33 Replies Latest reply on May 4, 2006 5:25 AM by Voddie
    IE Plugin Activation - Latest MS Update Disables Work-arounds
    gavinnosler Level 1
      Two of our computers at work were set to automatically update (not anymore!) and last night an update was installed. This was the first time I've seen this new "feature" in effect, so naturally I immediately set out to get around it. I've tried the work-arounds posted on Microsoft.com, Macromedia.com, and about 6 smaller sites with work-arounds. I've tried the "comment" work-around, the "noscript" work-around, the simple JavaScript external file work-around, and many variations of these. In the IE browsers that were updated yesterday, none of these work-arounds have any effect. In the browsers that were not updated, these work-arounds work as intended.
      Hopefully a new work-around will be figured out soon, since as we all know, this problem is a huge set back when we're all trying to make the Flash platform as integrated as possible.
      Please let me know if you have any info on this!
        • 1. Re: IE Plugin Activation - Latest MS Update Disables Work-arounds
          Mark-Bennett
          Are you sure that your script debugging is set correctly:
          == From the MS Site ========================================
          Warning If you uncheck the Disable Script Debugging (Internet Explorer) option in the Advanced Tab of the Internet Options Control Panel, controls created using these techniques will still require activation.
          Hope that helps
          Read my Active Content Blog:
          http://activecontent.blogspot.com/
          • 2. Re: IE Plugin Activation - Latest MS Update Disables Work-arounds
            gavinnosler Level 1
            "Disable Script Debugging (Internet Explorer)" and "Disable Script Debugging (Other)" are both checked. I haven't changed that setting on any of our computers. That's how it should be for the work-arounds to work correctly, right?
            • 3. Re: IE Plugin Activation - Latest MS Update Disables Work-arounds
              Mark-Bennett Level 1
              On my IE6 only [Disable Script Debugging (Internet Explorer)] is checked the other is unchecked, but that one shouldn't make a difference ???
              What OS/Browser are you using?
              Does the homepage of the macromedia site still show the 'click to active' border? If not, it maybe that you have an error in your usage of the workarounds.
              • 4. Re: IE Plugin Activation - Latest MS Update Disables Work-arounds
                gavinnosler Level 1
                I unchecked the "Other" option for script debugging and restarted IE, but still no fix. Macromedia.com shows the activation border; that's actually how we first noticed the problem. We thought macromedia.com was broken.
                Here's what IE shows as its version number: 6.0.2900.2180.xpsp_sp2_gdr.050301-1519
                We're all using Windows XP with SP2.
                • 5. Re: IE Plugin Activation - Latest MS Update Disables   Work-arounds
                  Level 7
                  > many variations of these. In the IE browsers that were updates yesterday, none
                  I've got the same problem. I have implemented the Microsoft recommended
                  solution, the Adobe solution, deconcept.com swfobject and my own custom
                  solution. All four work on half the machines, but not on the other half
                  (the same machines fail each time). The only commonality I could find is
                  that the machines it always failed on had an OEM version of XP Pro from
                  DELL installed on them.
                  I have tried checking and unchecking the various 'script debugging'
                  options in IE as suggested by Mark-Bennett but it doesn't seem to make
                  the slightest bit of difference.
                  MOLOKO
                  Macromedia Certified Flash MX 2004 Developer
                  Macromedia Certified Flash MX Developer
                  ::remove _underwear_ to reply::
                  'There ain't no devil - it's just God when he's drunk' Tom Waits
                  GCM/CS/IT/MC d-- S++:- a- C++ U--- P+ L++ !E W+++$ N++ O? K+ w+++$ !O M+
                  VMS? PS+++ PE- Y PGP+ t+ 5-- X-- R* tv++ b++++ DI++++ D+ G e h-- r+ y++
                  • 6. Re: IE Plugin Activation - Latest MS Update Disables   Work-arounds
                    Level 7
                    MOLOKO
                    • 7. Re: IE Plugin Activation - Latest MS Update Disables   Work-arounds
                      Level 7
                      MOLOKO
                      • 8. Re: IE Plugin Activation - Latest MS Update Disables   Work-arounds
                        Level 7
                        apologies for the multiple posts there - Thunderbird saying it failed to
                        send message when it actually had sent it caused that one!
                        MOLOKO
                        • 9. Re: IE Plugin Activation - Latest MS Update Disables   Work-arounds
                          FernandoGM
                          I was currently working on finding a solution for the "click to activate" a message and more or less I found it but after reading this, there is no point on applying it since users that update their browsers will still get the message.
                          Are you guys sure this is caused by a recent Microsoft's update?
                          This means that everyone will have the "click to activate" message again soon?
                          Fernando
                          • 10. Re: IE Plugin Activation - Latest MS Update Disables     Work-arounds
                            Level 7
                            absolutely 100% sure - it has been very well reported and documented all over the web that this is
                            the result of a long time Eolas patent lawsuit that MS fought and once won but recently lost in a
                            2nd legal battle. Google search for "active content".
                            --> Adobe Certified Expert *ACE*
                            --> www.mudbubble.com
                            --> www.keyframer.com
                            > message.
                            > Thanks,
                            > Fernando
                            • 11. Re: IE Plugin Activation - Latest MS Update Disables     Work-arounds
                              Level 7
                              also - considering this active content issue only happens if and when you update windows OS and
                              Internet Explorer - then it has to be assumed it is not a flash/Adobe issue - in fact it has to do
                              with several kinds of media players wrapped inside object tags. the proof is there.
                              > message.
                              > Thanks,
                              > Fernando
                              • 12. Re: IE Plugin Activation - Latest MS Update Disables     Work-arounds
                                Level 7
                                not "soon" - it is happening now.
                                • 13. Re: IE Plugin Activation - Latest MS Update Disables Work-arounds
                                  gavinnosler Level 1
                                  I'm not 100% sure it was caused by a recent update, but I know both of the machines that experienced the problem were updated by a recent MS update. I guess you might as well apply your fix now since judging from the lack of activity in this thread, not too many people are experiencing the fixes not working. I guess we'll see in the next week or two if a MS update is causing the fixes to stop working.
                                  • 14. Re: IE Plugin Activation - Latest MS Update Disables     Work-arounds
                                    gavinnosler Level 1
                                    Chris,
                                    This is a different issue. We're all well aware of the Eolas patent and how it has affected Microsoft Internet Explorer. The problem is that now, after installing the latest update by Microsoft, all the previous fixes for this "plugin activation" problem won't work.
                                    • 15. Re: IE Plugin Activation - Latest MS Update Disables       Work-arounds
                                      Level 7
                                      oh - sorry - well, that makes little sense though - does that mean MS is updating their own update?
                                      gavinnosler wrote:
                                      > Chris,
                                      • 16. Re: IE Plugin Activation - Latest MS Update Disables       Work-arounds
                                        gavinnosler Level 1
                                        Maybe Eolas saw that workarounds for this were pretty simple to implement and legally Microsoft had to block the workarounds. I'd like to think this isn't the case, but when the activation workarounds just simply don't work in recently updated browsers, it raises some questions.
                                        • 18. Re: IE Plugin Activation - Latest MS Update Disables       Work-arounds
                                          OK, I've been in contact with someone at Macromedia about this issue and it seems that those machines which won't accept the workaround are all running version 5.6.0.8515 of jscript.dll. Those that work are running version 5.6.0.8820.
                                          So, it seem pretty clear to me it's actually Micro$oft's error in that their workaround does NOT function for all machines due to the difference in DLL versions. Hopefully Macromedia and all the other suppliers of ActiveX controls will get in touch with Micro$oft and make them aware of this problem.
                                          Interestingly, all the machines we have with that version of jscript.dll are recently-bought Dell boxes with OEM installs of XP pro. I always said Dell were a bit dodgy ;-)
                                          • 19. Re: IE Plugin Activation - Latest MS Update Disables       Work-arounds
                                            Level 7
                                            So one just has to update the jscript.dll ?
                                            • 20. Re: IE Plugin Activation - Latest MS Update Disables       Work-arounds
                                              Level 7
                                              don't know what the knock-on effects of that might be, but it could be
                                              worth a try on a test kit!
                                              MOLOKO
                                              • 21. Re: IE Plugin Activation - Latest MS Update Disables       Work-arounds
                                                Voddie
                                                Hi
                                                Can someone please shed some light on this issue, I've spent all morning trying to find the right solution to my dilemma.
                                                I have updated player/flash 8 updates etc as stated in the adobe workaround and downloaded and installed the extension "FlashActiveContent_en".
                                                I have created a test swf, published as stated and uploaded the "AC_RunActiveContent.js" created. This is working fine and I don't get the grey box wanting activation........yipeee. I can now go around all my clients flash sites to update.
                                                My dilemma is that I also have a php content management system that has flash header and footer. The cms uses themes for the site and usually I just embed the flash content with the html template by giving it's full location of the flash file (ie www.mysite/flash/flashmovie.swf).
                                                I tried implimenting the same coding and js file as my test.swf file but the flash doesnt load at all.
                                                How do I get the grey activation boxes to disappear? Do I need the full url of the flash file, the full url of the .js file.
                                                Do I need to re-publish the flash header and footer?
                                                Can someone please point me in the right direction.
                                                Thank in advance
                                                Voddie
                                                • 22. Re: IE Plugin Activation - Latest MS Update Disables         Work-arounds
                                                  Level 7
                                                  Voddie wrote:
                                                  > Hi
                                                  > sites to update.
                                                  if the flash file exists on the same domain you never need to give a
                                                  fully-qualified path (as above), only a relative path - site-root
                                                  relative is probably best if header/footer stuff is involved as that way
                                                  the path is the same no matter what page you're on (e.g.
                                                  You would need to do the same for the .js file.
                                                  MOLOKO
                                                  • 24. Re: IE Plugin Activation - Latest MS Update Disables Work-arounds
                                                    indigo007
                                                    FYI:
                                                    If any of you are waiting for Microsoft to release a fix or an update on this issue quickly, think again! I have been in contact with Microsoft and asked them if they plan on fixing this issue with the way Active X is controlled and I have been informed that they are not currently working on anything. Below is the exact transmission I received from a Microsoft employee.
                                                    Microsoft:
                                                    Thanks for your feedback. From your reply I understand that you would like to confirm if Microsoft will have a permanent update which will handle Active X automatically without the web developer changing their web site. Please accept my sincere apologies for not answering this question earlier.
                                                    Customers may have some suggestions or feedbacks for the new feature in IE changed by the Active X update. We are collecting these feedbacks from the customer regarding this update. According to these feedbacks we will make further plans. I appreciate your feedback and will forward your concerns to
                                                    our appropriate department. If the related patch is released or the other related information are released as well, we will notify you as soon as possible. Also, I suggest checking back periodically with the information released on the Microsoft web site.
                                                    PLEASE SEND FEEDBACK TO MICROSOFT!!!!!!!! If enough of us contact them maybe they will fix this issue!
                                                    Obviously I have not had any luck with the workarounds either. I even tried the fix that Macromedia released for Flash 8 and no luck!
                                                    If anyone has received any further information in regards to updates from Macromedia or Microsoft please make sure to post!
                                                    • 25. Re: IE Plugin Activation - Latest MS Update Disables   Work-arounds
                                                      Level 7
                                                      t2webworx wrote:
                                                      > Try the solution at http://www.microsoft-activex-solutions.co.uk
                                                      still won't work for those users with the old version (5.6.0.8515) of
                                                      jscript.dll. So far it would appear that no solution works for those
                                                      machines.
                                                      MOLOKO
                                                      • 26. Re: IE Plugin Activation - Latest MS Update Disables   Work-arounds
                                                        Level 7
                                                        indigo007 wrote:
                                                        > FYI:
                                                        a fairly typical response from Microsoft then. Stupid thing is that this
                                                        problem affects them just as much as anyone else as Windoze Media Player
                                                        will also be affected.
                                                        Macromedia now seem to be aware of the exact issue (kits with an old
                                                        version - 5.6.0.8515 - of jscript.dll do not implement the workaround
                                                        properly) so hopefully they will have more clout in kicking Microsoft
                                                        into gear than we do.
                                                        MOLOKO
                                                        • 27. Re: IE Plugin Activation - Latest MS Update Disables         Work-arounds
                                                          Voddie Level 1
                                                          MOLOKO wrote
                                                          "if the flash file exists on the same domain you never need to give a
                                                          You would need to do the same for the .js file."
                                                          Im not sure where im going wrong, and i am not sure where abouts in the site i am when the cms loads, thats why i always put the full path.
                                                          Going back to my previous, one html page with one swf. I can only get this to work in test if the js file is in the same directory as the html file.
                                                          ie html/swf/js
                                                          If i move the swf to flash/swf it doesnt work, likewise if i move js to scripts/js this doesnt work.
                                                          I dont seem able to call either the swf or the js files away from the html residing directory.
                                                          Do I need to change any settings in the js file generated by flash8?
                                                          Do I need to change any settings in the js code called before the object<noscript> tag?
                                                          Thanks inadvance
                                                          Voddie
                                                          • 28. Re: IE Plugin Activation - Latest MS Update Disables           Work-arounds
                                                            Level 7
                                                            Voddie wrote:
                                                            the site i
                                                            that's exactly what a site-root relative path is for - it doesn't matter
                                                            where you are within the site, the path will always, always be the same.
                                                            You only need a fully-qualified path when trying to reach content on a
                                                            different server. Putting a fully-qualified name is a bad idea at other
                                                            times as it would then prevent you from shifting your content to another
                                                            domain name if you ever needed to.
                                                            > ie html/swf/js
                                                            > residing directory.
                                                            yes, I see what you mean - that Macromedia file is (surprise, surprise)
                                                            not particularly usuable!
                                                            I have worked out what you need to change and it is both the path to the
                                                            JavaScript file and the value of a variable 'movie'. There's also a
                                                            variable 'src' which looks like it needs to be changed too - but
                                                            changing it has no effect that I can see.
                                                            Quite frankly it's all pointlessly complicated, so I have posted a copy
                                                            on my webserver for you to have a look. see links below.
                                                            I have also done a version that utilises deconcept.com's excellent
                                                            swfobject and I think this is much better and clearer.
                                                            Macromedia version: http://www.moloko.f2s.com/flashtest/mm_index.html
                                                            (see lines 6, 126 & 140)
                                                            My version: http://www.moloko.f2s.com/flashtest/moloko_index.html
                                                            MOLOKO
                                                            • 29. Re: IE Plugin Activation - Latest MS Update Disables         Work-arounds
                                                              Voddie Level 1
                                                              Hi MOLOKO
                                                              Both versions work great, especially your version, its much more understandable to me.
                                                              In your version the writeFlashWithDetection.js and writeFlash.js are they available as Im not really a js man? are they both required?
                                                              I take the first detects if flash is present, and which version. Does the writeFlash.js a) allows the flash to play (without the grey border) and b)check to see if js is enabled?
                                                              Sorry if appearing a little dim, I am a liitle new to detection of flash player, using js and now this microsoft update has totally messed up most of my sites.
                                                              Thanks in advance
                                                              Voddie
                                                              • 30. Re: IE Plugin Activation - Latest MS Update Disables           Work-arounds
        Level 7
        Voddie wrote:
        > Hi MOLOKO
        thanks, no problem
        yes they are, please feel free to use. The writeFlashWithDetection.js
        includes code (unmodified) from deconcept.com. Many thanks to Geoff
        Stearns for writing such great flash detection code and making it
        available to us all.
        No, only one is required. In the example I sent the writeFlash.js is
        actually commented out so it's not in fact being used in that page. I
        just left it there so that it's easy to swap over for demo purposes.
        Not quite - they actually both have the ability to write out the flash
        object, but writeFlashWithDetection.js will also detect if the user has
        too low a version of flash and write out an appropriate warning instead.
        It needs a lot of extra code to do that though, so I also created the
        writeFlash.js as a 'lightweight' alternative if you don't need flash
        player version detection, or if you require a smaller file size.
        No matter which version you use though, they both get called in the same
        way:
        writeFlash(swffilename,width,height,playerversion,colour,flashvars)
        so you can just swap the .js files over without having to change any
        other code.
        Neither file checks to see if js is enabled, If js is disabled, the
        content in the <NOSCRIPT> tags will be displayed instead automatically.
        This is a feature of HTML,
        > sites.
        no problem, hope this helps out.
        MOLOKO
        • 31. Re: IE Plugin Activation - Latest MS Update Disables           Work-arounds
        Voddie Level 1
        Moloko
        Thank you for the reply and explaination, I understand a lot more now.
        One quick question, in your own version where the variables are "('_swf/testmovie.swf',400,200,'6.0.65.0','#FFFFFF',flashvars)" the player version i.e 6.0.65.0 obviously refers to flash player 6, how do I find the exact version? Are all flash 6 this 6.0.65.0? what about flash player 7 & 8, how do I find the exact numbers required?
        Thanks in advance
        Voddie
        • 32. Re: IE Plugin Activation - Latest MS Update Disables               Work-arounds
        Level 7
        Voddie wrote:
        > Moloko
        you can find out the exact flash player version *you* have installed by
        going here:
        http://www.adobe.com/go/tn_15507
        In terms of what you would put in the writeFlash command, that defines
        the minimum version you require the user to have and that depends on
        what content you have in your movie. Flash generally only allows you to
        publish for a major version (e.g. 6, 7, 8) but there are some exceptions:
        If publishing for 6 you also have the option of 'optimising for 6.0.65.0
        as this player release had some speed improvements you could take
        advantage of - but swfs optimized for that version couldn't be played in
        lower versions (e.g. 6.0.47.0).
        Similarly there are occasionally features that require specific versions
        again, for example the Delegate class only works in flash player
        6.0.79.0 or higher.
        On the whole, just use the lowest major flash version, e.g. if
        publishing for 6 - 6.0.47.0, if 7 - 7.0.19.0 and if 8 - 8.0.24.0
        MOLOKO
        • 33. Re: IE Plugin Activation - Latest MS Update Disables               Work-arounds
        Voddie Level 1
        Hi Moloko
        Thank you very much for explaining this in details, you have been very helpful and patient.
        As usual I can always find somebody willing to help in this forum, helps us poor newbies so much.
        I can now stop worrying so much about my sites until the next stage of updates from Microsoft.
        Ironic really, the link ( http://www.adobe.com/go/tn_15507) you sent me to check the version of my player, the swf in the page is suffering the same dreaded grey outline as we are trying to combat!
        Once again thank you for your time.
        Voddie
