I'm using RH8 and producing WebHelp. I'm trying to use the new IFrame feature to display a PDF in my webhelp output, but get an Adobe Acrobat error, followed by a RH crash.
Here's what happening:
Any ideas?
Hi Kathy
I'm confused about why you would need an Iframe to view the PDF. Doesn't it display in the topic pane? Or are other elements surrounding the Iframe and that's why you want it?
Perhaps you need to add the PDF to your baggage files list?
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin a self guided voyage of discovery learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
Yes, I have text in the topic before and after the PDF, which is why I thought an IFrame would be a good option. Plus I don't know how to display a PDF by itself as a topic. I'd like to try that--can you give me some basic instructions?
And, yes, the PDF is listed in the baggage files.
Hello again
To display a PDF as a topic, you just link from wherever (TOC, Another Topic, Index, etc) to the PDF.
Now as to whether the PDF is presented in its own window or into the Topic pane, I believe that may depend on the settings of the PDF Reader. I believe there are settings that govern the behavior of PDFs. I further believe these settings are machine specific and not exactly able to be influenced to behave identically across machines.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
Hi Rick,
Thanks for instructions. I didn't realize you could do that and, in theory, that works like a charm, but I'm still having issues. Here's what I just tried:
Since I just installed RH 8, I suspect that what I'm seeing is more of a problem with how Acrobat and Robohelp are interacting. I had Acrobat 8 Professional installed before installing Robohelp 8. Could that be it? If so, what's the best way to recover?
I fixed at least part of the problem by uninstalling and reinstalling Acrobat Pro. But the other part of the problem had to do with PDFs and Mark of the Web. Since that's a separate issue, I'm starting a new discussion....
