Learn about Edge Delivery Services in upcoming GEM session
Where did my data go
Avatar
Level 1
I received an Acrobat form and completed most of it a while ago. Yesterday I opened the same file so I could update one of the fields in the form. When I clicked Forms in the menu bar, “Edit Form in Designer” had replaced “Add or Edit Fields.”
So, I clicked Edit Form in Designer. The problem is that none of the fields I previously completed now have data in them. The data is there when I open the form in Acrobat, but not when I click Edit Form in Designer.
How do I get my data to show up in the LifeCyle option? Can I get rid of LifeCycle altogether?
Rod
System:
Acrobat 9.2
Win 7 Ultimate, 64 bit
Dell T3400
Intel Core 2 Quad
8 gig RAM
Avatar
Former Community Member
When you edit in Designer you are being shown the template that was used to collect the data. Data and template are kept separately. You coudl export your data from the form, make your changes to the template then import your data again. There are menu options under Forms/Manage Form Data in Acroabt and Reader.
Hope that helps
Paul
Avatar
Level 1
Thank you Paul, I'll give that a try.
Rod
Avatar
Level 1
Thanks again, Paul - I just did that without any problems!
Rod
Avatar
Level 1
Paul provided a perfect solution.
