When using the shift enter key for line breaks and the enter
key when creating tabs, I lose the formatting after generating it
to Webhelp or previewing it. Why does this happen? How should I fix
it? RoboHelp X5.
Does this happen in the supplied demo projects as well as
your own?
Shift Enter is a way of entering a line break. Enter creates
the next paragraph and there is no concept of tabs in HTML so I am
not sure what you are doing there.
The licensed version. It is when I have a numbered item and
then use the shift enter key to add a tip or a note. The tip/note
will have spacing issues when using the output view.
