1. Re: How to change file names for .icc profiles in CS4?
Chris Cox Jul 3, 2010 8:49 AM (in response to RichPate)The displayed name for an ICC profile isn't the filename - it's a longer name internal to the profile.
If you open a profile in ColorSync Utility, the field you're looking for is "Description" or "desc".
2. Re: How to change file names for .icc profiles in CS4?
c.pfaffenbichler Jul 3, 2010 8:54 AM (in response to RichPate)If you open the profiles with ColorSync Utility you might be able to change the ASCII Name under the tag »desc« … but is it advisable?
Edit: Hadn’t seen Mr.Cox reply.
3. Re: How to change file names for .icc profiles in CS4?
RichPate Jul 5, 2010 2:36 PM (in response to c.pfaffenbichler)Thanks Chris and c. Under Description I'm presented with three Names for the profile: ASCII, UniCode and Mac Script. ASCII and Mac Script are the same name for the profile, with nothing being in the UniCode Name box. Which do I change -- both?
Am I going to screw things up in Photoshop if I change these names to something I can comprehend? Looks like I may just have to make a sticky-note list of the cryptic profile names with my own descriptive name as a reference. Thanks.
4. Re: How to change file names for .icc profiles in CS4?
Chris Cox Jul 5, 2010 3:15 PM (in response to RichPate)Change the ones that are present.
And no, it won't screw anything up.
5. Re: How to change file names for .icc profiles in CS4?
Was DYP Jul 5, 2010 5:04 PM (in response to Chris Cox)Change the ones that are present.
It will if you happen to change the name to the same internal name in another profile.
Doyle
