RAL Pallete
Jul 01, 2010 Jul 01, 2010
I have need of a RAL Color
Pallete.
One particular color we've needed is a safety orange RAL 2010.  When I try to convert that to CMYK or RGB, I get 4 different results depending on which web site I use.  I might get more but I stopped looking at that point.  Some are more red, darker, lighter, yellower, browner, bluer, upsidedown, or backwards. Which one is right?
We will be upgrading from CS3 to CS5 later this year, we think, along with going to 64 bit computers.  Is there a RAL Swatch Pallete available in CS5.
Can anyone advise?
49.0K
Adobe
This one seems to be official:
https://www.ral-farben.de/info-ral-c1.html?&L=1
Jul 02, 2010 Jul 02, 2010
Which one is right?
Neither. For all intents and purposes, RAL colors are realworld colors (as in FS colors for paints), not even print-specific spot colors, so anything on screen can at best be an approximation. Safety orange cannot be simulated properly, anyway. It's a reflective luminescensce color just like DayGlo orange.
Mylenium
Engaged ,
Meanwhile, RAL colors are defined by Lab = CIELab values.
A subset can be found here:
http://www.dirp.cz/de/farbenmustermappe-ral-und-rgb-umsetzung
Ignore the unspecified RGB-values, use only Lab. I didn't check
the Lab numbers.
Whether a RAL color is out-of-gamut in any other color space
can be tested by Photoshop:
Make New doc1 in Lab
Specify foreground color by Lab values
Fill
Duplicate doc1 --> doc2  for a comparison
Select doc1 for soft.proofing
View > Proof setup (choose any RGB or CMYK space)
View > Proof color (for a visual comparison of doc1 and doc2).
If the color is out-of-gamut for the monitor (maybe near to sRGB),
then the test is not reliable. If differences are observed, then this
indicates problems to be expected.
View > Gamut warning (out-of-gamut in target space is indicated
by an alarm color of your choice). This is a reliable test, but it's
sometimes too 'strict'.
RAL colors are defined for varnish in 'real world'. Like for any other
real world colors, a description by CIELab is well suited (except
for fluorescent colors and colors with other effects like metallic).
Search further (Google) by  both words 'CIELab'  'RAL' simulta-
neously.
Complete color bases with varnish samples and data systems
for Lab, including newer developments like RAL Designer may not
be available for free.
Best regards --Gernot Hoffmann
Engaged ,
According to the link in my recent post, Signal Orange RAL 2010
has Lab values L=54.2, a=41.4, b=46.2.
This is in-gamut for sRGB and for the common offset color space
ISOcoated-v2-eci (or just ISOCoated, doesn't matter).
It's a rather dull orange!
Color software as mentioned by Monika Gause (1), by me (2) or
here (3)
http://www.dtpstudio.de/ral-designsystem.htm
isn't necessarily compatible with Photoshop or Adobe CS#.
Adobe CS# uses for the CIELab conversions the CIE standard
observer 2° and reference light D50. The mentioned color software
uses at least definitely in case (3) the 10° observer with reference
light D65.
This post is more a case for the color management forum.
Sorry for bothering the folks here, eventually.
Everything could be fine, if I didn't measure RAL 2010 in my
real world RAL swatch book. Here I found by two instruments the
value b=60, approximately - instead of b=46.
Best regards - Gernot Hoffmann
Thanks Gernot and others
.  I need to do some research to figure out what you are talking about,
but I appreciate the response. 🙂  When I get over the hump, I'll have time to do that. I do get that RAL does not neccessarily lend itself to digital, I'll cope.
The color RAL 2010 is specified in ISO 3864-2 Annex E as the safety orange.  I am writing/illustrating an equipment manual and need to format safety notices for the text. (pictograms drawn in AI).
