Hello,
I am currently trying to migrate a flex 3 project to Flash4...but when I replace <mx: application> to <s: Application> it gives following answer:
Could not resolve <s:Application> to a component implementation.
I have included the ur;s and libraries such as :
xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx"
Also I have used following to implement swiz framework:
xmlns:control="edu.mizzou.firefly.control.*" xmlns:view="edu.mizzou.firefly.view.*" xmlns:core="edu.mizzou.firefly.view.core.*" xmlns:swiz="http://swiz.swizframework.org
Please can any one suggest me where I am going wrong?? Any help would be highly appreciated
Akshay
Are you linking with the 4.0 (or later) SDK?
Not sure wht u meant by that but if your question is whether I am using Flash builder 4 or not then yes I am using Flash builder 4 and trying to migrate a Flex 3 project to flex 4
Open up the project properties window. Go to "Flex Compiler". What does it say at the top for "Flex SDK Version"? Which option do you have selected?
The SDK version is Flex4....Am I supposed to make any changes there??? Also I observed that in the application declaration below:
<s:Application frameRate="30" layout="absolute" backgroundGradientAlphas="[1.0, 1.0]"
horizontalScrollPolicy="off" verticalScrollPolicy="off" backgroundGradientColors="[#000000, #323232]" addedToStage="stageHandler(event)"
xmlns:mx="library://ns.adobe.com/flex/mx">
Some of the mx component doesn't work as intended in Flex 4 such as
layout= mx.Core.LayoutContainer
backgroundGradientAlphas=mx.Core.Application
horizontalScrollPolicy,verticalScrollPolicy=mx.Core.Container
I am looking into the documentation of Flex 4 but I am not able to find any solutions to them
Any suggestions from your side??
