Marc E wrote:
> we've actually been trying to go in the opposite
direction, mostly for ease
> of deployments. we have a cluster of CF servers, and
every time we do a code
> push, we have to migrate to all servers. it's annoying
and prone to
> problems.
Actually that's exactly the way we have our new high
availability
environment configured. All the code runs off an EMC device.
Not sure
why I didn't draw this parallel yesterday with running the
CFML on one
server and the CFCs on another server--as long as you have a
sufficiently fast network (we're on gigabit) and
device/drives (our
stuff is fiber channel), then as you mention below
performance probably
isn't an issue. I'd be curious if doing this over 100 megabit
with more
low-end hardware would perform as well as having things on a
local
drive, however.
> We want to move all our code onto one machine, such that
no webserver has
> any code on it at all. we deploy code to one machine,
and all webservers on
> the cluster benefit from the push. this machine is not
web accessible at all
> and thus one could say less prone to security problems
than a webserver is,
> although i'm not sure that's such a good reason. mostly
for us it's ease of
> deployment.
Yep, very true, and although the NAS/DAS device isn't
*directly*
accessible via the web, remember that's it's accessible by
the user
that's being used by the web site users, so there isn't a
huge security
benefit here vs. having the code locally. You're absolutely
right
> separating normal cfm files from objects seems kind of
silly, when if you
> want security you'd put all code on a separate,
non-web-accessible machine.
Yeah, this is where we head was earlier in the
discussion--putting the
CF "pages" on one server and the CFCs on another just seemed
a bit wacky
to me.
> thanks to CF mapping, you can just point "/" to the code
root of hte machine
> on which the code lives, and all is well with the world.
> This is actually how we have our internal environment
set up, it's just our
> production environment where our host is a pain in the
ass about it.
Right, this is what we do on our production environment but
we don't
even use a CF mapping (though you could). We just point our
web server
to the EMC device and everything else just falls into place,
provided
you've set up the user CF and your web server process (or
using "connect
as" in IIS in W2K3) are running as so they have access to the
network
storage device.
> i'd be extremely surprised to see a performance problem
with this setup.
> It's not like the web servers are in philly and the code
servers are in
> taiwan, sending thousands of bytes per second. you've
probably literally got
> the webserver sitting right beside the server on which
the code lives. it's
> virtually the same thing as just keeping CF on the C
drive and all the code
> on the D Drive (assuming disk speeds on the machines are
adequate).
True, good point. We have extremely good performance (might
even be
*faster* than local drive speed) with our EMC device, and
again I'm not
sure why I didn't see this parallel yesterday in the
discussions. Blame
it on a very hectic week. ;-)
Matt
Matt Woodward
mpwoodward@gmail.com
Adobe Community Expert - ColdFusion
