Hi guys.
I am using Flex and php to develop my project. Everything works great in my local machine. However, when I upload my files to my server (godaddy.com). I got the error when loading my flex application.
The pop-up error message is
send failed
channel.connect.failed.error
Netconnection.call.Badversion: url:
http://mydomail/folder/gateway.php
I have upload my ZendFramewrok folder into my server and amf_config.ini has been configured. (webroot =http://mydomain)
I am not sure what's going on here. Please help. Thanks.
Update: my gateway.php
<?php
ini_set("display_errors", 1);
$dir = dirname(__FILE__);
$webroot = $_SERVER['DOCUMENT_ROOT'];
$configfile = "$dir/amf_config.ini";
//default zend install directory
$zenddir = $webroot. '/ZendFramework/library'; //I did upload the ZendFramwork folder
//Load ini file and locate zend directory
if(file_exists($configfile)) {
$arr=parse_ini_file($configfile,true);
if(isset($arr['zend']['webroot'])){
$webroot = $arr['zend']['webroot'];
if(isset($arr['zend']['zend_path'])){
$zenddir = $arr['zend']['zend_path'];
// Setup include path
//add zend directory to include path
set_include_path(get_include_path().PATH_SEPARATOR.$zenddir);
// Initialize Zend Framework loader
require_once 'Zend/Loader/Autoloader.php';
Zend_Loader_Autoloader::getInstance();
// Load configuration
$default_config = new Zend_Config(array("production" => false), true);
$default_config->merge(new Zend_Config_Ini($configfile, 'zendamf'));
$default_config->setReadOnly();
$amf = $default_config->amf;
// Store configuration in the registry
Zend_Registry::set("amf-config", $amf);
// Initialize AMF Server
$server = new Zend_Amf_Server();
$server->setProduction($amf->production);
if(isset($amf->directories)) {
$dirs = $amf->directories->toArray();
foreach($dirs as $dir) {
// get the first character of the path.
// If it does not start with slash then it implies that the path is relative to webroot. Else it will be treated as absolute path
$length = strlen($dir);
$firstChar = $dir;
if($length >= 1)
$firstChar = $dir[0];
if($firstChar != "/"){
// if the directory is ./ path then we add the webroot only.
if($dir == "./"){
$server->addDirectory($webroot);
}else{
$tempPath = $webroot . "/" . $dir;
$server->addDirectory($tempPath);
}else{
$server->addDirectory($dir);
// Initialize introspector for non-production
if(!$amf->production) {
$server->setClass('Zend_Amf_Adobe_Introspector', '', array("config" => $default_config, "server" => $server));
$server->setClass('Zend_Amf_Adobe_DbInspector', '', array("config" => $default_config, "server" => $server));
// Handle request
echo $server->handle();
Error from gateway.php if I call it directly.
Warning: require_once(Zend/Loader/Autoloader.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/79/4687979/html/parkerList/gateway.php on line 27
Fatal error: require_once() [function.require]: Failed opening required 'Zend/Loader/Autoloader.php' (include_path='.:/usr/local/php5/lib/php:http://blackwheels.info//ZendFramework/library') in /home/content/79/4687979/html/parkerList/gateway.php on line 27
gateway.php is the rat. but I still can't figure out what's wrong. Zend/Loader/Autoloader.php is under the server root "ZendFramework/library" folder. I don't understand why my application can't find it. Thanks again!
Total Likes
You will get a better response if you repost your question on the Flex forums. This forum is for the Livecycle Data Services product.
Total Likes
