My eyes are going to bug out unless I can figure out how to change the background color for the code editor (from white to black)!
I found this informative article on changing overall appearance of the code editor, yet it still does not clarify exactly how to change the background color.
http://polygeek.com/1990_flex_making-flash-builder-your-bitch
All you have to do is set the editor background to black in Preferences > Appearance > Colors and Fonts. Then you can edit the syntax coloring for AS and MXML in Preferences > Flash Builder > Editors > Syntax Coloring. You’ll also want to edit the BG color of the current line of text at Preferences > General > Editors > Text Editors.
Okay, I get most of that. Except, I'm still not getting how to change the background to black. I went here, and did not see the right options:
Is it then under the "View and Editors Folders"? And if so, which item needs to be changed? I tried various ones, yet nothing seems to change the background.
How to change the background color of the code editor?!!
anyone know how to do this?
got it: it's in:
Preferences -> General -> Editors -> Text Editros
got several pointers on how to change color for code editor - many links/posts available if you google it.
but haven't found how to change the bg/fg color for the other window panes which have the default gray/white/black.
any help here. thx. gary
