Hi!
I was reading the user guide for RoboHelp HTML Version 8 ("Using RoboHelp HTML 8") and on page 22 (section Projects --> About Output Types) the document reads as follows:
Note:
Due to Microsoft security changes, Microsoft HTML Help is now used where the Help has to be run on the users PC; it cannot be installed on a server without registry changes. WebHelp and FlashHelp are used where the Help is to be run from a server. WebHelp and FlashHelp can be run locally, but it is not recommended.
Why is it not recommended to run WebHelp and FlashHelp locally? Is it because of the prompts that block the toolbar in Microsoft Internet Explorer (i.e. the yellow bar at the top of the Internet Explorer Window)?
If this is the case, wouldn't enabling the Add Mark of the Web option in the WebHelp and FlashHelp Layout Properties help to "circumvent" this issue?
Thanks for your help!
Possibly because for CHM you distribute a single file, whereas for webhelp and flashhelp you have to distribute hundreds of files. I know lots of devs have a fit if asked to package a webhelp output. "Can you tell me which exact files in this directory you want to distribute?"..."um, all of them..."
You can apply MOW to enable webhelp to run locally without the information bar appearing in IE but I think you may find links to PDFs will not work. Not sure off the top of my head but there is a problem with some links in some browsers.
FlashHelp has the added complication that each user would have to add the help to a safe zone so you would have to instruct them how to do that. Rick has a Captivate demo of the procedure and I am sure he will add a link to that later.
