I have a PDF form that pulls data from a SQL Server. The fields in
the PDF are populated from the database after selecting a specific
record from a drop down and then clicking on a button labeled "Fill".
The problem is that the dropdown does not display new records that
have been recently added to the database. I have to open the form up
in designer then save it, (*note - I change nothing at this point.)
Then when the form is opened back up in Adobe the dropdown show all
the records including the new ones. I even put a manual refresh on
form to try and fix this an it did not help. Seriously stumped.
Any help is greatly appreciated.
Here is my code for the dropdown.
topmostSubform.Page1.JobSelect::initialize - (JavaScript, client)
var sDataConnectionName = "BBCC"; // example - var sDataConnectionName
= "Test";
var sColHiddenValue = "ContractAdmin_Key"; // example - var
sColHiddenValue = "Dept_ID";
var sColDisplayText = "JobDescription"; // example - var
sColDisplayText = "Dept_ID"
// Search for sourceSet node which matchs the DataConnection name
var nIndex = 0;
while(xfa.sourceSet.nodes.item(nIndex).name != sDataConnectionName)
nIndex++;
// Search node with the class name "command"
var nDBIndex = 0;
while(oDB.nodes.item(nDBIndex).className != "command")
nDBIndex++;
oDB.nodes.item(nDBIndex).query.recordSet.setAttribute("stayBOF",
"bofAction");
oDB.nodes.item(nDBIndex).query.recordSet.setAttribute("stayEOF",
"eofAction");
// Clear the list
this.clearItems();
// Search for the record node with the matching Data Connection name
nIndex = 0;
while(xfa.record.nodes.item(nIndex).name != sDataConnectionName)
nIndex++;
// Find the value node
var oValueNode = null;
var oTextNode = null;
for(var nColIndex = 0; nColIndex < oRecord.nodes.length; nColIndex++)
{ if(oRecord.nodes.item(nColIndex).name == sColHiddenValue)
{ oValueNode = oRecord.nodes.item(nColIndex); } else
if(oRecord.nodes.item(nColIndex).name == sColDisplayText) { oTextNode
= oRecord.nodes.item(nColIndex); } }
while(!oDB.isEOF())
this.addItem(oTextNode.value, oValueNode.value);
oDB.next();
// Close connection
oDB.close();
Here is code for the refresh button
topmostSubform.Page1.Button27::click - (JavaScript, client)
sourceSet.BBCC.requery();
Solved! Go to Solution.
Total Likes
The other thing that might be happening is a refresh issue on the DropDownList. Try adding the command xfa.layout.relayout() after the database connection has been closed.
Paul
Total Likes
It sounds like some sort of caching issue where the query result is getting cached locally. Are there any settings on the ODBC connection that tell the connection to get a fresh result each time it is called?
Paul
Total Likes
Paul, I agree that it appears to be a caching issue. I am tweaking the ADO settings but I confess I don't know much about the various ADO parameters. I will follow up if any of the ADO settings I change make a difference.
Total Likes
Paul
Total Likes
Good catch Paul! Would you believe that I have been trying to get this resolved for almost two years! Works perfect now.
Thank you,
- Eric
Total Likes
