This error only occurs when I pass parameters to Configure return type dialog
As a follow on from http://forums.adobe.com/message/2663481
I am getting this in the log.
!ENTRY com.adobe.flexbuilder.DCDService 4 1 2010-06-15 11:45:29.323
!MESSAGE Please specify a valid <services/> file path in flex-config.xml.
!STACK 0
flex.messaging.config.ConfigurationException: Please specify a valid <services/> file path in flex-config.xml.
at flex.messaging.config.LocalFileResolver.getConfigurationFile(LocalFileResolver.java:79)
at flex.messaging.config.AbstractConfigurationParser.parse(AbstractConfigurationParser.java:67)
at flex.messaging.config.ServicesDependencies.getClientConfiguration(ServicesDependencies.java:150)
at com.adobe.flexbuilder.dcrad.utils.DCRADUtility.getServiceSettingsOnServer(DCRADUtility.java:1398)
at com.adobe.flexbuilder.dcrad.utils.DCRADUtility.getServerConfiguration(DCRADUtility.java:1374)
at com.adobe.flexbuilder.dcrad.views.ServiceExplorerView.refreshService(ServiceExplorerView.java:1703)
at com.adobe.flexbuilder.dcrad.views.ServiceExplorerView.refreshSelectedServices(ServiceExplorerView.java:1650)
at com.adobe.flexbuilder.dcrad.views.internal.actions.ServiceRefreshAction.run(ServiceRefreshAction.java:41)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java:109)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
One problem I keep getting is that FB keeps setting this setting as J2EE Server even when I tell it is standalone. When I add a server an tell FB that it is Remote, does that mean its J2ee?
Several others have been reporting this, its a pretty serious problem
This is definitely a Bug. I would have filed it but it would be better if we have the exact steps to reproduce the issue. I am aware that you might not be able to share all your source. But a scaled down example would really be helpful. Please do log this bug at
http://bugs.adobe.com/flex/
Nishad
Flash Builder Team
I'm pretty sure this bug has been logged before
I found that the only solution was to start with a fresh workspace,
Maybe the corruption occured when I applied cf nature to a flex project
After going through the stacktrace, we did have good reason to believe that there is a bug. And there has been no bug logged regarding this. Having a sample FB project in this case or a list of steps to reproduce the bug would be really helpful in tracing the root cause.
Nishad
Flash Builder team
trouble is I have a new workspace and can't reproduce it
Oh. Well, We will look into it. Thanks a lot for the stacktrace.
Nishad
Nikos,
Could you send us the services-config.xml file that you had used.
Nishad
