.eclipse.wst.common.uriresolver (1.1.301.v200805140415) "Common URI Resolver Framework" [Starting]
org.eclipse.wst.css.core (1.1.301.v200910161432) "Structured Source CSS Model" [Starting]
org.eclipse.wst.css.ui (1.0.401.v200907171457) "SSE CSS Source Editor" [Starting]
org.eclipse.wst.doc.user (1.2.0.v200806052254) "Master User Doc TOC" [Starting]
org.eclipse.wst.dtd.core (1.1.300.v200904181727) "Structured Source DTD Core" [Starting]
org.eclipse.wst.dtd.ui (1.0.400.v200904300717) "SSE DTD Source Editor" [Starting]
org.eclipse.wst.dtd.ui.infopop (1.0.300.v200805140200) "DTD Editor infopops" [Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.500.v200904292308) "DTD Editor documentation" [Resolved]
org.eclipse.wst.html.core (1.1.300.v200903120608) "Structured Source HTML Model" [Starting]
org.eclipse.wst.html.ui (1.0.401.v200908111935) "HTML UI Source Editor" [Starting]
org.eclipse.wst.html.ui.infopop (1.0.100.v200805301545) "HTML editor infopops" [Resolved]
org.eclipse.wst.internet.cache (1.0.301.v200805140020) "Cache URI Resolver Plug-in" [Starting]
org.eclipse.wst.internet.monitor.core (1.0.404.v20090609) "Monitor" [Starting]
org.eclipse.wst.internet.monitor.ui (1.0.305.v20100123) "TCP/IP Monitor" [Starting]
org.eclipse.wst.jsdt.core (1.0.201.v2010012803) "JavaScript Development Tools Core" [Starting]
org.eclipse.wst.jsdt.doc (1.0.200.v200903120608) "JSDT Doc Plugin" [Resolved]
org.eclipse.wst.jsdt.manipulation (1.0.100.v200809240707) "JavaScript Code Manipulation Functionality" [Starting]
org.eclipse.wst.jsdt.support.firefox (1.0.200.v200904290357) "FireFox Support for JSDT Plugin" [Starting]
org.eclipse.wst.jsdt.support.ie (1.0.200.v200904290539) "JSDT Support for Internet Explorer" [Resolved]
org.eclipse.wst.jsdt.ui (1.0.201.v2010012803) "JavaScript Developer Tools" [Starting]
org.eclipse.wst.jsdt.web.core (1.0.201.v201001221931) "JSDT Web Support Core" [Starting]
org.eclipse.wst.jsdt.web.ui (1.0.201.v2010012803) "JSDT Web Support UI" [Starting]
org.eclipse.wst.server.core (1.1.102.v20100123) "Server Core" [Starting]
org.eclipse.wst.server.discovery (1.0.1.v20100210) "Plug-in Discovery Plug-in" [Starting]
org.eclipse.wst.server.ui (1.1.103.v20100123) "Server UI" [Starting]
org.eclipse.wst.server.ui.doc.user (1.1.150.v200901232034) "Server Tools documentation for Web Standard Tools" [Starting]
org.eclipse.wst.server.ui.infopop (1.1.0.v200805140145) "Server Tools infopops for Web Standard Tools" [Resolved]
org.eclipse.wst.sse.core (1.1.402.v201001251516) "Structured Text Model" [Starting]
org.eclipse.wst.sse.doc.user (1.1.0.v200805211530) "Structured text editor and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.1.102.v200910200227) "Structured Source Editor" [Starting]
org.eclipse.wst.sse.ui.infopop (1.0.200.v200805301545) "SSE infopops" [Resolved]
org.eclipse.wst.standard.schemas (1.0.200.v200902270215) "Standard Schemas and DTDs" [Resolved]
org.eclipse.wst.validation (1.2.104.v200911120201) "Validation Framework" [Starting]
org.eclipse.wst.validation.doc.isv (1.2.101.v200906031420) "Validation Framework - Developer Guide" [Resolved]
org.eclipse.wst.validation.infopop (1.0.300.v200806041506) "WST validation infopop plug-in" [Resolved]
org.eclipse.wst.validation.ui (1.2.104.v200904232035) "Validation Framework UI" [Starting]
org.eclipse.wst.web (1.1.301.v200911302230) "Simple Web Plug-in" [Active]
org.eclipse.wst.web.ui (1.1.301.v201001252130) "Eclipse Web Developer Tools" [Starting]
org.eclipse.wst.web.ui.infopop (1.0.300.v200805140415) "Static Web infopop" [Starting]
org.eclipse.wst.webtools.doc.user (1.0.400.v200805150134) "Web tools documentation" [Starting]
org.eclipse.wst.ws (1.1.103.v200903111822) "Web Services" [Starting]
org.eclipse.wst.ws.api.doc (1.0.1.v200807181721) "Web Services API Documentation" [Starting]
org.eclipse.wst.ws.explorer (1.0.408.v200911241806) "Web Services Explorer" [Starting]
org.eclipse.wst.ws.infopop (1.0.300.v200805140230) "Web Services UI" [Starting]
org.eclipse.wst.ws.parser (1.0.402.v200901220107) "Web Services Description Parser" [Starting]
org.eclipse.wst.ws.service.policy (1.0.103.v200905151848) "Service policy" [Starting]
org.eclipse.wst.ws.service.policy.ui (1.0.102.v200903070248) "Service policy" [Active]
org.eclipse.wst.ws.ui (1.1.100.v200903112221) "Web Services UI" [Starting]
org.eclipse.wst.wsdl (1.2.2.v200911111930) "WSDL Model" [Starting]
org.eclipse.wst.wsdl.doc.isv (1.0.100.v200811240723) "WSDL EMF Model Javadoc Documentation" [Starting]
org.eclipse.wst.wsdl.ui (1.2.202.v200904271449) "WSDL UI" [Starting]
org.eclipse.wst.wsdl.ui.doc.user (1.0.550.v200901232040) "WSDL Editor Documentation" [Starting]
org.eclipse.wst.wsdl.validation (1.1.402.v200911251542) "WSDL Validator" [Starting]
org.eclipse.wst.wsi (1.0.305.v200902181431) "WSI Conformance Tools" [Starting]
org.eclipse.wst.wsi.ui (1.0.500.v200901141851) "Soap Monitor" [Starting]
org.eclipse.wst.wsi.ui.doc.user (1.0.401.v200809171927) "WS-I Validation Documentation" [Resolved]
org.eclipse.wst.xml.core (1.1.402.v201001222130) "Structured Source XML Model" [Starting]
org.eclipse.wst.xml.ui (1.1.2.v201001222130) "Eclipse XML Editors and Tools" [Starting]
org.eclipse.wst.xml.ui.infopop (1.0.300.v200805140200) "XML infopops" [Resolved]
org.eclipse.wst.xml.xpath.core (1.0.0.v200904240436) "XPath Core" [Resolved]
org.eclipse.wst.xml.xpath.ui (1.0.0.v200904240436) "XPath UI" [Starting]
org.eclipse.wst.xml.xpath2.processor (1.0.0.v200905300355) "PsychoPath XPath 2.0 Processor" [Starting]
org.eclipse.wst.xmleditor.doc.user (1.0.600.v200901231300) "XML editor" [Resolved]
org.eclipse.wst.xsd.core (1.1.401.v200903020335) "XSD Core Plugin" [Starting]
org.eclipse.wst.xsd.ui (1.2.204.v200909021537) "XML Schema Editor" [Starting]
org.eclipse.wst.xsdeditor.doc.user (1.0.700.v200905182240) "XML schema editor" [Resolved]
org.eclipse.wst.xsl (1.0.0.v200905250058) "Eclipse XSL Developer Tools" [Resolved]
org.eclipse.wst.xsl.core (1.0.1.v200908101420) "XSL Core" [Starting]
org.eclipse.wst.xsl.debug.ui (1.0.0.v200904240436) "XSL Debugger UI" [Starting]
org.eclipse.wst.xsl.doc (1.0.0.v200905071815) "XSL User Documentation (Incubating)" [Resolved]
org.eclipse.wst.xsl.jaxp.debug (1.0.0.v200904240436) "XSL JAXP Debugger" [Resolved]
org.eclipse.wst.xsl.jaxp.debug.ui (1.0.0.v200904240436) "XSL JAXP Debug UI" [Starting]
org.eclipse.wst.xsl.jaxp.launching (1.0.0.v200904240436) "XSL JAXP Launching" [Starting]
org.eclipse.wst.xsl.launching (1.0.0.v200904241348) "XSL Transform Launching" [Starting]
org.eclipse.wst.xsl.saxon (1.0.0.v200904240436) "XSL Saxon Support" [Resolved]
org.eclipse.wst.xsl.sdk.documentation (1.0.0.v200904240436) "pluginName" [Starting]
org.eclipse.wst.xsl.ui (1.0.100.v200907172129) "XSL Editor and Validation" [Starting]
org.eclipse.wst.xsl.xalan (1.0.0.v200904240436) "XSL Xalan Support" [Resolved]
org.eclipse.xsd (2.5.0.v200906151043) "XSD Model" [Starting]
org.eclipse.xsd.edit (2.5.0.v200906151043) "XSD Edit" [Starting]
org.hamcrest.core (1.1.0.v20090501071000) "Hamcrest Core Library of Matchers" [Starting]
org.jdom (1.0.0.v200806100616) "JDOM" [Resolved]
org.junit (3.8.2.v20090203-1005) "JUnit Testing Framework" [Resolved]
org.junit4 (4.5.0.v20090824) "JUnit Testing Framework Version 4" [Resolved]
org.mortbay.jetty.server (6.1.15.v200905151201) "Jetty Server" [Resolved]
org.mortbay.jetty.util (6.1.15.v200905182336) "Jetty Utilities" [Resolved]
org.objectweb.asm (3.1.0.v200803061910) "ASM" [Resolved]
org.sat4j.core (2.1.0.v20090520) "SAT4J Core" [Resolved]
org.sat4j.pb (2.1.0.v20090520) "SAT4J Pseudo" [Resolved]
org.tigris.subversion.clientadapter (1.6.12) "Subversion Client Adapter" [Starting]
org.tigris.subversion.clientadapter.javahl (1.6.12) "Subversion JavaHL" [Starting]
org.tigris.subversion.clientadapter.javahl.win32 (1.6.12) "Win32 JavaHL Binaries" [Resolved]
org.tigris.subversion.clientadapter.svnkit (1.6.12) "SVNKit Client Adapter" [Starting]
org.tigris.subversion.subclipse.core (1.6.12) "SVN Team Provider Core" [Starting]
org.tigris.subversion.subclipse.doc (1.3.0) "Subclipse Documentation" [Resolved]
org.tigris.subversion.subclipse.ui (1.6.12) "SVN Team Provider UI" [Starting]
org.tmatesoft.svnkit (1.3.3.6648) "SVNKit Library Plug-in" [Starting]
org.uddi4j (2.0.5.v200805270300) "UDDI4J" [Resolved]
*** User Preferences:
#Fri Jul 02 09:43:03 CEST 2010
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.MaxGCPaths,com.adobe.flash.profiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf=10
@org.eclipse.ui.editors=3.5.0.v20090527-2000
/instance/FlexPrettyPrintCommand/Actionscript.dontIndentPackageItems=false
@org.eclipse.debug.ui=3.5.1.v20090811_r351
@org.eclipse.core.net=1.2.1.r35x_20090812-1200
/profile/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/autoUpdateInit=true
/instance/FlexPrettyPrintCommand/MXML.sortExtraAttrs=false
/instance/FlexPrettyPrintCommand/ASRearr_ElementSortMetatags=false
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equinox.p2.core_cache/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/instance/com.adobe.flexbuilder.project/workspaceFXPUUID=ad8fd946-e426-480f-8880-319a04396885
/instance/com.collabnet.subversion.merge/merge_provider_set=true
@org.eclipse.wst.jsdt.ui=1.0.201.v2010012803
/instance/org.eclipse.ui.workbench/ColorsAndFontsPreferencePage.selectedElement=Torg.eclipse.ui.workbenchMisc
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.VariableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_templates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/instance/org.eclipse.jdt.ui/spelling_ignore_sentence=true
/instance/org.eclipse.ui.views.log/groupBy=0
/instance/FlexPrettyPrintCommand/ASRearr_ElementSortImports=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.compliance=1.6
/instance/FlexPrettyPrintCommand/Actionscript.advancedSpacesInsideLiteralBraces=0
/instance/com.adobe.flexbuilder.project/flexBuilderVersion=4.0.1.277662
@org.eclipse.jst.j2ee.webservice.ui=1.1.300.v200902052230
/instance/FlexPrettyPrintCommand/Actionscript.advancedSpacesInsideArrayDeclBrackets=0
@com.adobe.flexbuilder.mxml.editor=4.0.1.277662
/instance/org.eclipse.ui.browser/internalWebBrowserHistory=file\://D\:/flashBuilder_workspace/tina/bayron-man.html|*|file\:/D\:/flashBuilder_workspace/tina/bayron-man.html|*|file\://D\:/Tine/html/tina/Archiv/einkehren.html|*|file\:/D\:/Tine/html/tina/Archiv/einkehren.html|*|http\://www.eclipse.org|*|file\:/C\:/Program Files (x86)/Adobe/Adobe Flash Builder 4/plugins/com.adobe.flexbuilder.ui_4.0.0.272416/welcome/welcome.html?firstLaunch\=false&edition\=prem&version\=400|*|
/instance/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=always
@com.adobe.flexbuilder.flexunit=4.0.1.277662
/instance/org.eclipse.wst.html.core/elemCoexistence=2
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=false
/instance/org.eclipse.wst.jsdt.ui/spelling_locale_initialized=true
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/isSystem=true
/instance/com.adobe.flexbuilder.launching.ui/com.adobe.flexbuilder.launching.ui.warnLaunchingWillTerminateExistingLaunch=false
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/enabled=true
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/name=artifact listener dropins
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/enabled=true
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Courier New|10.0|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.ui.editors/occurrenceIndicationColor=0,255,255
/instance/org.eclipse.wst.html.core/elemDuplicate=2
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equinox.p2.core_cache/description=
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/provider=
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/name=C\:\\Program Files (x86)\\Adobe\\Adobe Flash Builder 4\\.eclipseextension
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.ExpressionView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684">\r\n<PRESENTATION_CONTEXT_PROPERTIES IMemento.internal.id\="org.eclipse.debug.ui.ExpressionView">\r\n<BOOLEAN BOOLEAN\="true" IMemento.internal.id\="PRESENTATION_SHOW_LOGICAL_STRUCTURES"/>\r\n</PRESENTATION_CONTEXT_PROPERTIES>\r\n</VariablesViewMemento>
/instance/FlexPrettyPrintCommand/Actionscript.blankLinesToKeep=0
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
@com.adobe.flexbuilder.standalone=4.0.1.277662
/instance/FlexPrettyPrintCommand/Actionscript.blankLinesBeforeFunctions=1
/instance/org.eclipse.core.resources/pathvariable.DOCUMENTS=D\:/flashBuilder_workspace
/instance/FlexPrettyPrintCommand/Actionscript.spacesAfterLabel=0
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
/instance/FlexPrettyPrintCommand/Actionscript.doRearrangeWhileFormatting=true
@org.eclipse.ui=3.5.1.M20090902-1000
/instance/FlexPrettyPrintCommand/Actionscript.blankLinesBeforeClasses=1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.inlineJsrBytecode=enabled
/instance/FlexPrettyPrintCommand/Actionscript.blankLinesBeforeProperties=1
/instance/FlexPrettyPrintCommand/MXML.sortAttrData=
/instance/FlexPrettyPrintCommand/MXML.alwaysUseMaxLineLength=false
@org.eclipse.wst.server.core=1.1.102.v20100123
/instance/FlexPrettyPrintCommand/ASRearr_RemoveExistingSectionHeaders=false
/instance/FlexPrettyPrintCommand/ASRearr_MinorSectionHeader=style\=1|width\=40|blankLines\=0|fillChar\=-|text\=|linesBefore\=1|
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizing_default_participant_sec_id=1274887787363
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.internal.ui.navigator.layout=1
/instance/org.eclipse.wst.html.core/piInvalidContent=2
/instance/FlexPrettyPrintCommand/MXML.tagsWithASContent=.*\:add,.*\:added,.*\:activate,.*\:addedToStage,.*\:buttonDown,.*\:change,.*\:childAdd,.*\:childIndexChange,.*\:childRemove,.*\:clickHandler,.*\:clear,.*\:click,.*\:complete,.*\:contextMenu,.*\:copy,.*\:creationComplete,.*\:currentStateChange,.*\:currentStateChanging,.*\:cut,.*\:dataChange,.*\:deactivate,.*\:doubleClick,.*\:dragComplete,.*\:dragDrop,.*\:dragEnter,.*\:dragExit,.*\:dragOver,.*\:dragStart,.*\:effectEnd,.*\:effectStart,.*\:enterFrame,.*\:enterState,.*\:exitFrame,.*\:exitState,.*\:focusIn,.*\:focusOut,.*\:frameConstructed,.*\:hide,.*\:httpStatus,.*\:init,.*\:initialize,.*\:invalid,.*\:ioError,.*\:itemClick,.*\:itemRollOut,.*\:itemRollOver,.*\:keyDown,.*\:keyFocusChange,.*\:keyUp,.*\:menuHide,.*\:menuShow,.*\:middleClick,.*\:middleMouseDown,.*\:middleMouseUp,.*\:mouseDown,.*\:mouseUp,.*\:mouseOver,.*\:mouseMove,.*\:mouseOut,.*\:mouseFocusChange,.*\:mouseWheel,.*\:mouseDownOutside,.*\:mouseWheelOutside,.*\:move,.*\:nativeDragComplete,.*\:nativeDragDrop,.*\:nativeDragEnter,.*\:nativeDragExit,.*\:nativeDragOver,.*\:nativeDragStart,.*\:nativeDragUpdate,.*\:open,.*\:paste,.*\:preinitialize,.*\:progress,.*\:record,.*\:remove,.*\:removed,.*\:removedFromStage,.*\:render,.*\:resize,.*\:rightClick,.*\:rightMouseDown,.*\:rightMouseUp,.*\:rollOut,.*\:rollOver,.*\:scroll,.*\:securityError,.*\:selectAll,.*\:show,.*\:tabChildrenChange,.*\:tabEnabledChange,.*\:tabIndexChange,.*\:thumbDrag,.*\:thumbPress,.*\:thumbRelease,.*\:toolTipCreate,.*\:toolTipEnd,.*\:toolTipHide,.*\:toolTipShow,.*\:toolTipShown,.*\:toolTipStart,.*\:updateComplete,.*\:unload,.*\:valid,.*\:valueCommit,.*\:Script,
/instance/com.adobe.flexide.mxml.core/expandStateFiltered=_custom_\:controls\:layout\:navigators\:z_charts\:
/instance/com.adobe.flexide.mxml.core/com.adobe.flexide.mxml.core.filetemplates.=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/instance/org.eclipse.wst.html.core/attrValueMismatch=1
/instance/org.eclipse.debug.ui/preferredTargets=default\:default|
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/enabled=true
@com.adobe.flexbuilder.css.editor=4.0.1.277662
@com.adobe.flexbuilder.project=4.0.1.277662
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/isSystem=true
/instance/org.eclipse.ui.editors/overviewRuler_migration=migrated_3.1
/instance/FlexPrettyPrintCommand/MXML.parentTagsToHaveBlankLinesAddedAfterThem=
/instance/FlexPrettyPrintCommand/MXML.spacesBeforeEmptyTagEnd=0
/instance/com.crispico.flower.mp.eclipse/useFlowerModelingPerspective=always
/instance/org.eclipse.wst.html.core/attrNameMismatch=2
/instance/org.eclipse.wst.html.core/attrDuplicate=2
/instance/FlexPrettyPrintCommand/Actionscript.blankLinesBeforeControlStatements=1
/instance/org.eclipse.wst.html.core/elemUnclosedStartTag=1
/instance/FlexPrettyPrintCommand/ASRearr_CopyrightHeader=style\=1|width\=80|blankLines\=2|fillChar\=-|text\=   Copyright 2010\n   All rights reserved.|linesBefore\=1|
/instance/com.adobe.flexbuilder.mxml.editor/compViewSize=400 x 300;300 x 200
/instance/FlexPrettyPrintCommand/Actionscript.useGlobalSpacesInsideParens=true
/instance/org.eclipse.ui/SHOW_PROGRESS_ON_STARTUP=true
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/isSystem=true
@org.eclipse.jdt.debug.ui=3.4.1.v20090811_r351
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/enabled=true
/instance/org.eclipse.jdt.ui/spelling_ignore_single_letters=true
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/isSystem=true
/instance/org.eclipse.wst.html.core/elemMissingStart=2
/instance/FlexPrettyPrintCommand/Flex.autoSyncLocalChangesFlag=true
/instance/FlexPrettyPrintCommand/MXML.attrsPerLine=1
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.MaxGCPaths,com.adobe.flash.profiler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=10
/instance/com.adobe.flash.profiler//Avg.\ Self\ Time\ (ms),com.adobe.flash.profiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=123
/instance/FlexPrettyPrintCommand/MXML.wrapIndentStyle=1001
/instance/org.eclipse.wst.html.core/attrUndefValue=2
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=D\:\\flashBuilder_workspace\nC\:\\Users\\Tine\\Adobe Flash Builder 4
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizing_default_participant=org.tigris.subversion.subclipse.participant
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/uri=file\:/C\:/Users/Tine/.eclipse/com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/
/instance/FlexPrettyPrintCommand/ASRearr_ElementSortNamespaces=true
/instance/com.adobe.flexbuilder.mxml.editor/appViewSizes=1024 x 768;800 x 600
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/suffix=eclipse
/instance/FlexPrettyPrintCommand/MXML.useAttrsToKeepOnSameLine=false
/instance/com.adobe.flash.profiler/saveViewIDs=com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,0,com.adobe.flash.profiler.ui.LiveObjects,1,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,1,com.adobe.flash.profiler.ui.LiveObjects,2,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,2,com.adobe.flash.profiler.ui.LiveObjects,19,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,19,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 20, 2010 3 17 24 PM - Apr 20, 2010 3 17 58 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 20, 2010 3 17 24 PM - Apr 20, 2010 3 17 58 PM),com.adobe.flash.profiler.ui.LiveObjects,20,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,20,com.adobe.flash.profiler.ui.LiveObjects,21,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,21,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 20, 2010 3 19 53 PM - Apr 20, 2010 3 20 21 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 20, 2010 3 19 53 PM - Apr 20, 2010 3 20 21 PM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/KinderPingui/bin-debug/Main.swf (Apr 21, 2010 5 35 34 PM - Apr 21, 2010 5 38 02 PM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 44 58 AM - Apr 22, 2010 9 46 07 AM),com.adobe.flash.profiler.ui.LiveObjects,1,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,1,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 9 50 39 AM - Apr 22, 2010 9 51 49 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 50 39 AM - Apr 22, 2010 9 51 49 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 9 50 39 AM - Apr 22, 2010 9 51 49 AM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 10 57 55 AM - Apr 22, 2010 10 58 30 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 10 57 55 AM - Apr 22, 2010 10 58 30 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 10 57 55 AM - Apr 22, 2010 10 58 30 AM),com.adobe.flash.profiler.ui.LiveObjects,1,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,1,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 11 05 48 AM - Apr 22, 2010 11 07 17 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 11 05 48 AM - Apr 22, 2010 11 07 17 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 11 05 48 AM - Apr 22, 2010 11 07 17 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 11 05 48 AM - Apr 22, 2010 11 07 17 AM),com.adobe.flash.profiler.ui.LiveObjects,4,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,4,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 11 24 09 AM - Apr 22, 2010 11 25 18 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 11 24 09 AM - Apr 22, 2010 11 25 18 AM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 11 24 09 AM - Apr 22, 2010 11 25 18 AM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 22, 2010 4 11 36 PM - Apr 22, 2010 4 12 18 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 4 11 36 PM - Apr 22, 2010 4 12 18 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 22, 2010 4 11 36 PM - Apr 22, 2010 4 12 18 PM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 23, 2010 4 47 19 PM - Apr 23, 2010 4 47 28 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 23, 2010 4 47 19 PM - Apr 23, 2010 4 47 28 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 23, 2010 4 47 19 PM - Apr 23, 2010 4 47 28 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 23, 2010 4 47 19 PM - Apr 23, 2010 4 47 28 PM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,0,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 26, 2010 12 06 24 PM - Apr 26, 2010 12 07 12 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 26, 2010 12 06 24 PM - Apr 26, 2010 12 07 12 PM),com.adobe.flash.profiler.ui.LiveObjects,1,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,1,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 26, 2010 12 09 30 PM - Apr 26, 2010 12 09 50 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf (Apr 26, 2010 12 09 30 PM - Apr 26, 2010 12 09 50 PM),com.adobe.flash.profiler.ui.LiveObjects,2,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,2,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 26, 2010 2 21 29 PM - Apr 26, 2010 2 21 42 PM),com.adobe.flash.profiler.ui.LiveObjects,3,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,3,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Apr 26, 2010 2 22 01 PM - Apr 26, 2010 2 22 09 PM),com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,0,com.adobe.flash.profiler.ui.LiveObjects,0,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,0,com.adobe.flash.profiler.ui.LiveObjects,11,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,11,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 17, 2010 5 25 17 PM - Jun 17, 2010 5 25 31 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 17, 2010 5 25 17 PM - Jun 17, 2010 5 25 31 PM),com.adobe.flash.profiler.ui.LiveObjects,12,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,12,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 18, 2010 4 19 24 PM - Jun 18, 2010 4 21 25 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 18, 2010 4 19 24 PM - Jun 18, 2010 4 21 25 PM),com.adobe.flash.profiler.ui.LiveObjects,1,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,1,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 19, 2010 2 49 46 PM - Jun 19, 2010 2 51 19 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/Life/bin-debug/Life.swf (Jun 19, 2010 2 49 46 PM - Jun 19, 2010 2 51 19 PM),com.adobe.flash.profiler.ui.LiveObjects,2,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,2,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 09 05 PM - Jun 25, 2010 4 10 49 PM),com.adobe.flash.profiler.ui.LiveObjects,3,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,3,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 25, 2010 4 34 59 PM - Jun 25, 2010 4 36 48 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 34 59 PM - Jun 25, 2010 4 36 48 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 34 59 PM - Jun 25, 2010 4 36 48 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 34 59 PM - Jun 25, 2010 4 36 48 PM),com.adobe.flash.profiler.ui.LiveObjects,4,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,4,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 25, 2010 4 45 21 PM - Jun 25, 2010 4 46 18 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 4 45 21 PM - Jun 25, 2010 4 46 18 PM),com.adobe.flash.profiler.ui.LiveObjects,5,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,5,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 25, 2010 5 03 56 PM - Jun 25, 2010 5 04 37 PM),com.adobe.flash.profiler.ui.LiveObjects,6,com.adobe.flash.profiler.ext.ui.MemoryUsageGraph,6,com.adobe.flash.profiler.ui.PerformanceProfile,Performance Profile (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),com.adobe.flash.profiler.ui.MethodStats,file /D /flashBuilder_workspace/MemoryLoops_trunk/bin-debug/Main.html (Jun 25, 2010 5 13 19 PM - Jun 25, 2010 5 13 54 PM),
/instance/org.eclipse.wst.html.core/docDoctypeUnclosed=1
@FlexPrettyPrintCommand=0.7.4
/instance/FlexPrettyPrintCommand/ASRearr_UseSectionHeadersInMXML=false
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equinox.p2.core_cache/name=download cache
/instance/org.eclipse.jst.jsp.core/org.eclipse.jst.jsp.core.taglib.TaglibIndex=CLEAN
/instance/org.eclipse.wst.html.core/docInvalidChar=2
/instance/org.eclipse.ui.workbench/org.eclipse.ui.commands=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<org.eclipse.ui.commands>\r\n<keyBinding commandId\="org.eclipse.search.ui.performTextSearchWorkspace" contextId\="org.eclipse.ui.contexts.window" keyConfigurationId\="org.eclipse.ui.defaultAcceleratorConfiguration" keySequence\="CTRL+SHIFT+F"/>\r\n<keyBinding contextId\="org.eclipse.ui.contexts.window" keyConfigurationId\="org.eclipse.ui.defaultAcceleratorConfiguration" keySequence\="ALT+CTRL+G"/>\r\n<keyBinding commandId\="com.adobe.flexbuilder.as.editor.generate.gettersetter" contextId\="com.adobe.flexide.as.core.flexEditorScope.actionscript" keyConfigurationId\="org.eclipse.ui.defaultAcceleratorConfiguration" keySequence\="CTRL+G"/>\r\n</org.eclipse.ui.commands>
/instance/FlexPrettyPrintCommand/ASRearr_ElementSortIncludes=true
/instance/FlexPrettyPrintCommand/Actionscript.tabCountForHangingIndent=1
/instance/FlexPrettyPrintCommand/ASRearr_ElementSortProperties=true
/instance/FlexPrettyPrintCommand/ASRearr_RemoveExistingCopyrightHeaders=false
/instance/org.eclipse.ui.views.log/orderValue=-1
/instance/FlexPrettyPrintCommand/ASRearr_BlankLinesBeforeElement=
/instance/org.eclipse.wst.html.core/elemMissingEnd=2
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/version=1.0.0
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Excludes,com.adobe.flash.profiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=,flash.*.*,mx.*.*,spark.*.*,
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.save_dirty_editors_before_launch=always
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/description=
/instance/FlexPrettyPrintCommand/MXML.blankLinesBeforeTags=0
/instance/org.eclipse.ui.ide/TASKS_FILTERS_MIGRATE=true
@com.adobe.flexide.editorcore=4.0.1.277662
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.internal.ui.navigator.layout=2
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_perspective_on_suspend=always
@com.adobe.flexide.mxml.core=4.0.1.277662
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.enumIdentifier=error
@org.eclipse.team.cvs.ui=3.3.201.R35x_v20090826-0905
/instance/org.eclipse.wst.jsdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.source=1.6
/instance/FlexPrettyPrintCommand/Actionscript.wrapExpressionMode=1
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equinox.p2.core_cache/isSystem=true
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equinox.p2.core_cache/uri=file\:/C\:/Users/Tine/.eclipse/com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/p2/org.eclipse.equinox.p2.core/cache/
/instance/org.eclipse.jdt.ui/content_assist_number_of_computers=14
/instance/FlexPrettyPrintCommand/Actionscript.spacesBeforeComma=0
/instance/com.adobe.flash.profiler//Method,com.adobe.flash.profiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=476
/instance/FlexPrettyPrintCommand/MXML.blankLinesBetweenSiblingTags=0
/instance/FlexPrettyPrintCommand/Actionscript.putCatchOnNewLine=false
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equinox.p2.core_cache/provider=
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<editors version\="3.1">\r\n<info extension\="sql" name\="*">\r\n<editor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n<editor id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n<defaultEditor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n<defaultEditor id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n</info>\r\n<info extension\="xslt" name\="*">\r\n<editor id\="org.eclipse.wst.xsl.ui.XSLEditor"/>\r\n<defaultEditor id\="org.eclipse.wst.xsl.ui.XSLEditor"/>\r\n</info>\r\n<info extension\="tag" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info>\r\n<info extension\="xfl" name\="*">\r\n<editor id\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor"/>\r\n<defaultEditor id\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor"/>\r\n</info>\r\n<info extension\="jpage" name\="*">\r\n<editor id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info>\r\n<info extension\="shtml" name\="*">\r\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n<info extension\="xsl" name\="*">\r\n<editor id\="org.eclipse.wst.xsl.ui.XSLEditor"/>\r\n<defaultEditor id\="org.eclipse.wst.xsl.ui.XSLEditor"/>\r\n</info>\r\n<info extension\="ddl" name\="*">\r\n<editor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n<defaultEditor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n</info>\r\n<info extension\="fla" name\="*">\r\n<editor id\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor"/>\r\n<defaultEditor id\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor"/>\r\n</info>\r\n<info extension\="html" name\="*">\r\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="htm" name\="*">\r\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="tagf" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info>\r\n<info extension\="jsf" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="js" name\="*">\r\n<editor id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n<defaultEditor id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n</info>\r\n<info extension\="uml4as" name\="*">\r\n<editor id\="com.crispico.flower.mp.eclipse.part.FlowerDiagramEditorLauncher"/>\r\n</info>\r\n<info extension\="sqlpage" name\="*">\r\n<editor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n<defaultEditor id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor"/>\r\n</info>\r\n<info extension\="jsp" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="xhtml" name\="*">\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="tagx" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info>\r\n<info extension\="jspx" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n<editor id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n</info>\r\n<info extension\="properties" name\="sample">\r\n<editor id\="org.eclipse.pde.ui.sampleEditor"/>\r\n<defaultEditor id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info extension\="jspf" name\="*">\r\n<editor id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info>\r\n<info extension\="rdsquery" name\="*">\r\n<editor id\="com.adobe.rds.QueryEditor"/>\r\n</info>\r\n<info extension\="mxml" name\="*">\r\n<editor id\="com.adobe.flexbuilder.editors.mxml.MXMLEditor"/>\r\n<defaultEditor id\="com.adobe.flexbuilder.editors.mxml.MXMLEditor"/>\r\n</info>\r\n<info extension\="jardesc" name\="*">\r\n<editor id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n<defaultEditor id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n<info extension\="css" name\="*">\r\n<editor id\="com.adobe.flexbuilder.editors.css.editors.CSSEditor"/>\r\n</info>\r\n<info extension\="as" name\="*">\r\n<editor id\="com.adobe.flexbuilder.editors.actionscript.ActionScriptEditor"/>\r\n<defaultEditor id\="com.adobe.flexbuilder.editors.actionscript.ActionScriptEditor"/>\r\n</info>\r\n<info extension\="server" name\="*">\r\n<editor id\="org.eclipse.wst.server.ui.editor"/>\r\n</info>\r\n<info extension\="fxg" name\="*">\r\n<editor id\="com.adobe.flexbuilder.mxml.editor.FXGEditor"/>\r\n</info>\r\n</editors>
/instance/FlexPrettyPrintCommand/Actionscript.keepSLCommentsOnColumn1=false
/instance/FlexPrettyPrintCommand/ASRearr_MajorSectionHeader=style\=1|width\=60|blankLines\=2|fillChar\=-|text\=|linesBefore\=1|
/instance/org.eclipse.wst.html.core/elemUnclosedEndTag=1
/instance/org.eclipse.wst.html.core/elemStartInvalidCase=2
/instance/org.eclipse.wst.html.core/refInvalidContent=2
/instance/org.eclipse.wst.html.core/elemInvalidContent=2
/instance/FlexPrettyPrintCommand/ASRearr_SortGettersAndSettersWithAssociatedStaticProperties=true
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.MaxGCPaths,com.adobe.flash.profiler.ui.LiveObjects,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=10
@com.adobe.flexbuilder.launching.ui=4.0.1.277662
/instance/FlexPrettyPrintCommand/ASRearr_UseModifierOrder_Class=true
/profile/_SELF_/org.eclipse.equinox.p2.ui.sdk/showLatestVersion=true
@com.crispico.flower.mp.eclipse=1.0.0.M0_2010-06-11
@org.eclipse.ant.ui=3.4.2.v20091204_r352
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Excludes,com.adobe.flash.profiler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf=,
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/description=
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Includes,com.adobe.flash.profiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf=,
/instance/FlexPrettyPrintCommand/Flex.useTabs=true
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/uri=file\:/C\:/Users/Tine/.eclipse/com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/configuration/org.eclipse.osgi/bundles/190/data/listener_1925729951/
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equinox.p2.core_cache/enabled=true
/instance/org.eclipse.ui.views.log/activate=true
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/FlexPrettyPrintCommand/Actionscript.advancedWrappingEnforceMax=false
/instance/org.eclipse.ant.ui/useAnnotationsPrefPage=true
/instance/FlexPrettyPrintCommand/Actionscript.advancedSpacesInsideArrayRefBrackets=0
@org.eclipse.jdt.core=3.5.2.v_981_R35x
/instance/org.eclipse.ui.views.log/show_filter_text=true
/instance/org.eclipse.jdt.ui/spelling_ignore_java_strings=true
/instance/FlexPrettyPrintCommand/MXML.blankLinesAfterParentTags=0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.assertIdentifier=error
/instance/org.tigris.subversion.subclipse.ui/pref_merge_provider=CollabNet Desktop
/instance/FlexPrettyPrintCommand/ASRearr_ImportOrder=adobe,com,flash,mx,
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/type=org.eclipse.equinox.p2.extensionlocation.metadataRepository
@org.eclipse.debug.core=3.5.0.v20090526-1600
/instance/org.eclipse.jdt.ui/spelling_ignore_digits=true
/instance/FlexPrettyPrintCommand/Actionscript.wrapMethodCallMode=4
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/name=Bundle pool
/instance/org.eclipse.jst.j2ee.webservice.ui/areThereWebServices=false
/instance/FlexPrettyPrintCommand/ASRearr_ElementFunctionVisibilityOrder=public\:true,protected\:true,internal\:true,private\:true,
/instance/FlexPrettyPrintCommand/Actionscript.putEmptyStatementsOnNewLine=true
/instance/org.eclipse.ant.ui/useQuickDiffPrefPage=true
@com.adobe.flexide.as.core=4.0.1.277662
@org.eclipse.team.ui=3.5.0.I20090430-0408
/instance/com.adobe.flexbuilder.project/fbBuildID=277662
/instance/FlexPrettyPrintCommand/ASRearr_UseSectionHeaders=true
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.core.resources=3.5.1.R35x_v20090826-0451
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/instance/org.eclipse.wst.html.ui/declBoder=\#004000 | null | false | false | false | false
/instance/FlexPrettyPrintCommand/Actionscript.spacesAfterColons=0
/instance/FlexPrettyPrintCommand/Actionscript.maxLineLength=200
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.idefactory.com_update/enabled=false
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.text.custom_templates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates><template autoinsert\="true" context\="jsdoc" deleted\="false" description\="author name" enabled\="true" id\="org.eclipse.wst.jsdt.ui.templates.author" name\="@author">@author Christine Emrich</template></templates>
/instance/FlexPrettyPrintCommand/Actionscript.advancedCRBeforeBraceSettings=2047
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equinox.p2.core_cache/version=1.0.0
/instance/FlexPrettyPrintCommand/ASRearr_UseCopyrightGeneration=false
/instance/org.eclipse.ui.workbench/PLUGINS_NOT_ACTIVATED_ON_STARTUP=
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.idefactory.com_update/uri=http\://www.idefactory.com/update
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launching.PREF_VM_XML=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<vmSettings defaultVM\="57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType13,1270719219389" defaultVMConnector\="">\r\n<vmType id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType">\r\n<vm id\="1270719219389" javadocURL\="http\://java.sun.com/javase/6/docs/api/" name\="Adobe Flash Builder 4" path\="C\:\\Program Files (x86)\\Adobe\\Adobe Flash Builder 4"/>\r\n</vmType>\r\n</vmSettings>\r\n
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/version=1
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/version=1
/instance/org.eclipse.wst.html.core/elemInvalidDirective=1
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/instance/FlexPrettyPrintCommand/MXML.keepBlankLines=true
@org.tigris.subversion.subclipse.ui=1.6.12
/instance/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionBackground=255,128,192
/instance/com.adobe.flexbuilder.mxml.editor/lastEditorView=Source
@org.eclipse.wst.html.core=1.1.300.v200903120608
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.text.code_templates_migrated=true
/instance/org.eclipse.wst.html.core/cdataUnclosed=1
/instance/com.adobe.flexbuilder.css.editor/LastCSSEditorView=Source
/instance/FlexPrettyPrintCommand/ASRearr_MetatagOrder=ArrayElementType,Bindable,DefaultProperty,Deprecated,Effect,Embed,Event,Exclude,ExcludeClass,IconFile,Inspectable,InstanceType,NonCommittingChangeEvent,RemoteClass,Style,SWF,Transient,
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/suffix=artifacts.xml
/instance/org.eclipse.ui.views.log/orderType=2
/configuration/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
@org.eclipse.ui.ide=3.5.1.M20090826-0800
/instance/FlexPrettyPrintCommand/ActionScript.metatagsOnSameLineAsTargetFunction=Bindable
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.width=
@org.eclipse.wst.html.ui=1.0.401.v200908111935
/instance/FlexPrettyPrintCommand/Actionscript.alwaysGenerateIndent=false
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/uri=file\:/C\:/Program%20Files%20(x86)/Adobe/Adobe%20Flash%20Builder%204/.eclipseextension
/instance/com.adobe.flexbuilder.editorcore/autoViewIDs=com.adobe.flexbuilder.mxml.editor.states.StatesViewer\=design-mxml\=0\=true,com.adobe.flexbuilder.mxml.editor.components.ComponentsView\=design-mxml\=0\=true,com.adobe.flexbuilder.mxml.editor.inspector.view.PropertiesView\=design-mxml;design-css\=0\=true,com.adobe.flexbuilder.as.editor.asdocviewer\=code\=0\=false,com.adobe.flexbuilder.mxml.editor.AppearanceView\=design-mxml\=1\=false
/instance/FlexPrettyPrintCommand/MXML.attrGroups=name\=properties|sort\=11|includeStates\=true|wrap\=54|attrs\=allowDisjointSelection,allowMultipleSelection,allowThumbOverlap,allowTrackClick,autoLayout,autoRepeat,automationName,cachePolicy,class,clipContent,condenseWhite,conversion,creationIndex,creationPolicy,currentState,data,dataDescriptor,dataProvider,dataTipFormatFunction,dayNames,defaultButton,direction,disabledDays,disabledRanges,displayedMonth,displayedYear,doubleClickEnabled,emphasized,enabled,explicitHeight,explicitMaxHeight,explicitMaxWidth,explicitMinHeight,explicitMinWidth,explicitWidth,firstDayOfWeek,focusEnabled,fontContext,height,horizontalLineScrollSize,horizontalPageScrollSize,horizontalScrollBar,horizontalScrollPolicy,horizontalScrollPosition,htmlText,icon,iconField,id,imeMode,includeInLayout,indeterminate,label,labelField,labelFunction,labelPlacement,labels,layout,lineScrollSize,listData,liveDragging,maxChars,maxHeight,maxScrollPosition,maxWidth,maxYear,maximum,measuredHeight,measuredMinHeight,measuredMinWidth,measuredWidth,menuBarItemRenderer,menuBarItems,menus,minHeight,minScrollPosition,minWidth,minYear,minimum,mode,monthNames,monthSymbol,mouseFocusEnabled,pageScrollSize,pageSize,percentHeight,percentWidth,scaleX,scaleY,scrollPosition,selectable,selectableRange,selected,selectedDate,selectedField,selectedIndex,selectedRanges,showDataTip,showRoot,showToday,sliderDataTipClass,sliderThumbClass,snapInterval,source,states,stepSize,stickyHighlighting,styleName,text,text,thumbCount,tickInterval,tickValues,toggle,toolTip,transitions,truncateToFit,validationSubField,value,value,verticalLineScrollSize,verticalPageScrollSize,verticalScrollBar,verticalScrollPolicy,verticalScrollPosition,width,x,y,yearNavigationEnabled,yearSymbol,|data\=-1|\nname\=xml_namespaces|sort\=11|includeStates\=true|wrap\=54|attrs\=xmlns,xmlns\:.*,|data\=-1|\nname\=events|sort\=11|includeStates\=true|wrap\=54|attrs\=add,added,activate,addedToStage,buttonDown,change,childAdd,childIndexChange,childRemove,clickHandler,clear,click,complete,contextMenu,copy,creationComplete,currentStateChange,currentStateChanging,cut,dataChange,deactivate,doubleClick,dragComplete,dragDrop,dragEnter,dragExit,dragOver,dragStart,effectEnd,effectStart,enterFrame,enterState,exitFrame,exitState,focusIn,focusOut,frameConstructed,hide,httpStatus,init,initialize,invalid,ioError,itemClick,itemRollOut,itemRollOver,keyDown,keyFocusChange,keyUp,menuHide,menuShow,middleClick,middleMouseDown,middleMouseUp,mouseDown,mouseUp,mouseOver,mouseMove,mouseOut,mouseFocusChange,mouseWheel,mouseDownOutside,mouseWheelOutside,move,nativeDragComplete,nativeDragDrop,nativeDragEnter,nativeDragExit,nativeDragOver,nativeDragStart,nativeDragUpdate,open,paste,preinitialize,progress,record,remove,removed,removedFromStage,render,resize,rightClick,rightMouseDown,rightMouseUp,rollOut,rollOver,scroll,securityError,selectAll,show,tabChildrenChange,tabEnabledChange,tabIndexChange,thumbDrag,thumbPress,thumbRelease,toolTipCreate,toolTipEnd,toolTipHide,toolTipShow,toolTipShown,toolTipStart,updateComplete,unload,valid,valueCommit,|data\=-1|\nname\=styles|sort\=11|includeStates\=true|wrap\=54|attrs\=backgroundAlpha,backgroundAttachment,backgroundColor,backgroundDisabledColor,backgroundImage,backgroundSize,backgroundSkin,barColor,barSkin,borderColor,borderSides,borderSkin,borderStyle,borderThickness,bottom,color,cornerRadius,dataTipOffset,dataTipPrecision,dataTipStyleName,disabledColor,disabledIcon,disabledIconColor,disabledSkin,disbledOverlayAlpha,downArrowDisabledSkin,downArrowDownSkin,downArrowOverSkin,downArrowUpSkin,downIcon,downSkin,dropShadowColor,dropShadowEnabled,errorColor,fillAlphas,fillColors,focusAlpha,focusBlendMode,focusRoundedCorners,focusSkin,focusThickness,fontAntiAliasType,fontFamily,fontGridFitType,fontSharpness,fontSize,fontStyle,fontThickness,fontWeight,fontfamily,headerColors,headerStyleName,highlightAlphas,horizontalAlign,horizontalCenter,horizontalGap,horizontalScrollBarStyleName,icon,iconColor,indeterminateMoveInterval,indeterminateSkin,itemDownSkin,itemOverSkin,itemUpSkin,kerning,labelOffset,labelStyleName,labelWidth,leading,left,letterSpacing,maskSkin,menuStyleName,nextMonthDisabledSkin,nextMonthDownSkin,nextMonthOverSkin,nextMonthSkin,nextMonthUpSkin,nextYearDisabledSkin,nextYearDownSkin,nextYearOverSkin,nextYearSkin,nextYearUpSkin,overIcon,overSkin,paddingBottom,paddingLeft,paddingRight,paddingTop,prevMonthDisabledSkin,prevMonthDownSkin,prevMonthOverSkin,prevMonthSkin,prevMonthUpSkin,prevYearDisabledSkin,prevYearDownSkin,prevYearOverSkin,prevYearSkin,prevYearUpSkin,repeatDelay,repeatInterval,right,rollOverColor,rollOverIndicatorSkin,selectedDisabledIcon,selectedDisabledSkin,selectedDownIcon,selectedDownSkin,selectedOverIcon,selectedOverSkin,selectedUpIcon,selectedUpSkin,selectionColor,selectionIndicatorSkin,shadowColor,shadowDirection,shadowDistance,showTrackHighlight,skin,slideDuration,slideEasingFunction,strokeColor,strokeWidth,textAlign,textDecoration,textIndent,textRollOverColor,textSelectedColor,themeColor,thumbDisabledSkin,thumbDownSkin,thumbIcon,thumbOffset,thumbOverSkin,thumbUpSkin,tickColor,tickLength,tickOffset,tickThickness,todayColor,todayIndicatorSkin,todayStyleName,top,tracHighlightSkin,trackColors,trackHeight,trackMargin,trackSkin,upArrowDisabledSkin,upArrowDownSkin,upArrowOverSkin,upArrowUpSkin,upIcon,upSkin,verticalAlign,verticalCenter,verticalGap,verticalScrollBarStyleName,weekDayStyleName,|data\=-1|\nname\=effects|sort\=11|includeStates\=true|wrap\=54|attrs\=addedEffect,completeEffect,creationCompleteEffect,focusInEffect,focusOutEffect,hideEffect,mouseDownEffect,mouseUpEffect,moveEffect,removedEffect,resizeEffect,rollOutEffect,rollOverEffect,showEffect,|data\=-1|\n
/instance/FlexPrettyPrintCommand/ActionScript.metatagsOnSameLineAsTargetProperty=Bindable
@org.eclipse.ui.browser=3.2.300.v20090526
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/suffix=content.xml
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.ExpressionView+org.eclipse.debug.ui.ToggleObjectBrowsersAction=true
/instance/FlexPrettyPrintCommand/ASRearr_UseElementStaticPropertyVisibilityOrder=true
/instance/org.eclipse.ui.workbench/ColorsAndFontsPreferencePage.expandedCategories=Tcom.adobe.flexide.editorcore.flexbuilder
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/provider=
/instance/org.eclipse.wst.html.core/attrUndefName=2
/instance/org.eclipse.jdt.ui/spelling_locale_initialized=true
/instance/org.eclipse.jdt.ui/spelling_ignore_upper=true
@com.collabnet.subversion.merge=2.1.0
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/provider=
/instance/org.eclipse.ui.workbench/editors=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<editors>\r\n<descriptor class\="org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor.SQLScrapbookEditor" id\="org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEditor" image\="images/qrydoc.gif" internal\="true" label\="SQL File Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.datatools.sqltools.sqlscrapbook"/>\r\n<descriptor class\="org.eclipse.datatools.sqltools.sqlbuilder.SQLBuilderEditor" id\="org.eclipse.datatools.sqltools.sqlbuilder" image\="images/qrydoc.gif" internal\="true" label\="SQL Query Builder" openMode\="1" open_in_place\="false" plugin\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n<descriptor class\="org.eclipse.wst.xsl.ui.internal.editor.XSLEditor" id\="org.eclipse.wst.xsl.ui.XSLEditor" image\="$nl$/icons/full/xslt_file.gif" internal\="true" label\="XSL Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.wst.xsl.ui"/>\r\n<descriptor class\="org.eclipse.wst.sse.ui.StructuredTextEditor" id\="org.eclipse.jst.jsp.core.jspsource.source" image\="$nl$/icons//full/obj16/sourceEditor.gif" internal\="true" label\="JSP Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.jst.jsp.ui"/>\r\n<descriptor id\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor" image\="icons/fb_fla_16x16.png" internal\="false" label\="Adobe Flash Editor" launcher\="com.adobe.flexbuilder.ui.editors.FlashExternalEditor" openMode\="4" open_in_place\="false" plugin\="com.adobe.flexbuilder.ui"/>\r\n<descriptor class\="org.eclipse.jdt.internal.debug.ui.snippeteditor.JavaSnippetEditor" id\="org.eclipse.jdt.debug.ui.SnippetEditor" image\="$nl$/icons/full/obj16/jsbook_obj.gif" internal\="true" label\="Scrapbook" openMode\="1" open_in_place\="false" plugin\="org.eclipse.jdt.debug.ui"/>\r\n<descriptor id\="org.eclipse.ui.browser.editorSupport" image\="$nl$/icons/obj16/internal_browser.gif" internal\="false" label\="Web Browser" launcher\="org.eclipse.ui.internal.browser.BrowserLauncher" openMode\="4" open_in_place\="false" plugin\="org.eclipse.ui.browser"/>\r\n<descriptor class\="org.eclipse.jst.pagedesigner.editors.HTMLEditor" id\="org.eclipse.jst.pagedesigner.PageDesignerEditor" image\="icons/PD_Plugin.gif" internal\="true" label\="Web Page Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.jst.pagedesigner"/>\r\n<descriptor class\="org.eclipse.wst.jsdt.internal.ui.javaeditor.CompilationUnitEditor" id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor" image\="$nl$/icons/full/obj16/jcu_obj.gif" internal\="true" label\="JavaScript Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.wst.jsdt.ui"/>\r\n<descriptor id\="com.crispico.flower.mp.eclipse.part.FlowerDiagramEditorLauncher" internal\="false" label\="Flower Modeling Platform" launcher\="com.crispico.flower.mp.eclipse.part.o" openMode\="4" open_in_place\="false" plugin\="com.crispico.flower.mp.eclipse"/>\r\n<descriptor class\="org.eclipse.pde.internal.ui.samples.SampleEditor" id\="org.eclipse.pde.ui.sampleEditor" image\="$nl$/icons/obj16/build_exec.gif" internal\="true" label\="Code Sample Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.pde.ui"/>\r\n<descriptor class\="com.adobe.rds.client.eclipse.editors.query.QueryEditor" id\="com.adobe.rds.QueryEditor" image\="src/com/adobe/rds/client/eclipse/views/P_RDSQuery_Sm_N.png" internal\="true" label\="RDS Query Editor" openMode\="1" open_in_place\="false" plugin\="com.adobe.coldfusion.rds.client"/>\r\n<descriptor class\="com.adobe.flexbuilder.mxml.editor.MXMLEditor" id\="com.adobe.flexbuilder.editors.mxml.MXMLEditor" image\="icons/fb_mxml_16x16.png" internal\="true" label\="MXML Editor" openMode\="1" open_in_place\="false" plugin\="com.adobe.flexbuilder.mxml.editor"/>\r\n<descriptor id\="org.eclipse.jdt.ui.JARDescEditor" image\="$nl$/icons/full/obj16/jar_desc_obj.gif" internal\="false" label\="JAR Export Wizard" launcher\="org.eclipse.jdt.internal.ui.jarpackager.OpenJarExportWizardEditorLauncher" openMode\="4" open_in_place\="false" plugin\="org.eclipse.jdt.ui"/>\r\n<descriptor class\="com.adobe.flexbuilder.css.editor.CSSEditor" id\="com.adobe.flexbuilder.editors.css.editors.CSSEditor" image\="icons/C_CSSFile_md.png" internal\="true" label\="CSS Editor" openMode\="1" open_in_place\="false" plugin\="com.adobe.flexbuilder.css.editor"/>\r\n<descriptor class\="com.adobe.flexbuilder.as.editor.ActionScriptEditor" id\="com.adobe.flexbuilder.editors.actionscript.ActionScriptEditor" image\="icons/fb_as_16x16.png" internal\="true" label\="ActionScript Editor" openMode\="1" open_in_place\="false" plugin\="com.adobe.flexbuilder.as.editor"/>\r\n<descriptor class\="org.eclipse.wst.server.ui.internal.editor.ServerEditor" id\="org.eclipse.wst.server.ui.editor" image\="icons/obj16/server.gif" internal\="true" label\="Server Editor" openMode\="1" open_in_place\="false" plugin\="org.eclipse.wst.server.ui"/>\r\n<descriptor class\="com.adobe.flexide.fxg.core.editor.FXGCoreEditor" id\="com.adobe.flexbuilder.mxml.editor.FXGEditor" image\="icons/fb_mxml_16x16.png" internal\="true" label\="FXG Editor" openMode\="1" open_in_place\="false" plugin\="com.adobe.flexbuilder.mxml.editor"/>\r\n</editors>
/instance/FlexPrettyPrintCommand/Actionscript.advancedSpacesAroundEqualsInOptionalParameters=4
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/version=1.0.0
/instance/FlexPrettyPrintCommand/ASRearr_ElementOrder=Import,Include,Namespace Definition,Default Namespace,Namespace Use,Static Property,Static Function,Static Initializer,Constructor,Property,Function,
/instance/org.eclipse.ui.editors/asOccurencesTextStyle=NONE
/instance/FlexPrettyPrintCommand/ASRearr_ElementStaticFunctionVisibilityOrder=public\:true,protected\:true,internal\:true,private\:true,
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/uri=file\:/C\:/Program%20Files%20(x86)/Adobe/Adobe%20Flash%20Builder%204/
/instance/FlexPrettyPrintCommand/Actionscript.advancedUseSpacesAroundEqualsInOptionalParameters=false
/instance/FlexPrettyPrintCommand/Actionscript.wrapEmbeddedXMLMode=2
@org.eclipse.wst.jsdt.core=1.0.201.v2010012803
/instance/org.eclipse.wst.xml.ui/lastActivePage=1
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.editor.tab.width=
/instance/org.eclipse.ui.editors/AbstractTextEditor.Color.FindScope=0,255,255
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Includes,com.adobe.flash.profiler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=,
/instance/org.eclipse.wst.html.core/docDuplicateTag=1
/instance/FlexPrettyPrintCommand/Actionscript.useGlobalCRBeforeBrace=true
/instance/org.eclipse.wst.html.ui/org.eclipse.wst.sse.ui.custom_templates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
@com.adobe.flexbuilder.editorcore=4.0.1.277662
/instance/FlexPrettyPrintCommand/ASRearr_UseElementFunctionVisibilityOrder=true
/instance/org.eclipse.wst.jsdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.formatterprofiles.version=11
/instance/FlexPrettyPrintCommand/ASRearr_ModifierOrder_Function=<Namespace>,override,native,public,private,protected,internal,static,dynamic,final
@com.adobe.flexide.css.core=4.0.1.277662
/instance/org.eclipse.jdt.ui/spelling_ignore_urls=true
/instance/FlexPrettyPrintCommand/Actionscript.putOpenBraceOnNewLine=true
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/suffix=eclipse
/instance/com.adobe.flexide.css.core/com.adobe.flexide.css.core.filetemplates.=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/instance/org.eclipse.ui.ide/PROBLEMS_FILTERS_MIGRATE=true
/instance/FlexPrettyPrintCommand/ASRearr_GroupGettersAndSettersWithProperties=false
/instance/org.eclipse.wst.html.core/elemInvalidEmptyTag=2
/instance/FlexPrettyPrintCommand/ASRearr_ModifierOrder_Property=<Namespace>,override,native,public,private,protected,internal,static,dynamic,final
/instance/com.adobe.flexbuilder.editorcore/activeViewIDs3=org.eclipse.ui.console.ConsoleView,com.adobe.flexbuilder.packageexplorer,org.eclipse.ui.views.ContentOutline,com.adobe.flexbuilder.mxml.editor.states.StatesViewer,com.adobe.flexbuilder.mxml.editor.components.ComponentsView,com.adobe.flexbuilder.mxml.editor.inspector.view.PropertiesView
/instance/com.adobe.flexbuilder.editorcore/activeViewIDs2=com.adobe.flexbuilder.packageexplorer,org.eclipse.ui.views.ProgressView,org.eclipse.ui.views.ContentOutline
/instance/org.eclipse.wst.html.core/elemUnknownName=2
@org.eclipse.ui.views.log=1.0.100.v20090731
/instance/FlexPrettyPrintCommand/Actionscript.spacesAroundColons=0
/instance/com.adobe.flexide.mxml.core/newAppLayout=absolute
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/isSystem=true
/instance/FlexPrettyPrintCommand/Actionscript.leaveExtraWhitespaceAroundVarDecls=false
/instance/FlexPrettyPrintCommand/Actionscript.breakLinesBeforeComma=false
/profile/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/migrated34Prefs=true
/instance/com.crispico.flower.mp.eclipse/toolbarSizePreferences=214
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/uri=file\:/C\:/Users/Tine/.eclipse/com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/configuration/org.eclipse.osgi/bundles/190/data/listener_1925729951/
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/FlexPrettyPrintCommand/MXML.onlyFormatASIfCDATABlock=false
/instance/FlexPrettyPrintCommand/Actionscript.advancedWrappingPreservePhrases=true
/instance/org.eclipse.wst.html.core/elemInvalidName=1
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/name=C\:\\Program Files (x86)\\Adobe\\Adobe Flash Builder 4\\.eclipseextension
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=com.adobe.flexbuilder.flashbridge.applicationDecorator\:true,com.adobe.flexbuilder.project.ui.applicationDecorator\:true,com.adobe.flexbuilder.project.ui.classpathDecorator\:true,org.eclipse.wst.server.ui.decorator\:false,org.eclipse.jdt.ui.override.decorator\:true,org.eclipse.jdt.ui.interface.decorator\:false,org.eclipse.jdt.ui.buildpath.decorator\:true,org.eclipse.team.cvs.ui.decorator\:true,org.eclipse.ui.LinkedResourceDecorator\:true,org.eclipse.ui.ContentTypeDecorator\:true,org.eclipse.wst.jsdt.ui.override.decorator\:true,org.eclipse.wst.jsdt.ui.interface.decorator\:false,org.eclipse.wst.server.ui.navigatorDecorator\:true,org.tigris.subversion.subclipse.ui.decorator\:true,
/instance/FlexPrettyPrintCommand/Actionscript.advancedSpacesInsideParens=1
/instance/org.eclipse.wst.jsdt.core/org.eclipse.wst.jsdt.core.codeComplete.visibilityCheck=enabled
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Excludes,com.adobe.flash.profiler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=,flash.*.*,mx.*.*,spark.*.*,
/instance/FlexPrettyPrintCommand/ASRearr_UseModifierOrder_Property=true
/instance/org.eclipse.ui.editors/asOccurencesIndicationColor=255,128,255
/instance/org.eclipse.wst.jsdt.ui/tabWidthPropagated=true
/instance/FlexPrettyPrintCommand/ASRearr_ModifierOrder_Class=<Namespace>,override,native,public,private,protected,internal,static,dynamic,final
/instance/FlexPrettyPrintCommand/ASRearr_AddDefaultHeaderForStaticProperties=1
/instance/FlexPrettyPrintCommand/ASRearr_ElementSortFunctions=true
/instance/org.eclipse.wst.html.core/cdataInvalidContent=2
/instance/FlexPrettyPrintCommand/MXML.sortAttrMode=0
/instance/org.eclipse.wst.html.core/elemUnnecessaryEnd=2
/instance/org.eclipse.wst.sse.core/task-tag-projects-already-scanned=Hyphenator,KinderPingui,c&m_animatedText,fBolo,SpellChecker_prototype,Flash_Audio_Player,pageflip,pageflip - Kopie,app_template,map-projection,MemoryLoops,MemoryLoops_trunk,UMLTest,AudioPlayer,eventTagTest,Untitled_1,content_assets,Applet,GuessTheNumber,InteraceTest,Life,GameOfLife,ivg_presentation,Test
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/name=metadata listener dropins
/instance/com.adobe.flexbuilder.standalone/flexbuilder.afterFirstLaunch=true
/instance/org.eclipse.ant.ui/org.eclipse.ant.ui.customtemplates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Includes,com.adobe.flash.profiler.ui.LiveObjects,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=,
/instance/org.eclipse.wst.jsdt.ui/useAnnotationsPrefPage=true
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/isSystem=true
@org.eclipse.wst.xml.ui=1.1.2.v201001222130
/instance/FlexPrettyPrintCommand/MXML.spacesAroundEquals=0
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/name=Bundle pool
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/provider=
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templates_migrated=true
/instance/com.adobe.flash.profiler//Avg.\ Cumulative\ Time\ (ms),com.adobe.flash.profiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=204
/instance/org.eclipse.jdt.ui/content_assist_proposals_foreground=0,0,0
/instance/FlexPrettyPrintCommand/Actionscript.braceStyle=5
/instance/FlexPrettyPrintCommand/Actionscript.putWhileOnNewLine=true
/instance/FlexPrettyPrintCommand/MXML.tagsCannotFormat=mx\:String,fx\:String,
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComplete.visibilityCheck=enabled
/instance/org.eclipse.wst.jsdt.web.core/jspIndexState=1
/instance/FlexPrettyPrintCommand/ASRearr_ElementPropertyVisibilityOrder=public\:true,protected\:true,internal\:true,private\:true,
/profile/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/enabled=false
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterprofiles.version=11
/instance/FlexPrettyPrintCommand/Actionscript.keepBlankLines=true
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.MaxGCPaths,com.adobe.flash.profiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=10
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/version=1.0.0
/instance/FlexPrettyPrintCommand/Actionscript.wrapMethodDeclMode=4
/instance/FlexPrettyPrintCommand/Actionscript.advancedWrappingGraceColumns=5
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/description=
@org.eclipse.wst.sse.core=1.1.402.v201001251516
/instance/org.eclipse.jdt.ui/content_assist_lru_history=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><history maxLHS\="100" maxRHS\="10"><lhs name\="java.awt.Paint"><rhs name\="java.awt.Color"/></lhs><lhs name\="java.awt.Transparency"><rhs name\="java.awt.Color"/></lhs><lhs name\="java.awt.Color"><rhs name\="java.awt.Color"/></lhs><lhs name\="java.lang.Runnable"><rhs name\="java.lang.Thread"/></lhs><lhs name\="java.lang.Thread"><rhs name\="java.lang.Thread"/></lhs><lhs name\="java.lang.Exception"><rhs name\="java.lang.InterruptedException"/></lhs><lhs name\="java.lang.Throwable"><rhs name\="java.lang.InterruptedException"/></lhs><lhs name\="java.lang.InterruptedException"><rhs name\="java.lang.InterruptedException"/></lhs><lhs name\="Ball"><rhs name\="Ball"/></lhs><lhs name\="org.wiigee.device.Device"><rhs name\="org.wiigee.device.Wiimote"/></lhs><lhs name\="org.wiigee.device.Wiimote"><rhs name\="org.wiigee.device.Wiimote"/></lhs></history>
@org.eclipse.wst.jsdt.web.core=1.0.201.v201001221931
/instance/org.eclipse.debug.ui/preferredDetailPanes=DefaultDetailPane\:DefaultDetailPane|
/instance/com.adobe.flexide.editorcore/prefDialogNoProject=false
@org.eclipse.ui.workbench=3.5.1.M20090826-0800a
/instance/FlexPrettyPrintCommand/Actionscript.spacesAroundAssignment=1
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.text.custom_code_templates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/instance/FlexPrettyPrintCommand/Actionscript.spacesBeforeColons=1
/instance/com.adobe.flexbuilder.flexunit/com.adobe.flexbuilder.flexunit.filetemplates.=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/instance/org.eclipse.debug.core/prefWatchExpressions=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<watchExpressions/>\r\n
/instance/FlexPrettyPrintCommand/MXML.attrsToKeepOnSameLine=4
/instance/FlexPrettyPrintCommand/ASRearr_AddDefaultHeaderForProperties=1
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.MaxGCPaths,com.adobe.flash.profiler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf=10
/instance/org.eclipse.ui.views.log/column4=150
/instance/org.eclipse.ui.views.log/column3=150
/instance/org.eclipse.ui.views.log/column2=497
@org.eclipse.jdt.ui=3.5.2.r352_v20100106-0800
/instance/org.eclipse.jdt.ui/spelling_user_dictionary_encoding=Cp1252
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_templates_migrated=true
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Excludes,com.adobe.flash.profiler.ui.LiveObjects,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=,flash.*.*,mx.*.*,spark.*.*,
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Includes,com.adobe.flash.profiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=,
/instance/org.eclipse.wst.html.core/attrInvalidValue=2
/instance/com.adobe.flexide.as.core/com.adobe.flexide.as.core.filetemplates.=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/instance/com.adobe.flexide.editorcore/autoDelay=0
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.text.templates_migrated=true
/instance/FlexPrettyPrintCommand/ASRearr_MoveImportsOutsideClass=true
/instance/FlexPrettyPrintCommand/MXML.blankLinesAfterSpecificParentTags=0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_code_templates=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates><template autoinsert\="false" context\="typecomment_context" deleted\="false" description\="Comment for created types" enabled\="true" id\="org.eclipse.jdt.ui.text.codetemplates.typecomment" name\="typecomment">/**\r\n * @author Christine Emrich\r\n *\r\n * ${tags}\r\n */</template><template autoinsert\="false" context\="typecomment_context" deleted\="false" description\="Comment for created types" enabled\="true" id\="org.eclipse.wst.jsdt.ui.text.codetemplates.typecomment" name\="typecomment">/**\r\n * @author Christine Emrich\r\n *\r\n * ${tags}\r\n */</template></templates>
/instance/org.eclipse.wst.html.core/attrValueUnclosed=2
/instance/org.eclipse.wst.html.core/attrInvalidName=2
/instance/FlexPrettyPrintCommand/MXML.attrWrapMode=52
/instance/org.eclipse.ui.workbench/perspectives=tine_flex
/instance/org.eclipse.wst.html.core/docInvalidContent=2
/instance/FlexPrettyPrintCommand/Actionscript.putElseOnNewLine=true
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/FlexPrettyPrintCommand/Actionscript.collapseSpacesForAdjacentParens=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=3
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time=false
/instance/org.eclipse.search/org.eclipse.search.defaultPerspective=org.eclipse.search.defaultPerspective.none
/instance/FlexPrettyPrintCommand/ASRearr_UseImportOrder=true
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<web-browsers current\="0">\r\n<system/>\r\n<external location\="C\:\\Program Files\\Internet Explorer\\iexplore.exe" name\="Internet Explorer"/>\r\n</web-browsers>
file_export_version=3.0
/instance/org.eclipse.ui/SHOW_TEXT_ON_PERSPECTIVE_BAR=false
@org.eclipse.jdt.launching=3.5.1.v20100108_r352
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_p2_org.eclipse.equinox.p2.core_cache/suffix=artifacts.xml
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438/version=1.0.0
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Excludes,com.adobe.flash.profiler.ui.PerformanceProfile,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf=,
/instance/FlexPrettyPrintCommand/Actionscript.useGlobalSpacesAroundColons=true
/instance/org.eclipse.wst.html.core/piUndefined=2
/instance/FlexPrettyPrintCommand/ASRearr_SortGettersAndSettersWithAssociatedProperties=true
/instance/org.eclipse.ui.workbench/overridepresentation=true
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Users_Tine_.eclipse_com.adobe.flexbuilder.standalone.product_4.0.1_1084004438_configuration_org.eclipse.osgi_bundles_190_data_listener_1925729951/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/instance/org.eclipse.core.resources/pathvariable.FLASHPRO_APPCONFIG=C\:/Program Files (x86)/Adobe/Adobe Flash CS5/Common/Configuration
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.javadoclocations.migrated=true
/instance/FlexPrettyPrintCommand/ASRearr_UseMetatagOrder=false
/instance/FlexPrettyPrintCommand/ASRearr_GroupGettersAndSettersWithStaticProperties=false
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/type=org.eclipse.equinox.p2.extensionlocation.artifactRepository
/instance/FlexPrettyPrintCommand/Actionscript.wrapIndentStyle=1001
/instance/FlexPrettyPrintCommand/ASRearr_ElementStaticPropertyVisibilityOrder=public\:true,protected\:true,internal\:true,private\:true,
/instance/org.eclipse.jdt.ui/fontPropagated=true
/profile/_SELF_/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
/instance/org.eclipse.wst.html.core/piUnclosed=1
/instance/FlexPrettyPrintCommand/ASRearr_ElementSortStaticProperties=true
/instance/com.crispico.flower.mp.eclipse/flatPackagePresentationPreferences=true
@org.eclipse.wst.sse.ui=1.1.102.v200910200227
/instance/org.eclipse.ui.workbench/tine_flex_persp=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<perspective editorAreaTrimState\="2" editorAreaVisible\="1" fixed\="0" version\="0.016">\r\n<descriptor descriptor\="com.adobe.flexbuilder.editors.mxml.ui.perspectives.development" id\="tine_flex" label\="tine_flex"/>\r\n<window height\="876" width\="1616" x\="-8" y\="-8"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.editorcore.modeswitch"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.standalone.navigate"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.cheatsheets.actionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.annotationNavigation"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.actionSet.keyBindings"/>\r\n<alwaysOnActionSet id\="org.eclipse.ui.actionSet.openFiles"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.standalone.launch"/>\r\n<alwaysOnActionSet id\="org.eclipse.debug.ui.breakpointActionSet"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.debug.ui.flexDebuggingActionSet"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.zzz.editors.common.ui.project.publish"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.as.editor.ui.NavigationActions"/>\r\n<alwaysOnActionSet id\="com.adobe.flexbuilder.dcrad.actionSet"/>\r\n<alwaysOnActionSet id\="org.eclipse.debug.ui.debugActionSet"/>\r\n<show_view_action id\="com.adobe.flexbuilder.mxml.editor.AppearanceView"/>\r\n<show_view_action id\="com.adobe.flexbuilder.mxml.editor.components.ComponentsView"/>\r\n<show_view_action id\="com.adobe.flexbuilder.packageexplorer"/>\r\n<show_view_action id\="org.eclipse.ui.views.ContentOutline"/>\r\n<show_view_action id\="org.eclipse.ui.views.ProblemView"/>\r\n<show_view_action id\="com.adobe.flexbuilder.mxml.editor.inspector.view.PropertiesView"/>\r\n<show_view_action id\="com.adobe.flexbuilder.mxml.editor.states.StatesViewer"/>\r\n<show_view_action id\="com.adobe.flexbuilder.dcrad.views.DataServicesView"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.editorcore.ui.project.wizards.newproject"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.project.ui.wizards.FlexLibraryProjectWizard"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.flashbridge.NewFlashProProjectWizard"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.project.ui.wizards.NewActionScriptProjectWizard"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.mxml.editor.ui.wizards.NewMXMLApplication"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.mxml.editor.ui.wizards.NewMXMLComponent"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.mxml.editor.ui.wizards.NewMXMLItemRenderer"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.mxml.editor.ui.wizards.NewMXMLModule"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.mxml.editor.ui.wizards.NewMXMLSkin"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.as.editor.wizards.NewActionScriptFile.flex"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.as.editor.classWizard.flex"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.as.editor.interfaceWizard.flex"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.css.editor.wizards.NewCSSFile"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.as.editor.flexUnitClassWizard.flex"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.as.editor.flexUnitTestSuiteClassWizard.flex"/>\r\n<new_wizard_action id\="com.adobe.flexbuilder.as.editor.packageWizard.flex"/>\r\n<new_wizard_action id\="org.eclipse.ui.wizards.new.folder"/>\r\n<new_wizard_action id\="org.eclipse.ui.wizards.new.file"/>\r\n<perspective_action id\="com.adobe.flexbuilder.editors.mxml.ui.perspectives.development"/>\r\n<perspective_action id\="com.adobe.flexbuilder.debug.ui.perspectives.debug"/>\r\n<perspective_action id\="com.adobe.flash.profiler.ui.ProfilingPerspective"/>\r\n<hide_toolbar_item_id id\="org.eclipse.ui.edit.text.toggleShowSelectedElementOnly"/>\r\n<view id\="org.eclipse.ui.views.ProblemView"/>\r\n<view id\="com.adobe.flexbuilder.dcrad.views.DataServicesView"/>\r\n<view id\="com.adobe.flexbuilder.monitors.network.view.NetworkMonitorView"/>\r\n<view id\="org.eclipse.search.ui.views.SearchView"/>\r\n<view id\="org.eclipse.debug.ui.DebugView"/>\r\n<view id\="com.collabnet.subversion.merge.views.MergeResultsView"/>\r\n<view id\="org.eclipse.team.ui.GenericHistoryView"/>\r\n<view id\="com.adobe.flash.profiler.ui.Monitor"/>\r\n<view id\="com.adobe.flexbuilder.as.editor.asdocviewer"/>\r\n<view id\="org.eclipse.debug.ui.VariableView"/>\r\n<view id\="com.adobe.flexbuilder.packageexplorer"/>\r\n<view id\="org.eclipse.ui.views.ContentOutline"/>\r\n<view id\="org.eclipse.ui.console.ConsoleView"/>\r\n<fastViewBars/>\r\n<layout>\r\n<mainWindow>\r\n<info folder\="true" part\="org.eclipse.ui.internal.ViewStack@ba0dfc">\r\n<folder activePageID\="com.adobe.flexbuilder.packageexplorer" appearance\="2" expanded\="2">\r\n<page content\="com.adobe.flexbuilder.packageexplorer" label\="Package Explorer"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\r\n<part id\="0"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n<info folder\="true" part\="stickyFolderRight" ratio\="0.75" ratioLeft\="750" ratioRight\="250" relationship\="2" relative\="org.eclipse.ui.internal.ViewStack@ba0dfc">\r\n<folder appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.help.ui.HelpView" label\="LabelNotFound"/>\r\n<page content\="org.eclipse.ui.internal.introview" label\="LabelNotFound"/>\r\n<page content\="org.eclipse.ui.cheatsheets.views.CheatSheetView" label\="LabelNotFound"/>\r\n</folder>\r\n</info>\r\n<info part\="org.eclipse.ui.editorss" ratio\="0.2410321" ratioLeft\="383" ratioRight\="1206" relationship\="2" relative\="org.eclipse.ui.internal.ViewStack@ba0dfc"/>\r\n<info folder\="true" part\="statesViewHolder" ratio\="0.65" ratioLeft\="520" ratioRight\="280" relationship\="2" relative\="org.eclipse.ui.editorss">\r\n<folder appearance\="2" expanded\="2">\r\n<page content\="com.adobe.flexbuilder.mxml.editor.states.StatesViewer" label\="LabelNotFound"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory"/>\r\n</folder>\r\n</info>\r\n<info folder\="true" part\="propertiesHolder" ratio\="0.24884081" ratioLeft\="161" ratioRight\="486" relationship\="4" relative\="statesViewHolder">\r\n<folder appearance\="2" expanded\="2">\r\n<page content\="com.adobe.flexbuilder.mxml.editor.inspector.view.PropertiesView" label\="LabelNotFound"/>\r\n<page content\="com.adobe.flexbuilder.mxml.editor.AppearanceView" label\="LabelNotFound"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory"/>\r\n</folder>\r\n</info>\r\n<info folder\="true" part\="bottomLayout" ratio\="0.7549889" ratioLeft\="681" ratioRight\="221" relationship\="4" relative\="org.eclipse.ui.editorss">\r\n<folder activePageID\="org.eclipse.debug.ui.VariableView" appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.ui.views.ProblemView" label\="Problems"/>\r\n<page content\="com.adobe.flexbuilder.dcrad.views.DataServicesView" label\="Data/Services"/>\r\n<page content\="com.adobe.flexbuilder.monitors.network.view.NetworkMonitorView" label\="Network Monitor"/>\r\n<page content\="org.eclipse.search.ui.views.SearchView" label\="Search"/>\r\n<page content\="org.eclipse.debug.ui.DebugView" label\="Debug"/>\r\n<page content\="com.collabnet.subversion.merge.views.MergeResultsView" label\="Merge Results"/>\r\n<page content\="org.eclipse.team.ui.GenericHistoryView" label\="History"/>\r\n<page content\="com.adobe.flash.profiler.ui.Monitor" label\="Profile"/>\r\n<page content\="com.adobe.flexbuilder.as.editor.asdocviewer" label\="ASDoc"/>\r\n<page content\="org.eclipse.debug.ui.VariableView" label\="Variables"/>\r\n<page content\="org.eclipse.ui.views.TaskList" label\="LabelNotFound"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\r\n<part id\="0"/>\r\n<part id\="1"/>\r\n<part id\="2"/>\r\n<part id\="3"/>\r\n<part id\="4"/>\r\n<part id\="5"/>\r\n<part id\="6"/>\r\n<part id\="7"/>\r\n<part id\="8"/>\r\n<part id\="9"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n<info folder\="true" part\="outlineHolder" ratio\="0.4992272" ratioLeft\="323" ratioRight\="324" relationship\="4" relative\="org.eclipse.ui.internal.ViewStack@ba0dfc">\r\n<folder appearance\="2" expanded\="2">\r\n<page content\="com.adobe.flexbuilder.mxml.editor.components.ComponentsView" label\="LabelNotFound"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory"/>\r\n</folder>\r\n</info>\r\n<info folder\="true" part\="org.eclipse.ui.internal.ViewStack@5445a6" ratio\="0.6019956" ratioLeft\="543" ratioRight\="359" relationship\="4" relative\="org.eclipse.ui.internal.ViewStack@ba0dfc">\r\n<folder activePageID\="org.eclipse.ui.views.ContentOutline" appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.ui.views.ContentOutline" label\="Outline"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\r\n<part id\="0"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n</mainWindow>\r\n<detachedWindow height\="781" width\="853" x\="-914" y\="79">\r\n<folder activePageID\="org.eclipse.ui.console.ConsoleView" appearance\="2" expanded\="2">\r\n<page content\="org.eclipse.ui.console.ConsoleView" label\="Console"/>\r\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\r\n<part id\="0"/>\r\n</presentation>\r\n</folder>\r\n</detachedWindow>\r\n</layout>\r\n</perspective>
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.idefactory.com_update/uri=http\://www.idefactory.com/update
/instance/FlexPrettyPrintCommand/Actionscript.wrapArrayDeclMode=4
/instance/FlexPrettyPrintCommand/Actionscript.spacesAfterComma=1
/instance/org.eclipse.jdt.ui/spelling_ignore_non_letters=true
/instance/FlexPrettyPrintCommand/ASRearr_UseElementPropertyVisibilityOrder=true
/instance/org.eclipse.wst.html.core/commentInvalidContent=2
/instance/FlexPrettyPrintCommand/Actionscript.spacesBeforeControlOpenParen=1
/instance/org.eclipse.jdt.ui/content_assist_proposals_background=255,255,255
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.jface.textfont=1|Courier New|10.0|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/FlexPrettyPrintCommand/ASRearr_ElementSortStaticFunctions=true
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.DebugVieworg.eclipse.debug.ui.DebugView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<DebugViewMemento org.eclipse.debug.ui.BREADCRUMB_DROPDOWN_AUTO_EXPAND\="false"/>
/instance/FlexPrettyPrintCommand/MXML.tagsToHaveBlankLinesAddedBeforeThem=
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAUNCH_PERSPECTIVES=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<launchPerspectives/>\r\n
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.idefactory.com_update/isSystem=false
/instance/FlexPrettyPrintCommand/ASRearr_UseElementStaticFunctionVisibilityOrder=true
@org.eclipse.jst.jsp.core=1.2.204.v201001270045
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.idefactory.com_update/enabled=false
/instance/org.eclipse.wst.html.core/commentUnclosed=1
/instance/FlexPrettyPrintCommand/Actionscript.newLineBeforeBindableFunction=true
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/description=
/instance/org.eclipse.jdt.ui/spelling_ignore_ampersand_in_properties=true
/instance/FlexPrettyPrintCommand/ActionScript.spacesBeforeFormalParameters=0
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Includes,com.adobe.flash.profiler.ui.MethodStats,localhost,file\:/D\:/flashBuilder_workspace/Hyphenator/bin-debug/TestBed.swf=,
/instance/FlexPrettyPrintCommand/ASRearr_UseElementOrder=true
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/provider=
@org.eclipse.search=3.5.1.r351_v20090708-0800
/instance/FlexPrettyPrintCommand/Actionscript.newLineBeforeBindableProperty=true
/profile/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.idefactory.com_update/isSystem=false
/instance/FlexPrettyPrintCommand/MXML.addNewlineAfterLastAttr=false
/instance/FlexPrettyPrintCommand/ASRearr_UseModifierOrder_Function=true
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/instance/com.adobe.flash.profiler//com.adobe.flash.profiler.Builtins,com.adobe.flash.profiler.ui.LiveObjects,localhost,file\:/D\:/flashBuilder_workspace/KinderPingui/bin-debug/Main.swf=true
/instance/FlexPrettyPrintCommand/Actionscript.spacesAroundBinarySymbolicOperator=1
/instance/FlexPrettyPrintCommand/Actionscript.useAdvancedWrapping=false
/instance/org.eclipse.team.cvs.ui/pref_first_startup=false
@com.adobe.flash.profiler=4.0.1.277662
/instance/org.eclipse.jdt.ui/spelling_ignore_mixed=true
/instance/FlexPrettyPrintCommand/ASRearr_UseGlobalModifierOrder=true
/instance/FlexPrettyPrintCommand/Actionscript.useBraceStyle=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.targetPlatform=1.6
/instance/FlexPrettyPrintCommand/Actionscript.spacesInsideParens=0
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204/description=
/instance/org.eclipse.wst.jsdt.ui/fontPropagated=true
/instance/com.adobe.flash.profiler/com.adobe.flash.profiler.Builtins=false
/instance/FlexPrettyPrintCommand/MXML.tagsCanFormat=mx\:List,fx\:List,
/instance/FlexPrettyPrintCommand/MXML.maxLineLength=200
/profile/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_C\:_Program%20Files%20(x86)_Adobe_Adobe%20Flash%20Builder%204_.eclipseextension/uri=file\:/C\:/Program%20Files%20(x86)/Adobe/Adobe%20Flash%20Builder%204/.eclipseextension
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.VariableView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684">\r\n<PRESENTATION_CONTEXT_PROPERTIES IMemento.internal.id\="org.eclipse.debug.ui.VariableView"/>\r\n</VariablesViewMemento>
/instance/com.crispico.flower.mp.eclipse/automaticSynchronizationPreferance=true
/instance/FlexPrettyPrintCommand/Actionscript.keepElseIfOnSameLine=false
/instance/FlexPrettyPrintCommand/Actionscript.advancedWrappingElements=165
/instance/org.eclipse.wst.html.core/elemEndInvalidCase=1
/instance/FlexPrettyPrintCommand/ASRearr_SectionHeaderMap=\#\r\n\#Sat Jun 05 00\:42\:26 CEST 2010\r\nFunction\=type\\\=1|id\\\=Function|enabled\\\=true|text\\\= internal methods|endID\\\=Function|\r\nStatic\\ Function\=type\\\=1|id\\\=Static Function|enabled\\\=true|text\\\=   Static mathods|endID\\\=Static Function|\r\n
/instance/org.eclipse.wst.server.core/module-start-timeout=300000
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocations.migrated=true
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.user_view_bindings=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<viewBindings>\r\n<view id\="org.eclipse.debug.ui.VariableView">\r\n<perspective id\="com.adobe.flexbuilder.editors.mxml.ui.perspectives.development" userAction\="opened"/>\r\n</view>\r\n<view id\="org.eclipse.debug.ui.ExpressionView">\r\n<perspective id\="com.adobe.flexbuilder.editors.mxml.ui.perspectives.development" userAction\="opened"/>\r\n</view>\r\n<view id\="org.eclipse.ui.console.ConsoleView">\r\n<perspective id\="com.adobe.flexbuilder.editors.mxml.ui.perspectives.development" userAction\="opened"/>\r\n<perspective id\="org.tigris.subversion.subclipse.ui.svnPerspective" userAction\="opened"/>\r\n<perspective id\="org.eclipse.jdt.ui.JavaPerspective" userAction\="opened"/>\r\n<perspective id\="com.adobe.flash.profiler.ui.ProfilingPerspective" userAction\="closed"/>\r\n</view>\r\n</viewBindings>\r\n
*** Current Install Configuration:
Install configuration:
Last changed on Jul 1, 2010
Location: C:\Program Files (x86)\Adobe\Adobe Flash Builder 4
Profile timestamp: 1277972070339
Installable Units in the profile:
Id: ActionscriptInfoCollector, Version: 0.7.4
Id: FlexASDocGenCommand, Version: 0.7.4
Id: FlexPrettyPrintCommand, Version: 0.7.4
Id: FlexPrettyPrintCommandFeature.feature.group, Version: 0.7.4
Id: FlexPrettyPrintCommandFeature.feature.jar, Version: 0.7.4
Id: a.jre.javase, Version: 1.6.0
Id: com.adobe.coldfusion.rds.client, Version: 1.0.272885
Id: com.adobe.coldfusion.rds.client.nl1, Version: 1.0.1.v20100112266797
Id: com.adobe.flash.codemodel.core, Version: 4.0.1.277662
Id: com.adobe.flash.codemodel.osgi, Version: 4.0.1.277662
Id: com.adobe.flash.profiler, Version: 4.0.1.277662
Id: com.adobe.flash.profiler.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.DCDService, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.DCDService.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.ajaxbridge, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.ajaxbridge.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.as.editor, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.as.editor.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.axis2, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.axis2.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.codemodel, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.codemodel.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.crimson, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.crimson.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.css.editor, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.css.editor.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.dcrad, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.dcrad.derived, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.dcrad.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.debug, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.debug.e33, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.debug.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.debug.ui, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.debug.ui.actions, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.debug.ui.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.designview, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.designview.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.editorcore, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.editorcore.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.editors.derived, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.editors.derived.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.exportimport, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.exportimport.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.feature.core.feature.group, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.feature.core.feature.jar, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.feature.core.nl1.feature.group, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.feature.core.nl1.feature.jar, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.feature.standalone.feature.group, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.feature.standalone.feature.jar, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.feature.standalone.nl1.feature.group, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.feature.standalone.nl1.feature.jar, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.flashbridge, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.flashbridge.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.flex, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.flexunit, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.flexunit.derived, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.flexunit.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.help, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.help.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.importartwork, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.importartwork.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.json, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.launching.ui, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.launching.ui.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.monitors.network, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.monitors.network.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.multisdk, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.mxml.editor, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.mxml.editor.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.mxmlmodel, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.project, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.project.e35, Version: 1.0.0.201001080934
Id: com.adobe.flexbuilder.project.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.project.ui, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.project.ui.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.BlazeDSService, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.CFService, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.CFService.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.HTTPService, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.HTTPService.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.J2EEService, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.J2EEService.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.LCDSService, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.PHPService, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.PHPService.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.StaticContentService, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.StaticContentService.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.WEBService, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.WEBService.derived, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.services.WEBService.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.standalone, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.standalone.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.standalone.product, Version: 4.0.1
Id: com.adobe.flexbuilder.standalone.product_root.win32.win32.x86, Version: 4.0.1
Id: com.adobe.flexbuilder.tengine, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.tengine.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.ui, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.ui.nl1, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.utils.osnative, Version: 4.0.1.277662
Id: com.adobe.flexbuilder.utils.osnative.win, Version: 4.0.1.277662
Id: com.adobe.flexide.amt, Version: 4.0.1.277662
Id: com.adobe.flexide.as.core, Version: 4.0.1.277662
Id: com.adobe.flexide.as.core.nl1, Version: 4.0.1.277662
Id: com.adobe.flexide.communityhelp, Version: 4.0.1.277662
Id: com.adobe.flexide.communityhelp.nl1, Version: 4.0.1.277662
Id: com.adobe.flexide.css.core, Version: 4.0.1.277662
Id: com.adobe.flexide.css.core.nl1, Version: 4.0.1.277662
Id: com.adobe.flexide.designitems, Version: 4.0.1.277662
Id: com.adobe.flexide.editorcore, Version: 4.0.1.277662
Id: com.adobe.flexide.editorcore.nl1, Version: 4.0.1.277662
Id: com.adobe.flexide.embeddedplayer, Version: 4.0.1.277662
Id: com.adobe.flexide.exportimport, Version: 4.0.1.277662
Id: com.adobe.flexide.exportimport.nl1, Version: 4.0.1.277662
Id: com.adobe.flexide.externaleditors, Version: 4.0.1.277662
Id: com.adobe.flexide.externaleditors.nl1, Version: 4.0.1.277662
Id: com.adobe.flexide.feature.feature.group, Version: 4.0.1.277662
Id: com.adobe.flexide.feature.feature.jar, Version: 4.0.1.277662
Id: com.adobe.flexide.feature.nl1.feature.group, Version: 4.0.1.277662
Id: com.adobe.flexide.feature.nl1.feature.jar, Version: 4.0.1.277662
Id: com.adobe.flexide.fonts, Version: 4.0.1.277662
Id: com.adobe.flexide.launching, Version: 4.0.1.277662
Id: com.adobe.flexide.launching.nl1, Version: 4.0.1.277662
Id: com.adobe.flexide.multisdk.nl1, Version: 4.0.1.277662
Id: com.adobe.flexide.mxml.core, Version: 4.0.1.277662
Id: com.adobe.flexide.mxml.core.nl1, Version: 4.0.1.277662
Id: com.adobe.flexide.nativelibs, Version: 4.0.1.277662
Id: com.adobe.flexide.playerview, Version: 4.0.1.277662
Id: com.adobe.flexide.refactoring.core, Version: 4.0.1.277662
Id: com.adobe.flexide.refactoring.core.nl1, Version: 4.0.1.277662
Id: com.adobe.flexide.utils.feature.feature.group, Version: 4.0.1.277662
Id: com.adobe.flexide.utils.feature.feature.jar, Version: 4.0.1.277662
Id: com.adobe.model.core, Version: 1.0.2.v20100315273147
Id: com.collabnet.subversion.merge, Version: 2.1.0
Id: com.collabnet.subversion.merge.feature.feature.group, Version: 2.1.0
Id: com.collabnet.subversion.merge.feature.feature.jar, Version: 2.1.0
Id: com.crispico.flexbridge, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.dependencies.internal, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.eclipse, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.eclipse.compare.base, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.eclipse.compare.codesync, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.eclipse.feature.feature.group, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.eclipse.feature.feature.jar, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.eclipse.uml4as, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.metamodel.classmetamodel, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.metamodel.codesync, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.metamodel.codesyncas, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.metamodelset.uml4asfile, Version: 1.0.0.M0_2010-06-11
Id: com.crispico.flower.mp.propertieseditor, Version: 1.0.0.M0_2010-06-11
Id: com.ibm.icu, Version: 4.0.1.v20090822
Id: com.idefactory.enterprisehelp, Version: 1.0.8.beta
Id: com.idefactory.enterpriseide.feature.jar, Version: 1.0.8.beta3
Id: com.idefactory.fxsdk, Version: 1.0.1
Id: com.idefactory.rhino, Version: 1.0.0
Id: com.jcraft.jsch, Version: 0.1.41.v200903070017
Id: com.sun.jna, Version: 3.2.3
Id: com.sun.jna.feature.group, Version: 3.2.3
Id: com.sun.jna.feature.jar, Version: 3.2.3
Id: config.a.jre.javase, Version: 1.6.0
Id: java_cup.runtime, Version: 0.10.0.v200803061811
Id: javax.activation, Version: 1.1.0.v200906290531
Id: javax.mail, Version: 1.4.0.v200905040518
Id: javax.servlet, Version: 2.5.0.v200806031605
Id: javax.servlet.jsp, Version: 2.0.0.v200806031607
Id: javax.wsdl, Version: 1.5.1.v200806030408
Id: javax.xml, Version: 1.3.4.v200902170245
Id: javax.xml.rpc, Version: 1.1.0.v200905122109
Id: javax.xml.soap, Version: 1.2.0.v200905122109
Id: net.sourceforge.lpg.lpgjavaruntime, Version: 1.1.0.v200803061910
Id: org.apache.ant, Version: 1.7.1.v20090120-1145
Id: org.apache.axis, Version: 1.4.0.v200905122109
Id: org.apache.bcel, Version: 5.2.0.v200803061811
Id: org.apache.commons.codec, Version: 1.3.0.v20080530-1600
Id: org.apache.commons.collections, Version: 3.2.0.v200803061811
Id: org.apache.commons.discovery, Version: 0.2.0.v200905122109
Id: org.apache.commons.el, Version: 1.0.0.v200806031608
Id: org.apache.commons.httpclient, Version: 3.1.0.v20080605-1935
Id: org.apache.commons.jxpath, Version: 1.2.0.v20080604-1500
Id: org.apache.commons.lang, Version: 2.1.0.v200803061811
Id: org.apache.commons.lang, Version: 2.4.0.v20081016-1030
Id: org.apache.commons.logging, Version: 1.0.4.v200904062259
Id: org.apache.jasper, Version: 5.5.17.v200903231320
Id: org.apache.log4j, Version: 1.2.13.v200903072027
Id: org.apache.lucene, Version: 1.9.1.v20080530-1600
Id: org.apache.lucene.analysis, Version: 1.9.1.v20080530-1600
Id: org.apache.oro, Version: 2.0.8.v200903061218
Id: org.apache.velocity, Version: 1.5.0.v200905192330
Id: org.apache.wsil4j, Version: 1.0.0.v200901211807
Id: org.apache.xalan, Version: 2.7.1.v200905122109
Id: org.apache.xerces, Version: 2.9.0.v200909240008
Id: org.apache.xml.resolver, Version: 1.2.0.v200902170519
Id: org.apache.xml.serializer, Version: 2.7.1.v200902170519
Id: org.eclipse.ant.core, Version: 3.2.100.v20090817_r351
Id: org.eclipse.ant.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ant.ui, Version: 3.4.2.v20091204_r352
Id: org.eclipse.compare, Version: 3.5.0.I20090514-0808
Id: org.eclipse.compare.core, Version: 3.5.0.I20090430-0408
Id: org.eclipse.compare.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.compare.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.compare.win32, Version: 1.0.0.I20090430-0408
Id: org.eclipse.compare.win32.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.boot, Version: 3.1.100.v20080218
Id: org.eclipse.core.boot.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.commands, Version: 3.5.0.I20090525-2000
Id: org.eclipse.core.commands.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.contenttype, Version: 3.4.1.R35x_v20090826-0451
Id: org.eclipse.core.contenttype.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.databinding, Version: 1.2.0.M20090819-0800
Id: org.eclipse.core.databinding.beans, Version: 1.2.0.I20090525-2000
Id: org.eclipse.core.databinding.beans.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.databinding.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.databinding.observable, Version: 1.2.0.M20090902-0800
Id: org.eclipse.core.databinding.property, Version: 1.2.0.M20090819-0800
Id: org.eclipse.core.expressions, Version: 3.4.100.v20090429-1800
Id: org.eclipse.core.expressions.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.filebuffers, Version: 3.5.0.v20090526-2000
Id: org.eclipse.core.filebuffers.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.filesystem, Version: 1.2.0.v20090507
Id: org.eclipse.core.filesystem.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.filesystem.win32.x86, Version: 1.1.0.v20080604-1400
Id: org.eclipse.core.jobs, Version: 3.4.100.v20090429-1800
Id: org.eclipse.core.jobs.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.net, Version: 1.2.1.r35x_20090812-1200
Id: org.eclipse.core.net.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.net.win32.x86, Version: 1.0.0.I20080909
Id: org.eclipse.core.resources, Version: 3.5.1.R35x_v20090826-0451
Id: org.eclipse.core.resources.compatibility, Version: 3.4.0.v20090505
Id: org.eclipse.core.resources.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.resources.win32.x86, Version: 3.5.0.v20081020
Id: org.eclipse.core.runtime, Version: 3.5.0.v20090525
Id: org.eclipse.core.runtime.compatibility, Version: 3.2.0.v20090413
Id: org.eclipse.core.runtime.compatibility.auth, Version: 3.2.100.v20090413
Id: org.eclipse.core.runtime.compatibility.auth.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.runtime.compatibility.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.runtime.compatibility.registry, Version: 3.2.200.v20090429-1800
Id: org.eclipse.core.runtime.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.core.variables, Version: 3.2.200.v20090521
Id: org.eclipse.core.variables.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.cvs, Version: 1.0.300.v200909170800
Id: org.eclipse.cvs.feature.group, Version: 1.1.101.R35x_v20090811-7E79FEd9KKF5H2YDWFLLBL01A16
Id: org.eclipse.cvs.feature.jar, Version: 1.1.101.R35x_v20090811-7E79FEd9KKF5H2YDWFLLBL01A16
Id: org.eclipse.datatools.connectivity, Version: 1.1.3.v201001230803
Id: org.eclipse.datatools.connectivity.apache.derby, Version: 1.0.100.v200906020900
Id: org.eclipse.datatools.connectivity.apache.derby.dbdefinition, Version: 1.0.2.v200906161815
Id: org.eclipse.datatools.connectivity.apache.derby.ui, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.connectivity.console.profile, Version: 1.0.0.v200906020553
Id: org.eclipse.datatools.connectivity.db.generic, Version: 1.0.1.v200908130547
Id: org.eclipse.datatools.connectivity.db.generic.ui, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.connectivity.dbdefinition.genericJDBC, Version: 1.0.1.v200906161815
Id: org.eclipse.datatools.connectivity.feature.feature.group, Version: 1.7.2.v200909251450-7B7OANEn1Xi4gycmhPC6njFVDz0q
Id: org.eclipse.datatools.connectivity.feature.feature.jar, Version: 1.7.2.v200909251450-7B7OANEn1Xi4gycmhPC6njFVDz0q
Id: org.eclipse.datatools.connectivity.oda, Version: 3.2.2.v201001270833
Id: org.eclipse.datatools.connectivity.oda.consumer, Version: 3.2.2.v201001261113
Id: org.eclipse.datatools.connectivity.oda.design, Version: 3.2.2.v201001210350
Id: org.eclipse.datatools.connectivity.oda.design.ui, Version: 3.2.2.v201001210350
Id: org.eclipse.datatools.connectivity.oda.designer.feature.feature.group, Version: 1.7.2.v200909251450-7E7C7BDZRDIVDUKiEaXU
Id: org.eclipse.datatools.connectivity.oda.designer.feature.feature.jar, Version: 1.7.2.v200909251450-7E7C7BDZRDIVDUKiEaXU
Id: org.eclipse.datatools.connectivity.oda.feature.feature.group, Version: 1.7.2.v200909251450-7H797BCcNBHBBHMWDbRK
Id: org.eclipse.datatools.connectivity.oda.feature.feature.jar, Version: 1.7.2.v200909251450-7H797BCcNBHBBHMWDbRK
Id: org.eclipse.datatools.connectivity.oda.flatfile, Version: 3.1.1.v201001131420
Id: org.eclipse.datatools.connectivity.oda.flatfile.ui, Version: 3.1.1.v201001131420
Id: org.eclipse.datatools.connectivity.oda.profile, Version: 3.2.2.v201001210350
Id: org.eclipse.datatools.connectivity.oda.template.ui, Version: 3.2.0.v200906020553
Id: org.eclipse.datatools.connectivity.sqm.core, Version: 1.1.1.v201001180200
Id: org.eclipse.datatools.connectivity.sqm.core.ui, Version: 1.1.100.v200910270525
Id: org.eclipse.datatools.connectivity.sqm.server.ui, Version: 1.1.100.v200910270503
Id: org.eclipse.datatools.connectivity.ui, Version: 1.1.5.v201001190218
Id: org.eclipse.datatools.connectivity.ui.dse, Version: 1.1.3.v201001270323
Id: org.eclipse.datatools.doc.user, Version: 1.7.0.20090521092446
Id: org.eclipse.datatools.doc.user.feature.group, Version: 1.7.2.v200909251450-47C08w95ENAK6AFDFK7
Id: org.eclipse.datatools.doc.user.feature.jar, Version: 1.7.2.v200909251450-47C08w95ENAK6AFDFK7
Id: org.eclipse.datatools.enablement.apache.derby.feature.feature.group, Version: 1.7.2.v200909251450-7768dBmKDLfMjHuIFJW7SBI
Id: org.eclipse.datatools.enablement.apache.derby.feature.feature.jar, Version: 1.7.2.v200909251450-7768dBmKDLfMjHuIFJW7SBI
Id: org.eclipse.datatools.enablement.feature.feature.group, Version: 1.7.2.v200909251450-7J8i7UBWwSLRWdU50unZvFu_Pz0t
Id: org.eclipse.datatools.enablement.feature.feature.jar, Version: 1.7.2.v200909251450-7J8i7UBWwSLRWdU50unZvFu_Pz0t
Id: org.eclipse.datatools.enablement.finfo, Version: 1.5.1.v200906161800
Id: org.eclipse.datatools.enablement.hsqldb, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.hsqldb.dbdefinition, Version: 1.0.0.v200906161800
Id: org.eclipse.datatools.enablement.hsqldb.feature.feature.group, Version: 1.7.2.v200909251450-67B2AqGBJVKbGuH3GP7SBI
Id: org.eclipse.datatools.enablement.hsqldb.feature.feature.jar, Version: 1.7.2.v200909251450-67B2AqGBJVKbGuH3GP7SBI
Id: org.eclipse.datatools.enablement.hsqldb.ui, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.ibm.db2.iseries, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinition, Version: 1.0.3.v200906161800
Id: org.eclipse.datatools.enablement.ibm.db2.iseries.ui, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.ibm.db2.luw, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition, Version: 1.0.3.v200906161800
Id: org.eclipse.datatools.enablement.ibm.db2.luw.ui, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.ibm.db2.zseries, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinition, Version: 1.0.3.v200906161800
Id: org.eclipse.datatools.enablement.ibm.db2.zseries.ui, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.ibm.feature.feature.group, Version: 1.7.2.v200909251450-7F47HFC7sRTNSjXAYIRR
Id: org.eclipse.datatools.enablement.ibm.feature.feature.jar, Version: 1.7.2.v200909251450-7F47HFC7sRTNSjXAYIRR
Id: org.eclipse.datatools.enablement.ibm.informix, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.ibm.informix.dbdefinition, Version: 1.0.3.v200906161800
Id: org.eclipse.datatools.enablement.ibm.informix.ui, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.ibm.ui, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.ingres, Version: 1.0.0.v200906111150
Id: org.eclipse.datatools.enablement.ingres.dbdefinition, Version: 1.0.0.v200906161800
Id: org.eclipse.datatools.enablement.ingres.feature.feature.group, Version: 1.7.2.v200909251450-540AkF77g7VBLBPH7
Id: org.eclipse.datatools.enablement.ingres.feature.feature.jar, Version: 1.7.2.v200909251450-540AkF77g7VBLBPH7
Id: org.eclipse.datatools.enablement.ingres.ui, Version: 1.0.0.v200906111150
Id: org.eclipse.datatools.enablement.jdbc.feature.feature.group, Version: 1.7.2.v200909251450-4-29oB55W5P7G6RAH
Id: org.eclipse.datatools.enablement.jdbc.feature.feature.jar, Version: 1.7.2.v200909251450-4-29oB55W5P7G6RAH
Id: org.eclipse.datatools.enablement.jdt.classpath, Version: 1.0.1.v200909240342
Id: org.eclipse.datatools.enablement.jdt.feature.feature.group, Version: 1.7.2.v200909251450-2-07w311A1A351453
Id: org.eclipse.datatools.enablement.jdt.feature.feature.jar, Version: 1.7.2.v200909251450-2-07w311A1A351453
Id: org.eclipse.datatools.enablement.msft.feature.feature.group, Version: 1.7.2.v200909251450-542AkF78Y7SBU9UAB
Id: org.eclipse.datatools.enablement.msft.feature.feature.jar, Version: 1.7.2.v200909251450-542AkF78Y7SBU9UAB
Id: org.eclipse.datatools.enablement.msft.sqlserver, Version: 1.0.1.v201001180222
Id: org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition, Version: 1.0.0.v200906161800
Id: org.eclipse.datatools.enablement.msft.sqlserver.ui, Version: 1.0.1.v200908130512
Id: org.eclipse.datatools.enablement.mysql, Version: 1.0.2.v201002041110
Id: org.eclipse.datatools.enablement.mysql.dbdefinition, Version: 1.0.4.v200906161800
Id: org.eclipse.datatools.enablement.mysql.feature.feature.group, Version: 1.7.2.v200909251450-546AkF78Y7R9PAX87
Id: org.eclipse.datatools.enablement.mysql.feature.feature.jar, Version: 1.7.2.v200909251450-546AkF78Y7R9PAX87
Id: org.eclipse.datatools.enablement.mysql.ui, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.oda.designer.feature.feature.group, Version: 1.7.2.v200909251450-3328s7353356I4F53
Id: org.eclipse.datatools.enablement.oda.designer.feature.feature.jar, Version: 1.7.2.v200909251450-3328s7353356I4F53
Id: org.eclipse.datatools.enablement.oda.feature.feature.group, Version: 1.7.2.v200909251450-7A7T78DZRDFuD_KmFcNp
Id: org.eclipse.datatools.enablement.oda.feature.feature.jar, Version: 1.7.2.v200909251450-7A7T78DZRDFuD_KmFcNp
Id: org.eclipse.datatools.enablement.oda.ws, Version: 1.2.2.v201001131420
Id: org.eclipse.datatools.enablement.oda.ws.ui, Version: 1.2.2.v201001260400
Id: org.eclipse.datatools.enablement.oda.xml, Version: 1.2.1.v201001151620
Id: org.eclipse.datatools.enablement.oda.xml.ui, Version: 1.2.1.v201001191820
Id: org.eclipse.datatools.enablement.oracle, Version: 1.0.0.v200908130544
Id: org.eclipse.datatools.enablement.oracle.dbdefinition, Version: 1.0.100.v200906161800
Id: org.eclipse.datatools.enablement.oracle.feature.feature.group, Version: 1.7.2.v200909251450-548aAkF77g7XAO9aBB
Id: org.eclipse.datatools.enablement.oracle.feature.feature.jar, Version: 1.7.2.v200909251450-548aAkF77g7XAO9aBB
Id: org.eclipse.datatools.enablement.oracle.ui, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.postgresql, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.postgresql.dbdefinition, Version: 1.0.1.v200906161800
Id: org.eclipse.datatools.enablement.postgresql.feature.feature.group, Version: 1.7.2.v200909251450-542AkF77g7V9N9e77
Id: org.eclipse.datatools.enablement.postgresql.feature.feature.jar, Version: 1.7.2.v200909251450-542AkF77g7V9N9e77
Id: org.eclipse.datatools.enablement.postgresql.ui, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.sap.feature.feature.group, Version: 1.7.2.v200909251450-540AkF77g7V9N9e77
Id: org.eclipse.datatools.enablement.sap.feature.feature.jar, Version: 1.7.2.v200909251450-540AkF77g7V9N9e77
Id: org.eclipse.datatools.enablement.sap.maxdb, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.sap.maxdb.dbdefinition, Version: 1.0.0.v200906161800
Id: org.eclipse.datatools.enablement.sap.maxdb.ui, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.sqlite, Version: 1.0.0.v201002041110
Id: org.eclipse.datatools.enablement.sqlite.dbdefinition, Version: 1.0.1.v201002041110
Id: org.eclipse.datatools.enablement.sqlite.feature.feature.group, Version: 1.7.2.v200909251450-541AkF79P7N8NAQ97
Id: org.eclipse.datatools.enablement.sqlite.feature.feature.jar, Version: 1.7.2.v200909251450-541AkF79P7N8NAQ97
Id: org.eclipse.datatools.enablement.sqlite.ui, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.sybase, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.sybase.asa, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.sybase.asa.dbdefinition, Version: 1.0.0.v200906161800
Id: org.eclipse.datatools.enablement.sybase.asa.models, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.sybase.asa.schemaobjecteditor.examples, Version: 2.5.0.200810071
Id: org.eclipse.datatools.enablement.sybase.asa.ui, Version: 1.0.1.v200906111150
Id: org.eclipse.datatools.enablement.sybase.ase, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.sybase.ase.dbdefinition, Version: 1.0.0.v200906161800
Id: org.eclipse.datatools.enablement.sybase.ase.models, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.sybase.ase.ui, Version: 1.0.1.v200906020900
Id: org.eclipse.datatools.enablement.sybase.feature.feature.group, Version: 1.7.2.v200909251450-7E45F9NiNWvOOXxPdVT
Id: org.eclipse.datatools.enablement.sybase.feature.feature.jar, Version: 1.7.2.v200909251450-7E45F9NiNWvOOXxPdVT
Id: org.eclipse.datatools.enablement.sybase.models, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.enablement.sybase.ui, Version: 1.0.0.v200906090458
Id: org.eclipse.datatools.help, Version: 1.5.0.v200906020553
Id: org.eclipse.datatools.modelbase.dbdefinition, Version: 1.0.1.v200906022249
Id: org.eclipse.datatools.modelbase.derby, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.modelbase.feature.feature.group, Version: 1.7.2.v200909251450-77-5CcNBCtCcCQJYZl
Id: org.eclipse.datatools.modelbase.feature.feature.jar, Version: 1.7.2.v200909251450-77-5CcNBCtCcCQJYZl
Id: org.eclipse.datatools.modelbase.sql, Version: 1.0.3.v200912150851
Id: org.eclipse.datatools.modelbase.sql.edit, Version: 1.0.0.v200906022249
Id: org.eclipse.datatools.modelbase.sql.query, Version: 1.0.2.v201002020730
Id: org.eclipse.datatools.modelbase.sql.query.edit, Version: 1.0.0.v200906022249
Id: org.eclipse.datatools.modelbase.sql.xml.query, Version: 1.0.0.v200906022249
Id: org.eclipse.datatools.oda.cshelp, Version: 1.1.1.v200907031118
Id: org.eclipse.datatools.sqldevtools.data.feature.feature.group, Version: 1.7.2.v200909251450-613BgJ9AiBPASF_KN
Id: org.eclipse.datatools.sqldevtools.data.feature.feature.jar, Version: 1.7.2.v200909251450-613BgJ9AiBPASF_KN
Id: org.eclipse.datatools.sqldevtools.ddl.feature.feature.group, Version: 1.7.2.v200909251450-26178B02G8S_ILGJxNiTuSn
Id: org.eclipse.datatools.sqldevtools.ddl.feature.feature.jar, Version: 1.7.2.v200909251450-26178B02G8S_ILGJxNiTuSn
Id: org.eclipse.datatools.sqldevtools.ddlgen.feature.feature.group, Version: 1.7.2.v200909251450-7A-1F7RZHKFIwMhStRm
Id: org.eclipse.datatools.sqldevtools.ddlgen.feature.feature.jar, Version: 1.7.2.v200909251450-7A-1F7RZHKFIwMhStRm
Id: org.eclipse.datatools.sqldevtools.feature.feature.group, Version: 1.7.2.v200909251450-7N7q7GFDr_mX5M8JAs38u8wWDRWU
Id: org.eclipse.datatools.sqldevtools.feature.feature.jar, Version: 1.7.2.v200909251450-7N7q7GFDr_mX5M8JAs38u8wWDRWU
Id: org.eclipse.datatools.sqldevtools.parsers.feature.feature.group, Version: 1.7.2.v200909251450-602BgJ99q9_9OGXFJ
Id: org.eclipse.datatools.sqldevtools.parsers.feature.feature.jar, Version: 1.7.2.v200909251450-602BgJ99q9_9OGXFJ
Id: org.eclipse.datatools.sqldevtools.results.feature.feature.group, Version: 1.7.2.v200909251450-4029oB56N5I7C9J5C
Id: org.eclipse.datatools.sqldevtools.results.feature.feature.jar, Version: 1.7.2.v200909251450-4029oB56N5I7C9J5C
Id: org.eclipse.datatools.sqldevtools.schemaobjecteditor.feature.feature.group, Version: 1.7.2.v200909251450-42-8375LG5BJ93413
Id: org.eclipse.datatools.sqldevtools.schemaobjecteditor.feature.feature.jar, Version: 1.7.2.v200909251450-42-8375LG5BJ93413
Id: org.eclipse.datatools.sqldevtools.sqlbuilder.feature.feature.group, Version: 1.7.2.v200909251450-79-0EVVFIxGhLaMvL_
Id: org.eclipse.datatools.sqldevtools.sqlbuilder.feature.feature.jar, Version: 1.7.2.v200909251450-79-0EVVFIxGhLaMvL_
Id: org.eclipse.datatools.sqltools.common.ui, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.data.core, Version: 1.1.0.v200910161545
Id: org.eclipse.datatools.sqltools.data.ui, Version: 1.1.2.v200912080845
Id: org.eclipse.datatools.sqltools.db.derby, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.sqltools.db.derby.ui, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.sqltools.db.generic, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.sqltools.db.generic.ui, Version: 1.0.0.v200906020900
Id: org.eclipse.datatools.sqltools.ddlgen.ui, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.debugger.core, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.debugger.core.ui, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.editor.core, Version: 1.0.0.v201001150815
Id: org.eclipse.datatools.sqltools.editor.core.ui, Version: 1.0.0.v201001150815
Id: org.eclipse.datatools.sqltools.parsers.sql, Version: 1.0.1.v200906022302
Id: org.eclipse.datatools.sqltools.parsers.sql.lexer, Version: 1.0.1.v200906030654
Id: org.eclipse.datatools.sqltools.parsers.sql.query, Version: 1.0.1.v200906022302
Id: org.eclipse.datatools.sqltools.parsers.sql.xml.query, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.plan, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.result, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.result.ui, Version: 1.0.2.v201002011830
Id: org.eclipse.datatools.sqltools.routineeditor, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.routineeditor.ui, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.schemaobjecteditor, Version: 1.1.0.v200906022302
Id: org.eclipse.datatools.sqltools.schemaobjecteditor.ui, Version: 1.1.0.200810071
Id: org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages, Version: 1.1.0.200810071
Id: org.eclipse.datatools.sqltools.sql, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.sql.ui, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.sqlbuilder, Version: 1.0.0.v201001200600
Id: org.eclipse.datatools.sqltools.sqleditor, Version: 1.0.1.v200912241345
Id: org.eclipse.datatools.sqltools.sqlscrapbook, Version: 1.0.0.v200906022302
Id: org.eclipse.datatools.sqltools.tabledataeditor, Version: 1.0.0.v200906022302
Id: org.eclipse.debug.core, Version: 3.5.0.v20090526-1600
Id: org.eclipse.debug.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.debug.ui, Version: 3.5.1.v20090811_r351
Id: org.eclipse.debug.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.draw2d, Version: 3.5.2.v20091126-1908
Id: org.eclipse.draw2d.feature.group, Version: 3.5.2.v20100111-1352-4417w311A223702A19
Id: org.eclipse.draw2d.feature.jar, Version: 3.5.2.v20100111-1352-4417w311A223702A19
Id: org.eclipse.ecf, Version: 3.0.0.v20090831-1906
Id: org.eclipse.ecf.filetransfer, Version: 3.0.0.v20090831-1906
Id: org.eclipse.ecf.identity, Version: 3.0.0.v20090831-1906
Id: org.eclipse.ecf.provider.filetransfer, Version: 3.0.1.v20090831-1906
Id: org.eclipse.ecf.provider.filetransfer.httpclient, Version: 3.0.1.v20090831-1906
Id: org.eclipse.ecf.provider.filetransfer.httpclient.ssl, Version: 1.0.0.v20090831-1906
Id: org.eclipse.ecf.provider.filetransfer.ssl, Version: 1.0.0.v20090831-1906
Id: org.eclipse.ecf.ssl, Version: 1.0.0.v20090831-1906
Id: org.eclipse.emf, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ant, Version: 2.4.0.v200906151043
Id: org.eclipse.emf.codegen, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.codegen.ecore, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.codegen.ecore.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.codegen.ecore.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.codegen.ecore.ui, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.codegen.ecore.ui.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.codegen.ecore.ui.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.codegen.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.codegen.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.codegen.ui, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.codegen.ui.feature.group, Version: 2.4.0.v200906151043
Id: org.eclipse.emf.codegen.ui.feature.jar, Version: 2.4.0.v200906151043
Id: org.eclipse.emf.common, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.common.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.common.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.common.ui, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.common.ui.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.common.ui.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.converter, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.converter.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.converter.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.databinding, Version: 1.1.0.v200906151043
Id: org.eclipse.emf.databinding.edit, Version: 1.1.0.v200906151043
Id: org.eclipse.emf.databinding.edit.feature.group, Version: 1.1.0.v200906151043
Id: org.eclipse.emf.databinding.edit.feature.jar, Version: 1.1.0.v200906151043
Id: org.eclipse.emf.databinding.feature.group, Version: 1.1.0.v200906151043
Id: org.eclipse.emf.databinding.feature.jar, Version: 1.1.0.v200906151043
Id: org.eclipse.emf.ecore, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ecore.change, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ecore.change.edit, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ecore.edit, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ecore.edit.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ecore.edit.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ecore.editor, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ecore.editor.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ecore.editor.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ecore.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ecore.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.ecore.xmi, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.edit, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.edit.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.edit.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.edit.ui, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.edit.ui.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.edit.ui.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.exporter, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.importer, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.importer.ecore, Version: 2.4.0.v200906151043
Id: org.eclipse.emf.importer.java, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.importer.rose, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ecore, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ecore.editor, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ecore.editor.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ecore.editor.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ecore.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ecore.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ecore2ecore, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ecore2ecore.editor, Version: 2.4.0.v200906151043
Id: org.eclipse.emf.mapping.ecore2xml, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ecore2xml.ui, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ui, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ui.feature.group, Version: 2.5.0.v200906151043
Id: org.eclipse.emf.mapping.ui.feature.jar, Version: 2.5.0.v200906151043
Id: org.eclipse.equinox.app, Version: 1.2.0.v20090520-1800
Id: org.eclipse.equinox.common, Version: 3.5.1.R35x_v20090807-1100
Id: org.eclipse.equinox.common.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.concurrent, Version: 1.0.1.R35x_v20100209
Id: org.eclipse.equinox.ds, Version: 1.1.1.R35x_v20090806
Id: org.eclipse.equinox.ds.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.frameworkadmin, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.frameworkadmin.equinox, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.http.jetty, Version: 2.0.0.v20090520-1800
Id: org.eclipse.equinox.http.registry, Version: 1.0.200.v20090520-1800
Id: org.eclipse.equinox.http.registry.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.http.servlet, Version: 1.0.200.v20090520-1800
Id: org.eclipse.equinox.http.servlet.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.jsp.jasper, Version: 1.0.200.v20090520-1800
Id: org.eclipse.equinox.jsp.jasper.registry, Version: 1.0.100.v20090520-1800
Id: org.eclipse.equinox.launcher, Version: 1.0.201.R35x_v20090715
Id: org.eclipse.equinox.launcher.win32.win32.x86, Version: 1.0.200.v20090519
Id: org.eclipse.equinox.p2.artifact.repository, Version: 1.0.101.R35x_v20090721
Id: org.eclipse.equinox.p2.artifact.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.console, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.p2.console.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.core, Version: 1.0.101.R35x_v20090819
Id: org.eclipse.equinox.p2.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.director, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.p2.director.app, Version: 1.0.100.v20090521-1912
Id: org.eclipse.equinox.p2.director.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.directorywatcher, Version: 1.0.100.v20090525
Id: org.eclipse.equinox.p2.engine, Version: 1.0.101.R35x_v20090825
Id: org.eclipse.equinox.p2.engine.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.exemplarysetup, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.p2.exemplarysetup.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.extensionlocation, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.p2.extensionlocation.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.garbagecollector, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.p2.garbagecollector.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.jarprocessor, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.p2.jarprocessor.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.metadata, Version: 1.0.100.v20090525
Id: org.eclipse.equinox.p2.metadata.generator, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.p2.metadata.generator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.metadata.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.metadata.repository, Version: 1.0.101.R35x_v20090812
Id: org.eclipse.equinox.p2.metadata.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.publisher, Version: 1.0.0.v20090527-1812
Id: org.eclipse.equinox.p2.publisher.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.reconciler.dropins, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.p2.reconciler.dropins.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.repository, Version: 1.0.1.v20090901-1041
Id: org.eclipse.equinox.p2.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.repository.tools, Version: 1.0.1.R35x_v20090806
Id: org.eclipse.equinox.p2.repository.tools.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.touchpoint.eclipse, Version: 1.0.101.R35x_20090820-1821
Id: org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.touchpoint.natives, Version: 1.0.101.R35x_v20090806
Id: org.eclipse.equinox.p2.touchpoint.natives.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.ui, Version: 1.0.101.R35x_v20090819
Id: org.eclipse.equinox.p2.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.ui.sdk, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.p2.ui.sdk.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.ui.sdk.scheduler, Version: 1.0.0.v20090520-1905
Id: org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.updatechecker, Version: 1.1.0.v20090520-1905
Id: org.eclipse.equinox.p2.updatechecker.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.updatesite, Version: 1.0.100.v20090525
Id: org.eclipse.equinox.p2.updatesite.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.p2.user.ui.feature.group, Version: 1.1.1.R35x_v20090811-7u6FbEFYXk1qWdbS0gnpRg2932
Id: org.eclipse.equinox.p2.user.ui.feature.jar, Version: 1.1.1.R35x_v20090811-7u6FbEFYXk1qWdbS0gnpRg2932
Id: org.eclipse.equinox.preferences, Version: 3.2.300.v20090520-1800
Id: org.eclipse.equinox.preferences.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.registry, Version: 3.4.100.v20090520-1800
Id: org.eclipse.equinox.registry.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.security, Version: 1.0.100.v20090520-1800
Id: org.eclipse.equinox.security.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.security.ui, Version: 1.0.100.v20090520-1800
Id: org.eclipse.equinox.security.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.equinox.security.win32.x86, Version: 1.0.100.v20090520-1800
Id: org.eclipse.equinox.simpleconfigurator, Version: 1.0.101.R35x_v20090807-1100
Id: org.eclipse.equinox.simpleconfigurator.manipulator, Version: 1.0.100.v20090520-1905
Id: org.eclipse.equinox.util, Version: 1.0.100.v20090520-1800
Id: org.eclipse.gef, Version: 3.5.1.v20090910-2020
Id: org.eclipse.gef.feature.group, Version: 3.5.2.v20100111-1352-777928194B66D5D476C33B2A
Id: org.eclipse.gef.feature.jar, Version: 3.5.2.v20100111-1352-777928194B66D5D476C33B2A
Id: org.eclipse.help, Version: 3.4.1.v20090805_35x
Id: org.eclipse.help.appserver, Version: 3.1.400.v20090429_1800
Id: org.eclipse.help.appserver.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.help.base, Version: 3.4.0.v200909170800
Id: org.eclipse.help.base.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.help.feature.group, Version: 1.1.1.R35x_v20090811-7e7eFAnFEx2XZoYz0uPgIfwD
Id: org.eclipse.help.feature.jar, Version: 1.1.1.R35x_v20090811-7e7eFAnFEx2XZoYz0uPgIfwD
Id: org.eclipse.help.ui, Version: 3.4.1.v20090819_35x
Id: org.eclipse.help.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.help.webapp, Version: 3.4.1.v20090819_35x
Id: org.eclipse.help.webapp.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.jdt, Version: 3.5.2.v201002111343
Id: org.eclipse.jdt.apt.core, Version: 3.3.202.R35x_v20091130-2300
Id: org.eclipse.jdt.apt.pluggable.core, Version: 1.0.201.R35x_v20090925-1100
Id: org.eclipse.jdt.apt.ui, Version: 3.3.200.v20090930-2100_R35x
Id: org.eclipse.jdt.compiler.apt, Version: 1.0.201.R35x_v20090925-1100
Id: org.eclipse.jdt.compiler.tool, Version: 1.0.100.v_981_R35x
Id: org.eclipse.jdt.core, Version: 3.5.2.v_981_R35x
Id: org.eclipse.jdt.core.manipulation, Version: 1.3.0.v20090603
Id: org.eclipse.jdt.debug, Version: 3.5.0.v20090526
Id: org.eclipse.jdt.debug.ui, Version: 3.4.1.v20090811_r351
Id: org.eclipse.jdt.doc.user, Version: 3.5.2.r352_v20091015
Id: org.eclipse.jdt.feature.group, Version: 3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6
Id: org.eclipse.jdt.feature.jar, Version: 3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6
Id: org.eclipse.jdt.junit, Version: 3.5.2.r352_v20100113-0800
Id: org.eclipse.jdt.junit.runtime, Version: 3.4.100.v20090513-2000
Id: org.eclipse.jdt.junit4.runtime, Version: 1.1.0.v20090513-2000
Id: org.eclipse.jdt.launching, Version: 3.5.1.v20100108_r352
Id: org.eclipse.jdt.ui, Version: 3.5.2.r352_v20100106-0800
Id: org.eclipse.jdt_root, Version: 3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6
Id: org.eclipse.jem, Version: 2.0.301.v201001252130
Id: org.eclipse.jem.proxy, Version: 2.0.201.v200908101600
Id: org.eclipse.jem.util, Version: 2.0.201.v201001252130
Id: org.eclipse.jem.util.source, Version: 2.0.201.v201001252130
Id: org.eclipse.jem.workbench, Version: 2.0.201.v200911302230
Id: org.eclipse.jface, Version: 3.5.1.M20090826-0800
Id: org.eclipse.jface.databinding, Version: 1.3.1.M20090826-0800
Id: org.eclipse.jface.databinding.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.jface.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.jface.text, Version: 3.5.1.r351_v20090708-0800
Id: org.eclipse.jface.text.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.jpt.branding, Version: 2.2.2.v200911250220
Id: org.eclipse.jpt.branding.source, Version: 2.2.2.v200911250220
Id: org.eclipse.jpt.core, Version: 2.2.1.v200908270220
Id: org.eclipse.jpt.core.source, Version: 2.2.1.v200908270220
Id: org.eclipse.jpt.db, Version: 1.2.102.v200911250220
Id: org.eclipse.jpt.db.source, Version: 1.2.102.v200911250220
Id: org.eclipse.jpt.db.ui, Version: 1.1.100.v200906070220
Id: org.eclipse.jpt.db.ui.source, Version: 1.1.100.v200906070220
Id: org.eclipse.jpt.doc.isv, Version: 1.2.0.v200906050220
Id: org.eclipse.jpt.doc.user, Version: 1.1.1.v200908270220
Id: org.eclipse.jpt.eclipselink.branding, Version: 2.2.2.v200911250220
Id: org.eclipse.jpt.eclipselink.branding.source, Version: 2.2.2.v200911250220
Id: org.eclipse.jpt.eclipselink.core, Version: 1.2.0.v200905310000
Id: org.eclipse.jpt.eclipselink.core.ddlgen, Version: 1.0.200.v200906070220
Id: org.eclipse.jpt.eclipselink.core.ddlgen.source, Version: 1.0.200.v200906070220
Id: org.eclipse.jpt.eclipselink.core.source, Version: 1.2.0.v200905310000
Id: org.eclipse.jpt.eclipselink.feature.feature.group, Version: 2.2.2.v200911250220-65A9AkF77g8OFL7BB7
Id: org.eclipse.jpt.eclipselink.feature.feature.jar, Version: 2.2.2.v200911250220-65A9AkF77g8OFL7BB7
Id: org.eclipse.jpt.eclipselink.feature.source.feature.group, Version: 2.2.2.v200911250220-65A9AkF77g8OFL7BB7
Id: org.eclipse.jpt.eclipselink.feature.source.feature.jar, Version: 2.2.2.v200911250220-65A9AkF77g8OFL7BB7
Id: org.eclipse.jpt.eclipselink.ui, Version: 1.2.0.v200905310000
Id: org.eclipse.jpt.eclipselink.ui.source, Version: 1.2.0.v200905310000
Id: org.eclipse.jpt.eclipselink_sdk.feature.feature.group, Version: 2.2.2.v200911250220-53383ADCMoJCFjDTINGJOJBlG88h
Id: org.eclipse.jpt.eclipselink_sdk.feature.feature.jar, Version: 2.2.2.v200911250220-53383ADCMoJCFjDTINGJOJBlG88h
Id: org.eclipse.jpt.feature.feature.group, Version: 2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je
Id: org.eclipse.jpt.feature.feature.jar, Version: 2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je
Id: org.eclipse.jpt.feature.source.feature.group, Version: 2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je
Id: org.eclipse.jpt.feature.source.feature.jar, Version: 2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je
Id: org.eclipse.jpt.gen, Version: 1.3.2.v201001290220
Id: org.eclipse.jpt.gen.source, Version: 1.3.2.v201001290220
Id: org.eclipse.jpt.ui, Version: 2.2.2.v200911250220
Id: org.eclipse.jpt.ui.source, Version: 2.2.2.v200911250220
Id: org.eclipse.jpt.utility, Version: 1.4.0.v200905310000
Id: org.eclipse.jpt.utility.source, Version: 1.4.0.v200905310000
Id: org.eclipse.jpt_sdk.feature.feature.group, Version: 2.2.2.v200911250220-65390UCTXVRIQtYa5VM2gvF9wCCp
Id: org.eclipse.jpt_sdk.feature.feature.jar, Version: 2.2.2.v200911250220-65390UCTXVRIQtYa5VM2gvF9wCCp
Id: org.eclipse.jsch.core, Version: 1.1.100.I20090430-0408
Id: org.eclipse.jsch.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.jsch.ui, Version: 1.1.200.I20090430-0408
Id: org.eclipse.jsch.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.jst.common.annotations.controller, Version: 1.1.100.v200805140020
Id: org.eclipse.jst.common.annotations.core, Version: 1.1.200.v201001272230
Id: org.eclipse.jst.common.frameworks, Version: 1.1.301.v201001252130
Id: org.eclipse.jst.common.project.facet.core, Version: 1.4.1.v200911141836
Id: org.eclipse.jst.common.project.facet.ui, Version: 1.4.1.v200912011928
Id: org.eclipse.jst.ejb.doc.user, Version: 1.1.100.v200810092245
Id: org.eclipse.jst.ejb.ui, Version: 1.1.301.v200908131325
Id: org.eclipse.jst.ejb.ui.infopop, Version: 1.0.200.v200905141725
Id: org.eclipse.jst.ejb.ui.source, Version: 1.1.301.v200908131325
Id: org.eclipse.jst.enterprise_core.feature.feature.group, Version: 3.1.1.v200908101600-52FGEAkF7AG7CDLCFIE
Id: org.eclipse.jst.enterprise_core.feature.feature.jar, Version: 3.1.1.v200908101600-52FGEAkF7AG7CDLCFIE
Id: org.eclipse.jst.enterprise_core.feature.source.feature.group, Version: 3.1.1.v200908101600-52FGEAkF7AG7CDLCFIE
Id: org.eclipse.jst.enterprise_core.feature.source.feature.jar, Version: 3.1.1.v200908101600-52FGEAkF7AG7CDLCFIE
Id: org.eclipse.jst.enterprise_sdk.feature.feature.group, Version: 3.1.1.v200908101600-771184eAHSuuJTW3Ue6ZhBIyV8tu
Id: org.eclipse.jst.enterprise_sdk.feature.feature.jar, Version: 3.1.1.v200908101600-771184eAHSuuJTW3Ue6ZhBIyV8tu
Id: org.eclipse.jst.enterprise_ui.feature.feature.group, Version: 3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq
Id: org.eclipse.jst.enterprise_ui.feature.feature.jar, Version: 3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq
Id: org.eclipse.jst.enterprise_ui.feature.source.feature.group, Version: 3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq
Id: org.eclipse.jst.enterprise_ui.feature.source.feature.jar, Version: 3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq
Id: org.eclipse.jst.enterprise_userdoc.feature.feature.group, Version: 3.1.0.v200809051357-62FIXBgJ99nBPBjIHN_
Id: org.eclipse.jst.enterprise_userdoc.feature.feature.jar, Version: 3.1.0.v200809051357-62FIXBgJ99nBPBjIHN_
Id: org.eclipse.jst.j2ee, Version: 1.1.302.v201004131604
Id: org.eclipse.jst.j2ee.core, Version: 1.1.301.v200911302230
Id: org.eclipse.jst.j2ee.doc.user, Version: 1.1.100.v200810071436
Id: org.eclipse.jst.j2ee.ejb, Version: 1.1.301.v201001252130
Id: org.eclipse.jst.j2ee.ejb.annotation.model, Version: 1.1.102.v200805140020
Id: org.eclipse.jst.j2ee.ejb.annotation.model.source, Version: 1.1.102.v200805140020
Id: org.eclipse.jst.j2ee.ejb.annotations.emitter, Version: 1.1.102.v200805140135
Id: org.eclipse.jst.j2ee.ejb.annotations.emitter.source, Version: 1.1.102.v200805140135
Id: org.eclipse.jst.j2ee.ejb.annotations.ui, Version: 1.1.102.v200805140020
Id: org.eclipse.jst.j2ee.ejb.annotations.ui.source, Version: 1.1.102.v200805140020
Id: org.eclipse.jst.j2ee.ejb.annotations.xdoclet, Version: 1.2.0.v200805140020
Id: org.eclipse.jst.j2ee.ejb.annotations.xdoclet.source, Version: 1.2.0.v200805140020
Id: org.eclipse.jst.j2ee.ejb.source, Version: 1.1.301.v201001252130
Id: org.eclipse.jst.j2ee.infopop, Version: 1.0.300.v200805140415
Id: org.eclipse.jst.j2ee.jca, Version: 1.1.301.v201001252130
Id: org.eclipse.jst.j2ee.jca.source, Version: 1.1.301.v201001252130
Id: org.eclipse.jst.j2ee.jca.ui, Version: 1.1.300.v200809052300
Id: org.eclipse.jst.j2ee.jca.ui.source, Version: 1.1.300.v200809052300
Id: org.eclipse.jst.j2ee.navigator.ui, Version: 1.1.301.v201001252130
Id: org.eclipse.jst.j2ee.navigator.ui.source, Version: 1.1.301.v201001252130
Id: org.eclipse.jst.j2ee.ui, Version: 1.1.301.v201001252130
Id: org.eclipse.jst.j2ee.ui.source, Version: 1.1.301.v201001252130
Id: org.eclipse.jst.j2ee.web, Version: 1.1.301.v200911302230
Id: org.eclipse.jst.j2ee.webservice, Version: 1.1.300.v200901220600
Id: org.eclipse.jst.j2ee.webservice.source, Version: 1.1.300.v200901220600
Id: org.eclipse.jst.j2ee.webservice.ui, Version: 1.1.300.v200902052230
Id: org.eclipse.jst.j2ee.webservice.ui.source, Version: 1.1.300.v200902052230
Id: org.eclipse.jst.j2ee.xdoclet.runtime, Version: 1.1.102.v200805140135
Id: org.eclipse.jst.j2ee.xdoclet.runtime.source, Version: 1.1.102.v200805140135
Id: org.eclipse.jst.jee, Version: 1.0.201.v201002021055
Id: org.eclipse.jst.jee.ejb, Version: 1.0.201.v201002021057
Id: org.eclipse.jst.jee.ejb.source, Version: 1.0.201.v201002021057
Id: org.eclipse.jst.jee.ui, Version: 1.0.201.v201002021208
Id: org.eclipse.jst.jee.ui.source, Version: 1.0.201.v201002021208
Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport, Version: 1.1.0.v20090525
Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport.feature.feature.group, Version: 2.2.0.v20090517-20-7w311A1636
Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport.feature.feature.jar, Version: 2.2.0.v20090517-20-7w311A1636
Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport.feature.source.feature.group, Version: 2.2.0.v20090517-20-7w311A1636
Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport.feature.source.feature.jar, Version: 2.2.0.v20090517-20-7w311A1636
Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport.source, Version: 1.1.0.v20090525
Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport_sdk.feature.feature.group, Version: 2.2.0.v20090310-53-8-52B6695K3B688x422B2747
Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport_sdk.feature.feature.jar, Version: 2.2.0.v20090310-53-8-52B6695K3B688x422B2747
Id: org.eclipse.jst.jsf.common, Version: 1.1.9.v201001271707
Id: org.eclipse.jst.jsf.common.runtime, Version: 1.0.201.v20090205
Id: org.eclipse.jst.jsf.common.ui, Version: 1.1.1.v20081209
Id: org.eclipse.jst.jsf.core, Version: 1.2.5.v201001271707
Id: org.eclipse.jst.jsf.facesconfig, Version: 1.1.3.v20090902
Id: org.eclipse.jst.jsp.core, Version: 1.2.204.v201001270045
Id: org.eclipse.jst.jsp.ui, Version: 1.1.401.v200908111935
Id: org.eclipse.jst.jsp.ui.infopop, Version: 1.0.100.v200805301545
Id: org.eclipse.jst.pagedesigner, Version: 1.2.3.v20100211
Id: org.eclipse.jst.pagedesigner.jsf.ui, Version: 1.1.4.v20100203
Id: org.eclipse.jst.pagedesigner.jsf.ui.source, Version: 1.1.4.v20100203
Id: org.eclipse.jst.pagedesigner.jsp.core, Version: 1.1.3.v201002111131
Id: org.eclipse.jst.pagedesigner.jsp.core.source, Version: 1.1.3.v201002111131
Id: org.eclipse.jst.pagedesigner.source, Version: 1.2.3.v20100211
Id: org.eclipse.jst.server.core, Version: 1.2.1.v20100127
Id: org.eclipse.jst.servlet.ui, Version: 1.1.301.v200908101600
Id: org.eclipse.jst.servlet.ui.infopop, Version: 1.0.300.v200805140415
Id: org.eclipse.jst.servlet.ui.source, Version: 1.1.301.v200908101600
Id: org.eclipse.jst.webpageeditor.feature.feature.group, Version: 2.2.2.v201001271707-43799oB5855B7A2242
Id: org.eclipse.jst.webpageeditor.feature.feature.jar, Version: 2.2.2.v201001271707-43799oB5855B7A2242
Id: org.eclipse.jst.webpageeditor.feature.source.feature.group, Version: 2.2.2.v201001271707-43799oB5855B7A2242
Id: org.eclipse.jst.webpageeditor.feature.source.feature.jar, Version: 2.2.2.v201001271707-43799oB5855B7A2242
Id: org.eclipse.jst.webpageeditor_sdk.feature.feature.group, Version: 2.2.2.v201001271707-533818ADCrFAI9FEHC98EEApC696
Id: org.eclipse.jst.webpageeditor_sdk.feature.feature.jar, Version: 2.2.2.v201001271707-533818ADCrFAI9FEHC98EEApC696
Id: org.eclipse.jst.ws, Version: 1.0.407.v200905191120
Id: org.eclipse.jst.ws.axis.consumption.core, Version: 1.0.306.v200810082309
Id: org.eclipse.jst.ws.axis.consumption.core.source, Version: 1.0.306.v200810082309
Id: org.eclipse.jst.ws.axis.consumption.ui, Version: 1.0.405.v200901261650
Id: org.eclipse.jst.ws.axis.consumption.ui.source, Version: 1.0.405.v200901261650
Id: org.eclipse.jst.ws.axis.creation.ui, Version: 1.0.406.v200903031852
Id: org.eclipse.jst.ws.axis.creation.ui.source, Version: 1.0.406.v200903031852
Id: org.eclipse.jst.ws.axis.infopop, Version: 1.0.300.v200805140230
Id: org.eclipse.jst.ws.axis.ui.doc.user, Version: 1.1.0.v200806092139
Id: org.eclipse.jst.ws.axis2.consumption.core, Version: 1.0.104.v200810151442
Id: org.eclipse.jst.ws.axis2.consumption.core.source, Version: 1.0.104.v200810151442
Id: org.eclipse.jst.ws.axis2.consumption.ui, Version: 1.0.102.v200807232000
Id: org.eclipse.jst.ws.axis2.consumption.ui.source, Version: 1.0.102.v200807232000
Id: org.eclipse.jst.ws.axis2.core, Version: 1.0.104.v200810151442
Id: org.eclipse.jst.ws.axis2.core.source, Version: 1.0.104.v200810151442
Id: org.eclipse.jst.ws.axis2.creation.core, Version: 1.0.105.v200901220134
Id: org.eclipse.jst.ws.axis2.creation.core.source, Version: 1.0.105.v200901220134
Id: org.eclipse.jst.ws.axis2.creation.ui, Version: 1.0.103.v200807162242
Id: org.eclipse.jst.ws.axis2.creation.ui.source, Version: 1.0.103.v200807162242
Id: org.eclipse.jst.ws.axis2.ui, Version: 1.0.302.v200905260749
Id: org.eclipse.jst.ws.axis2.ui.doc.user, Version: 1.0.1.v200807302329
Id: org.eclipse.jst.ws.axis2.ui.source, Version: 1.0.302.v200905260749
Id: org.eclipse.jst.ws.axis2tools.feature.feature.group, Version: 1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe
Id: org.eclipse.jst.ws.axis2tools.feature.feature.jar, Version: 1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe
Id: org.eclipse.jst.ws.axis2tools.feature.source.feature.group, Version: 1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe
Id: org.eclipse.jst.ws.axis2tools.feature.source.feature.jar, Version: 1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe
Id: org.eclipse.jst.ws.axis2tools_sdk.feature.feature.group, Version: 1.1.0.v200905242110-31-84D2INsLdYIIAIfZoNpmVE_SE
Id: org.eclipse.jst.ws.axis2tools_sdk.feature.feature.jar, Version: 1.1.0.v200905242110-31-84D2INsLdYIIAIfZoNpmVE_SE
Id: org.eclipse.jst.ws.consumption, Version: 1.0.408.v200911241817
Id: org.eclipse.jst.ws.consumption.infopop, Version: 1.0.300.v200805140230
Id: org.eclipse.jst.ws.consumption.source, Version: 1.0.408.v200911241817
Id: org.eclipse.jst.ws.consumption.ui, Version: 1.1.106.v200911241851
Id: org.eclipse.jst.ws.consumption.ui.doc.user, Version: 1.0.550.v200901232040
Id: org.eclipse.jst.ws.consumption.ui.source, Version: 1.1.106.v200911241851
Id: org.eclipse.jst.ws.creation.ejb.ui, Version: 1.0.200.v200805140230
Id: org.eclipse.jst.ws.creation.ejb.ui.source, Version: 1.0.200.v200805140230
Id: org.eclipse.jst.ws.creation.ui, Version: 1.0.409.v200911241856
Id: org.eclipse.jst.ws.creation.ui.source, Version: 1.0.409.v200911241856
Id: org.eclipse.jst.ws.doc.user, Version: 1.0.500.v200809092107
Id: org.eclipse.jst.ws.infopop, Version: 1.0.300.v200805140230
Id: org.eclipse.jst.ws.source, Version: 1.0.407.v200905191120
Id: org.eclipse.jst.ws.uddiregistry, Version: 1.0.400.v200901261650
Id: org.eclipse.jst.ws.uddiregistry.source, Version: 1.0.400.v200901261650
Id: org.eclipse.jst.ws.ui, Version: 1.0.402.v200903111822
Id: org.eclipse.jst.ws.ui.source, Version: 1.0.402.v200903111822
Id: org.eclipse.ltk.core.refactoring, Version: 3.5.0.v20090513-2000
Id: org.eclipse.ltk.core.refactoring.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ltk.ui.refactoring, Version: 3.4.100.v20090604
Id: org.eclipse.ltk.ui.refactoring.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.osgi, Version: 3.5.1.R35x_v20090827
Id: org.eclipse.osgi.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.osgi.services, Version: 3.2.0.v20090520-1800
Id: org.eclipse.osgi.services.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.osgi.util, Version: 3.2.0.v20090520-1800
Id: org.eclipse.osgi.util.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.pde, Version: 3.4.100.v201002111343
Id: org.eclipse.pde.api.tools, Version: 1.0.101.v20090714
Id: org.eclipse.pde.api.tools.ee.javase16, Version: 1.0.0.v20090407-1030
Id: org.eclipse.pde.api.tools.ui, Version: 1.0.101.v20090820
Id: org.eclipse.pde.build, Version: 3.5.2.R35x_20100114
Id: org.eclipse.pde.core, Version: 3.5.101.v20100104
Id: org.eclipse.pde.doc.user, Version: 3.5.0.v20090818
Id: org.eclipse.pde.ds.core, Version: 1.0.1.v20100118
Id: org.eclipse.pde.ds.ui, Version: 1.0.0.v20100209-maintenance
Id: org.eclipse.pde.feature.group, Version: 3.5.2.R35x_v20100119-7Z7_FA2FDX-aXQYWqYDBz-z0qufo
Id: org.eclipse.pde.feature.jar, Version: 3.5.2.R35x_v20100119-7Z7_FA2FDX-aXQYWqYDBz-z0qufo
Id: org.eclipse.pde.junit.runtime, Version: 3.4.0.v20090527
Id: org.eclipse.pde.runtime, Version: 3.4.100.v20090731
Id: org.eclipse.pde.ua.core, Version: 1.0.0.v20090429-1800
Id: org.eclipse.pde.ua.ui, Version: 1.0.0.v20090511
Id: org.eclipse.pde.ui, Version: 3.5.1.v201001121200
Id: org.eclipse.pde.ui.templates, Version: 3.4.100.v20090527
Id: org.eclipse.platform, Version: 3.3.201.v200909170800
Id: org.eclipse.platform.doc.user, Version: 3.5.1.r351_v20090821-0800
Id: org.eclipse.platform.doc.user.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.platform.feature.group, Version: 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7
Id: org.eclipse.platform.feature.jar, Version: 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7
Id: org.eclipse.platform.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.rcp, Version: 3.5.0.v200909170800
Id: org.eclipse.rcp.feature.group, Version: 3.5.1.R35x_v20090811-9SA0FxVFqE70OL1ARMrfcO6e7BA6
Id: org.eclipse.rcp.feature.jar, Version: 3.5.1.R35x_v20090811-9SA0FxVFqE70OL1ARMrfcO6e7BA6
Id: org.eclipse.search, Version: 3.5.1.r351_v20090708-0800
Id: org.eclipse.search.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.servertools.doc.isv, Version: 1.0.100.v20090414
Id: org.eclipse.swt, Version: 3.5.1.v3555a
Id: org.eclipse.swt.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.swt.win32.win32.x86, Version: 3.5.1.v3555a
Id: org.eclipse.team.core, Version: 3.5.0.I20090527-0620
Id: org.eclipse.team.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.team.cvs.core, Version: 3.3.200.I20090430-0408
Id: org.eclipse.team.cvs.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.team.cvs.ssh, Version: 3.2.100.I20090508-2000
Id: org.eclipse.team.cvs.ssh.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.team.cvs.ssh2, Version: 3.2.200.I20090508-2000
Id: org.eclipse.team.cvs.ssh2.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.team.cvs.ui, Version: 3.3.201.R35x_v20090826-0905
Id: org.eclipse.team.cvs.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.team.ui, Version: 3.5.0.I20090430-0408
Id: org.eclipse.team.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.text, Version: 3.5.0.v20090513-2000
Id: org.eclipse.text.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui, Version: 3.5.1.M20090902-1000
Id: org.eclipse.ui.browser, Version: 3.2.300.v20090526
Id: org.eclipse.ui.browser.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.cheatsheets, Version: 3.3.200.v20090526
Id: org.eclipse.ui.cheatsheets.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.console, Version: 3.4.0.v20090513
Id: org.eclipse.ui.console.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.editors, Version: 3.5.0.v20090527-2000
Id: org.eclipse.ui.editors.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.externaltools, Version: 3.2.0.v20090504
Id: org.eclipse.ui.externaltools.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.forms, Version: 3.4.1.v20090714_35x
Id: org.eclipse.ui.forms.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.ide, Version: 3.5.1.M20090826-0800
Id: org.eclipse.ui.ide.application, Version: 1.0.101.M20090826-0800
Id: org.eclipse.ui.ide.application.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.ide.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.intro, Version: 3.3.1.v20090805_35x
Id: org.eclipse.ui.intro.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.intro.universal, Version: 3.2.300.v20090526
Id: org.eclipse.ui.intro.universal.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.navigator, Version: 3.4.1.M20090911-1550
Id: org.eclipse.ui.navigator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.navigator.resources, Version: 3.4.1.M20090826-0800
Id: org.eclipse.ui.navigator.resources.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.net, Version: 1.2.1.r35x_20090812-1200
Id: org.eclipse.ui.net.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.presentations.r21, Version: 3.2.100.I20081007-0800
Id: org.eclipse.ui.presentations.r21.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.views, Version: 3.4.1.M20090826-0800
Id: org.eclipse.ui.views.log, Version: 1.0.100.v20090731
Id: org.eclipse.ui.views.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.views.properties.tabbed, Version: 3.5.0.I20090429-1800
Id: org.eclipse.ui.views.properties.tabbed.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.win32, Version: 3.2.100.v20090429-1800
Id: org.eclipse.ui.workbench, Version: 3.5.1.M20090826-0800a
Id: org.eclipse.ui.workbench.compatibility, Version: 3.2.0.I20090429-1800
Id: org.eclipse.ui.workbench.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.ui.workbench.texteditor, Version: 3.5.0.v20090603
Id: org.eclipse.ui.workbench.texteditor.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.update.configurator, Version: 3.3.0.v20090312
Id: org.eclipse.update.configurator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.update.core, Version: 3.2.300.v20090525
Id: org.eclipse.update.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.update.core.win32, Version: 3.2.100.v20080107
Id: org.eclipse.update.scheduler, Version: 3.2.200.v20081127
Id: org.eclipse.update.scheduler.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.update.ui, Version: 3.2.201.R35x_v20090813
Id: org.eclipse.update.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401
Id: org.eclipse.wst.command.env, Version: 1.0.408.v200903110045
Id: org.eclipse.wst.command.env.core, Version: 1.0.204.v200805140020
Id: org.eclipse.wst.command.env.core.source, Version: 1.0.204.v200805140020
Id: org.eclipse.wst.command.env.doc.user, Version: 1.5.200.v200806092138
Id: org.eclipse.wst.command.env.infopop, Version: 1.0.100.v200805301544
Id: org.eclipse.wst.command.env.source, Version: 1.0.408.v200903110045
Id: org.eclipse.wst.command.env.ui, Version: 1.1.2.v200811200248
Id: org.eclipse.wst.command.env.ui.source, Version: 1.1.2.v200811200248
Id: org.eclipse.wst.common.api.doc, Version: 1.0.1.v200807181737
Id: org.eclipse.wst.common.core, Version: 1.1.201.v200806010600
Id: org.eclipse.wst.common.core.source, Version: 1.1.201.v200806010600
Id: org.eclipse.wst.common.emf, Version: 1.1.301.v200908181930
Id: org.eclipse.wst.common.emf.source, Version: 1.1.301.v200908181930
Id: org.eclipse.wst.common.emfworkbench.integration, Version: 1.1.301.v200908101600
Id: org.eclipse.wst.common.emfworkbench.integration.source, Version: 1.1.301.v200908101600
Id: org.eclipse.wst.common.environment, Version: 1.0.301.v200908101600
Id: org.eclipse.wst.common.environment.source, Version: 1.0.301.v200908101600
Id: org.eclipse.wst.common.frameworks, Version: 1.1.300.v200904160730
Id: org.eclipse.wst.common.frameworks.source, Version: 1.1.300.v200904160730
Id: org.eclipse.wst.common.frameworks.ui, Version: 1.1.301.v200908101600
Id: org.eclipse.wst.common.frameworks.ui.source, Version: 1.1.301.v200908101600
Id: org.eclipse.wst.common.infopop, Version: 1.0.100.v200805301550
Id: org.eclipse.wst.common.infopop.source, Version: 1.0.100.v200805301550
Id: org.eclipse.wst.common.modulecore, Version: 1.1.301.v201001252130
Id: org.eclipse.wst.common.modulecore.source, Version: 1.1.301.v201001252130
Id: org.eclipse.wst.common.project.facet.core, Version: 1.4.1.v200911141735
Id: org.eclipse.wst.common.project.facet.ui, Version: 1.4.1.v200908111817
Id: org.eclipse.wst.common.snippets, Version: 1.1.301.v201001280015
Id: org.eclipse.wst.common.snippets.source, Version: 1.1.301.v201001280015
Id: org.eclipse.wst.common.ui, Version: 1.1.402.v200901262305
Id: org.eclipse.wst.common.ui.source, Version: 1.1.402.v200901262305
Id: org.eclipse.wst.common.uriresolver, Version: 1.1.301.v200805140415
Id: org.eclipse.wst.common.uriresolver.source, Version: 1.1.301.v200805140415
Id: org.eclipse.wst.common_core.feature.feature.group, Version: 3.1.1.v200908102300-7B77FZ6F7RZHKDIwRlOwUN
Id: org.eclipse.wst.common_core.feature.feature.jar, Version: 3.1.1.v200908102300-7B77FZ6F7RZHKDIwRlOwUN
Id: org.eclipse.wst.common_core.feature.source.feature.group, Version: 3.1.1.v200908102300-7B77FZ6F7RZHKDIwRlOwUN
Id: org.eclipse.wst.common_core.feature.source.feature.jar, Version: 3.1.1.v200908102300-7B77FZ6F7RZHKDIwRlOwUN
Id: org.eclipse.wst.common_sdk.feature.feature.group, Version: 3.1.1.v200908102300-7938c9xOCMxOeqvXiT-qoyvN9BV2
Id: org.eclipse.wst.common_sdk.feature.feature.jar, Version: 3.1.1.v200908102300-7938c9xOCMxOeqvXiT-qoyvN9BV2
Id: org.eclipse.wst.common_ui.feature.feature.group, Version: 3.1.1.v200908102300-7B5FRHDhdMOGnoekn4gtEJxSmPxV
Id: org.eclipse.wst.common_ui.feature.feature.jar, Version: 3.1.1.v200908102300-7B5FRHDhdMOGnoekn4gtEJxSmPxV
Id: org.eclipse.wst.common_ui.feature.source.feature.group, Version: 3.1.1.v200908102300-7B5FRHDhdMOGnoekn4gtEJxSmPxV
Id: org.eclipse.wst.common_ui.feature.source.feature.jar, Version: 3.1.1.v200908102300-7B5FRHDhdMOGnoekn4gtEJxSmPxV
Id: org.eclipse.wst.css.core, Version: 1.1.301.v200910161432
Id: org.eclipse.wst.css.core.source, Version: 1.1.301.v200910161432
Id: org.eclipse.wst.css.ui, Version: 1.0.401.v200907171457
Id: org.eclipse.wst.css.ui.source, Version: 1.0.401.v200907171457
Id: org.eclipse.wst.doc.user, Version: 1.2.0.v200806052254
Id: org.eclipse.wst.dtd.core, Version: 1.1.300.v200904181727
Id: org.eclipse.wst.dtd.core.source, Version: 1.1.300.v200904181727
Id: org.eclipse.wst.dtd.ui, Version: 1.0.400.v200904300717
Id: org.eclipse.wst.dtd.ui.infopop, Version: 1.0.300.v200805140200
Id: org.eclipse.wst.dtd.ui.source, Version: 1.0.400.v200904300717
Id: org.eclipse.wst.dtdeditor.doc.user, Version: 1.0.500.v200904292308
Id: org.eclipse.wst.html.core, Version: 1.1.300.v200903120608
Id: org.eclipse.wst.html.core.source, Version: 1.1.300.v200903120608
Id: org.eclipse.wst.html.ui, Version: 1.0.401.v200908111935
Id: org.eclipse.wst.html.ui.infopop, Version: 1.0.100.v200805301545
Id: org.eclipse.wst.html.ui.source, Version: 1.0.401.v200908111935
Id: org.eclipse.wst.internet.cache, Version: 1.0.301.v200805140020
Id: org.eclipse.wst.internet.cache.source, Version: 1.0.301.v200805140020
Id: org.eclipse.wst.internet.monitor.core, Version: 1.0.404.v20090609
Id: org.eclipse.wst.internet.monitor.core.source, Version: 1.0.404.v20090609
Id: org.eclipse.wst.internet.monitor.ui, Version: 1.0.305.v20100123
Id: org.eclipse.wst.internet.monitor.ui.source, Version: 1.0.305.v20100123
Id: org.eclipse.wst.jsdt.core, Version: 1.0.201.v2010012803
Id: org.eclipse.wst.jsdt.core.source, Version: 1.0.201.v2010012803
Id: org.eclipse.wst.jsdt.doc, Version: 1.0.200.v200903120608
Id: org.eclipse.wst.jsdt.feature.feature.group, Version: 1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb
Id: org.eclipse.wst.jsdt.feature.feature.jar, Version: 1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb
Id: org.eclipse.wst.jsdt.feature.source.feature.group, Version: 1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb
Id: org.eclipse.wst.jsdt.feature.source.feature.jar, Version: 1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb
Id: org.eclipse.wst.jsdt.manipulation, Version: 1.0.100.v200809240707
Id: org.eclipse.wst.jsdt.manipulation.source, Version: 1.0.100.v200809240707
Id: org.eclipse.wst.jsdt.support.firefox, Version: 1.0.200.v200904290357
Id: org.eclipse.wst.jsdt.support.firefox.source, Version: 1.0.200.v200904290357
Id: org.eclipse.wst.jsdt.support.ie, Version: 1.0.200.v200904290539
Id: org.eclipse.wst.jsdt.support.ie.source, Version: 1.0.200.v200904290539
Id: org.eclipse.wst.jsdt.ui, Version: 1.0.201.v2010012803
Id: org.eclipse.wst.jsdt.ui.source, Version: 1.0.201.v2010012803
Id: org.eclipse.wst.jsdt.web.core, Version: 1.0.201.v201001221931
Id: org.eclipse.wst.jsdt.web.core.source, Version: 1.0.201.v201001221931
Id: org.eclipse.wst.jsdt.web.ui, Version: 1.0.201.v2010012803
Id: org.eclipse.wst.jsdt.web.ui.source, Version: 1.0.201.v2010012803
Id: org.eclipse.wst.jsdt_sdk.feature.feature.group, Version: 1.1.2.v200908101420-31384C2ISGNgQFKoEZWyDtYrDdOC
Id: org.eclipse.wst.jsdt_sdk.feature.feature.jar, Version: 1.1.2.v200908101420-31384C2ISGNgQFKoEZWyDtYrDdOC
Id: org.eclipse.wst.server.core, Version: 1.1.102.v20100123
Id: org.eclipse.wst.server.core.source, Version: 1.1.102.v20100123
Id: org.eclipse.wst.server.discovery, Version: 1.0.1.v20100210
Id: org.eclipse.wst.server.discovery.source, Version: 1.0.1.v20100210
Id: org.eclipse.wst.server.ui, Version: 1.1.103.v20100123
Id: org.eclipse.wst.server.ui.doc.user, Version: 1.1.150.v200901232034
Id: org.eclipse.wst.server.ui.infopop, Version: 1.1.0.v200805140145
Id: org.eclipse.wst.server.ui.source, Version: 1.1.103.v20100123
Id: org.eclipse.wst.server_core.feature.feature.group, Version: 3.1.1.v20090727b-30Eu8s734C3A5F
Id: org.eclipse.wst.server_core.feature.feature.jar, Version: 3.1.1.v20090727b-30Eu8s734C3A5F
Id: org.eclipse.wst.server_core.feature.source.feature.group, Version: 3.1.1.v20090727b-30Eu8s734C3A5F
Id: org.eclipse.wst.server_core.feature.source.feature.jar, Version: 3.1.1.v20090727b-30Eu8s734C3A5F
Id: org.eclipse.wst.server_sdk.feature.feature.group, Version: 3.1.1.v20090728b-7818a90K8IlG7Rp3b5hRfsOFdxYe
Id: org.eclipse.wst.server_sdk.feature.feature.jar, Version: 3.1.1.v20090728b-7818a90K8IlG7Rp3b5hRfsOFdxYe
Id: org.eclipse.wst.server_ui.feature.feature.group, Version: 3.1.1.v20090727b-7B3DPAtJZRZxULQRALIM4256
Id: org.eclipse.wst.server_ui.feature.feature.jar, Version: 3.1.1.v20090727b-7B3DPAtJZRZxULQRALIM4256
Id: org.eclipse.wst.server_ui.feature.source.feature.group, Version: 3.1.1.v20090727b-7B3DPAtJZRZxULQRALIM4256
Id: org.eclipse.wst.server_ui.feature.source.feature.jar, Version: 3.1.1.v20090727b-7B3DPAtJZRZxULQRALIM4256
Id: org.eclipse.wst.server_userdoc.feature.feature.group, Version: 3.1.0.v200903071919-209L7w311A12343145
Id: org.eclipse.wst.server_userdoc.feature.feature.jar, Version: 3.1.0.v200903071919-209L7w311A12343145
Id: org.eclipse.wst.sse.core, Version: 1.1.402.v201001251516
Id: org.eclipse.wst.sse.core.source, Version: 1.1.402.v201001251516
Id: org.eclipse.wst.sse.doc.user, Version: 1.1.0.v200805211530
Id: org.eclipse.wst.sse.ui, Version: 1.1.102.v200910200227
Id: org.eclipse.wst.sse.ui.infopop, Version: 1.0.200.v200805301545
Id: org.eclipse.wst.sse.ui.source, Version: 1.1.102.v200910200227
Id: org.eclipse.wst.standard.schemas, Version: 1.0.200.v200902270215
Id: org.eclipse.wst.validation, Version: 1.2.104.v200911120201
Id: org.eclipse.wst.validation.doc.isv, Version: 1.2.101.v200906031420
Id: org.eclipse.wst.validation.infopop, Version: 1.0.300.v200806041506
Id: org.eclipse.wst.validation.source, Version: 1.2.104.v200911120201
Id: org.eclipse.wst.validation.ui, Version: 1.2.104.v200904232035
Id: org.eclipse.wst.validation.ui.source, Version: 1.2.104.v200904232035
Id: org.eclipse.wst.web, Version: 1.1.301.v200911302230
Id: org.eclipse.wst.web.source, Version: 1.1.301.v200911302230
Id: org.eclipse.wst.web.ui, Version: 1.1.301.v201001252130
Id: org.eclipse.wst.web.ui.infopop, Version: 1.0.300.v200805140415
Id: org.eclipse.wst.web.ui.source, Version: 1.1.301.v201001252130
Id: org.eclipse.wst.web_core.feature.feature.group, Version: 3.1.1.v200908120400-7H77FDCAT7oGlivgHN1M2RkCBHz0
Id: org.eclipse.wst.web_core.feature.feature.jar, Version: 3.1.1.v200908120400-7H77FDCAT7oGlivgHN1M2RkCBHz0
Id: org.eclipse.wst.web_core.feature.source.feature.group, Version: 3.1.1.v200908120400-7H77FDCAT7oGlivgHN1M2RkCBHz0
Id: org.eclipse.wst.web_core.feature.source.feature.jar, Version: 3.1.1.v200908120400-7H77FDCAT7oGlivgHN1M2RkCBHz0
Id: org.eclipse.wst.web_sdk.feature.feature.group, Version: 3.1.1.v200908120400-7H5778a3PixJeiw96KaEgaNvfKgN
Id: org.eclipse.wst.web_sdk.feature.feature.jar, Version: 3.1.1.v200908120400-7H5778a3PixJeiw96KaEgaNvfKgN
Id: org.eclipse.wst.web_ui.feature.feature.group, Version: 3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3
Id: org.eclipse.wst.web_ui.feature.feature.jar, Version: 3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3
Id: org.eclipse.wst.web_ui.feature.source.feature.group, Version: 3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3
Id: org.eclipse.wst.web_ui.feature.source.feature.jar, Version: 3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3
Id: org.eclipse.wst.web_userdoc.feature.feature.group, Version: 3.1.0.v200903071919-31DF8s733J3E4D56BB
Id: org.eclipse.wst.web_userdoc.feature.feature.jar, Version: 3.1.0.v200903071919-31DF8s733J3E4D56BB
Id: org.eclipse.wst.webtools.doc.user, Version: 1.0.400.v200805150134
Id: org.eclipse.wst.ws, Version: 1.1.103.v200903111822
Id: org.eclipse.wst.ws.api.doc, Version: 1.0.1.v200807181721
Id: org.eclipse.wst.ws.explorer, Version: 1.0.408.v200911241806
Id: org.eclipse.wst.ws.explorer.source, Version: 1.0.408.v200911241806
Id: org.eclipse.wst.ws.infopop, Version: 1.0.300.v200805140230
Id: org.eclipse.wst.ws.parser, Version: 1.0.402.v200901220107
Id: org.eclipse.wst.ws.parser.source, Version: 1.0.402.v200901220107
Id: org.eclipse.wst.ws.service.policy, Version: 1.0.103.v200905151848
Id: org.eclipse.wst.ws.service.policy.source, Version: 1.0.103.v200905151848
Id: org.eclipse.wst.ws.service.policy.ui, Version: 1.0.102.v200903070248
Id: org.eclipse.wst.ws.service.policy.ui.source, Version: 1.0.102.v200903070248
Id: org.eclipse.wst.ws.source, Version: 1.1.103.v200903111822
Id: org.eclipse.wst.ws.ui, Version: 1.1.100.v200903112221
Id: org.eclipse.wst.ws.ui.source, Version: 1.1.100.v200903112221
Id: org.eclipse.wst.ws_core.feature.feature.group, Version: 3.1.2.v200911111930-7L7RFTXFGtGcn6ij-pviG6462A
Id: org.eclipse.wst.ws_core.feature.feature.jar, Version: 3.1.2.v200911111930-7L7RFTXFGtGcn6ij-pviG6462A
Id: org.eclipse.wst.ws_core.feature.source.feature.group, Version: 3.1.2.v200911111930-7L7RFTXFGtGcn6ij-pviG6462A
Id: org.eclipse.wst.ws_core.feature.source.feature.jar, Version: 3.1.2.v200911111930-7L7RFTXFGtGcn6ij-pviG6462A
Id: org.eclipse.wst.ws_sdk.feature.feature.group, Version: 3.1.2.v200911241834-7918d9xVDMuyV3awj9oF1I8PN8Qc
Id: org.eclipse.wst.ws_sdk.feature.feature.jar, Version: 3.1.2.v200911241834-7918d9xVDMuyV3awj9oF1I8PN8Qc
Id: org.eclipse.wst.ws_ui.feature.feature.group, Version: 3.1.2.v200911241834-7I6FPpEtEnGx_Csz-6wI8hoH_MRt
Id: org.eclipse.wst.ws_ui.feature.feature.jar, Version: 3.1.2.v200911241834-7I6FPpEtEnGx_Csz-6wI8hoH_MRt
Id: org.eclipse.wst.ws_ui.feature.source.feature.group, Version: 3.1.2.v200911241834-7I6FPpEtEnGx_Csz-6wI8hoH_MRt
Id: org.eclipse.wst.ws_ui.feature.source.feature.jar, Version: 3.1.2.v200911241834-7I6FPpEtEnGx_Csz-6wI8hoH_MRt
Id: org.eclipse.wst.ws_userdoc.feature.feature.group, Version: 3.1.0.v200903071919-44FGz9oB55U5L8OAFEK
Id: org.eclipse.wst.ws_userdoc.feature.feature.jar, Version: 3.1.0.v200903071919-44FGz9oB55U5L8OAFEK
Id: org.eclipse.wst.ws_wsdl15.feature.feature.group, Version: 1.5.3.v200903071919-2407w311917141519
Id: org.eclipse.wst.ws_wsdl15.feature.feature.jar, Version: 1.5.3.v200903071919-2407w311917141519
Id: org.eclipse.wst.wsdl, Version: 1.2.2.v200911111930
Id: org.eclipse.wst.wsdl.doc.isv, Version: 1.0.100.v200811240723
Id: org.eclipse.wst.wsdl.source, Version: 1.2.2.v200911111930
Id: org.eclipse.wst.wsdl.ui, Version: 1.2.202.v200904271449
Id: org.eclipse.wst.wsdl.ui.doc.user, Version: 1.0.550.v200901232040
Id: org.eclipse.wst.wsdl.ui.source, Version: 1.2.202.v200904271449
Id: org.eclipse.wst.wsdl.validation, Version: 1.1.402.v200911251542
Id: org.eclipse.wst.wsdl.validation.source, Version: 1.1.402.v200911251542
Id: org.eclipse.wst.wsi, Version: 1.0.305.v200902181431
Id: org.eclipse.wst.wsi.source, Version: 1.0.305.v200902181431
Id: org.eclipse.wst.wsi.ui, Version: 1.0.500.v200901141851
Id: org.eclipse.wst.wsi.ui.doc.user, Version: 1.0.401.v200809171927
Id: org.eclipse.wst.wsi.ui.source, Version: 1.0.500.v200901141851
Id: org.eclipse.wst.xml.core, Version: 1.1.402.v201001222130
Id: org.eclipse.wst.xml.core.source, Version: 1.1.402.v201001222130
Id: org.eclipse.wst.xml.ui, Version: 1.1.2.v201001222130
Id: org.eclipse.wst.xml.ui.infopop, Version: 1.0.300.v200805140200
Id: org.eclipse.wst.xml.ui.source, Version: 1.1.2.v201001222130
Id: org.eclipse.wst.xml.xpath.core, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xml.xpath.core.source, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xml.xpath.ui, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xml.xpath.ui.source, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xml.xpath2.processor, Version: 1.0.0.v200905300355
Id: org.eclipse.wst.xml.xpath2.processor.source, Version: 1.0.0.v200905300355
Id: org.eclipse.wst.xml_core.feature.feature.group, Version: 3.1.1.v200907161031-7C7OFPiF7RZHKFHgU1LkY6
Id: org.eclipse.wst.xml_core.feature.feature.jar, Version: 3.1.1.v200907161031-7C7OFPiF7RZHKFHgU1LkY6
Id: org.eclipse.wst.xml_core.feature.source.feature.group, Version: 3.1.1.v200907161031-7C7OFPiF7RZHKFHgU1LkY6
Id: org.eclipse.wst.xml_core.feature.source.feature.jar, Version: 3.1.1.v200907161031-7C7OFPiF7RZHKFHgU1LkY6
Id: org.eclipse.wst.xml_sdk.feature.feature.group, Version: 3.1.1.v200907161031-7A228DXETAqLQFBNMuHkC8-_dRPY
Id: org.eclipse.wst.xml_sdk.feature.feature.jar, Version: 3.1.1.v200907161031-7A228DXETAqLQFBNMuHkC8-_dRPY
Id: org.eclipse.wst.xml_ui.feature.feature.group, Version: 3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo
Id: org.eclipse.wst.xml_ui.feature.feature.jar, Version: 3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo
Id: org.eclipse.wst.xml_ui.feature.source.feature.group, Version: 3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo
Id: org.eclipse.wst.xml_ui.feature.source.feature.jar, Version: 3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo
Id: org.eclipse.wst.xml_userdoc.feature.feature.group, Version: 3.1.1.v200906020459-50FR7AkF77f7MESDKEF
Id: org.eclipse.wst.xml_userdoc.feature.feature.jar, Version: 3.1.1.v200906020459-50FR7AkF77f7MESDKEF
Id: org.eclipse.wst.xmleditor.doc.user, Version: 1.0.600.v200901231300
Id: org.eclipse.wst.xsd.core, Version: 1.1.401.v200903020335
Id: org.eclipse.wst.xsd.core.source, Version: 1.1.401.v200903020335
Id: org.eclipse.wst.xsd.ui, Version: 1.2.204.v200909021537
Id: org.eclipse.wst.xsd.ui.source, Version: 1.2.204.v200909021537
Id: org.eclipse.wst.xsdeditor.doc.user, Version: 1.0.700.v200905182240
Id: org.eclipse.wst.xsl, Version: 1.0.0.v200905250058
Id: org.eclipse.wst.xsl.core, Version: 1.0.1.v200908101420
Id: org.eclipse.wst.xsl.core.source, Version: 1.0.1.v200908101420
Id: org.eclipse.wst.xsl.debug.ui, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.debug.ui.source, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.doc, Version: 1.0.0.v200905071815
Id: org.eclipse.wst.xsl.feature.feature.group, Version: 1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1
Id: org.eclipse.wst.xsl.feature.feature.jar, Version: 1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1
Id: org.eclipse.wst.xsl.feature.source.feature.group, Version: 1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1
Id: org.eclipse.wst.xsl.feature.source.feature.jar, Version: 1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1
Id: org.eclipse.wst.xsl.jaxp.debug, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.jaxp.debug.source, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.jaxp.debug.ui, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.jaxp.debug.ui.source, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.jaxp.launching, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.jaxp.launching.source, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.launching, Version: 1.0.0.v200904241348
Id: org.eclipse.wst.xsl.launching.source, Version: 1.0.0.v200904241348
Id: org.eclipse.wst.xsl.saxon, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.saxon.source, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.sdk.documentation, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.source, Version: 1.0.0.v200905250058
Id: org.eclipse.wst.xsl.ui, Version: 1.0.100.v200907172129
Id: org.eclipse.wst.xsl.ui.source, Version: 1.0.100.v200907172129
Id: org.eclipse.wst.xsl.xalan, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl.xalan.source, Version: 1.0.0.v200904240436
Id: org.eclipse.wst.xsl_sdk.feature.feature.group, Version: 1.0.2.v200908271520-4-390_CYVxWRxOsrgiEZFM0TlMiJ
Id: org.eclipse.wst.xsl_sdk.feature.feature.jar, Version: 1.0.2.v200908271520-4-390_CYVxWRxOsrgiEZFM0TlMiJ
Id: org.eclipse.xsd, Version: 2.5.0.v200906151043
Id: org.eclipse.xsd.edit, Version: 2.5.0.v200906151043
Id: org.hamcrest.core, Version: 1.1.0.v20090501071000
Id: org.jdom, Version: 1.0.0.v200806100616
Id: org.junit, Version: 3.8.2.v20090203-1005
Id: org.junit4, Version: 4.5.0.v20090824
Id: org.mortbay.jetty.server, Version: 6.1.15.v200905151201
Id: org.mortbay.jetty.util, Version: 6.1.15.v200905182336
Id: org.objectweb.asm, Version: 3.1.0.v200803061910
Id: org.sat4j.core, Version: 2.1.0.v20090520
Id: org.sat4j.pb, Version: 2.1.0.v20090520
Id: org.tigris.subversion.clientadapter, Version: 1.6.12
Id: org.tigris.subversion.clientadapter.feature.feature.group, Version: 1.6.12
Id: org.tigris.subversion.clientadapter.feature.feature.jar, Version: 1.6.12
Id: org.tigris.subversion.clientadapter.javahl, Version: 1.6.12
Id: org.tigris.subversion.clientadapter.javahl.feature.feature.group, Version: 1.6.12
Id: org.tigris.subversion.clientadapter.javahl.feature.feature.jar, Version: 1.6.12
Id: org.tigris.subversion.clientadapter.javahl.win32, Version: 1.6.12
Id: org.tigris.subversion.clientadapter.svnkit, Version: 1.6.12
Id: org.tigris.subversion.clientadapter.svnkit.feature.feature.group, Version: 1.6.12
Id: org.tigris.subversion.clientadapter.svnkit.feature.feature.jar, Version: 1.6.12
Id: org.tigris.subversion.subclipse.core, Version: 1.6.12
Id: org.tigris.subversion.subclipse.doc, Version: 1.3.0
Id: org.tigris.subversion.subclipse.feature.group, Version: 1.6.12
Id: org.tigris.subversion.subclipse.feature.jar, Version: 1.6.12
Id: org.tigris.subversion.subclipse.ui, Version: 1.6.12
Id: org.tmatesoft.svnkit, Version: 1.3.3.6648
Id: org.tmatesoft.svnkit.feature.group, Version: 1.3.3.6648
Id: org.tmatesoft.svnkit.feature.jar, Version: 1.3.3.6648
Id: org.uddi4j, Version: 2.0.5.v200805270300
Id: tooling.org.eclipse.update.feature.default, Version: 1.0.0
Id: tooling.osgi.bundle.default, Version: 1.0.0
Id: tooling.source.default, Version: 1.0.0
Id: toolingcom.adobe.flexbuilder.standalone.product.config.win32.win32.x86, Version: 4.0.1
Id: toolingcom.adobe.flexbuilder.standalone.product.configuration, Version: 4.0.1
Id: toolingcom.adobe.flexbuilder.standalone.product.ini.win32.win32.x86, Version: 4.0.1
Id: toolingcom.adobe.flexbuilder.standalone.product_root.win32.win32.x86, Version: 4.0.1
Id: toolingorg.eclipse.equinox.launcher, Version: 1.0.201.R35x_v20090715
Id: toolingorg.eclipse.equinox.launcher.win32.win32.x86, Version: 1.0.200.v20090519
Id: toolingwin32.win32.x86org.eclipse.core.runtime, Version: 4.0.1
Id: toolingwin32.win32.x86org.eclipse.equinox.common, Version: 4.0.1
Id: toolingwin32.win32.x86org.eclipse.equinox.ds, Version: 4.0.1
Id: toolingwin32.win32.x86org.eclipse.equinox.p2.reconciler.dropins, Version: 4.0.1
Id: toolingwin32.win32.x86org.eclipse.equinox.simpleconfigurator, Version: 4.0.1
Id: toolingwin32.win32.x86org.eclipse.update.configurator, Version: 4.0.1
Bundles in the system:
Id: ActionscriptInfoCollector, Version: 0.7.4, Location: reference:file:plugins/ActionscriptInfoCollector_0.7.4.jar
Id: FlexASDocGenCommand, Version: 0.7.4, Location: reference:file:plugins/FlexASDocGenCommand_0.7.4.jar
Id: FlexPrettyPrintCommand, Version: 0.7.4, Location: reference:file:plugins/FlexPrettyPrintCommand_0.7.4.jar
Id: com.adobe.coldfusion.rds.client, Version: 1.0.272885, Location: reference:file:plugins/com.adobe.coldfusion.rds.client_1.0.272885.jar
Id: com.adobe.coldfusion.rds.client.nl1, Version: 1.0.1.v20100112266797, Location: reference:file:plugins/com.adobe.coldfusion.rds.client.nl1_1.0.1.v20100112266797.jar
Id: com.adobe.flash.codemodel.core, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flash.codemodel.core_4.0.1.277662/
Id: com.adobe.flash.codemodel.osgi, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flash.codemodel.osgi_4.0.1.277662/
Id: com.adobe.flash.profiler, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flash.profiler_4.0.1.277662/
Id: com.adobe.flash.profiler.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flash.profiler.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.DCDService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.DCDService_4.0.1.277662/
Id: com.adobe.flexbuilder.DCDService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.DCDService.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.ajaxbridge, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.ajaxbridge_4.0.1.277662/
Id: com.adobe.flexbuilder.ajaxbridge.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.ajaxbridge.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.as.editor, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.as.editor_4.0.1.277662/
Id: com.adobe.flexbuilder.as.editor.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.as.editor.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.axis2, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.axis2_4.0.1.277662/
Id: com.adobe.flexbuilder.axis2.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.axis2.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.codemodel, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.codemodel_4.0.1.277662/
Id: com.adobe.flexbuilder.codemodel.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.codemodel.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.crimson, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.crimson_4.0.1.277662/
Id: com.adobe.flexbuilder.crimson.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.crimson.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.css.editor, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.css.editor_4.0.1.277662/
Id: com.adobe.flexbuilder.css.editor.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.css.editor.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.dcrad, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.dcrad_4.0.1.277662/
Id: com.adobe.flexbuilder.dcrad.derived, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.dcrad.derived_4.0.1.277662/
Id: com.adobe.flexbuilder.dcrad.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.dcrad.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.debug, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug_4.0.1.277662/
Id: com.adobe.flexbuilder.debug.e33, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug.e33_4.0.1.277662/
Id: com.adobe.flexbuilder.debug.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.debug.ui, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug.ui_4.0.1.277662/
Id: com.adobe.flexbuilder.debug.ui.actions, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug.ui.actions_4.0.1.277662/
Id: com.adobe.flexbuilder.debug.ui.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.debug.ui.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.designview, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.designview_4.0.1.277662/
Id: com.adobe.flexbuilder.designview.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.designview.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.editorcore, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.editorcore_4.0.1.277662/
Id: com.adobe.flexbuilder.editorcore.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.editorcore.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.editors.derived, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.editors.derived_4.0.1.277662/
Id: com.adobe.flexbuilder.editors.derived.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.editors.derived.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.exportimport, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.exportimport_4.0.1.277662/
Id: com.adobe.flexbuilder.exportimport.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.exportimport.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.flashbridge, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flashbridge_4.0.1.277662/
Id: com.adobe.flexbuilder.flashbridge.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flashbridge.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.flex, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flex_4.0.1.277662/
Id: com.adobe.flexbuilder.flexunit, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flexunit_4.0.1.277662/
Id: com.adobe.flexbuilder.flexunit.derived, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flexunit.derived_4.0.1.277662/
Id: com.adobe.flexbuilder.flexunit.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.flexunit.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.help, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.help_4.0.1.277662/
Id: com.adobe.flexbuilder.help.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.help.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.importartwork, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.importartwork_4.0.1.277662/
Id: com.adobe.flexbuilder.importartwork.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.importartwork.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.json, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.json_4.0.1.277662/
Id: com.adobe.flexbuilder.launching.ui, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.launching.ui_4.0.1.277662/
Id: com.adobe.flexbuilder.launching.ui.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.launching.ui.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.monitors.network, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.monitors.network_4.0.1.277662/
Id: com.adobe.flexbuilder.monitors.network.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.monitors.network.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.multisdk, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.multisdk_4.0.1.277662/
Id: com.adobe.flexbuilder.mxml.editor, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.mxml.editor_4.0.1.277662/
Id: com.adobe.flexbuilder.mxml.editor.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.mxml.editor.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.mxmlmodel, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.mxmlmodel_4.0.1.277662/
Id: com.adobe.flexbuilder.project, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.project_4.0.1.277662/
Id: com.adobe.flexbuilder.project.e35, Version: 1.0.0.201001080934, Location: reference:file:plugins/com.adobe.flexbuilder.project.e35_1.0.0.201001080934.jar
Id: com.adobe.flexbuilder.project.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.project.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.project.ui, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.project.ui_4.0.1.277662/
Id: com.adobe.flexbuilder.project.ui.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.project.ui.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.services.BlazeDSService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.BlazeDSService_4.0.1.277662/
Id: com.adobe.flexbuilder.services.CFService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.CFService_4.0.1.277662/
Id: com.adobe.flexbuilder.services.CFService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.CFService.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.services.HTTPService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.HTTPService_4.0.1.277662/
Id: com.adobe.flexbuilder.services.HTTPService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.HTTPService.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.services.J2EEService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.J2EEService_4.0.1.277662/
Id: com.adobe.flexbuilder.services.J2EEService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.J2EEService.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.services.LCDSService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.LCDSService_4.0.1.277662/
Id: com.adobe.flexbuilder.services.PHPService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.PHPService_4.0.1.277662/
Id: com.adobe.flexbuilder.services.PHPService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.PHPService.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.services.StaticContentService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.StaticContentService_4.0.1.277662/
Id: com.adobe.flexbuilder.services.StaticContentService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.StaticContentService.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.services.WEBService, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.WEBService_4.0.1.277662/
Id: com.adobe.flexbuilder.services.WEBService.derived, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.WEBService.derived_4.0.1.277662/
Id: com.adobe.flexbuilder.services.WEBService.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.services.WEBService.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.standalone, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.standalone_4.0.1.277662/
Id: com.adobe.flexbuilder.standalone.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.standalone.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.tengine, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.tengine_4.0.1.277662/
Id: com.adobe.flexbuilder.tengine.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.tengine.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.ui, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.ui_4.0.1.277662/
Id: com.adobe.flexbuilder.ui.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.ui.nl1_4.0.1.277662/
Id: com.adobe.flexbuilder.utils.osnative, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.utils.osnative_4.0.1.277662/
Id: com.adobe.flexbuilder.utils.osnative.win, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexbuilder.utils.osnative.win_4.0.1.277662/
Id: com.adobe.flexide.amt, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.amt_4.0.1.277662/
Id: com.adobe.flexide.as.core, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.as.core_4.0.1.277662/
Id: com.adobe.flexide.as.core.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.as.core.nl1_4.0.1.277662/
Id: com.adobe.flexide.communityhelp, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.communityhelp_4.0.1.277662/
Id: com.adobe.flexide.communityhelp.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.communityhelp.nl1_4.0.1.277662/
Id: com.adobe.flexide.css.core, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.css.core_4.0.1.277662/
Id: com.adobe.flexide.css.core.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.css.core.nl1_4.0.1.277662/
Id: com.adobe.flexide.designitems, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.designitems_4.0.1.277662/
Id: com.adobe.flexide.editorcore, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.editorcore_4.0.1.277662/
Id: com.adobe.flexide.editorcore.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.editorcore.nl1_4.0.1.277662/
Id: com.adobe.flexide.embeddedplayer, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.embeddedplayer_4.0.1.277662/
Id: com.adobe.flexide.exportimport, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.exportimport_4.0.1.277662/
Id: com.adobe.flexide.exportimport.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.exportimport.nl1_4.0.1.277662/
Id: com.adobe.flexide.externaleditors, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.externaleditors_4.0.1.277662/
Id: com.adobe.flexide.externaleditors.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.externaleditors.nl1_4.0.1.277662/
Id: com.adobe.flexide.fonts, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.fonts_4.0.1.277662/
Id: com.adobe.flexide.launching, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.launching_4.0.1.277662/
Id: com.adobe.flexide.launching.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.launching.nl1_4.0.1.277662/
Id: com.adobe.flexide.multisdk.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.multisdk.nl1_4.0.1.277662/
Id: com.adobe.flexide.mxml.core, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.mxml.core_4.0.1.277662/
Id: com.adobe.flexide.mxml.core.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.mxml.core.nl1_4.0.1.277662/
Id: com.adobe.flexide.nativelibs, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.nativelibs_4.0.1.277662/
Id: com.adobe.flexide.playerview, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.playerview_4.0.1.277662/
Id: com.adobe.flexide.refactoring.core, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.refactoring.core_4.0.1.277662/
Id: com.adobe.flexide.refactoring.core.nl1, Version: 4.0.1.277662, Location: reference:file:plugins/com.adobe.flexide.refactoring.core.nl1_4.0.1.277662/
Id: com.adobe.model.core, Version: 1.0.2.v20100315273147, Location: reference:file:plugins/com.adobe.model.core_1.0.2.v20100315273147.jar
Id: com.collabnet.subversion.merge, Version: 2.1.0, Location: reference:file:plugins/com.collabnet.subversion.merge_2.1.0.jar
Id: com.crispico.flexbridge, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flexbridge_1.0.0.M0_2010-06-11.jar
Id: com.crispico.flower.mp, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp_1.0.0.M0_2010-06-11.jar
Id: com.crispico.flower.mp.dependencies.internal, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.dependencies.internal_1.0.0.M0_2010-06-11.jar
Id: com.crispico.flower.mp.eclipse, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.eclipse_1.0.0.M0_2010-06-11/
Id: com.crispico.flower.mp.eclipse.compare.base, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.eclipse.compare.base_1.0.0.M0_2010-06-11.jar
Id: com.crispico.flower.mp.eclipse.compare.codesync, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.eclipse.compare.codesync_1.0.0.M0_2010-06-11.jar
Id: com.crispico.flower.mp.eclipse.uml4as, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.eclipse.uml4as_1.0.0.M0_2010-06-11.jar
Id: com.crispico.flower.mp.metamodel.classmetamodel, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.metamodel.classmetamodel_1.0.0.M0_2010-06-11.jar
Id: com.crispico.flower.mp.metamodel.codesync, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.metamodel.codesync_1.0.0.M0_2010-06-11.jar
Id: com.crispico.flower.mp.metamodel.codesyncas, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.metamodel.codesyncas_1.0.0.M0_2010-06-11.jar
Id: com.crispico.flower.mp.metamodelset.uml4asfile, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.metamodelset.uml4asfile_1.0.0.M0_2010-06-11.jar
Id: com.crispico.flower.mp.propertieseditor, Version: 1.0.0.M0_2010-06-11, Location: reference:file:plugins/com.crispico.flower.mp.propertieseditor_1.0.0.M0_2010-06-11/
Id: com.ibm.icu, Version: 4.0.1.v20090822, Location: reference:file:plugins/com.ibm.icu_4.0.1.v20090822.jar
Id: com.idefactory.enterprisehelp, Version: 1.0.8.beta, Location: reference:file:plugins/com.idefactory.enterprisehelp_1.0.8.beta.jar
Id: com.idefactory.fxsdk, Version: 1.0.1, Location: reference:file:plugins/com.idefactory.fxsdk_1.0.1.jar
Id: com.idefactory.rhino, Version: 1.0.0, Location: reference:file:plugins/com.idefactory.rhino_1.0.0.jar
Id: com.jcraft.jsch, Version: 0.1.41.v200903070017, Location: reference:file:plugins/com.jcraft.jsch_0.1.41.v200903070017.jar
Id: com.sun.jna, Version: 3.2.3, Location: reference:file:plugins/com.sun.jna_3.2.3.jar
Id: java_cup.runtime, Version: 0.10.0.v200803061811, Location: reference:file:plugins/java_cup.runtime_0.10.0.v200803061811.jar
Id: javax.activation, Version: 1.1.0.v200906290531, Location: reference:file:plugins/javax.activation_1.1.0.v200906290531.jar
Id: javax.mail, Version: 1.4.0.v200905040518, Location: reference:file:plugins/javax.mail_1.4.0.v200905040518.jar
Id: javax.servlet, Version: 2.5.0.v200806031605, Location: reference:file:plugins/javax.servlet_2.5.0.v200806031605.jar
Id: javax.servlet.jsp, Version: 2.0.0.v200806031607, Location: reference:file:plugins/javax.servlet.jsp_2.0.0.v200806031607.jar
Id: javax.wsdl, Version: 1.5.1.v200806030408, Location: reference:file:plugins/javax.wsdl_1.5.1.v200806030408.jar
Id: javax.xml, Version: 1.3.4.v200902170245, Location: reference:file:plugins/javax.xml_1.3.4.v200902170245.jar
Id: javax.xml.rpc, Version: 1.1.0.v200905122109, Location: reference:file:plugins/javax.xml.rpc_1.1.0.v200905122109/
Id: javax.xml.soap, Version: 1.2.0.v200905122109, Location: reference:file:plugins/javax.xml.soap_1.2.0.v200905122109/
Id: net.sourceforge.lpg.lpgjavaruntime, Version: 1.1.0.v200803061910, Location: reference:file:plugins/net.sourceforge.lpg.lpgjavaruntime_1.1.0.v200803061910.jar
Id: org.apache.ant, Version: 1.7.1.v20090120-1145, Location: reference:file:plugins/org.apache.ant_1.7.1.v20090120-1145/
Id: org.apache.axis, Version: 1.4.0.v200905122109, Location: reference:file:plugins/org.apache.axis_1.4.0.v200905122109/
Id: org.apache.bcel, Version: 5.2.0.v200803061811, Location: reference:file:plugins/org.apache.bcel_5.2.0.v200803061811.jar
Id: org.apache.commons.codec, Version: 1.3.0.v20080530-1600, Location: reference:file:plugins/org.apache.commons.codec_1.3.0.v20080530-1600.jar
Id: org.apache.commons.collections, Version: 3.2.0.v200803061811, Location: reference:file:plugins/org.apache.commons.collections_3.2.0.v200803061811.jar
Id: org.apache.commons.discovery, Version: 0.2.0.v200905122109, Location: reference:file:plugins/org.apache.commons.discovery_0.2.0.v200905122109/
Id: org.apache.commons.el, Version: 1.0.0.v200806031608, Location: reference:file:plugins/org.apache.commons.el_1.0.0.v200806031608.jar
Id: org.apache.commons.httpclient, Version: 3.1.0.v20080605-1935, Location: reference:file:plugins/org.apache.commons.httpclient_3.1.0.v20080605-1935.jar
Id: org.apache.commons.jxpath, Version: 1.2.0.v20080604-1500, Location: reference:file:plugins/org.apache.commons.jxpath_1.2.0.v20080604-1500.jar
Id: org.apache.commons.lang, Version: 2.1.0.v200803061811, Location: reference:file:plugins/org.apache.commons.lang_2.1.0.v200803061811.jar
Id: org.apache.commons.lang, Version: 2.4.0.v20081016-1030, Location: reference:file:plugins/org.apache.commons.lang_2.4.0.v20081016-1030.jar
Id: org.apache.commons.logging, Version: 1.0.4.v200904062259, Location: reference:file:plugins/org.apache.commons.logging_1.0.4.v200904062259.jar
Id: org.apache.jasper, Version: 5.5.17.v200903231320, Location: reference:file:plugins/org.apache.jasper_5.5.17.v200903231320.jar
Id: org.apache.log4j, Version: 1.2.13.v200903072027, Location: reference:file:plugins/org.apache.log4j_1.2.13.v200903072027.jar
Id: org.apache.lucene, Version: 1.9.1.v20080530-1600, Location: reference:file:plugins/org.apache.lucene_1.9.1.v20080530-1600.jar
Id: org.apache.lucene.analysis, Version: 1.9.1.v20080530-1600, Location: reference:file:plugins/org.apache.lucene.analysis_1.9.1.v20080530-1600.jar
Id: org.apache.oro, Version: 2.0.8.v200903061218, Location: reference:file:plugins/org.apache.oro_2.0.8.v200903061218.jar
Id: org.apache.velocity, Version: 1.5.0.v200905192330, Location: reference:file:plugins/org.apache.velocity_1.5.0.v200905192330.jar
Id: org.apache.wsil4j, Version: 1.0.0.v200901211807, Location: reference:file:plugins/org.apache.wsil4j_1.0.0.v200901211807.jar
Id: org.apache.xalan, Version: 2.7.1.v200905122109, Location: reference:file:plugins/org.apache.xalan_2.7.1.v200905122109.jar
Id: org.apache.xerces, Version: 2.9.0.v200909240008, Location: reference:file:plugins/org.apache.xerces_2.9.0.v200909240008.jar
Id: org.apache.xml.resolver, Version: 1.2.0.v200902170519, Location: reference:file:plugins/org.apache.xml.resolver_1.2.0.v200902170519.jar
Id: org.apache.xml.serializer, Version: 2.7.1.v200902170519, Location: reference:file:plugins/org.apache.xml.serializer_2.7.1.v200902170519.jar
Id: org.eclipse.ant.core, Version: 3.2.100.v20090817_r351, Location: reference:file:plugins/org.eclipse.ant.core_3.2.100.v20090817_r351.jar
Id: org.eclipse.ant.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ant.core.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ant.ui, Version: 3.4.2.v20091204_r352, Location: reference:file:plugins/org.eclipse.ant.ui_3.4.2.v20091204_r352.jar
Id: org.eclipse.compare, Version: 3.5.0.I20090514-0808, Location: reference:file:plugins/org.eclipse.compare_3.5.0.I20090514-0808.jar
Id: org.eclipse.compare.core, Version: 3.5.0.I20090430-0408, Location: reference:file:plugins/org.eclipse.compare.core_3.5.0.I20090430-0408.jar
Id: org.eclipse.compare.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.compare.core.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.compare.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.compare.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.compare.win32, Version: 1.0.0.I20090430-0408, Location: reference:file:plugins/org.eclipse.compare.win32_1.0.0.I20090430-0408.jar
Id: org.eclipse.compare.win32.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.compare.win32.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.boot, Version: 3.1.100.v20080218, Location: reference:file:plugins/org.eclipse.core.boot_3.1.100.v20080218.jar
Id: org.eclipse.core.boot.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.boot.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.commands, Version: 3.5.0.I20090525-2000, Location: reference:file:plugins/org.eclipse.core.commands_3.5.0.I20090525-2000.jar
Id: org.eclipse.core.commands.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.commands.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.contenttype, Version: 3.4.1.R35x_v20090826-0451, Location: reference:file:plugins/org.eclipse.core.contenttype_3.4.1.R35x_v20090826-0451.jar
Id: org.eclipse.core.contenttype.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.contenttype.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.databinding, Version: 1.2.0.M20090819-0800, Location: reference:file:plugins/org.eclipse.core.databinding_1.2.0.M20090819-0800.jar
Id: org.eclipse.core.databinding.beans, Version: 1.2.0.I20090525-2000, Location: reference:file:plugins/org.eclipse.core.databinding.beans_1.2.0.I20090525-2000.jar
Id: org.eclipse.core.databinding.beans.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.databinding.beans.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.databinding.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.databinding.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.databinding.observable, Version: 1.2.0.M20090902-0800, Location: reference:file:plugins/org.eclipse.core.databinding.observable_1.2.0.M20090902-0800.jar
Id: org.eclipse.core.databinding.property, Version: 1.2.0.M20090819-0800, Location: reference:file:plugins/org.eclipse.core.databinding.property_1.2.0.M20090819-0800.jar
Id: org.eclipse.core.expressions, Version: 3.4.100.v20090429-1800, Location: reference:file:plugins/org.eclipse.core.expressions_3.4.100.v20090429-1800.jar
Id: org.eclipse.core.expressions.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.expressions.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.filebuffers, Version: 3.5.0.v20090526-2000, Location: reference:file:plugins/org.eclipse.core.filebuffers_3.5.0.v20090526-2000.jar
Id: org.eclipse.core.filebuffers.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.filebuffers.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.filesystem, Version: 1.2.0.v20090507, Location: reference:file:plugins/org.eclipse.core.filesystem_1.2.0.v20090507.jar
Id: org.eclipse.core.filesystem.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.filesystem.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.filesystem.win32.x86, Version: 1.1.0.v20080604-1400, Location: reference:file:plugins/org.eclipse.core.filesystem.win32.x86_1.1.0.v20080604-1400.jar
Id: org.eclipse.core.jobs, Version: 3.4.100.v20090429-1800, Location: reference:file:plugins/org.eclipse.core.jobs_3.4.100.v20090429-1800.jar
Id: org.eclipse.core.jobs.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.jobs.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.net, Version: 1.2.1.r35x_20090812-1200, Location: reference:file:plugins/org.eclipse.core.net_1.2.1.r35x_20090812-1200.jar
Id: org.eclipse.core.net.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.net.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.net.win32.x86, Version: 1.0.0.I20080909, Location: reference:file:plugins/org.eclipse.core.net.win32.x86_1.0.0.I20080909.jar
Id: org.eclipse.core.resources, Version: 3.5.1.R35x_v20090826-0451, Location: reference:file:plugins/org.eclipse.core.resources_3.5.1.R35x_v20090826-0451.jar
Id: org.eclipse.core.resources.compatibility, Version: 3.4.0.v20090505, Location: reference:file:plugins/org.eclipse.core.resources.compatibility_3.4.0.v20090505.jar
Id: org.eclipse.core.resources.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.resources.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.resources.win32.x86, Version: 3.5.0.v20081020, Location: reference:file:plugins/org.eclipse.core.resources.win32.x86_3.5.0.v20081020.jar
Id: org.eclipse.core.runtime, Version: 3.5.0.v20090525, Location: reference:file:plugins/org.eclipse.core.runtime_3.5.0.v20090525.jar
Id: org.eclipse.core.runtime.compatibility, Version: 3.2.0.v20090413, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility_3.2.0.v20090413.jar
Id: org.eclipse.core.runtime.compatibility.auth, Version: 3.2.100.v20090413, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility.auth_3.2.100.v20090413.jar
Id: org.eclipse.core.runtime.compatibility.auth.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility.auth.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.runtime.compatibility.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.runtime.compatibility.registry, Version: 3.2.200.v20090429-1800, Location: reference:file:plugins/org.eclipse.core.runtime.compatibility.registry_3.2.200.v20090429-1800/
Id: org.eclipse.core.runtime.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.runtime.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.core.variables, Version: 3.2.200.v20090521, Location: reference:file:plugins/org.eclipse.core.variables_3.2.200.v20090521.jar
Id: org.eclipse.core.variables.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.core.variables.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.cvs, Version: 1.0.300.v200909170800, Location: reference:file:plugins/org.eclipse.cvs_1.0.300.v200909170800.jar
Id: org.eclipse.datatools.connectivity, Version: 1.1.3.v201001230803, Location: reference:file:plugins/org.eclipse.datatools.connectivity_1.1.3.v201001230803.jar
Id: org.eclipse.datatools.connectivity.apache.derby, Version: 1.0.100.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.connectivity.apache.derby_1.0.100.v200906020900.jar
Id: org.eclipse.datatools.connectivity.apache.derby.dbdefinition, Version: 1.0.2.v200906161815, Location: reference:file:plugins/org.eclipse.datatools.connectivity.apache.derby.dbdefinition_1.0.2.v200906161815.jar
Id: org.eclipse.datatools.connectivity.apache.derby.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.connectivity.apache.derby.ui_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.connectivity.console.profile, Version: 1.0.0.v200906020553, Location: reference:file:plugins/org.eclipse.datatools.connectivity.console.profile_1.0.0.v200906020553.jar
Id: org.eclipse.datatools.connectivity.db.generic, Version: 1.0.1.v200908130547, Location: reference:file:plugins/org.eclipse.datatools.connectivity.db.generic_1.0.1.v200908130547.jar
Id: org.eclipse.datatools.connectivity.db.generic.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.connectivity.db.generic.ui_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.connectivity.dbdefinition.genericJDBC, Version: 1.0.1.v200906161815, Location: reference:file:plugins/org.eclipse.datatools.connectivity.dbdefinition.genericJDBC_1.0.1.v200906161815.jar
Id: org.eclipse.datatools.connectivity.oda, Version: 3.2.2.v201001270833, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda_3.2.2.v201001270833.jar
Id: org.eclipse.datatools.connectivity.oda.consumer, Version: 3.2.2.v201001261113, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.consumer_3.2.2.v201001261113.jar
Id: org.eclipse.datatools.connectivity.oda.design, Version: 3.2.2.v201001210350, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.design_3.2.2.v201001210350.jar
Id: org.eclipse.datatools.connectivity.oda.design.ui, Version: 3.2.2.v201001210350, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.design.ui_3.2.2.v201001210350.jar
Id: org.eclipse.datatools.connectivity.oda.flatfile, Version: 3.1.1.v201001131420, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.flatfile_3.1.1.v201001131420.jar
Id: org.eclipse.datatools.connectivity.oda.flatfile.ui, Version: 3.1.1.v201001131420, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.flatfile.ui_3.1.1.v201001131420.jar
Id: org.eclipse.datatools.connectivity.oda.profile, Version: 3.2.2.v201001210350, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.profile_3.2.2.v201001210350.jar
Id: org.eclipse.datatools.connectivity.oda.template.ui, Version: 3.2.0.v200906020553, Location: reference:file:plugins/org.eclipse.datatools.connectivity.oda.template.ui_3.2.0.v200906020553.jar
Id: org.eclipse.datatools.connectivity.sqm.core, Version: 1.1.1.v201001180200, Location: reference:file:plugins/org.eclipse.datatools.connectivity.sqm.core_1.1.1.v201001180200.jar
Id: org.eclipse.datatools.connectivity.sqm.core.ui, Version: 1.1.100.v200910270525, Location: reference:file:plugins/org.eclipse.datatools.connectivity.sqm.core.ui_1.1.100.v200910270525.jar
Id: org.eclipse.datatools.connectivity.sqm.server.ui, Version: 1.1.100.v200910270503, Location: reference:file:plugins/org.eclipse.datatools.connectivity.sqm.server.ui_1.1.100.v200910270503.jar
Id: org.eclipse.datatools.connectivity.ui, Version: 1.1.5.v201001190218, Location: reference:file:plugins/org.eclipse.datatools.connectivity.ui_1.1.5.v201001190218.jar
Id: org.eclipse.datatools.connectivity.ui.dse, Version: 1.1.3.v201001270323, Location: reference:file:plugins/org.eclipse.datatools.connectivity.ui.dse_1.1.3.v201001270323.jar
Id: org.eclipse.datatools.doc.user, Version: 1.7.0.20090521092446, Location: reference:file:plugins/org.eclipse.datatools.doc.user_1.7.0.20090521092446.jar
Id: org.eclipse.datatools.enablement.finfo, Version: 1.5.1.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.finfo_1.5.1.v200906161800.jar
Id: org.eclipse.datatools.enablement.hsqldb, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.hsqldb_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.hsqldb.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.hsqldb.dbdefinition_1.0.0.v200906161800.jar
Id: org.eclipse.datatools.enablement.hsqldb.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.hsqldb.ui_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.ibm.db2.iseries, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.iseries_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinition, Version: 1.0.3.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinition_1.0.3.v200906161800.jar
Id: org.eclipse.datatools.enablement.ibm.db2.iseries.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.iseries.ui_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.ibm.db2.luw, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.luw_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition, Version: 1.0.3.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition_1.0.3.v200906161800.jar
Id: org.eclipse.datatools.enablement.ibm.db2.luw.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.luw.ui_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.ibm.db2.zseries, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.zseries_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinition, Version: 1.0.3.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinition_1.0.3.v200906161800.jar
Id: org.eclipse.datatools.enablement.ibm.db2.zseries.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.db2.zseries.ui_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.ibm.informix, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.informix_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.ibm.informix.dbdefinition, Version: 1.0.3.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.informix.dbdefinition_1.0.3.v200906161800.jar
Id: org.eclipse.datatools.enablement.ibm.informix.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.informix.ui_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.ibm.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.ibm.ui_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.ingres, Version: 1.0.0.v200906111150, Location: reference:file:plugins/org.eclipse.datatools.enablement.ingres_1.0.0.v200906111150.jar
Id: org.eclipse.datatools.enablement.ingres.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.ingres.dbdefinition_1.0.0.v200906161800.jar
Id: org.eclipse.datatools.enablement.ingres.ui, Version: 1.0.0.v200906111150, Location: reference:file:plugins/org.eclipse.datatools.enablement.ingres.ui_1.0.0.v200906111150.jar
Id: org.eclipse.datatools.enablement.jdt.classpath, Version: 1.0.1.v200909240342, Location: reference:file:plugins/org.eclipse.datatools.enablement.jdt.classpath_1.0.1.v200909240342.jar
Id: org.eclipse.datatools.enablement.msft.sqlserver, Version: 1.0.1.v201001180222, Location: reference:file:plugins/org.eclipse.datatools.enablement.msft.sqlserver_1.0.1.v201001180222.jar
Id: org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition_1.0.0.v200906161800.jar
Id: org.eclipse.datatools.enablement.msft.sqlserver.ui, Version: 1.0.1.v200908130512, Location: reference:file:plugins/org.eclipse.datatools.enablement.msft.sqlserver.ui_1.0.1.v200908130512.jar
Id: org.eclipse.datatools.enablement.mysql, Version: 1.0.2.v201002041110, Location: reference:file:plugins/org.eclipse.datatools.enablement.mysql_1.0.2.v201002041110.jar
Id: org.eclipse.datatools.enablement.mysql.dbdefinition, Version: 1.0.4.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.mysql.dbdefinition_1.0.4.v200906161800.jar
Id: org.eclipse.datatools.enablement.mysql.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.mysql.ui_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.oda.ws, Version: 1.2.2.v201001131420, Location: reference:file:plugins/org.eclipse.datatools.enablement.oda.ws_1.2.2.v201001131420.jar
Id: org.eclipse.datatools.enablement.oda.ws.ui, Version: 1.2.2.v201001260400, Location: reference:file:plugins/org.eclipse.datatools.enablement.oda.ws.ui_1.2.2.v201001260400.jar
Id: org.eclipse.datatools.enablement.oda.xml, Version: 1.2.1.v201001151620, Location: reference:file:plugins/org.eclipse.datatools.enablement.oda.xml_1.2.1.v201001151620.jar
Id: org.eclipse.datatools.enablement.oda.xml.ui, Version: 1.2.1.v201001191820, Location: reference:file:plugins/org.eclipse.datatools.enablement.oda.xml.ui_1.2.1.v201001191820.jar
Id: org.eclipse.datatools.enablement.oracle, Version: 1.0.0.v200908130544, Location: reference:file:plugins/org.eclipse.datatools.enablement.oracle_1.0.0.v200908130544.jar
Id: org.eclipse.datatools.enablement.oracle.dbdefinition, Version: 1.0.100.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.oracle.dbdefinition_1.0.100.v200906161800.jar
Id: org.eclipse.datatools.enablement.oracle.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.oracle.ui_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.postgresql, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.postgresql_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.postgresql.dbdefinition, Version: 1.0.1.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.postgresql.dbdefinition_1.0.1.v200906161800.jar
Id: org.eclipse.datatools.enablement.postgresql.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.postgresql.ui_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.sap.maxdb, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sap.maxdb_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.sap.maxdb.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.sap.maxdb.dbdefinition_1.0.0.v200906161800.jar
Id: org.eclipse.datatools.enablement.sap.maxdb.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sap.maxdb.ui_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.sqlite, Version: 1.0.0.v201002041110, Location: reference:file:plugins/org.eclipse.datatools.enablement.sqlite_1.0.0.v201002041110.jar
Id: org.eclipse.datatools.enablement.sqlite.dbdefinition, Version: 1.0.1.v201002041110, Location: reference:file:plugins/org.eclipse.datatools.enablement.sqlite.dbdefinition_1.0.1.v201002041110.jar
Id: org.eclipse.datatools.enablement.sqlite.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sqlite.ui_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.sybase, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.sybase.asa, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.asa_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.sybase.asa.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.asa.dbdefinition_1.0.0.v200906161800.jar
Id: org.eclipse.datatools.enablement.sybase.asa.models, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.asa.models_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.sybase.asa.schemaobjecteditor.examples, Version: 2.5.0.200810071, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.asa.schemaobjecteditor.examples_2.5.0.200810071.jar
Id: org.eclipse.datatools.enablement.sybase.asa.ui, Version: 1.0.1.v200906111150, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.asa.ui_1.0.1.v200906111150.jar
Id: org.eclipse.datatools.enablement.sybase.ase, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.ase_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.sybase.ase.dbdefinition, Version: 1.0.0.v200906161800, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.ase.dbdefinition_1.0.0.v200906161800.jar
Id: org.eclipse.datatools.enablement.sybase.ase.models, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.ase.models_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.sybase.ase.ui, Version: 1.0.1.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.ase.ui_1.0.1.v200906020900.jar
Id: org.eclipse.datatools.enablement.sybase.models, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.models_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.enablement.sybase.ui, Version: 1.0.0.v200906090458, Location: reference:file:plugins/org.eclipse.datatools.enablement.sybase.ui_1.0.0.v200906090458.jar
Id: org.eclipse.datatools.help, Version: 1.5.0.v200906020553, Location: reference:file:plugins/org.eclipse.datatools.help_1.5.0.v200906020553.jar
Id: org.eclipse.datatools.modelbase.dbdefinition, Version: 1.0.1.v200906022249, Location: reference:file:plugins/org.eclipse.datatools.modelbase.dbdefinition_1.0.1.v200906022249.jar
Id: org.eclipse.datatools.modelbase.derby, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.modelbase.derby_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.modelbase.sql, Version: 1.0.3.v200912150851, Location: reference:file:plugins/org.eclipse.datatools.modelbase.sql_1.0.3.v200912150851.jar
Id: org.eclipse.datatools.modelbase.sql.edit, Version: 1.0.0.v200906022249, Location: reference:file:plugins/org.eclipse.datatools.modelbase.sql.edit_1.0.0.v200906022249.jar
Id: org.eclipse.datatools.modelbase.sql.query, Version: 1.0.2.v201002020730, Location: reference:file:plugins/org.eclipse.datatools.modelbase.sql.query_1.0.2.v201002020730.jar
Id: org.eclipse.datatools.modelbase.sql.query.edit, Version: 1.0.0.v200906022249, Location: reference:file:plugins/org.eclipse.datatools.modelbase.sql.query.edit_1.0.0.v200906022249.jar
Id: org.eclipse.datatools.modelbase.sql.xml.query, Version: 1.0.0.v200906022249, Location: reference:file:plugins/org.eclipse.datatools.modelbase.sql.xml.query_1.0.0.v200906022249.jar
Id: org.eclipse.datatools.oda.cshelp, Version: 1.1.1.v200907031118, Location: reference:file:plugins/org.eclipse.datatools.oda.cshelp_1.1.1.v200907031118.jar
Id: org.eclipse.datatools.sqltools.common.ui, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.common.ui_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.data.core, Version: 1.1.0.v200910161545, Location: reference:file:plugins/org.eclipse.datatools.sqltools.data.core_1.1.0.v200910161545.jar
Id: org.eclipse.datatools.sqltools.data.ui, Version: 1.1.2.v200912080845, Location: reference:file:plugins/org.eclipse.datatools.sqltools.data.ui_1.1.2.v200912080845.jar
Id: org.eclipse.datatools.sqltools.db.derby, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.sqltools.db.derby_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.sqltools.db.derby.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.sqltools.db.derby.ui_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.sqltools.db.generic, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.sqltools.db.generic_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.sqltools.db.generic.ui, Version: 1.0.0.v200906020900, Location: reference:file:plugins/org.eclipse.datatools.sqltools.db.generic.ui_1.0.0.v200906020900.jar
Id: org.eclipse.datatools.sqltools.ddlgen.ui, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.ddlgen.ui_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.debugger.core, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.debugger.core_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.debugger.core.ui, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.debugger.core.ui_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.editor.core, Version: 1.0.0.v201001150815, Location: reference:file:plugins/org.eclipse.datatools.sqltools.editor.core_1.0.0.v201001150815.jar
Id: org.eclipse.datatools.sqltools.editor.core.ui, Version: 1.0.0.v201001150815, Location: reference:file:plugins/org.eclipse.datatools.sqltools.editor.core.ui_1.0.0.v201001150815.jar
Id: org.eclipse.datatools.sqltools.parsers.sql, Version: 1.0.1.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.parsers.sql_1.0.1.v200906022302.jar
Id: org.eclipse.datatools.sqltools.parsers.sql.lexer, Version: 1.0.1.v200906030654, Location: reference:file:plugins/org.eclipse.datatools.sqltools.parsers.sql.lexer_1.0.1.v200906030654.jar
Id: org.eclipse.datatools.sqltools.parsers.sql.query, Version: 1.0.1.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.parsers.sql.query_1.0.1.v200906022302.jar
Id: org.eclipse.datatools.sqltools.parsers.sql.xml.query, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.parsers.sql.xml.query_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.plan, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.plan_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.result, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.result_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.result.ui, Version: 1.0.2.v201002011830, Location: reference:file:plugins/org.eclipse.datatools.sqltools.result.ui_1.0.2.v201002011830.jar
Id: org.eclipse.datatools.sqltools.routineeditor, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.routineeditor_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.routineeditor.ui, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.routineeditor.ui_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.schemaobjecteditor, Version: 1.1.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.schemaobjecteditor_1.1.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.schemaobjecteditor.ui, Version: 1.1.0.200810071, Location: reference:file:plugins/org.eclipse.datatools.sqltools.schemaobjecteditor.ui_1.1.0.200810071.jar
Id: org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages, Version: 1.1.0.200810071, Location: reference:file:plugins/org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages_1.1.0.200810071.jar
Id: org.eclipse.datatools.sqltools.sql, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.sql_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.sql.ui, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.sql.ui_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.sqlbuilder, Version: 1.0.0.v201001200600, Location: reference:file:plugins/org.eclipse.datatools.sqltools.sqlbuilder_1.0.0.v201001200600.jar
Id: org.eclipse.datatools.sqltools.sqleditor, Version: 1.0.1.v200912241345, Location: reference:file:plugins/org.eclipse.datatools.sqltools.sqleditor_1.0.1.v200912241345.jar
Id: org.eclipse.datatools.sqltools.sqlscrapbook, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.sqlscrapbook_1.0.0.v200906022302.jar
Id: org.eclipse.datatools.sqltools.tabledataeditor, Version: 1.0.0.v200906022302, Location: reference:file:plugins/org.eclipse.datatools.sqltools.tabledataeditor_1.0.0.v200906022302.jar
Id: org.eclipse.debug.core, Version: 3.5.0.v20090526-1600, Location: reference:file:plugins/org.eclipse.debug.core_3.5.0.v20090526-1600.jar
Id: org.eclipse.debug.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.debug.core.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.debug.ui, Version: 3.5.1.v20090811_r351, Location: reference:file:plugins/org.eclipse.debug.ui_3.5.1.v20090811_r351.jar
Id: org.eclipse.debug.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.debug.ui.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.draw2d, Version: 3.5.2.v20091126-1908, Location: reference:file:plugins/org.eclipse.draw2d_3.5.2.v20091126-1908.jar
Id: org.eclipse.ecf, Version: 3.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf_3.0.0.v20090831-1906.jar
Id: org.eclipse.ecf.filetransfer, Version: 3.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.filetransfer_3.0.0.v20090831-1906.jar
Id: org.eclipse.ecf.identity, Version: 3.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.identity_3.0.0.v20090831-1906.jar
Id: org.eclipse.ecf.provider.filetransfer, Version: 3.0.1.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer_3.0.1.v20090831-1906.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient, Version: 3.0.1.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient_3.0.1.v20090831-1906.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient.ssl, Version: 1.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient.ssl_1.0.0.v20090831-1906.jar
Id: org.eclipse.ecf.provider.filetransfer.ssl, Version: 1.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20090831-1906.jar
Id: org.eclipse.ecf.ssl, Version: 1.0.0.v20090831-1906, Location: reference:file:plugins/org.eclipse.ecf.ssl_1.0.0.v20090831-1906.jar
Id: org.eclipse.emf, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf_2.5.0.v200906151043.jar
Id: org.eclipse.emf.ant, Version: 2.4.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ant_2.4.0.v200906151043.jar
Id: org.eclipse.emf.codegen, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.codegen_2.5.0.v200906151043.jar
Id: org.eclipse.emf.codegen.ecore, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.codegen.ecore_2.5.0.v200906151043.jar
Id: org.eclipse.emf.codegen.ecore.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.codegen.ecore.ui_2.5.0.v200906151043.jar
Id: org.eclipse.emf.codegen.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.codegen.ui_2.5.0.v200906151043.jar
Id: org.eclipse.emf.common, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.common_2.5.0.v200906151043.jar
Id: org.eclipse.emf.common.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.common.ui_2.5.0.v200906151043.jar
Id: org.eclipse.emf.converter, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.converter_2.5.0.v200906151043.jar
Id: org.eclipse.emf.databinding, Version: 1.1.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.databinding_1.1.0.v200906151043.jar
Id: org.eclipse.emf.databinding.edit, Version: 1.1.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.databinding.edit_1.1.0.v200906151043.jar
Id: org.eclipse.emf.ecore, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore_2.5.0.v200906151043.jar
Id: org.eclipse.emf.ecore.change, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore.change_2.5.0.v200906151043.jar
Id: org.eclipse.emf.ecore.change.edit, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore.change.edit_2.5.0.v200906151043.jar
Id: org.eclipse.emf.ecore.edit, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore.edit_2.5.0.v200906151043.jar
Id: org.eclipse.emf.ecore.editor, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore.editor_2.5.0.v200906151043.jar
Id: org.eclipse.emf.ecore.xmi, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.ecore.xmi_2.5.0.v200906151043.jar
Id: org.eclipse.emf.edit, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.edit_2.5.0.v200906151043.jar
Id: org.eclipse.emf.edit.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.edit.ui_2.5.0.v200906151043.jar
Id: org.eclipse.emf.exporter, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.exporter_2.5.0.v200906151043.jar
Id: org.eclipse.emf.importer, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.importer_2.5.0.v200906151043.jar
Id: org.eclipse.emf.importer.ecore, Version: 2.4.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.importer.ecore_2.4.0.v200906151043.jar
Id: org.eclipse.emf.importer.java, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.importer.java_2.5.0.v200906151043.jar
Id: org.eclipse.emf.importer.rose, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.importer.rose_2.5.0.v200906151043.jar
Id: org.eclipse.emf.mapping, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping_2.5.0.v200906151043.jar
Id: org.eclipse.emf.mapping.ecore, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore_2.5.0.v200906151043.jar
Id: org.eclipse.emf.mapping.ecore.editor, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore.editor_2.5.0.v200906151043.jar
Id: org.eclipse.emf.mapping.ecore2ecore, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore2ecore_2.5.0.v200906151043.jar
Id: org.eclipse.emf.mapping.ecore2ecore.editor, Version: 2.4.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore2ecore.editor_2.4.0.v200906151043.jar
Id: org.eclipse.emf.mapping.ecore2xml, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore2xml_2.5.0.v200906151043.jar
Id: org.eclipse.emf.mapping.ecore2xml.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ecore2xml.ui_2.5.0.v200906151043.jar
Id: org.eclipse.emf.mapping.ui, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.emf.mapping.ui_2.5.0.v200906151043.jar
Id: org.eclipse.equinox.app, Version: 1.2.0.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.app_1.2.0.v20090520-1800.jar
Id: org.eclipse.equinox.common, Version: 3.5.1.R35x_v20090807-1100, Location: reference:file:plugins/org.eclipse.equinox.common_3.5.1.R35x_v20090807-1100.jar
Id: org.eclipse.equinox.common.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.common.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.concurrent, Version: 1.0.1.R35x_v20100209, Location: reference:file:plugins/org.eclipse.equinox.concurrent_1.0.1.R35x_v20100209.jar
Id: org.eclipse.equinox.ds, Version: 1.1.1.R35x_v20090806, Location: initial@reference:file:plugins/org.eclipse.equinox.ds_1.1.1.R35x_v20090806.jar/
Id: org.eclipse.equinox.ds.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.ds.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.frameworkadmin, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.frameworkadmin.equinox, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin.equinox_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.http.jetty, Version: 2.0.0.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.http.jetty_2.0.0.v20090520-1800.jar
Id: org.eclipse.equinox.http.registry, Version: 1.0.200.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.http.registry_1.0.200.v20090520-1800.jar
Id: org.eclipse.equinox.http.registry.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.http.registry.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.http.servlet, Version: 1.0.200.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.http.servlet_1.0.200.v20090520-1800.jar
Id: org.eclipse.equinox.http.servlet.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.http.servlet.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.jsp.jasper, Version: 1.0.200.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper_1.0.200.v20090520-1800.jar
Id: org.eclipse.equinox.jsp.jasper.registry, Version: 1.0.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper.registry_1.0.100.v20090520-1800.jar
Id: org.eclipse.equinox.launcher, Version: 1.0.201.R35x_v20090715, Location: reference:file:plugins/org.eclipse.equinox.launcher_1.0.201.R35x_v20090715.jar
Id: org.eclipse.equinox.launcher.win32.win32.x86, Version: 1.0.200.v20090519, Location: reference:file:plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519/
Id: org.eclipse.equinox.p2.artifact.repository, Version: 1.0.101.R35x_v20090721, Location: reference:file:plugins/org.eclipse.equinox.p2.artifact.repository_1.0.101.R35x_v20090721.jar
Id: org.eclipse.equinox.p2.artifact.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.artifact.repository.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.console, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.console_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.p2.console.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.console.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.core, Version: 1.0.101.R35x_v20090819, Location: reference:file:plugins/org.eclipse.equinox.p2.core_1.0.101.R35x_v20090819.jar
Id: org.eclipse.equinox.p2.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.core.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.director, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.director_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.p2.director.app, Version: 1.0.100.v20090521-1912, Location: reference:file:plugins/org.eclipse.equinox.p2.director.app_1.0.100.v20090521-1912.jar
Id: org.eclipse.equinox.p2.director.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.director.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.directorywatcher, Version: 1.0.100.v20090525, Location: reference:file:plugins/org.eclipse.equinox.p2.directorywatcher_1.0.100.v20090525.jar
Id: org.eclipse.equinox.p2.engine, Version: 1.0.101.R35x_v20090825, Location: reference:file:plugins/org.eclipse.equinox.p2.engine_1.0.101.R35x_v20090825.jar
Id: org.eclipse.equinox.p2.engine.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.engine.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.exemplarysetup, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.exemplarysetup_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.p2.exemplarysetup.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.exemplarysetup.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.extensionlocation, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.extensionlocation_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.p2.extensionlocation.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.extensionlocation.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.garbagecollector, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.garbagecollector_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.p2.garbagecollector.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.garbagecollector.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.jarprocessor, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.jarprocessor_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.p2.jarprocessor.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.jarprocessor.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.metadata, Version: 1.0.100.v20090525, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata_1.0.100.v20090525.jar
Id: org.eclipse.equinox.p2.metadata.generator, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.generator_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.p2.metadata.generator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.generator.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.metadata.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.metadata.repository, Version: 1.0.101.R35x_v20090812, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.repository_1.0.101.R35x_v20090812.jar
Id: org.eclipse.equinox.p2.metadata.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.repository.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.publisher, Version: 1.0.0.v20090527-1812, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher_1.0.0.v20090527-1812.jar
Id: org.eclipse.equinox.p2.publisher.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.reconciler.dropins, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.p2.reconciler.dropins.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.repository, Version: 1.0.1.v20090901-1041, Location: reference:file:plugins/org.eclipse.equinox.p2.repository_1.0.1.v20090901-1041.jar
Id: org.eclipse.equinox.p2.repository.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.repository.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.repository.tools, Version: 1.0.1.R35x_v20090806, Location: reference:file:plugins/org.eclipse.equinox.p2.repository.tools_1.0.1.R35x_v20090806.jar
Id: org.eclipse.equinox.p2.repository.tools.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.repository.tools.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.touchpoint.eclipse, Version: 1.0.101.R35x_20090820-1821, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse_1.0.101.R35x_20090820-1821.jar
Id: org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.touchpoint.natives, Version: 1.0.101.R35x_v20090806, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.natives_1.0.101.R35x_v20090806.jar
Id: org.eclipse.equinox.p2.touchpoint.natives.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.natives.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.ui, Version: 1.0.101.R35x_v20090819, Location: reference:file:plugins/org.eclipse.equinox.p2.ui_1.0.101.R35x_v20090819.jar
Id: org.eclipse.equinox.p2.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.ui.sdk, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.p2.ui.sdk.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.ui.sdk.scheduler, Version: 1.0.0.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.scheduler_1.0.0.v20090520-1905.jar
Id: org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.scheduler.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.updatechecker, Version: 1.1.0.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.p2.updatechecker_1.1.0.v20090520-1905.jar
Id: org.eclipse.equinox.p2.updatechecker.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.updatechecker.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.p2.updatesite, Version: 1.0.100.v20090525, Location: reference:file:plugins/org.eclipse.equinox.p2.updatesite_1.0.100.v20090525.jar
Id: org.eclipse.equinox.p2.updatesite.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.p2.updatesite.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.preferences, Version: 3.2.300.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.preferences_3.2.300.v20090520-1800.jar
Id: org.eclipse.equinox.preferences.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.preferences.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.registry, Version: 3.4.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.registry_3.4.100.v20090520-1800.jar
Id: org.eclipse.equinox.registry.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.registry.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.security, Version: 1.0.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.security_1.0.100.v20090520-1800.jar
Id: org.eclipse.equinox.security.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.security.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.security.ui, Version: 1.0.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.security.ui_1.0.100.v20090520-1800.jar
Id: org.eclipse.equinox.security.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.equinox.security.ui.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.equinox.security.win32.x86, Version: 1.0.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.security.win32.x86_1.0.100.v20090520-1800.jar
Id: org.eclipse.equinox.simpleconfigurator, Version: 1.0.101.R35x_v20090807-1100, Location: initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.0.101.R35x_v20090807-1100.jar/
Id: org.eclipse.equinox.simpleconfigurator.manipulator, Version: 1.0.100.v20090520-1905, Location: reference:file:plugins/org.eclipse.equinox.simpleconfigurator.manipulator_1.0.100.v20090520-1905.jar
Id: org.eclipse.equinox.util, Version: 1.0.100.v20090520-1800, Location: reference:file:plugins/org.eclipse.equinox.util_1.0.100.v20090520-1800.jar
Id: org.eclipse.gef, Version: 3.5.1.v20090910-2020, Location: reference:file:plugins/org.eclipse.gef_3.5.1.v20090910-2020.jar
Id: org.eclipse.help, Version: 3.4.1.v20090805_35x, Location: reference:file:plugins/org.eclipse.help_3.4.1.v20090805_35x.jar
Id: org.eclipse.help.appserver, Version: 3.1.400.v20090429_1800, Location: reference:file:plugins/org.eclipse.help.appserver_3.1.400.v20090429_1800.jar
Id: org.eclipse.help.appserver.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.help.appserver.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.help.base, Version: 3.4.0.v200909170800, Location: reference:file:plugins/org.eclipse.help.base_3.4.0.v200909170800.jar
Id: org.eclipse.help.base.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.help.base.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.help.ui, Version: 3.4.1.v20090819_35x, Location: reference:file:plugins/org.eclipse.help.ui_3.4.1.v20090819_35x.jar
Id: org.eclipse.help.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.help.ui.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.help.webapp, Version: 3.4.1.v20090819_35x, Location: reference:file:plugins/org.eclipse.help.webapp_3.4.1.v20090819_35x.jar
Id: org.eclipse.help.webapp.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.help.webapp.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.jdt, Version: 3.5.2.v201002111343, Location: reference:file:plugins/org.eclipse.jdt_3.5.2.v201002111343.jar
Id: org.eclipse.jdt.apt.core, Version: 3.3.202.R35x_v20091130-2300, Location: reference:file:plugins/org.eclipse.jdt.apt.core_3.3.202.R35x_v20091130-2300.jar
Id: org.eclipse.jdt.apt.pluggable.core, Version: 1.0.201.R35x_v20090925-1100, Location: reference:file:plugins/org.eclipse.jdt.apt.pluggable.core_1.0.201.R35x_v20090925-1100.jar
Id: org.eclipse.jdt.apt.ui, Version: 3.3.200.v20090930-2100_R35x, Location: reference:file:plugins/org.eclipse.jdt.apt.ui_3.3.200.v20090930-2100_R35x.jar
Id: org.eclipse.jdt.compiler.apt, Version: 1.0.201.R35x_v20090925-1100, Location: reference:file:plugins/org.eclipse.jdt.compiler.apt_1.0.201.R35x_v20090925-1100.jar
Id: org.eclipse.jdt.compiler.tool, Version: 1.0.100.v_981_R35x, Location: reference:file:plugins/org.eclipse.jdt.compiler.tool_1.0.100.v_981_R35x.jar
Id: org.eclipse.jdt.core, Version: 3.5.2.v_981_R35x, Location: reference:file:plugins/org.eclipse.jdt.core_3.5.2.v_981_R35x.jar
Id: org.eclipse.jdt.core.manipulation, Version: 1.3.0.v20090603, Location: reference:file:plugins/org.eclipse.jdt.core.manipulation_1.3.0.v20090603.jar
Id: org.eclipse.jdt.debug, Version: 3.5.0.v20090526, Location: reference:file:plugins/org.eclipse.jdt.debug_3.5.0.v20090526/
Id: org.eclipse.jdt.debug.ui, Version: 3.4.1.v20090811_r351, Location: reference:file:plugins/org.eclipse.jdt.debug.ui_3.4.1.v20090811_r351.jar
Id: org.eclipse.jdt.doc.user, Version: 3.5.2.r352_v20091015, Location: reference:file:plugins/org.eclipse.jdt.doc.user_3.5.2.r352_v20091015.jar
Id: org.eclipse.jdt.junit, Version: 3.5.2.r352_v20100113-0800, Location: reference:file:plugins/org.eclipse.jdt.junit_3.5.2.r352_v20100113-0800.jar
Id: org.eclipse.jdt.junit.runtime, Version: 3.4.100.v20090513-2000, Location: reference:file:plugins/org.eclipse.jdt.junit.runtime_3.4.100.v20090513-2000.jar
Id: org.eclipse.jdt.junit4.runtime, Version: 1.1.0.v20090513-2000, Location: reference:file:plugins/org.eclipse.jdt.junit4.runtime_1.1.0.v20090513-2000.jar
Id: org.eclipse.jdt.launching, Version: 3.5.1.v20100108_r352, Location: reference:file:plugins/org.eclipse.jdt.launching_3.5.1.v20100108_r352.jar
Id: org.eclipse.jdt.ui, Version: 3.5.2.r352_v20100106-0800, Location: reference:file:plugins/org.eclipse.jdt.ui_3.5.2.r352_v20100106-0800.jar
Id: org.eclipse.jem, Version: 2.0.301.v201001252130, Location: reference:file:plugins/org.eclipse.jem_2.0.301.v201001252130.jar
Id: org.eclipse.jem.proxy, Version: 2.0.201.v200908101600, Location: reference:file:plugins/org.eclipse.jem.proxy_2.0.201.v200908101600.jar
Id: org.eclipse.jem.util, Version: 2.0.201.v201001252130, Location: reference:file:plugins/org.eclipse.jem.util_2.0.201.v201001252130.jar
Id: org.eclipse.jem.workbench, Version: 2.0.201.v200911302230, Location: reference:file:plugins/org.eclipse.jem.workbench_2.0.201.v200911302230.jar
Id: org.eclipse.jface, Version: 3.5.1.M20090826-0800, Location: reference:file:plugins/org.eclipse.jface_3.5.1.M20090826-0800.jar
Id: org.eclipse.jface.databinding, Version: 1.3.1.M20090826-0800, Location: reference:file:plugins/org.eclipse.jface.databinding_1.3.1.M20090826-0800.jar
Id: org.eclipse.jface.databinding.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.jface.databinding.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.jface.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.jface.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.jface.text, Version: 3.5.1.r351_v20090708-0800, Location: reference:file:plugins/org.eclipse.jface.text_3.5.1.r351_v20090708-0800.jar
Id: org.eclipse.jface.text.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.jface.text.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.jpt.branding, Version: 2.2.2.v200911250220, Location: reference:file:plugins/org.eclipse.jpt.branding_2.2.2.v200911250220.jar
Id: org.eclipse.jpt.core, Version: 2.2.1.v200908270220, Location: reference:file:plugins/org.eclipse.jpt.core_2.2.1.v200908270220.jar
Id: org.eclipse.jpt.db, Version: 1.2.102.v200911250220, Location: reference:file:plugins/org.eclipse.jpt.db_1.2.102.v200911250220.jar
Id: org.eclipse.jpt.db.ui, Version: 1.1.100.v200906070220, Location: reference:file:plugins/org.eclipse.jpt.db.ui_1.1.100.v200906070220.jar
Id: org.eclipse.jpt.doc.isv, Version: 1.2.0.v200906050220, Location: reference:file:plugins/org.eclipse.jpt.doc.isv_1.2.0.v200906050220.jar
Id: org.eclipse.jpt.doc.user, Version: 1.1.1.v200908270220, Location: reference:file:plugins/org.eclipse.jpt.doc.user_1.1.1.v200908270220.jar
Id: org.eclipse.jpt.eclipselink.branding, Version: 2.2.2.v200911250220, Location: reference:file:plugins/org.eclipse.jpt.eclipselink.branding_2.2.2.v200911250220.jar
Id: org.eclipse.jpt.eclipselink.core, Version: 1.2.0.v200905310000, Location: reference:file:plugins/org.eclipse.jpt.eclipselink.core_1.2.0.v200905310000.jar
Id: org.eclipse.jpt.eclipselink.core.ddlgen, Version: 1.0.200.v200906070220, Location: reference:file:plugins/org.eclipse.jpt.eclipselink.core.ddlgen_1.0.200.v200906070220.jar
Id: org.eclipse.jpt.eclipselink.ui, Version: 1.2.0.v200905310000, Location: reference:file:plugins/org.eclipse.jpt.eclipselink.ui_1.2.0.v200905310000.jar
Id: org.eclipse.jpt.gen, Version: 1.3.2.v201001290220, Location: reference:file:plugins/org.eclipse.jpt.gen_1.3.2.v201001290220.jar
Id: org.eclipse.jpt.ui, Version: 2.2.2.v200911250220, Location: reference:file:plugins/org.eclipse.jpt.ui_2.2.2.v200911250220.jar
Id: org.eclipse.jpt.utility, Version: 1.4.0.v200905310000, Location: reference:file:plugins/org.eclipse.jpt.utility_1.4.0.v200905310000.jar
Id: org.eclipse.jsch.core, Version: 1.1.100.I20090430-0408, Location: reference:file:plugins/org.eclipse.jsch.core_1.1.100.I20090430-0408.jar
Id: org.eclipse.jsch.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.jsch.core.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.jsch.ui, Version: 1.1.200.I20090430-0408, Location: reference:file:plugins/org.eclipse.jsch.ui_1.1.200.I20090430-0408.jar
Id: org.eclipse.jsch.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.jsch.ui.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.jst.common.annotations.controller, Version: 1.1.100.v200805140020, Location: reference:file:plugins/org.eclipse.jst.common.annotations.controller_1.1.100.v200805140020.jar
Id: org.eclipse.jst.common.annotations.core, Version: 1.1.200.v201001272230, Location: reference:file:plugins/org.eclipse.jst.common.annotations.core_1.1.200.v201001272230.jar
Id: org.eclipse.jst.common.frameworks, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.jst.common.frameworks_1.1.301.v201001252130.jar
Id: org.eclipse.jst.common.project.facet.core, Version: 1.4.1.v200911141836, Location: reference:file:plugins/org.eclipse.jst.common.project.facet.core_1.4.1.v200911141836.jar
Id: org.eclipse.jst.common.project.facet.ui, Version: 1.4.1.v200912011928, Location: reference:file:plugins/org.eclipse.jst.common.project.facet.ui_1.4.1.v200912011928.jar
Id: org.eclipse.jst.ejb.doc.user, Version: 1.1.100.v200810092245, Location: reference:file:plugins/org.eclipse.jst.ejb.doc.user_1.1.100.v200810092245.jar
Id: org.eclipse.jst.ejb.ui, Version: 1.1.301.v200908131325, Location: reference:file:plugins/org.eclipse.jst.ejb.ui_1.1.301.v200908131325.jar
Id: org.eclipse.jst.ejb.ui.infopop, Version: 1.0.200.v200905141725, Location: reference:file:plugins/org.eclipse.jst.ejb.ui.infopop_1.0.200.v200905141725.jar
Id: org.eclipse.jst.j2ee, Version: 1.1.302.v201004131604, Location: reference:file:plugins/org.eclipse.jst.j2ee_1.1.302.v201004131604.jar
Id: org.eclipse.jst.j2ee.core, Version: 1.1.301.v200911302230, Location: reference:file:plugins/org.eclipse.jst.j2ee.core_1.1.301.v200911302230.jar
Id: org.eclipse.jst.j2ee.doc.user, Version: 1.1.100.v200810071436, Location: reference:file:plugins/org.eclipse.jst.j2ee.doc.user_1.1.100.v200810071436.jar
Id: org.eclipse.jst.j2ee.ejb, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.jst.j2ee.ejb_1.1.301.v201001252130.jar
Id: org.eclipse.jst.j2ee.ejb.annotation.model, Version: 1.1.102.v200805140020, Location: reference:file:plugins/org.eclipse.jst.j2ee.ejb.annotation.model_1.1.102.v200805140020.jar
Id: org.eclipse.jst.j2ee.ejb.annotations.emitter, Version: 1.1.102.v200805140135, Location: reference:file:plugins/org.eclipse.jst.j2ee.ejb.annotations.emitter_1.1.102.v200805140135.jar
Id: org.eclipse.jst.j2ee.ejb.annotations.ui, Version: 1.1.102.v200805140020, Location: reference:file:plugins/org.eclipse.jst.j2ee.ejb.annotations.ui_1.1.102.v200805140020.jar
Id: org.eclipse.jst.j2ee.ejb.annotations.xdoclet, Version: 1.2.0.v200805140020, Location: reference:file:plugins/org.eclipse.jst.j2ee.ejb.annotations.xdoclet_1.2.0.v200805140020.jar
Id: org.eclipse.jst.j2ee.infopop, Version: 1.0.300.v200805140415, Location: reference:file:plugins/org.eclipse.jst.j2ee.infopop_1.0.300.v200805140415.jar
Id: org.eclipse.jst.j2ee.jca, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.jst.j2ee.jca_1.1.301.v201001252130.jar
Id: org.eclipse.jst.j2ee.jca.ui, Version: 1.1.300.v200809052300, Location: reference:file:plugins/org.eclipse.jst.j2ee.jca.ui_1.1.300.v200809052300.jar
Id: org.eclipse.jst.j2ee.navigator.ui, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.jst.j2ee.navigator.ui_1.1.301.v201001252130.jar
Id: org.eclipse.jst.j2ee.ui, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.jst.j2ee.ui_1.1.301.v201001252130.jar
Id: org.eclipse.jst.j2ee.web, Version: 1.1.301.v200911302230, Location: reference:file:plugins/org.eclipse.jst.j2ee.web_1.1.301.v200911302230.jar
Id: org.eclipse.jst.j2ee.webservice, Version: 1.1.300.v200901220600, Location: reference:file:plugins/org.eclipse.jst.j2ee.webservice_1.1.300.v200901220600.jar
Id: org.eclipse.jst.j2ee.webservice.ui, Version: 1.1.300.v200902052230, Location: reference:file:plugins/org.eclipse.jst.j2ee.webservice.ui_1.1.300.v200902052230.jar
Id: org.eclipse.jst.j2ee.xdoclet.runtime, Version: 1.1.102.v200805140135, Location: reference:file:plugins/org.eclipse.jst.j2ee.xdoclet.runtime_1.1.102.v200805140135.jar
Id: org.eclipse.jst.jee, Version: 1.0.201.v201002021055, Location: reference:file:plugins/org.eclipse.jst.jee_1.0.201.v201002021055.jar
Id: org.eclipse.jst.jee.ejb, Version: 1.0.201.v201002021057, Location: reference:file:plugins/org.eclipse.jst.jee.ejb_1.0.201.v201002021057.jar
Id: org.eclipse.jst.jee.ui, Version: 1.0.201.v201002021208, Location: reference:file:plugins/org.eclipse.jst.jee.ui_1.0.201.v201002021208.jar
Id: org.eclipse.jst.jsf.apache.trinidad.tagsupport, Version: 1.1.0.v20090525, Location: reference:file:plugins/org.eclipse.jst.jsf.apache.trinidad.tagsupport_1.1.0.v20090525.jar
Id: org.eclipse.jst.jsf.common, Version: 1.1.9.v201001271707, Location: reference:file:plugins/org.eclipse.jst.jsf.common_1.1.9.v201001271707.jar
Id: org.eclipse.jst.jsf.common.runtime, Version: 1.0.201.v20090205, Location: reference:file:plugins/org.eclipse.jst.jsf.common.runtime_1.0.201.v20090205.jar
Id: org.eclipse.jst.jsf.common.ui, Version: 1.1.1.v20081209, Location: reference:file:plugins/org.eclipse.jst.jsf.common.ui_1.1.1.v20081209.jar
Id: org.eclipse.jst.jsf.core, Version: 1.2.5.v201001271707, Location: reference:file:plugins/org.eclipse.jst.jsf.core_1.2.5.v201001271707.jar
Id: org.eclipse.jst.jsf.facesconfig, Version: 1.1.3.v20090902, Location: reference:file:plugins/org.eclipse.jst.jsf.facesconfig_1.1.3.v20090902.jar
Id: org.eclipse.jst.jsp.core, Version: 1.2.204.v201001270045, Location: reference:file:plugins/org.eclipse.jst.jsp.core_1.2.204.v201001270045.jar
Id: org.eclipse.jst.jsp.ui, Version: 1.1.401.v200908111935, Location: reference:file:plugins/org.eclipse.jst.jsp.ui_1.1.401.v200908111935.jar
Id: org.eclipse.jst.jsp.ui.infopop, Version: 1.0.100.v200805301545, Location: reference:file:plugins/org.eclipse.jst.jsp.ui.infopop_1.0.100.v200805301545.jar
Id: org.eclipse.jst.pagedesigner, Version: 1.2.3.v20100211, Location: reference:file:plugins/org.eclipse.jst.pagedesigner_1.2.3.v20100211.jar
Id: org.eclipse.jst.pagedesigner.jsf.ui, Version: 1.1.4.v20100203, Location: reference:file:plugins/org.eclipse.jst.pagedesigner.jsf.ui_1.1.4.v20100203.jar
Id: org.eclipse.jst.pagedesigner.jsp.core, Version: 1.1.3.v201002111131, Location: reference:file:plugins/org.eclipse.jst.pagedesigner.jsp.core_1.1.3.v201002111131.jar
Id: org.eclipse.jst.server.core, Version: 1.2.1.v20100127, Location: reference:file:plugins/org.eclipse.jst.server.core_1.2.1.v20100127.jar
Id: org.eclipse.jst.servlet.ui, Version: 1.1.301.v200908101600, Location: reference:file:plugins/org.eclipse.jst.servlet.ui_1.1.301.v200908101600.jar
Id: org.eclipse.jst.servlet.ui.infopop, Version: 1.0.300.v200805140415, Location: reference:file:plugins/org.eclipse.jst.servlet.ui.infopop_1.0.300.v200805140415.jar
Id: org.eclipse.jst.ws, Version: 1.0.407.v200905191120, Location: reference:file:plugins/org.eclipse.jst.ws_1.0.407.v200905191120.jar
Id: org.eclipse.jst.ws.axis.consumption.core, Version: 1.0.306.v200810082309, Location: reference:file:plugins/org.eclipse.jst.ws.axis.consumption.core_1.0.306.v200810082309.jar
Id: org.eclipse.jst.ws.axis.consumption.ui, Version: 1.0.405.v200901261650, Location: reference:file:plugins/org.eclipse.jst.ws.axis.consumption.ui_1.0.405.v200901261650.jar
Id: org.eclipse.jst.ws.axis.creation.ui, Version: 1.0.406.v200903031852, Location: reference:file:plugins/org.eclipse.jst.ws.axis.creation.ui_1.0.406.v200903031852.jar
Id: org.eclipse.jst.ws.axis.infopop, Version: 1.0.300.v200805140230, Location: reference:file:plugins/org.eclipse.jst.ws.axis.infopop_1.0.300.v200805140230.jar
Id: org.eclipse.jst.ws.axis.ui.doc.user, Version: 1.1.0.v200806092139, Location: reference:file:plugins/org.eclipse.jst.ws.axis.ui.doc.user_1.1.0.v200806092139.jar
Id: org.eclipse.jst.ws.axis2.consumption.core, Version: 1.0.104.v200810151442, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.consumption.core_1.0.104.v200810151442.jar
Id: org.eclipse.jst.ws.axis2.consumption.ui, Version: 1.0.102.v200807232000, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.consumption.ui_1.0.102.v200807232000.jar
Id: org.eclipse.jst.ws.axis2.core, Version: 1.0.104.v200810151442, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.core_1.0.104.v200810151442.jar
Id: org.eclipse.jst.ws.axis2.creation.core, Version: 1.0.105.v200901220134, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.creation.core_1.0.105.v200901220134.jar
Id: org.eclipse.jst.ws.axis2.creation.ui, Version: 1.0.103.v200807162242, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.creation.ui_1.0.103.v200807162242.jar
Id: org.eclipse.jst.ws.axis2.ui, Version: 1.0.302.v200905260749, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.ui_1.0.302.v200905260749.jar
Id: org.eclipse.jst.ws.axis2.ui.doc.user, Version: 1.0.1.v200807302329, Location: reference:file:plugins/org.eclipse.jst.ws.axis2.ui.doc.user_1.0.1.v200807302329.jar
Id: org.eclipse.jst.ws.consumption, Version: 1.0.408.v200911241817, Location: reference:file:plugins/org.eclipse.jst.ws.consumption_1.0.408.v200911241817.jar
Id: org.eclipse.jst.ws.consumption.infopop, Version: 1.0.300.v200805140230, Location: reference:file:plugins/org.eclipse.jst.ws.consumption.infopop_1.0.300.v200805140230.jar
Id: org.eclipse.jst.ws.consumption.ui, Version: 1.1.106.v200911241851, Location: reference:file:plugins/org.eclipse.jst.ws.consumption.ui_1.1.106.v200911241851.jar
Id: org.eclipse.jst.ws.consumption.ui.doc.user, Version: 1.0.550.v200901232040, Location: reference:file:plugins/org.eclipse.jst.ws.consumption.ui.doc.user_1.0.550.v200901232040.jar
Id: org.eclipse.jst.ws.creation.ejb.ui, Version: 1.0.200.v200805140230, Location: reference:file:plugins/org.eclipse.jst.ws.creation.ejb.ui_1.0.200.v200805140230.jar
Id: org.eclipse.jst.ws.creation.ui, Version: 1.0.409.v200911241856, Location: reference:file:plugins/org.eclipse.jst.ws.creation.ui_1.0.409.v200911241856.jar
Id: org.eclipse.jst.ws.doc.user, Version: 1.0.500.v200809092107, Location: reference:file:plugins/org.eclipse.jst.ws.doc.user_1.0.500.v200809092107.jar
Id: org.eclipse.jst.ws.infopop, Version: 1.0.300.v200805140230, Location: reference:file:plugins/org.eclipse.jst.ws.infopop_1.0.300.v200805140230.jar
Id: org.eclipse.jst.ws.uddiregistry, Version: 1.0.400.v200901261650, Location: reference:file:plugins/org.eclipse.jst.ws.uddiregistry_1.0.400.v200901261650.jar
Id: org.eclipse.jst.ws.ui, Version: 1.0.402.v200903111822, Location: reference:file:plugins/org.eclipse.jst.ws.ui_1.0.402.v200903111822.jar
Id: org.eclipse.ltk.core.refactoring, Version: 3.5.0.v20090513-2000, Location: reference:file:plugins/org.eclipse.ltk.core.refactoring_3.5.0.v20090513-2000.jar
Id: org.eclipse.ltk.core.refactoring.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ltk.core.refactoring.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ltk.ui.refactoring, Version: 3.4.100.v20090604, Location: reference:file:plugins/org.eclipse.ltk.ui.refactoring_3.4.100.v20090604.jar
Id: org.eclipse.ltk.ui.refactoring.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ltk.ui.refactoring.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.osgi, Version: 3.5.1.R35x_v20090827, Location: System Bundle
Id: org.eclipse.osgi.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.osgi.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.osgi.services, Version: 3.2.0.v20090520-1800, Location: reference:file:plugins/org.eclipse.osgi.services_3.2.0.v20090520-1800.jar
Id: org.eclipse.osgi.services.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.osgi.services.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.osgi.util, Version: 3.2.0.v20090520-1800, Location: reference:file:plugins/org.eclipse.osgi.util_3.2.0.v20090520-1800.jar
Id: org.eclipse.osgi.util.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.osgi.util.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.pde, Version: 3.4.100.v201002111343, Location: reference:file:plugins/org.eclipse.pde_3.4.100.v201002111343.jar
Id: org.eclipse.pde.api.tools, Version: 1.0.101.v20090714, Location: reference:file:plugins/org.eclipse.pde.api.tools_1.0.101.v20090714.jar
Id: org.eclipse.pde.api.tools.ee.javase16, Version: 1.0.0.v20090407-1030, Location: reference:file:plugins/org.eclipse.pde.api.tools.ee.javase16_1.0.0.v20090407-1030/
Id: org.eclipse.pde.api.tools.ui, Version: 1.0.101.v20090820, Location: reference:file:plugins/org.eclipse.pde.api.tools.ui_1.0.101.v20090820.jar
Id: org.eclipse.pde.build, Version: 3.5.2.R35x_20100114, Location: reference:file:plugins/org.eclipse.pde.build_3.5.2.R35x_20100114/
Id: org.eclipse.pde.core, Version: 3.5.101.v20100104, Location: reference:file:plugins/org.eclipse.pde.core_3.5.101.v20100104.jar
Id: org.eclipse.pde.doc.user, Version: 3.5.0.v20090818, Location: reference:file:plugins/org.eclipse.pde.doc.user_3.5.0.v20090818.jar
Id: org.eclipse.pde.ds.core, Version: 1.0.1.v20100118, Location: reference:file:plugins/org.eclipse.pde.ds.core_1.0.1.v20100118.jar
Id: org.eclipse.pde.ds.ui, Version: 1.0.0.v20100209-maintenance, Location: reference:file:plugins/org.eclipse.pde.ds.ui_1.0.0.v20100209-maintenance.jar
Id: org.eclipse.pde.junit.runtime, Version: 3.4.0.v20090527, Location: reference:file:plugins/org.eclipse.pde.junit.runtime_3.4.0.v20090527.jar
Id: org.eclipse.pde.runtime, Version: 3.4.100.v20090731, Location: reference:file:plugins/org.eclipse.pde.runtime_3.4.100.v20090731.jar
Id: org.eclipse.pde.ua.core, Version: 1.0.0.v20090429-1800, Location: reference:file:plugins/org.eclipse.pde.ua.core_1.0.0.v20090429-1800.jar
Id: org.eclipse.pde.ua.ui, Version: 1.0.0.v20090511, Location: reference:file:plugins/org.eclipse.pde.ua.ui_1.0.0.v20090511.jar
Id: org.eclipse.pde.ui, Version: 3.5.1.v201001121200, Location: reference:file:plugins/org.eclipse.pde.ui_3.5.1.v201001121200.jar
Id: org.eclipse.pde.ui.templates, Version: 3.4.100.v20090527, Location: reference:file:plugins/org.eclipse.pde.ui.templates_3.4.100.v20090527.jar
Id: org.eclipse.platform, Version: 3.3.201.v200909170800, Location: reference:file:plugins/org.eclipse.platform_3.3.201.v200909170800/
Id: org.eclipse.platform.doc.user, Version: 3.5.1.r351_v20090821-0800, Location: reference:file:plugins/org.eclipse.platform.doc.user_3.5.1.r351_v20090821-0800.jar
Id: org.eclipse.platform.doc.user.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.platform.doc.user.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.platform.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.platform.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.rcp, Version: 3.5.0.v200909170800, Location: reference:file:plugins/org.eclipse.rcp_3.5.0.v200909170800.jar
Id: org.eclipse.search, Version: 3.5.1.r351_v20090708-0800, Location: reference:file:plugins/org.eclipse.search_3.5.1.r351_v20090708-0800.jar
Id: org.eclipse.search.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.search.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.servertools.doc.isv, Version: 1.0.100.v20090414, Location: reference:file:plugins/org.eclipse.servertools.doc.isv_1.0.100.v20090414.jar
Id: org.eclipse.swt, Version: 3.5.1.v3555a, Location: reference:file:plugins/org.eclipse.swt_3.5.1.v3555a.jar
Id: org.eclipse.swt.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.swt.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.swt.win32.win32.x86, Version: 3.5.1.v3555a, Location: reference:file:plugins/org.eclipse.swt.win32.win32.x86_3.5.1.v3555a.jar
Id: org.eclipse.team.core, Version: 3.5.0.I20090527-0620, Location: reference:file:plugins/org.eclipse.team.core_3.5.0.I20090527-0620.jar
Id: org.eclipse.team.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.core.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.team.cvs.core, Version: 3.3.200.I20090430-0408, Location: reference:file:plugins/org.eclipse.team.cvs.core_3.3.200.I20090430-0408.jar
Id: org.eclipse.team.cvs.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.cvs.core.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.team.cvs.ssh, Version: 3.2.100.I20090508-2000, Location: reference:file:plugins/org.eclipse.team.cvs.ssh_3.2.100.I20090508-2000.jar
Id: org.eclipse.team.cvs.ssh.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.cvs.ssh.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.team.cvs.ssh2, Version: 3.2.200.I20090508-2000, Location: reference:file:plugins/org.eclipse.team.cvs.ssh2_3.2.200.I20090508-2000.jar
Id: org.eclipse.team.cvs.ssh2.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.cvs.ssh2.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.team.cvs.ui, Version: 3.3.201.R35x_v20090826-0905, Location: reference:file:plugins/org.eclipse.team.cvs.ui_3.3.201.R35x_v20090826-0905.jar
Id: org.eclipse.team.cvs.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.cvs.ui.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.team.ui, Version: 3.5.0.I20090430-0408, Location: reference:file:plugins/org.eclipse.team.ui_3.5.0.I20090430-0408.jar
Id: org.eclipse.team.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.team.ui.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.text, Version: 3.5.0.v20090513-2000, Location: reference:file:plugins/org.eclipse.text_3.5.0.v20090513-2000.jar
Id: org.eclipse.text.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.text.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui, Version: 3.5.1.M20090902-1000, Location: reference:file:plugins/org.eclipse.ui_3.5.1.M20090902-1000.jar
Id: org.eclipse.ui.browser, Version: 3.2.300.v20090526, Location: reference:file:plugins/org.eclipse.ui.browser_3.2.300.v20090526.jar
Id: org.eclipse.ui.browser.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.browser.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.cheatsheets, Version: 3.3.200.v20090526, Location: reference:file:plugins/org.eclipse.ui.cheatsheets_3.3.200.v20090526.jar
Id: org.eclipse.ui.cheatsheets.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.cheatsheets.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.console, Version: 3.4.0.v20090513, Location: reference:file:plugins/org.eclipse.ui.console_3.4.0.v20090513.jar
Id: org.eclipse.ui.console.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.console.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.editors, Version: 3.5.0.v20090527-2000, Location: reference:file:plugins/org.eclipse.ui.editors_3.5.0.v20090527-2000.jar
Id: org.eclipse.ui.editors.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.editors.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.externaltools, Version: 3.2.0.v20090504, Location: reference:file:plugins/org.eclipse.ui.externaltools_3.2.0.v20090504.jar
Id: org.eclipse.ui.externaltools.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.externaltools.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.forms, Version: 3.4.1.v20090714_35x, Location: reference:file:plugins/org.eclipse.ui.forms_3.4.1.v20090714_35x.jar
Id: org.eclipse.ui.forms.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.forms.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.ide, Version: 3.5.1.M20090826-0800, Location: reference:file:plugins/org.eclipse.ui.ide_3.5.1.M20090826-0800.jar
Id: org.eclipse.ui.ide.application, Version: 1.0.101.M20090826-0800, Location: reference:file:plugins/org.eclipse.ui.ide.application_1.0.101.M20090826-0800.jar
Id: org.eclipse.ui.ide.application.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.ide.application.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.ide.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.ide.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.intro, Version: 3.3.1.v20090805_35x, Location: reference:file:plugins/org.eclipse.ui.intro_3.3.1.v20090805_35x.jar
Id: org.eclipse.ui.intro.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.intro.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.intro.universal, Version: 3.2.300.v20090526, Location: reference:file:plugins/org.eclipse.ui.intro.universal_3.2.300.v20090526/
Id: org.eclipse.ui.intro.universal.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.intro.universal.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.navigator, Version: 3.4.1.M20090911-1550, Location: reference:file:plugins/org.eclipse.ui.navigator_3.4.1.M20090911-1550.jar
Id: org.eclipse.ui.navigator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.navigator.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.navigator.resources, Version: 3.4.1.M20090826-0800, Location: reference:file:plugins/org.eclipse.ui.navigator.resources_3.4.1.M20090826-0800.jar
Id: org.eclipse.ui.navigator.resources.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.navigator.resources.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.net, Version: 1.2.1.r35x_20090812-1200, Location: reference:file:plugins/org.eclipse.ui.net_1.2.1.r35x_20090812-1200.jar
Id: org.eclipse.ui.net.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.net.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.presentations.r21, Version: 3.2.100.I20081007-0800, Location: reference:file:plugins/org.eclipse.ui.presentations.r21_3.2.100.I20081007-0800.jar
Id: org.eclipse.ui.presentations.r21.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.presentations.r21.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.views, Version: 3.4.1.M20090826-0800, Location: reference:file:plugins/org.eclipse.ui.views_3.4.1.M20090826-0800.jar
Id: org.eclipse.ui.views.log, Version: 1.0.100.v20090731, Location: reference:file:plugins/org.eclipse.ui.views.log_1.0.100.v20090731.jar
Id: org.eclipse.ui.views.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.views.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.views.properties.tabbed, Version: 3.5.0.I20090429-1800, Location: reference:file:plugins/org.eclipse.ui.views.properties.tabbed_3.5.0.I20090429-1800.jar
Id: org.eclipse.ui.views.properties.tabbed.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.views.properties.tabbed.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.win32, Version: 3.2.100.v20090429-1800, Location: reference:file:plugins/org.eclipse.ui.win32_3.2.100.v20090429-1800.jar
Id: org.eclipse.ui.workbench, Version: 3.5.1.M20090826-0800a, Location: reference:file:plugins/org.eclipse.ui.workbench_3.5.1.M20090826-0800a.jar
Id: org.eclipse.ui.workbench.compatibility, Version: 3.2.0.I20090429-1800, Location: reference:file:plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20090429-1800/
Id: org.eclipse.ui.workbench.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.workbench.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.ui.workbench.texteditor, Version: 3.5.0.v20090603, Location: reference:file:plugins/org.eclipse.ui.workbench.texteditor_3.5.0.v20090603.jar
Id: org.eclipse.ui.workbench.texteditor.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.ui.workbench.texteditor.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.update.configurator, Version: 3.3.0.v20090312, Location: reference:file:plugins/org.eclipse.update.configurator_3.3.0.v20090312.jar
Id: org.eclipse.update.configurator.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.update.configurator.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.update.core, Version: 3.2.300.v20090525, Location: reference:file:plugins/org.eclipse.update.core_3.2.300.v20090525.jar
Id: org.eclipse.update.core.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.update.core.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.update.core.win32, Version: 3.2.100.v20080107, Location: reference:file:plugins/org.eclipse.update.core.win32_3.2.100.v20080107.jar
Id: org.eclipse.update.scheduler, Version: 3.2.200.v20081127, Location: reference:file:plugins/org.eclipse.update.scheduler_3.2.200.v20081127.jar
Id: org.eclipse.update.scheduler.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.update.scheduler.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.update.ui, Version: 3.2.201.R35x_v20090813, Location: reference:file:plugins/org.eclipse.update.ui_3.2.201.R35x_v20090813.jar
Id: org.eclipse.update.ui.nl1_3.5.0.v20091121043401, Version: 3.5.0.v20091121043401, Location: reference:file:plugins/org.eclipse.update.ui.nl1_3.5.0.v20091121043401.jar
Id: org.eclipse.wst.command.env, Version: 1.0.408.v200903110045, Location: reference:file:plugins/org.eclipse.wst.command.env_1.0.408.v200903110045.jar
Id: org.eclipse.wst.command.env.core, Version: 1.0.204.v200805140020, Location: reference:file:plugins/org.eclipse.wst.command.env.core_1.0.204.v200805140020.jar
Id: org.eclipse.wst.command.env.doc.user, Version: 1.5.200.v200806092138, Location: reference:file:plugins/org.eclipse.wst.command.env.doc.user_1.5.200.v200806092138.jar
Id: org.eclipse.wst.command.env.infopop, Version: 1.0.100.v200805301544, Location: reference:file:plugins/org.eclipse.wst.command.env.infopop_1.0.100.v200805301544.jar
Id: org.eclipse.wst.command.env.ui, Version: 1.1.2.v200811200248, Location: reference:file:plugins/org.eclipse.wst.command.env.ui_1.1.2.v200811200248.jar
Id: org.eclipse.wst.common.api.doc, Version: 1.0.1.v200807181737, Location: reference:file:plugins/org.eclipse.wst.common.api.doc_1.0.1.v200807181737.jar
Id: org.eclipse.wst.common.core, Version: 1.1.201.v200806010600, Location: reference:file:plugins/org.eclipse.wst.common.core_1.1.201.v200806010600.jar
Id: org.eclipse.wst.common.emf, Version: 1.1.301.v200908181930, Location: reference:file:plugins/org.eclipse.wst.common.emf_1.1.301.v200908181930.jar
Id: org.eclipse.wst.common.emfworkbench.integration, Version: 1.1.301.v200908101600, Location: reference:file:plugins/org.eclipse.wst.common.emfworkbench.integration_1.1.301.v200908101600.jar
Id: org.eclipse.wst.common.environment, Version: 1.0.301.v200908101600, Location: reference:file:plugins/org.eclipse.wst.common.environment_1.0.301.v200908101600.jar
Id: org.eclipse.wst.common.frameworks, Version: 1.1.300.v200904160730, Location: reference:file:plugins/org.eclipse.wst.common.frameworks_1.1.300.v200904160730.jar
Id: org.eclipse.wst.common.frameworks.ui, Version: 1.1.301.v200908101600, Location: reference:file:plugins/org.eclipse.wst.common.frameworks.ui_1.1.301.v200908101600.jar
Id: org.eclipse.wst.common.infopop, Version: 1.0.100.v200805301550, Location: reference:file:plugins/org.eclipse.wst.common.infopop_1.0.100.v200805301550.jar
Id: org.eclipse.wst.common.modulecore, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.wst.common.modulecore_1.1.301.v201001252130.jar
Id: org.eclipse.wst.common.project.facet.core, Version: 1.4.1.v200911141735, Location: reference:file:plugins/org.eclipse.wst.common.project.facet.core_1.4.1.v200911141735.jar
Id: org.eclipse.wst.common.project.facet.ui, Version: 1.4.1.v200908111817, Location: reference:file:plugins/org.eclipse.wst.common.project.facet.ui_1.4.1.v200908111817.jar
Id: org.eclipse.wst.common.snippets, Version: 1.1.301.v201001280015, Location: reference:file:plugins/org.eclipse.wst.common.snippets_1.1.301.v201001280015.jar
Id: org.eclipse.wst.common.ui, Version: 1.1.402.v200901262305, Location: reference:file:plugins/org.eclipse.wst.common.ui_1.1.402.v200901262305.jar
Id: org.eclipse.wst.common.uriresolver, Version: 1.1.301.v200805140415, Location: reference:file:plugins/org.eclipse.wst.common.uriresolver_1.1.301.v200805140415.jar
Id: org.eclipse.wst.css.core, Version: 1.1.301.v200910161432, Location: reference:file:plugins/org.eclipse.wst.css.core_1.1.301.v200910161432.jar
Id: org.eclipse.wst.css.ui, Version: 1.0.401.v200907171457, Location: reference:file:plugins/org.eclipse.wst.css.ui_1.0.401.v200907171457.jar
Id: org.eclipse.wst.doc.user, Version: 1.2.0.v200806052254, Location: reference:file:plugins/org.eclipse.wst.doc.user_1.2.0.v200806052254.jar
Id: org.eclipse.wst.dtd.core, Version: 1.1.300.v200904181727, Location: reference:file:plugins/org.eclipse.wst.dtd.core_1.1.300.v200904181727.jar
Id: org.eclipse.wst.dtd.ui, Version: 1.0.400.v200904300717, Location: reference:file:plugins/org.eclipse.wst.dtd.ui_1.0.400.v200904300717.jar
Id: org.eclipse.wst.dtd.ui.infopop, Version: 1.0.300.v200805140200, Location: reference:file:plugins/org.eclipse.wst.dtd.ui.infopop_1.0.300.v200805140200.jar
Id: org.eclipse.wst.dtdeditor.doc.user, Version: 1.0.500.v200904292308, Location: reference:file:plugins/org.eclipse.wst.dtdeditor.doc.user_1.0.500.v200904292308.jar
Id: org.eclipse.wst.html.core, Version: 1.1.300.v200903120608, Location: reference:file:plugins/org.eclipse.wst.html.core_1.1.300.v200903120608.jar
Id: org.eclipse.wst.html.ui, Version: 1.0.401.v200908111935, Location: reference:file:plugins/org.eclipse.wst.html.ui_1.0.401.v200908111935.jar
Id: org.eclipse.wst.html.ui.infopop, Version: 1.0.100.v200805301545, Location: reference:file:plugins/org.eclipse.wst.html.ui.infopop_1.0.100.v200805301545.jar
Id: org.eclipse.wst.internet.cache, Version: 1.0.301.v200805140020, Location: reference:file:plugins/org.eclipse.wst.internet.cache_1.0.301.v200805140020.jar
Id: org.eclipse.wst.internet.monitor.core, Version: 1.0.404.v20090609, Location: reference:file:plugins/org.eclipse.wst.internet.monitor.core_1.0.404.v20090609.jar
Id: org.eclipse.wst.internet.monitor.ui, Version: 1.0.305.v20100123, Location: reference:file:plugins/org.eclipse.wst.internet.monitor.ui_1.0.305.v20100123.jar
Id: org.eclipse.wst.jsdt.core, Version: 1.0.201.v2010012803, Location: reference:file:plugins/org.eclipse.wst.jsdt.core_1.0.201.v2010012803.jar
Id: org.eclipse.wst.jsdt.doc, Version: 1.0.200.v200903120608, Location: reference:file:plugins/org.eclipse.wst.jsdt.doc_1.0.200.v200903120608.jar
Id: org.eclipse.wst.jsdt.manipulation, Version: 1.0.100.v200809240707, Location: reference:file:plugins/org.eclipse.wst.jsdt.manipulation_1.0.100.v200809240707.jar
Id: org.eclipse.wst.jsdt.support.firefox, Version: 1.0.200.v200904290357, Location: reference:file:plugins/org.eclipse.wst.jsdt.support.firefox_1.0.200.v200904290357.jar
Id: org.eclipse.wst.jsdt.support.ie, Version: 1.0.200.v200904290539, Location: reference:file:plugins/org.eclipse.wst.jsdt.support.ie_1.0.200.v200904290539.jar
Id: org.eclipse.wst.jsdt.ui, Version: 1.0.201.v2010012803, Location: reference:file:plugins/org.eclipse.wst.jsdt.ui_1.0.201.v2010012803.jar
Id: org.eclipse.wst.jsdt.web.core, Version: 1.0.201.v201001221931, Location: reference:file:plugins/org.eclipse.wst.jsdt.web.core_1.0.201.v201001221931.jar
Id: org.eclipse.wst.jsdt.web.ui, Version: 1.0.201.v2010012803, Location: reference:file:plugins/org.eclipse.wst.jsdt.web.ui_1.0.201.v2010012803.jar
Id: org.eclipse.wst.server.core, Version: 1.1.102.v20100123, Location: reference:file:plugins/org.eclipse.wst.server.core_1.1.102.v20100123.jar
Id: org.eclipse.wst.server.discovery, Version: 1.0.1.v20100210, Location: reference:file:plugins/org.eclipse.wst.server.discovery_1.0.1.v20100210.jar
Id: org.eclipse.wst.server.ui, Version: 1.1.103.v20100123, Location: reference:file:plugins/org.eclipse.wst.server.ui_1.1.103.v20100123.jar
Id: org.eclipse.wst.server.ui.doc.user, Version: 1.1.150.v200901232034, Location: reference:file:plugins/org.eclipse.wst.server.ui.doc.user_1.1.150.v200901232034.jar
Id: org.eclipse.wst.server.ui.infopop, Version: 1.1.0.v200805140145, Location: reference:file:plugins/org.eclipse.wst.server.ui.infopop_1.1.0.v200805140145.jar
Id: org.eclipse.wst.sse.core, Version: 1.1.402.v201001251516, Location: reference:file:plugins/org.eclipse.wst.sse.core_1.1.402.v201001251516.jar
Id: org.eclipse.wst.sse.doc.user, Version: 1.1.0.v200805211530, Location: reference:file:plugins/org.eclipse.wst.sse.doc.user_1.1.0.v200805211530.jar
Id: org.eclipse.wst.sse.ui, Version: 1.1.102.v200910200227, Location: reference:file:plugins/org.eclipse.wst.sse.ui_1.1.102.v200910200227.jar
Id: org.eclipse.wst.sse.ui.infopop, Version: 1.0.200.v200805301545, Location: reference:file:plugins/org.eclipse.wst.sse.ui.infopop_1.0.200.v200805301545.jar
Id: org.eclipse.wst.standard.schemas, Version: 1.0.200.v200902270215, Location: reference:file:plugins/org.eclipse.wst.standard.schemas_1.0.200.v200902270215.jar
Id: org.eclipse.wst.validation, Version: 1.2.104.v200911120201, Location: reference:file:plugins/org.eclipse.wst.validation_1.2.104.v200911120201.jar
Id: org.eclipse.wst.validation.doc.isv, Version: 1.2.101.v200906031420, Location: reference:file:plugins/org.eclipse.wst.validation.doc.isv_1.2.101.v200906031420.jar
Id: org.eclipse.wst.validation.infopop, Version: 1.0.300.v200806041506, Location: reference:file:plugins/org.eclipse.wst.validation.infopop_1.0.300.v200806041506.jar
Id: org.eclipse.wst.validation.ui, Version: 1.2.104.v200904232035, Location: reference:file:plugins/org.eclipse.wst.validation.ui_1.2.104.v200904232035.jar
Id: org.eclipse.wst.web, Version: 1.1.301.v200911302230, Location: reference:file:plugins/org.eclipse.wst.web_1.1.301.v200911302230.jar
Id: org.eclipse.wst.web.ui, Version: 1.1.301.v201001252130, Location: reference:file:plugins/org.eclipse.wst.web.ui_1.1.301.v201001252130.jar
Id: org.eclipse.wst.web.ui.infopop, Version: 1.0.300.v200805140415, Location: reference:file:plugins/org.eclipse.wst.web.ui.infopop_1.0.300.v200805140415.jar
Id: org.eclipse.wst.webtools.doc.user, Version: 1.0.400.v200805150134, Location: reference:file:plugins/org.eclipse.wst.webtools.doc.user_1.0.400.v200805150134.jar
Id: org.eclipse.wst.ws, Version: 1.1.103.v200903111822, Location: reference:file:plugins/org.eclipse.wst.ws_1.1.103.v200903111822.jar
Id: org.eclipse.wst.ws.api.doc, Version: 1.0.1.v200807181721, Location: reference:file:plugins/org.eclipse.wst.ws.api.doc_1.0.1.v200807181721.jar
Id: org.eclipse.wst.ws.explorer, Version: 1.0.408.v200911241806, Location: reference:file:plugins/org.eclipse.wst.ws.explorer_1.0.408.v200911241806.jar
Id: org.eclipse.wst.ws.infopop, Version: 1.0.300.v200805140230, Location: reference:file:plugins/org.eclipse.wst.ws.infopop_1.0.300.v200805140230.jar
Id: org.eclipse.wst.ws.parser, Version: 1.0.402.v200901220107, Location: reference:file:plugins/org.eclipse.wst.ws.parser_1.0.402.v200901220107.jar
Id: org.eclipse.wst.ws.service.policy, Version: 1.0.103.v200905151848, Location: reference:file:plugins/org.eclipse.wst.ws.service.policy_1.0.103.v200905151848.jar
Id: org.eclipse.wst.ws.service.policy.ui, Version: 1.0.102.v200903070248, Location: reference:file:plugins/org.eclipse.wst.ws.service.policy.ui_1.0.102.v200903070248.jar
Id: org.eclipse.wst.ws.ui, Version: 1.1.100.v200903112221, Location: reference:file:plugins/org.eclipse.wst.ws.ui_1.1.100.v200903112221.jar
Id: org.eclipse.wst.wsdl, Version: 1.2.2.v200911111930, Location: reference:file:plugins/org.eclipse.wst.wsdl_1.2.2.v200911111930.jar
Id: org.eclipse.wst.wsdl.doc.isv, Version: 1.0.100.v200811240723, Location: reference:file:plugins/org.eclipse.wst.wsdl.doc.isv_1.0.100.v200811240723.jar
Id: org.eclipse.wst.wsdl.ui, Version: 1.2.202.v200904271449, Location: reference:file:plugins/org.eclipse.wst.wsdl.ui_1.2.202.v200904271449.jar
Id: org.eclipse.wst.wsdl.ui.doc.user, Version: 1.0.550.v200901232040, Location: reference:file:plugins/org.eclipse.wst.wsdl.ui.doc.user_1.0.550.v200901232040.jar
Id: org.eclipse.wst.wsdl.validation, Version: 1.1.402.v200911251542, Location: reference:file:plugins/org.eclipse.wst.wsdl.validation_1.1.402.v200911251542.jar
Id: org.eclipse.wst.wsi, Version: 1.0.305.v200902181431, Location: reference:file:plugins/org.eclipse.wst.wsi_1.0.305.v200902181431.jar
Id: org.eclipse.wst.wsi.ui, Version: 1.0.500.v200901141851, Location: reference:file:plugins/org.eclipse.wst.wsi.ui_1.0.500.v200901141851.jar
Id: org.eclipse.wst.wsi.ui.doc.user, Version: 1.0.401.v200809171927, Location: reference:file:plugins/org.eclipse.wst.wsi.ui.doc.user_1.0.401.v200809171927.jar
Id: org.eclipse.wst.xml.core, Version: 1.1.402.v201001222130, Location: reference:file:plugins/org.eclipse.wst.xml.core_1.1.402.v201001222130.jar
Id: org.eclipse.wst.xml.ui, Version: 1.1.2.v201001222130, Location: reference:file:plugins/org.eclipse.wst.xml.ui_1.1.2.v201001222130.jar
Id: org.eclipse.wst.xml.ui.infopop, Version: 1.0.300.v200805140200, Location: reference:file:plugins/org.eclipse.wst.xml.ui.infopop_1.0.300.v200805140200.jar
Id: org.eclipse.wst.xml.xpath.core, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xml.xpath.core_1.0.0.v200904240436.jar
Id: org.eclipse.wst.xml.xpath.ui, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xml.xpath.ui_1.0.0.v200904240436.jar
Id: org.eclipse.wst.xml.xpath2.processor, Version: 1.0.0.v200905300355, Location: reference:file:plugins/org.eclipse.wst.xml.xpath2.processor_1.0.0.v200905300355.jar
Id: org.eclipse.wst.xmleditor.doc.user, Version: 1.0.600.v200901231300, Location: reference:file:plugins/org.eclipse.wst.xmleditor.doc.user_1.0.600.v200901231300.jar
Id: org.eclipse.wst.xsd.core, Version: 1.1.401.v200903020335, Location: reference:file:plugins/org.eclipse.wst.xsd.core_1.1.401.v200903020335.jar
Id: org.eclipse.wst.xsd.ui, Version: 1.2.204.v200909021537, Location: reference:file:plugins/org.eclipse.wst.xsd.ui_1.2.204.v200909021537.jar
Id: org.eclipse.wst.xsdeditor.doc.user, Version: 1.0.700.v200905182240, Location: reference:file:plugins/org.eclipse.wst.xsdeditor.doc.user_1.0.700.v200905182240.jar
Id: org.eclipse.wst.xsl, Version: 1.0.0.v200905250058, Location: reference:file:plugins/org.eclipse.wst.xsl_1.0.0.v200905250058.jar
Id: org.eclipse.wst.xsl.core, Version: 1.0.1.v200908101420, Location: reference:file:plugins/org.eclipse.wst.xsl.core_1.0.1.v200908101420.jar
Id: org.eclipse.wst.xsl.debug.ui, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.debug.ui_1.0.0.v200904240436.jar
Id: org.eclipse.wst.xsl.doc, Version: 1.0.0.v200905071815, Location: reference:file:plugins/org.eclipse.wst.xsl.doc_1.0.0.v200905071815.jar
Id: org.eclipse.wst.xsl.jaxp.debug, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.jaxp.debug_1.0.0.v200904240436.jar
Id: org.eclipse.wst.xsl.jaxp.debug.ui, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.jaxp.debug.ui_1.0.0.v200904240436.jar
Id: org.eclipse.wst.xsl.jaxp.launching, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.jaxp.launching_1.0.0.v200904240436.jar
Id: org.eclipse.wst.xsl.launching, Version: 1.0.0.v200904241348, Location: reference:file:plugins/org.eclipse.wst.xsl.launching_1.0.0.v200904241348.jar
Id: org.eclipse.wst.xsl.saxon, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.saxon_1.0.0.v200904240436.jar
Id: org.eclipse.wst.xsl.sdk.documentation, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.sdk.documentation_1.0.0.v200904240436.jar
Id: org.eclipse.wst.xsl.ui, Version: 1.0.100.v200907172129, Location: reference:file:plugins/org.eclipse.wst.xsl.ui_1.0.100.v200907172129.jar
Id: org.eclipse.wst.xsl.xalan, Version: 1.0.0.v200904240436, Location: reference:file:plugins/org.eclipse.wst.xsl.xalan_1.0.0.v200904240436.jar
Id: org.eclipse.xsd, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.xsd_2.5.0.v200906151043.jar
Id: org.eclipse.xsd.edit, Version: 2.5.0.v200906151043, Location: reference:file:plugins/org.eclipse.xsd.edit_2.5.0.v200906151043.jar
Id: org.hamcrest.core, Version: 1.1.0.v20090501071000, Location: reference:file:plugins/org.hamcrest.core_1.1.0.v20090501071000.jar
Id: org.jdom, Version: 1.0.0.v200806100616, Location: reference:file:plugins/org.jdom_1.0.0.v200806100616.jar
Id: org.junit, Version: 3.8.2.v20090203-1005, Location: reference:file:plugins/org.junit_3.8.2.v20090203-1005/
Id: org.junit4, Version: 4.5.0.v20090824, Location: reference:file:plugins/org.junit4_4.5.0.v20090824/
Id: org.mortbay.jetty.server, Version: 6.1.15.v200905151201, Location: reference:file:plugins/org.mortbay.jetty.server_6.1.15.v200905151201.jar
Id: org.mortbay.jetty.util, Version: 6.1.15.v200905182336, Location: reference:file:plugins/org.mortbay.jetty.util_6.1.15.v200905182336.jar
Id: org.objectweb.asm, Version: 3.1.0.v200803061910, Location: reference:file:plugins/org.objectweb.asm_3.1.0.v200803061910.jar
Id: org.sat4j.core, Version: 2.1.0.v20090520, Location: reference:file:plugins/org.sat4j.core_2.1.0.v20090520.jar
Id: org.sat4j.pb, Version: 2.1.0.v20090520, Location: reference:file:plugins/org.sat4j.pb_2.1.0.v20090520.jar
Id: org.tigris.subversion.clientadapter, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.clientadapter_1.6.12.jar
Id: org.tigris.subversion.clientadapter.javahl, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.clientadapter.javahl_1.6.12.jar
Id: org.tigris.subversion.clientadapter.javahl.win32, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.clientadapter.javahl.win32_1.6.12/
Id: org.tigris.subversion.clientadapter.svnkit, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.clientadapter.svnkit_1.6.12.jar
Id: org.tigris.subversion.subclipse.core, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.subclipse.core_1.6.12.jar
Id: org.tigris.subversion.subclipse.doc, Version: 1.3.0, Location: reference:file:plugins/org.tigris.subversion.subclipse.doc_1.3.0.jar
Id: org.tigris.subversion.subclipse.ui, Version: 1.6.12, Location: reference:file:plugins/org.tigris.subversion.subclipse.ui_1.6.12.jar
Id: org.tmatesoft.svnkit, Version: 1.3.3.6648, Location: reference:file:plugins/org.tmatesoft.svnkit_1.3.3.6648.jar
Id: org.uddi4j, Version: 2.0.5.v200805270300, Location: reference:file:plugins/org.uddi4j_2.0.5.v200805270300.jar
*** Security Configuration:
Providers (9):
Provider: SUN, Version: 1.6, Class: sun.security.provider.Sun
  Description: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
  Services (23):
   Service: MessageDigest, Algorithm: SHA-512, Class: sun.security.provider.SHA5$SHA512
   Service: Configuration, Algorithm: JavaLoginConfig, Class: sun.security.provider.ConfigSpiFile
   Service: Signature, Algorithm: NONEwithDSA, Class: sun.security.provider.DSA$RawDSA
    Aliases: RawDSA
    Attributes:
      SupportedKeyClasses: java.security.interfaces.DSAPublicKey|java.security.interfaces.DSAPrivateKey
   Service: CertPathBuilder, Algorithm: PKIX, Class: sun.security.provider.certpath.SunCertPathBuilder
    Attributes:
      ImplementedIn: Software
      ValidationAlgorithm: RFC3280
   Service: CertStore, Algorithm: LDAP, Class: sun.security.provider.certpath.LDAPCertStore
    Attributes:
      LDAPSchema: RFC2587
   Service: MessageDigest, Algorithm: SHA, Class: sun.security.provider.SHA
    Aliases: SHA1
    Attributes:
   Service: CertificateFactory, Algorithm: X.509, Class: sun.security.provider.X509Factory
    Aliases: X509
    Attributes:
   Service: MessageDigest, Algorithm: SHA-384, Class: sun.security.provider.SHA5$SHA384
   Service: KeyPairGenerator, Algorithm: DSA, Class: sun.security.provider.DSAKeyPairGenerator
    Aliases: OID.1.2.840.10040.4.1
    Attributes:
      KeySize: 1024
   Service: KeyStore, Algorithm: JKS, Class: sun.security.provider.JavaKeyStore$JKS
    Attributes:
   Service: KeyStore, Algorithm: CaseExactJKS, Class: sun.security.provider.JavaKeyStore$CaseExactJKS
   Service: MessageDigest, Algorithm: SHA-256, Class: sun.security.provider.SHA2
   Service: CertStore, Algorithm: com.sun.security.IndexedCollection, Class: sun.security.provider.certpath.IndexedCollectionCertStore
    Attributes:
   Service: KeyFactory, Algorithm: DSA, Class: sun.security.provider.DSAKeyFactory
    Attributes:
   Service: SecureRandom, Algorithm: SHA1PRNG, Class: sun.security.provider.SecureRandom
    Attributes:
   Service: CertPathValidator, Algorithm: PKIX, Class: sun.security.provider.certpath.PKIXCertPathValidator
    Attributes:
   Service: CertStore, Algorithm: Collection, Class: sun.security.provider.certpath.CollectionCertStore
    Attributes:
   Service: MessageDigest, Algorithm: MD5, Class: sun.security.provider.MD5
    Attributes:
   Service: AlgorithmParameters, Algorithm: DSA, Class: sun.security.provider.DSAParameters
    Attributes:
   Service: Policy, Algorithm: JavaPolicy, Class: sun.security.provider.PolicySpiFile
   Service: MessageDigest, Algorithm: MD2, Class: sun.security.provider.MD2
   Service: Signature, Algorithm: SHA1withDSA, Class: sun.security.provider.DSA$SHA1withDSA
    Aliases: DSAWithSHA1
    Attributes:
      KeySize: 1024
   Service: AlgorithmParameterGenerator, Algorithm: DSA, Class: sun.security.provider.DSAParameterGenerator
    Attributes:
      KeySize: 1024
Provider: SunRsaSign, Version: 1.5, Class: sun.security.rsa.SunRsaSign
  Description: Sun RSA signature provider
  Services (8):
   Service: Signature, Algorithm: SHA512withRSA, Class: sun.security.rsa.RSASignature$SHA512withRSA
    Aliases: OID.1.2.840.113549.1.1.13
    Attributes:
      SupportedKeyClasses: java.security.interfaces.RSAPublicKey|java.security.interfaces.RSAPrivateKey
   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.rsa.RSASignature$MD5withRSA
    Aliases: 1.2.840.113549.1.1.4
    Attributes:
   Service: KeyFactory, Algorithm: RSA, Class: sun.security.rsa.RSAKeyFactory
   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.rsa.RSASignature$SHA1withRSA
    Aliases: OID.1.2.840.113549.1.1.5
    Attributes:
   Service: Signature, Algorithm: SHA384withRSA, Class: sun.security.rsa.RSASignature$SHA384withRSA
    Aliases: OID.1.2.840.113549.1.1.12
    Attributes:
   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.rsa.RSASignature$MD2withRSA
    Aliases: 1.2.840.113549.1.1.2
    Attributes:
   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.rsa.RSAKeyPairGenerator
   Service: Signature, Algorithm: SHA256withRSA, Class: sun.security.rsa.RSASignature$SHA256withRSA
    Aliases: OID.1.2.840.113549.1.1.11
    Attributes:
Provider: SunJSSE, Version: 1.6, Class: com.sun.net.ssl.internal.ssl.Provider
  Description: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
  Services (16):
   Service: Signature, Algorithm: MD5andSHA1withRSA, Class: com.sun.net.ssl.internal.ssl.RSASignature
   Service: SSLContext, Algorithm: Default, Class: com.sun.net.ssl.internal.ssl.DefaultSSLContextImpl
   Service: KeyManagerFactory, Algorithm: SunX509, Class: com.sun.net.ssl.internal.ssl.KeyManagerFactoryImpl$SunX509
   Service: SSLContext, Algorithm: SSL, Class: com.sun.net.ssl.internal.ssl.SSLContextImpl
   Service: TrustManagerFactory, Algorithm: SunX509, Class: com.sun.net.ssl.internal.ssl.TrustManagerFactoryImpl$SimpleFactory
   Service: SSLContext, Algorithm: SSLv3, Class: com.sun.net.ssl.internal.ssl.SSLContextImpl
   Service: KeyStore, Algorithm: PKCS12, Class: com.sun.net.ssl.internal.pkcs12.PKCS12KeyStore
   Service: SSLContext, Algorithm: TLS, Class: com.sun.net.ssl.internal.ssl.SSLContextImpl
   Service: SSLContext, Algorithm: TLSv1, Class: com.sun.net.ssl.internal.ssl.SSLContextImpl
   Service: KeyManagerFactory, Algorithm: NewSunX509, Class: com.sun.net.ssl.internal.ssl.KeyManagerFactoryImpl$X509
   Service: TrustManagerFactory, Algorithm: PKIX, Class: com.sun.net.ssl.internal.ssl.TrustManagerFactoryImpl$PKIXFactory
    Aliases: X.509
Provider: SunJCE, Version: 1.6, Class: com.sun.crypto.provider.SunJCE
  Description: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
  Services (60):
   Service: KeyGenerator, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyGenerator
    Aliases: TripleDES
   Service: KeyGenerator, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA384KG
   Service: AlgorithmParameters, Algorithm: OAEP, Class: com.sun.crypto.provider.OAEPParameters
   Service: KeyGenerator, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.KeyGeneratorCore$ARCFOURKeyGenerator
    Aliases: RC4
   Service: Cipher, Algorithm: AESWrap, Class: com.sun.crypto.provider.AESWrapCipher
    Attributes:
      SupportedPaddings: NOPADDING
      SupportedKeyFormats: RAW
      SupportedModes: ECB
   Service: KeyGenerator, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA256KG
   Service: KeyGenerator, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA512KG
   Service: AlgorithmParameters, Algorithm: AES, Class: com.sun.crypto.provider.AESParameters
    Aliases: Rijndael
   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEParameters
   Service: AlgorithmParameters, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Parameters
   Service: KeyStore, Algorithm: JCEKS, Class: com.sun.crypto.provider.JceKeyStore
   Service: KeyGenerator, Algorithm: SunTlsPrf, Class: com.sun.crypto.provider.TlsPrfGenerator
   Service: Cipher, Algorithm: DES, Class: com.sun.crypto.provider.DESCipher
    Attributes:
      SupportedPaddings: NOPADDING|PKCS5PADDING|ISO10126PADDING
      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OFB24|OFB32|OFB40|OFB48|OFB56|OFB64
   Service: Cipher, Algorithm: RSA, Class: com.sun.crypto.provider.RSACipher
    Attributes:
      SupportedPaddings: NOPADDING|PKCS1PADDING|OAEPWITHMD5ANDMGF1PADDING|OAEPWITHSHA1ANDMGF1PADDING|OAEPWITHSHA-1ANDMGF1PADDING|OAEPWITHSHA-256ANDMGF1PADDING|OAEPWITHSHA-384ANDMGF1PADDING|OAEPWITHSHA-512ANDMGF1PADDING
      SupportedModes: ECB
   Service: KeyFactory, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyFactory
    Aliases: DH
   Service: Cipher, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndDESede
    Aliases: OID.1.2.840.113549.1.12.1.3
   Service: AlgorithmParameters, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameters
    Aliases: DH
   Service: Cipher, Algorithm: DESedeWrap, Class: com.sun.crypto.provider.DESedeWrapCipher
    Attributes:
      SupportedModes: CBC
   Service: KeyGenerator, Algorithm: SunTlsRsaPremasterSecret, Class: com.sun.crypto.provider.TlsRsaPremasterSecretGenerator
   Service: AlgorithmParameters, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeParameters
    Aliases: TripleDES
   Service: KeyGenerator, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1KeyGenerator
   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndDES
    Aliases: 1.2.840.113549.1.5.3
   Service: Cipher, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndRC2_40
    Aliases: OID.1.2.840.113549.1.12.1.6
   Service: Mac, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5
    Attributes:
   Service: SecretKeyFactory, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyFactory
    Aliases: TripleDES
   Service: Mac, Algorithm: SslMacSHA1, Class: com.sun.crypto.provider.SslMacCore$SslMacSHA1
    Attributes:
   Service: KeyGenerator, Algorithm: SunTlsMasterSecret, Class: com.sun.crypto.provider.TlsMasterSecretGenerator
   Service: KeyGenerator, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyGenerator
   Service: Cipher, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEWithMD5AndTripleDESCipher
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEParameters
   Service: Cipher, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.ARCFOURCipher
    Aliases: RC4
    Attributes:
      SupportedModes: ECB
   Service: AlgorithmParameters, Algorithm: PBE, Class: com.sun.crypto.provider.PBEParameters
   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndTripleDES
   Service: Mac, Algorithm: HmacPBESHA1, Class: com.sun.crypto.provider.HmacPKCS12PBESHA1
    Attributes:
   Service: Cipher, Algorithm: AES, Class: com.sun.crypto.provider.AESCipher
    Aliases: Rijndael
    Attributes:
      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OFB24|OFB32|OFB40|OFB48|OFB56|OFB64|CFB72|CFB80|CFB88|CFB96|CFB104|CFB112|CFB120|CFB128|OFB72|OFB80|OFB88|OFB96|OFB104|OFB112|OFB120|OFB128
   Service: SecretKeyFactory, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyFactory
   Service: Cipher, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Cipher
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEParameters
   Service: KeyAgreement, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyAgreement
    Aliases: DH
    Attributes:
      SupportedKeyClasses: javax.crypto.interfaces.DHPublicKey|javax.crypto.interfaces.DHPrivateKey
   Service: KeyGenerator, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishKeyGenerator
   Service: KeyPairGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyPairGenerator
    Aliases: DH
   Service: Cipher, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEWithMD5AndDESCipher
   Service: Cipher, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishCipher
    Attributes:
   Service: AlgorithmParameters, Algorithm: DES, Class: com.sun.crypto.provider.DESParameters
   Service: KeyGenerator, Algorithm: AES, Class: com.sun.crypto.provider.AESKeyGenerator
    Aliases: Rijndael
   Service: KeyGenerator, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5KeyGenerator
   Service: SecretKeyFactory, Algorithm: PBKDF2WithHmacSHA1, Class: com.sun.crypto.provider.PBKDF2HmacSHA1Factory
    Aliases: OID.1.2.840.113549.1.5.12
   Service: KeyGenerator, Algorithm: RC2, Class: com.sun.crypto.provider.KeyGeneratorCore$RC2KeyGenerator
   Service: Mac, Algorithm: SslMacMD5, Class: com.sun.crypto.provider.SslMacCore$SslMacMD5
    Attributes:
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndDESede
   Service: AlgorithmParameterGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameterGenerator
    Aliases: DH
   Service: Mac, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1
    Attributes:
   Service: Mac, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.HmacCore$HmacSHA384
    Attributes:
   Service: KeyGenerator, Algorithm: SunTlsKeyMaterial, Class: com.sun.crypto.provider.TlsKeyMaterialGenerator
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndRC2_40
   Service: Mac, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.HmacCore$HmacSHA256
    Attributes:
   Service: AlgorithmParameters, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishParameters
   Service: Mac, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.HmacCore$HmacSHA512
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEParameters
   Service: Cipher, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeCipher
    Aliases: TripleDES
    Attributes:
Provider: SunJGSS, Version: 1.0, Class: sun.security.jgss.SunProvider
  Description: Sun (Kerberos v5, SPNEGO)
  Services (2):
   Service: GssApiMechanism, Algorithm: 1.3.6.1.5.5.2, Class: sun.security.jgss.spnego.SpNegoMechFactory
   Service: GssApiMechanism, Algorithm: 1.2.840.113554.1.2.2, Class: sun.security.jgss.krb5.Krb5MechFactory
Provider: SunSASL, Version: 1.5, Class: com.sun.security.sasl.Provider
  Description: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5)
  Services (8):
   Service: SaslServerFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ServerFactoryImpl
   Service: SaslClientFactory, Algorithm: PLAIN, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslClientFactory, Algorithm: EXTERNAL, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslServerFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
   Service: SaslClientFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
   Service: SaslClientFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
   Service: SaslClientFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslServerFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
Provider: XMLDSig, Version: 1.0, Class: org.jcp.xml.dsig.internal.dom.XMLDSigRI
  Description: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
  Services (11):
   Service: KeyInfoFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMKeyInfoFactory
   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xpath-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXPathTransform
    Aliases: XPATH
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
    Aliases: INCLUSIVE_WITH_COMMENTS
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#base64, Class: org.jcp.xml.dsig.internal.dom.DOMBase64Transform
    Aliases: BASE64
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#enveloped-signature, Class: org.jcp.xml.dsig.internal.dom.DOMEnvelopedTransform
    Aliases: ENVELOPED
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
    Aliases: INCLUSIVE
    Attributes:
      MechanismType: DOM
   Service: XMLSignatureFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMXMLSignatureFactory
   Service: TransformService, Algorithm: http://www.w3.org/2002/06/xmldsig-filter2, Class: org.jcp.xml.dsig.internal.dom.DOMXPathFilter2Transform
    Aliases: XPATH2
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
    Aliases: EXCLUSIVE
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xslt-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXSLTTransform
    Aliases: XSLT
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
    Aliases: EXCLUSIVE_WITH_COMMENTS
    Attributes:
      MechanismType: DOM
Provider: SunPCSC, Version: 1.6, Class: sun.security.smartcardio.SunPCSC
  Description: Sun PC/SC provider
  Services (1):
   Service: TerminalFactory, Algorithm: PC/SC, Class: sun.security.smartcardio.SunPCSC$Factory
Provider: SunMSCAPI, Version: 1.6, Class: sun.security.mscapi.SunMSCAPI
  Description: Sun's Microsoft Crypto API provider
  Services (9):
   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.mscapi.RSASignature$MD5
    Attributes:
      SupportedKeyClasses: sun.security.mscapi.Key
   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.mscapi.RSASignature$SHA1
    Attributes:
   Service: Cipher, Algorithm: RSA, Class: sun.security.mscapi.RSACipher
    Attributes:
      SupportedPaddings: PKCS1PADDING
      SupportedModes: ECB
   Service: SecureRandom, Algorithm: Windows-PRNG, Class: sun.security.mscapi.PRNG
   Service: KeyStore, Algorithm: Windows-ROOT, Class: sun.security.mscapi.KeyStore$ROOT
   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.mscapi.RSAKeyPairGenerator
    Attributes:
      KeySize: 1024
   Service: Cipher, Algorithm: RSA/ECB/PKCS1Padding, Class: sun.security.mscapi.RSACipher
   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.mscapi.RSASignature$MD2
    Attributes:
   Service: KeyStore, Algorithm: Windows-MY, Class: sun.security.mscapi.KeyStore$MY
Jul 02, 2010 Jul 02, 2010
Thanks for the info about the Flex project versions you've been using.
That leads to a related question: if you open the Preferences dialog after updating to 4.0.1, were all 3 SDKs showing as available?
- 3.5
- 4.0
- 4.5
Also, which SDK is configured as the default in the Preferences dialog: 3.5, 4.0, or 4.5?
-Chris
Hi Chris,
here is a screenshot of the preferences screen with the installed SDKs. Is the "Flex 4.1"-entry okay?!
I removed Flex 4.1 from this list and set 4.0 as default value, but the errors are not gone.
Miracula
Yes, the Flex 4.1 SDK entry is correct.
That was a typo (4.5) on my part above, but the expected list is what's showing in your screenshot:
- 3.5
- 4.0
- 4.1 (default)
I don't think removing the 4.1 SDK from the list is a good idea - you should probably put it back for future use (sorry for confusing). It's fine to change the default though, if you're mostly using 3.5 currently.
-Chris
Hi Chris,
I didn't broke anything and restored the defaults, so nothing happened
Miracula
Guest
Rewriting the same update as in http://bugs.adobe.com/jira/browse/FB-27100 for wider audience :
It appears that mxmlc.jar file in the path - C:\Program Files  (x86)\Adobe\Adobe Flash Builder  4\plugins\com.adobe.flexbuilder.flex_4.0.1.277662\lib\ is replaced with  an older version (Flex SDK v3.5), due to which Flash bulider code was  not able to find the required (new) method.
Please shutdown Flash Builder and then, replace that mxmlc.jar (in  com.adobe.flexbuilder.flex_4.0.1.277662\lib\) file from the path -  C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\sdks\4.1.0\lib.  Restarting Flash Builder should eliminate the NoSuchMethodError  exception and the it should come up normally.
In any case of any failure, please send the entire .metadata folder  zipped.
Jul 01, 2010 Jul 01, 2010
Thanks a lot for cross-posting that, and identifying the Teamprise conflict.
Since you've narrowed that down already, there's no longer a need for sending the installer or amt3 logs mentioned earlier - just wanted to rule out install-time and licensing problems. Sending the full workspace log would still be helpful though, as it might contain additional clues about the runtime conflict.
-Chris
I went ahead and just deleted flex and then reinstalled 4.0 choosing not to do the update for 4.0.1.
[redundant message deleted]
